查看: 3281|回復: 4
基于c51電子密碼鎖源代碼
ID:398790 發表于 2018-9-16 21:32 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
void key_scan();
uchar count0,count1,count3,num,n=0,temp,a,j,count4;
uchar mima[8];                                                        //初始密碼存儲區
uchar tab_key[50];                                                //輸入密碼存儲區
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71};
bit enterflag;                                                        //確認鍵按下與否的標志
bit mimaflag;                                                        //密碼正確與否的標志
bit xiugaiflag;                                                        //修改密碼標志
bit enter1flag;                                                //修改密碼確認鍵標志
sbit red=P3^7;
sbit bell=P3^6;
sbit rs=P2^0;
sbit rw=P2^1;
sbit lcden=P2^2;
sbit scl=P3^4;
sbit sda=P3^5;
uchar code table1[]="input the passco";
uchar code table2[]="de:     --------";
uchar code table3[]="*";
uchar code table4[]="right   (^_^)   ";
uchar code table5[]="first  error!!!!";
uchar code table6[]="second error!!!!";
uchar code table7[]="third error see ";
uchar code table8[]="u tomorrow (^_^)";
uchar code table9[]="define the passc";
uchar code table10[]="ode:    --------";
uchar code table11[]="code   is    new";
//******************************鍵盤消抖函數*******************************
void delay1()
void delay2(uchar x)
        uchar a,b;
        for(a=x;a>0;a--)
         for(b=100;b>0;b--);
void delay(uint z)
        uint x,y;
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
//****************************e^2room的初始化*******************************
void start()  //開始信號
        sda=1;
        delay1();
        scl=1;
        delay1();
        sda=0;
        delay1();
void stop()   //停止
        sda=0;
        delay1();
        scl=1;
        delay1();
        sda=1;
        delay1();
//****************************應答信號*************************************
void respond()
        uchar i;
        scl=1;
        delay1();
        while((sda==1)&&(i<250))i++;
        scl=0;
        delay1();
//*****************************寫字節操作函數**********************************
void write_byte(uchar date)
        uchar i,temp;
        temp=date;
        for(i=0;i<8;i++)
                temp=temp<<1;                        //保持最高位,左移到進位CY
                scl=0;
            delay1();
                sda=CY;
                delay1();
                scl=1;
                delay1();
        scl=0;
        delay1();
        sda=1;//總線釋放
        delay1();
//*******************************讀字節操作函數*****************************
uchar read_byte()
        uchar i,k;
        scl=0;
        delay1();
        sda=1;
        delay1();
        for(i=0;i<8;i++)
                scl=1;
                delay1();
                k=(k<<1)|sda;    //或運算,放到最低位
                scl=0;
                delay1();
        return k;
//**********************************寫地址函數******************************
void write_add(uchar address,uchar date)
        start();
        write_byte(0xa0);
        respond();
        write_byte(address);
        respond();
        write_byte(date);
        respond();
        stop();
//*******************************讀地址函數*************************************
uchar read_add(uchar address)
        uchar date;
        start();
        write_byte(0xa0);
        respond();
        respond();
        start();
        write_byte(0xa1);
        respond();
        date=read_byte();
        stop();
        return date;
//****************************LCD1602的初始化*******************************
void write_com(uchar com)
        rs=0;
        lcden=0;
        P0=com;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
void write_date(uchar date)
        rs=1;
        lcden=0;
        P0=date;
        delay(5);
        lcden=1;
        delay(5);
        lcden=0;
//***************************************密碼比較函數********************************
bit mimacmp()
        bit flag;
        uchar i;
        for(i=0;i<8;i++)
                        if(mima[i]==tab_key[i])
                                flag=1;
                                flag=0;
                                i=8;
        return(flag);                                                        //返回flag
////**********************************LCD顯示函數開始**************************************
void lcd_display()
uchar i=0;
write_com(0x80+0x40+8);
for(i=0;i<n;i++)
write_date(table3[0]);
//****************************************鍵盤功能分配函數群開始****************************
//** 0 ** 1 **2 ** 3**
//** 4** 5** 6 **7 **
//**8** 9** 確認(A)  **無效(B)
//**取消(C)**修改密碼鍵(D)**確認修改鍵(E)**無效(F)
void key_manage1()
tab_key[n]=0;
n++;
if(xiugaiflag==1)
mima[count4]=0;
count4++;
void key_manage2()
tab_key[n]=1;
n++;
if(xiugaiflag==1)
mima[count4]=1;
count4++;
void key_manage3()
tab_key[n]=2;
n++;
if(xiugaiflag==1)
mima[count4]=2;
count4++;
void key_manage4()
tab_key[n]=3;
n++;
if(xiugaiflag==1)
mima[count4]=3;
count4++;
void key_manage5()
tab_key[n]=4;
n++;
if(xiugaiflag==1)
mima[count4]=4;
count4++;
void key_manage6()
tab_key[n]=5;
n++;
if(xiugaiflag==1)
mima[count4]=5;
count4++;
void key_manage7()
tab_key[n]=6;
n++;
if(xiugaiflag==1)
mima[count4]=6;
count4++;
void key_manage8()
tab_key[n]=7;
n++;
if(xiugaiflag==1)
mima[count4]=7;
count4++;
void key_manage9()
tab_key[n]=8;
n++;
if(xiugaiflag==1)
mima[count4]=8;
count4++;
void key_manage10()
tab_key[n]=9;
n++;
if(xiugaiflag==1)
mima[count4]=9;
count4++;
//**********************************確認鍵**************************************************************
void key_manage11()
        enterflag=1;                                        //確認鍵按下
        if(n==8)                                           //只有輸入8個密碼后按確認才做比較
                mimaflag=mimacmp();
                mimaflag=0;
         if(enterflag==1)
                        enterflag=0;
                        n=0;
                        //用FFFFFFFF清除已經輸入的密碼
                        for(count3=0;count3<8;count3++)
                                delay(5);
                                tab_key[count3]=0x0f;
                        TR1=1;        //打開計數器1
                        count1=0;        //定時器1由50MS累計到1S所用的計數器
                        if(mimaflag==1)
                                a=0;
                                write_com(0x01);
                                write_com(0x80);
                                for(count3=0;count3<16;count3++)
                                        write_date(table4[count3]);        //密碼正確,顯示RIGHT,綠燈亮
                                        delay(5);
                                 n=0;
                                 red=0;
                            bell=0;
                                a++;
                                if(a==1)
                                        for(count3=0;count3<8;count3++) //ffffffff清除密碼
                                                delay(5);
                                        write_com(0x01);
                                        write_com(0x80);
                                                write_date(table5[count3]);        //密碼錯誤,顯示 first error,紅燈亮
                                                delay(5);
                                                TR1=1;
                                if(a==2)
                                                delay(5);
                                                write_com(0x01);
                                                write_com(0x80);
                                                        write_date(table6[count3]);        //密碼錯誤,顯示SECOND ERROR,紅燈亮
                                                        delay(5);
                                                        TR1=1;
                                  if(a==3)
                                                        delay(5);
                                                write_com(0x01);
                                                write_com(0x80);
                                                        write_date(table7[count3]);        //密碼錯誤,顯示third error see,紅燈亮
                                                        delay(5);
                                                write_com(0x80+0x40);
                                                        write_date(table8[count3]);//密碼錯誤,顯示 U TOMORROW ,紅燈亮
                                                        delay(5);
                                                        TR1=0;
void key_manage12()
tab_key[n]=11;
n++;                                                  //密碼計數清零
//****************************************************取消鍵********************************************
void key_manage13()
n=0;                                                  //密碼計數清零
write_com(0x80);                                                //指針所指位置
        write_date(table1[count3]);                //第一行顯示INPUT THE PASSPORD:
        delay(5);
        write_date(table2[count3]);        //開機顯示--------
        delay(5);
        tab_key[count3]=0x0f;                        //用FFFFFFFF清楚已經輸入的密碼
//*******************************************修改密碼鍵**********************************
void key_manage14()
        uchar aa=0;
        n=0;
        xiugaiflag=1;
        write_com(0x01);
        write_com(0x80);
        write_date(table9[count3]);        //顯示define the password
        delay(5);
        write_date(table10[count3]);        //顯示--------
        delay(5);
TR0=1;
//******************************************修改密碼鍵的確認鍵********************************
void key_manage15()
n=0;
enter1flag=1;
if(enter1flag==1)
        enter1flag=0;
        count4=0;
        write_com(0x01);
        write_com(0x80);
                write_date(table11[count3]);
                delay(100);
        TR1=1;
        count1=0;
void key_manage16()
tab_key[n]=15;
n++;
//****************************************定時器1的50MS,共延時1秒*****************************
void time_1() interrupt 3
        TH1=(65536-50000)/256;
        TL1=(65536-50000)%256;
        if(count1<20)
                count1++;
        else                                                         //計時到1S
                TR1=0;
                count1=0;
                mimaflag=0;
                red=1;
                bell=1;
                //顯示FFFFFFFF
                write_com(0x01);
                write_com(0x80);
                                write_date(table1[count3]);        //顯示INPUT THE PASSCODE
                                delay(5);
                                write_date(table2[count3]);        //開機顯示FFFFFFFF
                                delay(5);
//***********************************************定時0**********************************************
void time_0() interrupt 1
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
if(count4<8)
        key_scan();
        TR0=0;
        count4=0;
//初始化函數
void init()
        uchar i;
        lcden=0;
        write_com(0x38);                                        //打開顯示模式設置
        write_com(0x0c);                                        //打開顯示,光標等等設置未零
        write_com(0x06);                                        //當讀或寫一個字符后地址指針加一,且光標加一,當寫一個字符后整頻顯示左移,
        write_com(0x01);                                        //清零指令
        //定時器初始化
        TMOD=0x11;                                                        //T0,T1工作方式1
        TH0=(65536-2000)/256;
        TL0=(65536-2000)%256;                                //T0初始化2MS
        TL1=(65536-50000)%256;                                //T1初始化50MS
        TR1=0;
        ET1=1;
        EA=1;
        TR0=0;
        ET0=1;
        count0=0;                                                        //初始沒有密碼輸入,故為零
        enterflag=0;                                                //沒有確認鍵按下
        mimaflag=0;                                                        //密碼正確與否鍵先置零
        red=1;        //紅燈不亮
//************密碼存入EPROM中**********************************
        sda=1;
        delay(5);
        scl=1;
        delay(5);
        for(i=0;i<8;i++)
                write_add(i,8);
                delay2(100);
        for(i=0;i<8;i++)
                mima[i]=read_add(i);
                delay(5);
{        rw=0;
        init();
                delay(5);
                delay(5);
                key_scan();                                                      //調用鍵盤掃描函數
                lcd_display();
//**************************************************鍵盤掃描函數開始********************************
void key_scan()
//**********掃描第一行*********
P1=0xfe;
temp=P1;
temp=temp&0xf0;
if(temp!=0xf0)
delay(100);
if(temp!=0xf0)
temp=P1;
switch(temp)
case 0xee:
key_manage1();
break;
case 0xde:
key_manage2();
break;
case 0xbe:
key_manage3();
break;
case 0x7e:
key_manage4();
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
//**************************************************掃描第二行***********************************
P1=0xfd;
temp=P1;
temp=temp&0xf0;
if(temp!=0xf0)
delay(100);
if(temp!=0xf0)
temp=P1;
switch(temp)
case 0xed:
key_manage5();
break;
case 0xdd:
key_manage6();
break;
case 0xbd:
key_manage7();
break;
case 0x7d:
key_manage8();
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
//*********************************************掃描第三行***********************************
P1=0xfb;
temp=P1;
temp=temp&0xf0;
if(temp!=0xf0)
delay(100);
if(temp!=0xf0)
temp=P1;
switch(temp)
case 0xeb:
key_manage9();
break;
case 0xdb:
key_manage10();
break;
case 0xbb:
key_manage11();
break;
case 0x7b:
key_manage12();
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
//***************************************************掃描第四行****************************************
P1=0xf7;
temp=P1;
temp=temp&0xf0;
if(temp!=0xf0)
delay(100);
if(temp!=0xf0)
temp=P1;
switch(temp)
case 0xe7:
key_manage13();
break;
case 0xd7:
key_manage14();
break;
case 0xb7:
key_manage15();
break;
case 0x77:
key_manage16();
break;
while(temp!=0xf0)
temp=P1;
temp=temp&0xf0;
收藏收藏3 分享淘帖 頂 踩
ID:1 發表于 2018-9-17 00:00 | 只看該作者
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
ID:398790 發表于 2018-9-18 20:06 | 只看該作者
上面描述的原理圖
ID:398790 發表于 2018-9-18 20:20 | 只看該作者
仿真圖,源代碼,鍵盤排列
電子密碼鎖.rar
12.8 MB, 下載次數: 29, 下載積分: 黑幣 -5
仿真圖,源代碼,鍵盤排列
ID:185815 發表于 2018-11-6 08:28 | 只看該作者
感謝分享
