查看: 1731|回復(fù): 0
四線雙極性電機的單片機程序按鍵沒有反應(yīng)
ID:397079 發(fā)表于 2018-9-12 19:12 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
有沒有大神幫我看一下問題出在哪里
插上后 按鍵沒反應(yīng)
課設(shè)要做的
希望哪位朋友給點幫助  不勝感激
下面是原程序:
  1. #include<reg52.h>
  2. #define uint  unsigned int
  4. sbit K1=P3^0;        //定義五個按鍵
  5. sbit K2=P3^1;        //
  6. sbit K3=P3^2;        //
  7. sbit K4=P3^3;        //
  8. sbit K5=P3^4;        //
  9. sbit motoA=P1^0;//四線雙極性電機in_A
  10. sbit motoB=P1^1;//in_B
  11. sbit motoC=P1^2;//in_c
  12. sbit motoD=P1^3;//in_d
  13. uchar state=0;        //狀態(tài)變量
  14. uint Time=60;         //轉(zhuǎn)速
  15. void delay(uint ms)                           //Ñóê±£¬óÃóúμ÷Ëù
  16. {
  17.         uint t;
  18.         while(ms--)
  19.                 for(t=0;t<120;t++);
  20. }
  21. void motor_zz()                  //正轉(zhuǎn)
  22. {
  23.
  24.         while(1){
  25.
  26.                               motoA = 1;
  27.                                 motoB = 1;
  28.                                 motoC = 0;
  29.                                 motoD = 1;
  30.                                 delay(Time);
  31.                                 motoA = 0;
  32.                                 motoB = 1;
  33.                                 motoC = 1;
  34.                                 motoD = 1;
  35.                                 delay(Time);
  36.                                 motoA = 1;
  37.                                 motoB = 1;
  38.                                 motoC = 1;
  39.                                 motoD = 0;
  40.                                 delay(Time);
  41.                                 motoA = 1;
  42.                                 motoB = 0;
  43.                                 motoC = 1;
  44.                                 motoD = 1;
  45.                                 delay(Time);
  46.         if(P3==0xfe)
  47.                                 {
  48.                            break;
  49.                                 }
  50.
  51. }
  52. }
  53. void motor_fz()                  //反轉(zhuǎn)
  54. {
  55.
  56.         while(1)
  57.         {
  58.                                 motoA = 1;
  59.                                 motoB = 0;
  60.                                 motoC = 1;
  61.                                 motoD = 1;
  62.                                 delay(Time);
  63.                                 motoA = 1;
  64.                                 motoB = 1;
  65.                                 motoC = 1;
  66.                                 motoD = 0;
  67.                                 delay(Time);
  68.                                 motoA = 0;
  69.                                 motoB = 1;
  70.                                 motoC = 1;
  71.                                 motoD = 1;
  72.                                 delay(Time);
  73.                                 motoA = 1;
  74.                                 motoB = 1;
  75.                                 motoC = 0;
  76.                                 motoD = 1;
  77.                                 delay(Time);
  78.         if(P3==0xfe)
  79.                                 {
  80.                            break;
  81.                                 }
  82.
  83. }
  84. }
  85. void main()
  86. {
  87. P1=0x00;
  88.         while(1)
  89.         {
  90.                 while(state==0)                        //×′ì¬0£¬í£Ö1
  91.                 {
  92.                         if(K2==0)   //°′ÏÂK2£¬μç»úÕy×a
  93.                         {
  94.                                 state=1;
  95.
  96.                                 break;
  97.                         }
  98.                         if(K3==0)           //°′ÏÂK3£¬μç»ú·′×a
  99.                         {
  100.                                 state=2;
  101.
  102.                                 break;
  103.                         }
  104.                         P0=0x00;
  105.
  106.                 }
  107.
  108.                 while(state==1)                        //×′ì¬1£¬Õy×a
  109.                 {
  110.                         if(K1==0)           //°′ÏÂK1£¬μç»ú·′×a
  111.                         {
  112.                                 state=0;
  113.
  114.                                 break;
  115.                         }
  116.                         if(K2==0)                //°′ÏÂK2£¬μç»úÕy×a
  117.                         {
  118.                                 state=1;
  119.
  120.                                 break;
  121.                         }
  122.                         if(K3==0)                //°′ÏÂK3£¬μç»ú·′×a
  123.                         {
  124.                                 state=2;
  125.
  126.                                 break;
  127.                         }
  128.                         if(K4==0)                //°′ÏÂK4£¬μç»ú¼óËù
  129.                         {
  130.                                 Time=Time-5;
  131.                                 if(Time<20)
  132.                                 Time=20;
  133.                                 while(K4==0);
  134.                         }
  135.                         if(K5==0)                //°′ÏÂK5£¬μç»ú¼õËù
  136.                         {
  137.                                 Time=Time+5;
  138.                                 if(Time>100)
  139.                                 Time=100;
  140.                                 while(K5==0);
  141.                         }
  142.                         motor_zz();                 //×′ì¬1£¬Õy×a
  143.                 }
  144.                 while(state==2)                   //×′ì¬2£¬·′×a
  145.                 {
  146.                         if(K1==0)                 //°′ÏÂK1£¬μç»ú·′×a
  147.                         {
  148.                                 state=0;
  149.
  150.                                 break;
  151.                         }
  152.                         if(K2==0)                 //°′ÏÂK2£¬μç»úÕy×a
  153.                         {
  154.                                 state=1;
  155.
  156.                                 break;
  157.                         }
  158.                         if(K3==0)                  //°′ÏÂK3£¬μç»ú·′×a
  159.                         {
  160.                                 state=2;
  161.
  162.                                 break;
  163.                         }
  164.                         if(K4==0)                   //°′ÏÂK4£¬μç»ú¼óËù
  165.                         {
  166.                                 Time=Time-5;
  167.                                 if(Time<20)
  168.                                 Time=20;
  169.                                 while(K4==0);
  170.                         }
  171.                         if(K5==0)                   //°′ÏÂK5£¬μç»ú¼õËù
  172.                         {
  173.                                 Time=Time+5;
  174.                                 if(Time>100)
  175.                                 Time=100;
  176.                                 while(K5==0);
  177.                         }
  178.                         motor_fz();                //×′ì¬2£¬·′×a
  179.                 }
  180.         }
  181. }
