查看: 1967|回復(fù): 0
在串口助手中,隨意輸入“16進(jìn)制數(shù)(6位以下)+n”,顯示在數(shù)碼管上;
ID:398256 發(fā)表于 2018-9-15 11:15 | 顯示全部樓層 |閱讀模式
# include <reg52.h>                        //輸入一個(gè)6字符顯示在數(shù)碼管上
# define uint unsigned int
# define uchar unsigned char
sbit dula = P2^6;
sbit wela = P2^7;
uchar a, i, k;
uchar  shuwei[6];
char code temp_dula[]={
        0x3f,0x06,0x5b,0x4f,
        0x66,0x6d,0x7d,0x07,
        0x7f,0x67,0x77,0x7c,
        0x39,0x5e,0x79,0x71
char code weixuan[]={
        0xdf,0xef,0xf7,0xfb,
        0xfd,0xfe
char code temp_shu[]={
        '0','1','2','3',
        '4','5','6','7',
        '8','9'
uchar code zifu[] = {
        0x30, 0x31, 0x32, 0x33,
        0x34, 0x35, 0x36, 0x37,
        0x38, 0x39, 0x61, 0x62,
        0x63, 0x64, 0x65, 0x66,
void init();
void delay(uint k);
void display();
void shiliu_shuma();
        init();
                display();
void init()
        TMOD = 0x20;
        TH1 = 0xfd;
        TL1 = 0xfd;
        TR1 = 1;
        EA = 1;
        ES = 1;
        SM0 = 0;
        SM1 = 1;
        REN = 1;
        i = 0;
        k = 1;
void ser () interrupt 4
        shiliu_shuma();
void delay(uint k)                //軟件延時(shí)
        uint x, y;
        for(x=k;x>0;x--)
                for(y=10000;y>0;y--);
void shiliu_shuma()
        uchar j, x, y, z;
        if(RI == 1)
                RI = 0;
                a = SBUF;
                if(a == 0x6e)                //當(dāng)a==n時(shí),只顯示當(dāng)前輸入字符,并且重新排序
                        for(x=0,y=i-1;x<y;x++,y--)
                                z = shuwei[x];
                                shuwei[x] = shuwei[y];
                                shuwei[y] = z;
                        k = i;
                        i = 0;
                        for(j=0;j<16;j++)
                                if(zifu[j] == a)
                                        shuwei[i] = j;
                        j = 0;
                        k++;
                        i++;
void display()                //動態(tài)顯示窗口
        uchar u;
        for(u=0;u<k;u++)
                        delay(1);
                        wela = 1;
                        P0 = weixuan[u];
                        wela = 0;
                        dula = 1;
                        P0 = temp_dula[shuwei[u]];
                        dula = 0;
