查看: 1738|回復(fù): 0
基于stc12c5a60s2的3D8光立方
ID:388135 發(fā)表于 2018-9-10 20:46 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
部分源碼
  1. #include <STC12C5A60S2.H>
  2. #include <intrins.h>
  3. #include"zimo.h"
  4. #include"yinpin.h"
  5. #include"flash.h"
  6. #include"hanshu.h"
  7. uchar data rxcnt=0;
  8. /*************************************************************************/
  9. void main()
  10. {
  11.     out=1;
  12.         menu=0;
  13.         bb=3;
  14.         AK=0;
  15.         BK=1;
  16.         InitUart();
  17.     initial595();
  18.     initial5952();
  19.     timer0init();
  20.           while(1)
  21.           {
  22.            huxi();
  23.                 zhu2();
  24.            }
  25. }
  26. /******************************************************************************/
  27. /**************************************************************************/
  28.   void print1() interrupt 3
  29. {
  30.     if(out==1)
  31. {
  32.                 TR1=0;                //關(guān)閉定時(shí)器1
  33.                 TH1=(65536-2500)/256;  //定時(shí)  time = F63C ;104.1us
  34.                 TL1=(65536-2500)%256;
  35.         if(num>=(amenu-1))
  36.                 num=0;
  37.         else
  38.                 num++;
  39.         if(b[num]<c[num])
  40.         {
  41.                 b[num]++;
  42.          }
  43.         if(b[num]>c[num])
  44.          {
  45.                 b[num]--;
  46.           }
  47.         if(b[num]>8)
  48.          {
  49.                 b[num]=8;
  50.           }
  51.
  52. switch(yp)
  53.   {
  54.             case 1:        send_data2(~tuku2[b[num]]);
  55.                     if(amenu<=2){}
  56.                             else delay(50);
  57.                                 break;
  58.             case 2:        send_data2(~tuku1[b[num]]);
  59.                                 if(amenu<=2){}
  60.                                 else delay(50);
  61.                                 break;
  62.             case 3:        send_data2(~tuku3[b[num]]);
  63.                                 if(amenu<=2){}
  64.                                 else delay(50);
  65.                                 default:break;
  66.     }
  67.   }
  68. if(out==2||out==3)
  69.         {
  70.                         uchar i;
  71.                     static uchar layer=0;
  72.           for(i=0;i<8;i++)
  73.             {   buffer[i]=~display[layer][i];
  74.                         }
  75.                         xiansi1();
  76.                             cheng=(0x01<<layer);
  77.                             DS2 = ~cheng&0x01; //發(fā)送最低位
  78.                              receive_sta=0;       //清除接受成功標(biāo)志,這步很重要
  79.                                 SH_CP2 = 1;
  80.                                 SH_CP2 = 0;                  //移位寄存器移位
  81.                                 ST_CP=1;
  82.                             ST_CP=0;
  83.                                 ST_CP2=1;
  84.                             ST_CP2=0;
  85.                 if (layer<7)
  86.                 layer++;
  87.         else
  88.                 layer=0;
  89.                             TH1=0xfe;
  90.                             TL1=0xfe;
  91.                             delay(2);
  92.
  93.                                 key_amenu_scan();
  94.                                 key_menu_scan();
  95.                                 key_out_scan();
  96.                         if(out==4)
  97.                             {IAP_CONTR=0x20;}
  98.
  99.         }
  100.                                    TR1=1;//啟動(dòng)定時(shí)?
  101. }
  102. /***************************************************************************/
  103. void UartIntterupt() interrupt 4
  104. {
  105.    unsigned char res=0;
  106.         if(RI==1)//進(jìn)入到接受中斷
  107.         {
  108.                  RI=0;
  109.                 if(receive_sta==1)return;//如果接受完成啦就直接退出,等待main函數(shù)將數(shù)據(jù)給顯示完
  110.                 res=SBUF;
  111.                 if(byte_cnt==0)cmd_type=res;//第一個(gè)字節(jié)為命令類型
  112.                 switch(cmd_type)
  113.                 {
  114.                    case 0xf5: //動(dòng)畫下載
  115.                      cube_frame[byte_cnt]=res;
  116.                          byte_cnt++;
  117.                          menu=1;
  118.                          out=2;
  119.                          sa=0;
  120.                          if(byte_cnt==73)
  121.                          { byte_cnt=0;
  122.                            receive_sta=1;//表示接受完成
  123.                            }
  124.                      break;
  125.                    case 0xf4: //進(jìn)入音頻模式
  126.                                 menu=1;
  127.                                 out=1;
  128.                                receive_sta=1; //因?yàn)榇嗣罹鸵粋(gè)字節(jié),所以直接接受完成.下面類似
  129.                      break;
  130.                    case 0xD4: //脫機(jī)動(dòng)畫
  131.                                 menu=1;
  132.                                 out=3;
  133.                         receive_sta=1;
  134.                      break;
  135.                    case 0xf1: //動(dòng)畫音量增加
  136.                                 k3=0;
  137.                                         delay2(50000);
  138.                                         delay2(50000);
  139.                                         delay2(50000);
  140.                                         delay2(50000);
  141.                                         k3=1;
  142.                                    receive_sta=1;
  143.                      break;
  144.                    case 0xf0: //動(dòng)畫音量減小
  145.                             k2=0;
  146.                                         delay2(50000);
  147.                                         delay2(50000);
  148.                                         delay2(50000);
  149.                                         delay2(50000);
  150.                                         k2=1;
  151.                         receive_sta=1;
  152.                      break;
  153.                    case 0xef: //上一曲
  154.                             k2=0;
  155.                                         delay2(20000);
  156.                                         k2=1;
  157.                         receive_sta=1;
  158.                      break;
  159.                    case 0xee: //下一曲
  160.                                     k3=0;
  161.                                         delay2(20000);
  162.                                         k3=1;
  163.                         receive_sta=1;
  164.                          break;
  165.                    case 0xed: //eq音樂類型,搖滾,爵士,流行
  166.                                     k1=0;
  167.                                         delay2(20000);
  168.                                         k1=1;
  169.                         receive_sta=1;
  170.                      break;
  171.                    case 0xec: //暫停與播放
  172.                                     k1=0;
  173.                                         delay2(20000);
  174.                                         k1=1;
  175.                         receive_sta=1;
  176.                      break;
  177.                    case 0xeb: //音頻模式切換
  178.                              amenu++;
  179.                                 if(amenu==8)
  180.                                     amenu=1;
  181.                            receive_sta=1;
  182.                             break;
  183.                    case 0xea: //進(jìn)入待機(jī)
  184.                              out=4;                   //
  185.                                              IAP_CONTR=0x20;
  186.                                          receive_sta=1;
  187.                                           break;
  188.                    case 0xe9: //脫機(jī)動(dòng)畫音量速度
  189.                                    bb++;
  190.                                 if(bb==15)
  191.                                     bb=1;
  192.                                         receive_sta=1;
  193.                                     break;
  194.                    case 0xe8: //脫機(jī)動(dòng)畫顏色
  195.                             yanse++;
  196.                                 if(yanse==8)
  197.                                     yanse=0;
  198.                                         receive_sta=1;
  199.                                     break;
  200.
  201.                   case 0xD0: //外部音頻
  202.                             AK=1;
  203.                                         BK=0;
  204.                                         receive_sta=1;
  205.                                     break;
  206.                   case 0xD1: //內(nèi)部音頻
  207.                             AK=0;
  208.                                         BK=1;
  209.                                         receive_sta=1;
  210.                                     break;
  211.                    case 0xD2: //亮度
  212.                             ABL=~ABL;
  213.                                         receive_sta=1;
  214.                                     break;
  215.                   case 0xD3: //模式切換
  216.                             k3=0;
  217.                                         delay2(20000);
  218.                                         k3=1;
  219.                                         delay2(10000);
  220.                                         k3=0;
  221.                                         delay2(20000);
  222.                                         k3=1;
  223.                                         receive_sta=1;
  224.                                     break;
  225.                    default:break;//藍(lán)牙的連接成功或者斷開連接消息
  226.                 }
  227.         }
  228. }
  229. void ADC_Finish() interrupt 5
  230. {          int yinpin;
  231.       yinpin++;
  232.           if(yinpin==20000)
  233.           {        yinpin=0;
  234.                            yp++;
  235.                            if(yp==4)
  236.                            yp=1;
  237.                            amenu++;
  238.                            if(amenu==9)
  239.                            amenu=1;
  240.            }
  241.             if(ADC_CONTR&0x10)  //判斷ADC-FLGA位是否為1,為1表明A/D已轉(zhuǎn)換完成。
  242.       delay(1);
  243. }
rtf格式文件可以word打開。
MT10-單色app程序源碼.rar
228.38 KB, 下載次數(shù): 17, 下載積分: 黑幣 -5
MT10-原理圖.rar
1.89 MB, 下載次數(shù): 9, 下載積分: 黑幣 -5
評(píng)分
參與人數(shù) 1黑幣 +50 收起 理由
查看全部評(píng)分
收藏收藏3 分享淘帖 頂 踩
