查看: 2530|回復: 3
巡線小車程序分享
ID:322248 發表于 2018-9-9 11:50 | 顯示全部樓層 |閱讀模式
#include <REGX52.H> //°üo¬51μ¥Ƭ»úÏà1ØμÄí·Îļt
sbit LeftLed=P2^0;
sbit RightLed=P0^7;
sbit FontLled=P1^0;
sbit LeftIR=P3^5;
sbit RightIR=P3^6;
sbit FontIR=P3^7;
sbit M1A=P0^0;
sbit M1B=P0^1;
sbit M2A=P0^2;
sbit M2B=P0^3;
sbit B1=P0^4;
sbit SB1=P0^6;
void tingzhi()
   M1A=0;
   M1B=0;
   M2A=0;
   M2B=0;
void qianjin()
   M1A=1;
   M1B=0;
   M2A=1;
   M2B=0;
void houtui()
   M1A=0;
   M1B=1;
   M2A=0;
   M2B=1;
void zuozhuan()
   M1A=0;
   M1B=1;
   M2A=1;
   M2B=0;
void youzhuan()
   M1A=1;
   M1B=0;
   M2A=0;
   M2B=1;
void delay_nus(unsigned int i)
  i=i/10;
  while(--i);
void delay_nms(unsigned int n)
  n=n+1;
  while(--n)
  delay_nus(900);
void ControlCar(unsigned char ConType)
  tingzhi();
switch(ConType)
  case 1:  //ǰ½ø
    qianjin();
    break;
  case 2: //oóíË
    houtui();
    break;
  case 3: //×ó×a
    zuozhuan();
        break;
  case 4: //óò×a
    youzhuan();
        break;
  case 8: //í£Ö1
    tingzhi();
        break;
  bit RunFlag=0;
  //RunShow=0;
  ControlCar(8);
   Start:
   LeftLed=LeftIR;
   RightLed=RightIR;
   FontLled= FontIR;
   SB1=LeftIR;
   if(LeftIR == 0 && RightIR == 0)
      ControlCar(1);
      delay_nms (10);
          goto NextRun;
   if(LeftIR == 0 && RightIR == 1)
      ControlCar(3);
      delay_nms (10);
          goto NextRun;
   if(LeftIR == 1 && RightIR == 0)
      ControlCar(4);
      delay_nms (10);
          goto NextRun;
   goto Start;
   NextRun:
   ControlCar(8);
ID:396331 發表于 2018-9-14 13:50 | 顯示全部樓層
感謝分享
ID:408592 發表于 2018-10-12 14:56 | 顯示全部樓層
請問這個適用于四路紅外感應嗎?超萌新提問
ID:322248 發表于 2019-10-23 17:27 | 顯示全部樓層
我愛羅是是是 發表于 2018-10-12 14:56
適用,原理是一樣的,只是更改相應的引腳而已。
