查看: 6365|回復: 6
低成本AVR單片機+LCD示波器(源碼+原理圖)
低成本AVR+LCD示波器,內有源碼,原理圖等 。
電路原理圖如下:
  1. /* AVR oscilloscope with 128x64 graphic LCD.
  2.    Created by Serasidis Vassilis and finished at 03.Aug.2007
  3.    e-mail: info@serasidis.gr and avrsite@yahoo.gr
  4.    This code is ditributed under GPL licence.
  5. */
  6. #include <avr/io.h>                // include I/O definitions (port names, pin names, etc)
  7. #include <avr/interrupt.h>
  8. #include "glcd.c"
  9. void USART_Init(unsigned int baudrate);
  10. void timePause(unsigned long count);
  11. void ADC_init (void);
  12. void initTimer (void);
  13. /* define CPU frequency in Mhz here if not defined in Makefile */
  14. #ifndef F_CPU
  15. #define F_CPU 16000000UL
  16. #endif
  17. #define msUp                                1
  18. #define msDwn                                4
  19. #define YposUp                                0
  20. #define YposDwn                                3
  21. #define freeze                                2
  22. #define AC                                         0
  23. #define DC                                         1
  24. #define SQUARE                                2
  25. #define TRUE                                0
  26. #define FALSE                                1
  27. unsigned int counter = 0;
  28. unsigned int dataCounter = 0;
  29. unsigned int timeDiv = 52;
  30. unsigned int analogInput = 0;
  31. unsigned char trigger = 2;
  32. unsigned char cnt = 0;
  33. unsigned char empty = 0;
  34. unsigned int out = 0;
  35. unsigned char findZero = 0;
  36. unsigned char pressedButton = 0;
  37. unsigned char upLimit = 0;
  38. unsigned char dnLimit = 255;
  39. unsigned char limitBkup = 0;
  40. unsigned char  voltageType = AC;
  41. unsigned char  complete = TRUE;
  42. signed char Ypos   = 0;
  43. signed char Ypos2   = 0;
  44. signed char position  = 0;
  45. int main (void)
  46. {
  47.         DDRC = 0b00000000;
  48.         PORTC = 0b11111111;
  49.         DDRA = 0b00000000;
  50.         unsigned char temp1;
  51.         unsigned int temp2;
  52.         unsigned char i;
  53.         glcdInit();
  54.         ADC_init();
  55.         createWelcomeScreen();
  56.         showTheWave();
  57.         timePause(10000000);
  58.         for(;;)
  59.         {
  60.         //---------
  61.                         if (pressedButton == 0)
  62.                         {
  63.                         if (~PINC & (1<<msUp) && (timeDiv <= 1000))
  64.                                 {
  65.                                         if(timeDiv == 0)
  66.                                                 timeDiv = 52;
  67.                                         else
  68.                                     timeDiv += 145;
  69.                                         pressedButton = 1;
  70.                                 }
  71.
  72.                                 if (~PINC & (1<<msDwn) && (timeDiv >= 52))
  73.                                 {
  74.                                         if(timeDiv <= 145)
  75.                                                 timeDiv = 0;
  76.                                         else
  77.                                                 timeDiv -= 145;
  78.                                         pressedButton = 1;
  79.                                 }
  80.
  81.                                 if (~PINC & (1<<YposUp) && (Ypos2 <= 60))
  82.                             Ypos2++;
  83.
  84.                                 if (~PINC & (1<<YposDwn) && (Ypos2 >= -60))
  85.                                         Ypos2--;
  86.                                 if (~PINC & (1<<freeze))
  87.                                         while (~PINC & (1<<freeze)); // It freezes the display to watch the wave.
  88.
  89.                         }
  90.                         else
  91.                         {
  92.                                 temp1 = PINC;
  93.                                 if (temp1 == 255)
  94.                                         pressedButton = 0;
  95.                         }
  96.
  97. //--------v
  98. // This routine makes the trigger.
  99.                         dataCounter = 0;
  100.                         findZero = 0;
  101.                         upLimit = 0;
  102.                         dnLimit = 255;
  103.                 for (i=99; i>0; i--)
  104.                 {
  105.                         ADCSRA |= (1 << ADSC); // Enable ADC
  106.                         loop_until_bit_is_set(ADCSRA, ADIF);                // wait until conversion complete.
  107.                         temp1 = ADCL;
  108.                         temp2 = ADCH;
  109.                         timePause(timeDiv); //(7);
  110.                         if (upLimit < temp2) // find the higher voltage level of the input waveform.
  111.                                 upLimit = temp2;
  112.                         if (dnLimit > temp2) // find the lower voltage level of the input waveform.
  113.                                 dnLimit = temp2;
  114.                         if (temp2 > 0)
  115.                         {
  116.                                 temp2 += 5;
  117.                                 temp2 /= 5;
  118.                                 temp2 += 2;
  119.                         }else temp2 = 2;
  120.
  121.                         position = temp2 + Ypos2 +5;
  122.                         if (position <= 63 && position >= 0)  // Adjust Up-Down the wave.
  123.                                 fillDataLcdBuffer(i,position);
  124.                         else
  125.                                 fillDataLcdBuffer(i,0);
  126.                 }
  127.                 if(upLimit != dnLimit)
  128.                         trigger = (((upLimit - dnLimit)/2)+ dnLimit); // find the middle of the wave, to be used it as a trigger.
  129. //--------^
  130.                 createRaster();
  131.                 createWave();
  132.                 showTheWave();
  133.
  134.                                 dataCounter = 0;
  135.                                 do
  136.                                 {
  137.                                         limitBkup = temp2;
  138.                                         ADCSRA |= (1 << ADSC); // Enable ADC
  139.                                         loop_until_bit_is_set(ADCSRA, ADIF);
  140.                                         temp1 = ADCL;
  141.                                         temp2 = ADCH;
  142.                                         //timerPause(timeDiv);
  143.                                         if(limitBkup == temp2)
  144.                                         {
  145.                                                 dataCounter++;
  146.                                                 if(dataCounter >= 500)
  147.                                                         voltageType = DC;
  148.                                                 else
  149.                                                         voltageType = AC;
  150.                                         }
  151.                                         if((voltageType == AC) && ((temp2 == trigger) && (limitBkup < temp2)))
  152.                                                 complete = TRUE;
  153.                                         else
  154.                                         if((voltageType == DC) && (limitBkup == temp2) && (upLimit != dnLimit))
  155.                                         {
  156.                                                 dataCounter = 0;
  157.                                                 do
  158.                                                 {
  159.                                                         ADCSRA |= (1 << ADSC); // Enable ADC
  160.                                                         loop_until_bit_is_set(ADCSRA, ADIF);
  161.                                                         temp1 = ADCL;
  162.                                                         temp2 = ADCH;
  163.                                                         complete = TRUE;
  164.                                                         dataCounter++;
  165.                                                 }while ((temp2 > trigger) && (dataCounter <1000));
  166.
  167.                                                 dataCounter = 0;
  168.                                                 do
  169.                                                 {
  170.                                                         ADCSRA |= (1 << ADSC); // Enable ADC
  171.                                                         loop_until_bit_is_set(ADCSRA, ADIF);
  172.                                                         temp1 = ADCL;
  173.                                                         temp2 = ADCH;
  174.                                                         complete = TRUE;
  175.                                                         dataCounter++;
  176.                                                 }while ((temp2 < trigger) && (dataCounter <1000));
  177.                                         }
  178.                                         else
  179.                                         if((voltageType == DC) && (limitBkup == temp2))
  180.                                                 complete = TRUE;
  181.                                         else
  182.                                                 complete = FALSE;
  183.
  184. ……………………
  185. …………限于本文篇幅 余下代碼請從51黑下載附件…………
低成本AVR LCD示波器.rar (920.44 KB, 下載次數: 54)
收藏收藏4 分享淘帖 頂 踩
ID:79874 發表于 2019-1-30 07:13 | 只看該作者
能上傳pcb嗎
ID:91346 發表于 2019-1-30 10:24 | 只看該作者
能實現具體哪些基本功能?謝謝
ID:480245 發表于 2019-2-25 10:16 來自觸屏版 | 只看該作者
好東西,我喜歡。
ID:486279 發表于 2019-3-7 15:03 | 只看該作者
確實厲害了   我也想做一個
ID:486279 發表于 2019-3-7 15:04 | 只看該作者
這個當然可以上傳
ID:467922 發表于 2019-3-19 14:56 | 只看該作者
這個很好呀
