查看: 4123|回復: 2
STM32讀取寫入EEPRIOM 24C02程序(理論支持24全系列)
ID:327448 發表于 2018-9-13 17:24 | 顯示全部樓層 |閱讀模式
代碼中有詳細連接方式,IIC讀取寫入EEPROM
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "sys.h"
  4. #include "usart.h"
  5. #include "lcd.h"
  6. #include "key.h"
  7. #include "24cxx.h"
  8. #include "myiic.h"
  9. #include "oled.h"
  10. //要寫入到24c02的字符串數組
  11. const u8 TEXT_Buffer[]={"CUIT"};
  12. #define SIZE0 sizeof(TEXT_Buffer)
  13.
  14. int main(void)
  15. {
  16.         u8 key;
  17.         u16 i=0;
  18.         u8 datatemp[SIZE0];
  19.         NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設置中斷優先級分組2
  20.         delay_init();                     //延時函數初始化
  21.         uart_init(115200);                 //串口初始化為9600
  22.         LED_Init();                                  //初始化與LED連接的硬件接口
  23.         KEY_Init();                                //按鍵初始化
  24.         AT24CXX_Init();                        //IIC初始化
  25.         OLED_Init();
  26.         OLED_Clear();
  27.          PBout(9)=0;
  28.          PBout(8)=0;
  29.         while(AT24CXX_Check())//檢測不到24c02
  30.         {
  31.                 printf("24C02 Check Failed! \n");
  32.                         OLED_ShowString(1,1,"24C02 Check !",8);
  33.
  34.                 delay_ms(500);
  35.                 printf("Please Check!       \n");
  36.                         OLED_ShowString(1,3,"Please Check! ",8);
  37.                 delay_ms(500);
  38.         }
  39.                         OLED_Clear();
  40.                 printf("24C02 Ready! \n");
  41.                                 OLED_ShowString(1,1,"24C02 Ready!",8);
  42.         delay_ms(800);
  43.         delay_ms(800);
  44.         delay_ms(800);
  45.           OLED_Clear();
  46.                           printf("Start Write 24C02....\n");
  47.                                 OLED_ShowString(4,3,"Start Write...",8);
  48.         delay_ms(800);
  49.         delay_ms(800);
  50.         delay_ms(800);
  51.                           AT24CXX_Write(0,(u8*)TEXT_Buffer,SIZE0);
  52.
  53.                           printf("24C02 Write Finished!  \n");
  54.                                 OLED_ShowString(4,3,"Write Finished !",8);
  55.         delay_ms(800);
  56.         delay_ms(800);
  57.         delay_ms(800);
  58.                                  OLED_Clear();
  59. //                }
  60.
  61. //                if(key==KEY0_PRES)//KEY0 按下,讀取字符串并顯示
  62. //                {
  63.                         printf("Start Read 24C02....  \n");
  64.                                         OLED_ShowString(4,3,"Start Read ...",8);
  65.         delay_ms(800);
  66.         delay_ms(800);
  67.         delay_ms(800);
  68.                         AT24CXX_Read(0,datatemp,SIZE0);
  69.                                                  OLED_Clear();
  70.
  71.                         OLED_ShowNum(5,5,SIZE0,3,8);
  72.                         printf("The Data Is:  \n");
  73.
  74.                             OLED_ShowString(2,1,"The Data Is:",8);
  75.                                         OLED_ShowString(4,3,datatemp,8);
  76.                         printf("%s \n",datatemp);
  77. //                }
  78.         }
  79. //}
IIC-24C02.rar (380.94 KB, 下載次數: 72)
參與人數 2黑幣 +62 收起 理由
muzhi + 12 很給力!
ID:342911 發表于 2019-12-11 23:51 | 顯示全部樓層
感謝感謝,IIC初始化時忘了改變指定管腳映射這回事,坑了好久
ID:658039 發表于 2020-1-16 14:36 | 顯示全部樓層
好像C02與后面的不一樣,
