只需一步,快速開(kāi)始
查看: 1699|回復(fù): 1
超聲波測(cè)距
ID:402747 發(fā)表于 2018-9-26 16:34 | 顯示全部樓層 |閱讀模式
最簡(jiǎn)單的超聲波測(cè)距程序之一
S=(time*1.893)/100;   中的1.893可調(diào)
#include <AT89x51.H>                //器件配置文件
                         #include <intrins.h>
                         #include "sanxian.h"
                         #define  RX  P1_0
                         #define  TX  P1_2
                         unsigned int  time=0;
                         unsigned int  timer=0;
                         unsigned char posit=0;
                         unsigned long S=0;
                         bit      flag =0;
                         sbit key=P1^6;
                         unsigned char const discode[] ={ 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
                         unsigned char const positon[4]={ 0xfe,0xfd,0xfb,0xf7};
                         unsigned char disbuff[4]           ={ 0,0,0,0,};
    void Display(void)                                 //掃描數(shù)碼管
         if(posit==0)
         {P0=(discode[disbuff[posit]])&0x7f;}
         {P0=discode[disbuff[posit]];}
          P3=positon[posit];
          if(++posit>=3)
          posit=0;
    void Conut(void)
         time=TH0*256+TL0;
         TH0=0;
         TL0=0;
         S=(time*1.893)/100;     //算出來(lái)是CM
         if((S>=700)||flag==1) //超出測(cè)量范圍顯示“-”
          flag=0;
          disbuff[0]=10;           //“-”
          disbuff[1]=10;           //“-”
          disbuff[2]=10;
          disbuff[3]=10;           //“-”
          disbuff[0]=S%1000/100;
          disbuff[1]=S%1000%100/10;
          disbuff[2]=S%1000%10 %10;
     void zd0() interrupt 1                  //T0中斷用來(lái)計(jì)數(shù)器溢出,超過(guò)測(cè)距范圍
    flag=1;                                                         //中斷溢出標(biāo)志
   void  zd3()  interrupt 3                  //T1中斷用來(lái)掃描數(shù)碼管和計(jì)800MS啟動(dòng)模塊
         TH1=0xf8;
         TL1=0x30;
         Display();
         timer++;
         if(timer>=400)
          timer=0;
          TX=1;                                        //800MS  啟動(dòng)一次模塊
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          TX=0;
void Delay(uint  i)                 //延時(shí)函數(shù)
        uint k,j;                                        //延時(shí)參數(shù)
        for(k=i; i>0; i--)
                for(j=110; j>0; j--);
        void  main(  void  )
  { uchar i=0;
        init_WT588D();                                                        //定義接收緩沖區(qū)
        Delay(100);
    TMOD=0x11;                   //設(shè)T0為方式1,GATE=1;
        TH0=0;
        TL0=0;
        TH1=0xf8;                   //2MS定時(shí)
        TL1=0x30;
        ET0=1;             //允許T0中斷
        ET1=1;                           //允許T1中斷
        TR1=1;                           //開(kāi)啟定時(shí)器
        EA=1;                           //開(kāi)啟總中斷
         while(!RX);                //當(dāng)RX為零時(shí)等待
         TR0=1;                            //開(kāi)啟計(jì)數(shù)
         while(RX);                        //當(dāng)RX為1計(jì)數(shù)并等待
         TR0=0;                                //關(guān)閉計(jì)數(shù)
          Conut();                        //計(jì)算           Line_3A(disbuff[0]);
           Delay_1ms(1200);
           Line_3A(disbuff[1]+1);
           Delay_1ms(1200);
           Line_3A(disbuff[2]+11);
           Delay_1ms(1200);
ID:1 發(fā)表于 2018-9-26 18:04 | 顯示全部樓層
補(bǔ)全原理圖或者詳細(xì)說(shuō)明一下電路連接即可獲得100+黑幣
