本帖最后由 zhong2463 于 2018-9-25 09:04 編輯
就正常是一天加一,現(xiàn)在是只能通過按鍵加一。
#include <REGX51.H>
#include<intrins.h> //包含_nop_();定義的頭文件
#include<LS595driver.h>
#include<LS595_2driver.h>
#include<ds1302driver.h>
SYSTEMTIME today; //2018.1.2 12:00:00 2
unsigned int T0loop; //記錄進入T0的次數(shù)
unsigned int flag; //約10秒1次,
unsigned int countupday; //記錄正計時天數(shù)的參數(shù)
unsigned char olddaytemp,newdaytemp; //用來比較是否已經(jīng)過一天
unsigned char keyvalue;//記錄按鍵掃描函數(shù)的返回值
//unsigned int test[10]={0,111,222,333,444,555,666,777,888,999}; //記錄倒計時天數(shù)的參數(shù)
unsigned char i;
sbit key1 = P1^0;
sbit key2 = P1^1;
sbit key3 = P1^2;
sbit LEDr=P1^3;
sbit LEDg=P1^4;
sbit LEDy=P1^5;
void Init_89C52(); //初始化89C52
void InitT0();
char Keyscan(); //按鍵掃描并返回鍵值
void Setcountupday(); //按鍵設(shè)置正計時天數(shù)
Init_89C52();
Delay_ms(1000);
countupday = 1;
LEDr = 1;
LEDg = 1;
LEDy = 1;
Init_1302(); //初始化時鐘
InitT0(); //初始化T0定時器
Displayround();
Displaysecond_595(&today);
Displayday_595(&today);
Displayhour_595(&today);
Displayminute_595(&today);
Setcountupday(unsigned int chu=888);
Displaycountupnum(countupday);
if(flag==1)
flag = 0;
if(olddaytemp=!newdaytemp)
countupday++;
//Time0中斷函數(shù)
//功能:定時出10秒/50毫秒=200個循環(huán)
//參數(shù):無
void Time0(void) interrupt 1 using 1
TR0 = 0;
T0loop++;
if(T0loop==200)
Gettime_1302(&today);
olddaytemp = today.day;
if(T0loop==400)
newdaytemp = today.day;
flag = 1;
T0loop = 0;
TH0 = (65536-46083)/256; //重新給T0賦初始值
TL0 = (65536-46083)%256; //
TR0 = 1; //啟動T0
//Time0中斷函數(shù)
//功能:每8秒進入中斷,執(zhí)行開門或關(guān)門操作,并重設(shè)Time0
//參數(shù):無
void InitT0()
TMOD=0x01; //使用定時器T0,11.0592MHz晶振的12分頻,16位定時器65536-1
TH0 =(65536-46083)/256; //將定時器計時時間設(shè)定為46083*1.085微秒=50000微秒=50毫秒
TL0 =(65536-46083)%256; //
EA = 1; //開啟總中斷
ET0 = 1; //T0中斷允許
TR0 = 1; //啟動定時器T0
T0loop = 0; //記錄進入T0的次數(shù)
flag = 0; //10秒一個周期
/*89C52初始化*/
void Init_89C52()
P0 = 0;
P1 = 1;
P2 = 0;
T0loop = 0;
/*按鍵掃描函數(shù)*/
char Keyscan()
if(key1==0)
Delay_ms(200);
if(key1==0)
return 1;
if(key2==1)
Delay_ms(200);
if(key2==1)
return 2;
if(key3==1)
Delay_ms(200);
if(key3==1)
return 2;
return 0;
/*按鍵調(diào)整函數(shù)*/
switch(Keyscan())
case 1:
countupday++;
break;
case 2:
countupday--;
break;
default:
break;
頭文件595
/* 第二組級聯(lián)74LS595_2數(shù)碼管驅(qū)動程序 */
#ifndef _LS595_2driver_H_
#define _LS595_2driver_H_
sbit RCK_595_2 = P0^4; //第二組級聯(lián)595的并行輸出時鐘
sbit DS_595_2 = P0^3; //第二組級聯(lián)595數(shù)據(jù)線
sbit CLK_595_2 = P0^5; //第二組級聯(lián)595移位輸入時鐘
unsigned char code countupseg[] = //第二組595中定義0~9,高亮低滅
{// 0 1 2 3 4 5 6 7 8 9
0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F
unsigned char code roundseg[6]={0x01,0x02,0x04,0x08,0x10,0x20}; //花式旋轉(zhuǎn)
/*延時函數(shù) 1ms為單位*/
void Delay_ms(unsigned int t) //延時函數(shù),t/ms
unsigned int a,b;
for(a=0;a<t;a++)
for(b=0;b<100;b++)
_nop_();
/* 向1個LS595_2寫入1個字節(jié)*/
void Send1byte_595_2(unsigned char dat)
unsigned char i;
for(i=0;i<8;i++)
if(dat&0x80)
DS_595_2 = 1;
DS_595_2 = 0;
dat <<=1;
CLK_595_2 = 0;
_nop_();
CLK_595_2 = 1;
/* 向3個級聯(lián)LS595_2寫入3個字節(jié)*/
void Send3byte_595_2(unsigned char dat1,unsigned char dat2,unsigned char dat3)
Send1byte_595_2(dat1);
Send1byte_595_2(dat2);
Send1byte_595_2(dat3);
/*允許將LS595輸出并行數(shù)據(jù)*/
void Out_595_2()
RCK_595_2 = 0;
_nop_();
RCK_595_2 = 1;
/*顯示倒計時 3位*/
void Displaycountupnum(unsigned int num)
unsigned int units,tens,hundreds;
units = num%10;
tens = (num/10)%10;
hundreds = num/100;
Send3byte_595_2(countupseg[hundreds],countupseg[tens],countupseg[units]); //顯示倒計時的個、十、百位
Out_595_2();
/*大字花式轉(zhuǎn)圈*/
void Displayround()
unsigned char j;
for(j=0;j<5;j++)
Send3byte_595_2(roundseg[j],roundseg[j],roundseg[j]);
Out_595_2();
Delay_ms(800);
#endif
