查看: 2065|回復: 1
stm32溫度傳感器的使用
ID:398578 發表于 2018-9-16 10:57 | 顯示全部樓層 |閱讀模式
#include "adc.h"
#include "delay.h"
//初始化ADC
//這里我們僅以規則通道為例
//我們默認將開啟通道0~3
void  Adc_Init(void)
          GPIO_InitTypeDef  GPIO_InitStructure;
          ADC_InitTypeDef  ADC_InitStructure;
        RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA |RCC_APB2Periph_ADC1        , ENABLE );
        RCC_ADCCLKConfig (RCC_PCLK2_Div6);// 小于14M
        ADC_DeInit (ADC1 );
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;                                 //LED0-->PB.5 端口配置
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;                  //推挽輸出
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
  GPIO_Init(GPIOA, &GPIO_InitStructure);
        ADC_DeInit (ADC1 );//復位ADC1,將外設 ADC1 的全部寄存器重設為缺省值
        ADC_InitStructure.ADC_ContinuousConvMode= DISABLE ;
        ADC_InitStructure.ADC_DataAlign= ADC_DataAlign_Right;
        ADC_InitStructure.ADC_ExternalTrigConv=ADC_ExternalTrigConv_None;
        ADC_InitStructure.ADC_Mode=ADC_Mode_Independent;
        ADC_InitStructure.ADC_NbrOfChannel=1;
        ADC_InitStructure.ADC_ScanConvMode=DISABLE ;
        ADC_Init (ADC1 ,&ADC_InitStructure);
        ADC_Cmd (ADC1 ,ENABLE );
        ADC_TempSensorVrefintCmd (ENABLE );
        ADC_ResetCalibration(ADC1);        //使能復位校準
        while(ADC_GetResetCalibrationStatus(ADC1));        //等待復位校準結束
        ADC_StartCalibration(ADC1);         //開啟AD校準
        while(ADC_GetCalibrationStatus(ADC1));         //等待校準結束
//        ADC_SoftwareStartConvCmd(ADC1, ENABLE);                //使能指定的ADC1的軟件轉換啟動功能
u16  Get_Adc(u8 ch)
ADC_RegularChannelConfig (ADC1 ,ch,1,ADC_SampleTime_239Cycles5);//選擇第幾個規則通道   以及規則通道的順序
ADC_SoftwareStartConvCmd (ADC1 ,ENABLE );
while(!ADC_GetFlagStatus (ADC1 ,ADC_FLAG_EOC));
return ADC_GetConversionValue (ADC1 );
u16 Get_Adc_Average(u8 ch,u8 times)
u32 temp;
        u8 t;
        for(t=0;t<times ;t++)
                temp+= Get_Adc(ch);
          delay_ms (5);
return  temp /times ;
u16  T_Get_Adc(u8 ch) //獲得某個通道值
        while(!ADC_GetFlagStatus (ADC1 ,ADC_FLAG_EOC ));
u16  T_Get_Adc_Average(u8 ch,u8 times)//局部變量
        u32 temp;
        u8 t;
        temp +=T_Get_Adc (ch);
        delay_ms(5);
        return temp/times ;
short Get_Temprate(void)
   u32 adcx;
        short result;
        double temperate;
        adcx =T_Get_Adc_Average(ADC_Channel_16 ,20) ;
        temperate=(float)adcx*(3.3/4096);
        temperate=(1.43-temperate)/0.0043+25;
        result =temperate *=10;
        return result ;
ID:1 發表于 2018-9-16 15:55 | 顯示全部樓層
補全原理圖或者詳細說明一下電路連接即可獲得100+黑幣
