查看: 1406|回復(fù): 0
KD3004-DD11Ae_Rev.C
ID:396835 發(fā)表于 2018-9-12 09:43 | 只看該作者 回帖獎(jiǎng)勵(lì) |正序?yàn)g覽 |閱讀模式
This specification is applied to ROHM standard type of thermal printhead KD3004-DD11A.
Production Place: China
1. Outlines
(1)  Dimensional Outline  Fig.1
(2)  Heat Element Structure  2 heaters/dot
(3)  Number of Heat Elements  1280 dots
(4)  Heat Element Pitch  0.0847mm pitch (11.81 dots mm )
(5)  Print Width  108.416mm  ± 0.2  mm
(6)  Average Resistance Value (R ave )  *1 1000Ω  ± 3  %
(7)  Circuit Diagram  Fig.2
(8)  Pin out Diagram  Table1
(9)  Electrical Characteristics of Circuit  Table2, Fig.3
(10)  Thermistor  Table3, Fig.4
(11)  Package diagram  Fig.5
*1 Average resistance value is the one obtained as averaged resistance value of each heat element of the printhead.
Tolerance ±3% shows the distribution of such averaged resistance value of the printhead.
KD3004-DD11Ae_Rev.C.PDF
252.54 KB, 下載次數(shù): 2, 下載積分: 黑幣 -5
