查看: 1635|回復: 0
51單片機經典實例源碼
#include <reg52.h>
#include "LCD1602.h"
uint Num=0;
uchar NumCode[4]={0,0,0,0};
//---------------中斷加一--------------
void my_INT1(void) interrupt 0
Num++;
void Disp()
uint m;
NumCode[0]=Num/1000;
NumCode[1]=Num%1000/100;
NumCode[2]=Num%100/10;
NumCode[3]=Num%10;
for(m=0;m<4;m++)
LCD_Disp(0,5+m,NumCode[m]+0x30);
IT0=1;EA=1;EX0=1;
LCD_Init();
Disp();
#include <reg52.h>
uint Num=3728;
//-----------------------自動加一-------------------------
void Disp()
uchar m;
NumCode[3]=Num%10;
for(m=0;m<4;m++)
LCD_Disp(0,6+m,NumCode[m]+0x30);
LCD_Init();
Disp();
Num++;
Delay(50000);
#include<reg51.h>
uint Num=5432;
//----------定時器T0按鍵加一---------------
void T0Init()
{    TMOD=0x0d;
TH0=5432/256;
TL0=5432%256;
TR0=1;  }
void Disp()
{    int m;
NumCode[3]=Num%10;
for(m=0;m<4;m++)
T0Init();
LCD_Init();
Num=TH0*256+TL0;
Disp();
#include<reg51.h>
uchar T0Num;
sbit LED=P1^0;
//--------定時器TO使LED自動一秒閃一下---------
void T0Init()
TMOD=0x01;
TH0=(65536-10000)/256;
TL0=(65536-10000)%256;
TR0=1;
ET0=1;
EA=1;
void T0Sever() interrupt 1
T0Num++;
if(T0Num==100)
LED=~LED;
T0Num=0;
T0Init();
#include <reg52.h>
uchar num[10]=
0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f
uint shu;
//-----------外部中斷按鍵加減一----------
shu--;
void my_INT2(void) interrupt 2
shu++;
shu=5;
IT0=1;EA=1;EX0=1;
IT1=1;EA=1;EX1=1;
P2=num[shu];
if(shu==10){shu=0;}
if(shu==-1){shu=9;}
#include <reg51.h>
uchar Disp[4]={0x9a,0xca,0xa9,0xac};
//------------------------交通燈---------------------
void delay3ms(uchar i)
uint n,j,k;
for(;i>=1;i--)
for(n=2;n>=1;n--)
for(j=250;j>=1;j--)
for(k=200;k>=1;k--);
P1=Disp[0];delay3ms(4);
P1=Disp[1];delay3ms(1);
P1=Disp[2];delay3ms(4);
P1=Disp[3];delay3ms(1);
#include <reg51.h>
uchar T0Num=0;
uchar PWM=50;
sbit LED=P3^7;
