查看: 3319|回復(fù): 15
單片機(jī)數(shù)碼管顯示疑問,這個(gè)7的f段亮了變成帶鉤的7了
ID:386381 發(fā)表于 2018-9-5 07:22 來自觸屏版 | 只看該作者 |只看大圖 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
這個(gè)溫度計(jì)用的共陽的數(shù)碼管,這個(gè)7的f段亮了變成帶鉤的7了,請(qǐng)師傅們指點(diǎn)下改那里能不讓f段亮變成正常的7,謝謝您!
ID:386381 發(fā)表于 2018-9-5 07:23 來自觸屏版 | 只看該作者
后面這張圖片上傳后這么模糊呀,我拍的好清晰的
ID:386381 發(fā)表于 2018-9-5 08:32 來自觸屏版 | 只看該作者
#include <AT89X52.h> #define uint unsigned int#define uchar unsigned char           //宏定義#define SET  P3_1                            //定義調(diào)整鍵#define DEC  P3_2                            //定義減少鍵#define ADD  P3_3                            //定義增加鍵#define BEEP P3_6                            //定義蜂鳴器#define ALAM P1_2                                //定義燈光報(bào)警#define DQ   P3_7                             //定義DS18B20總線I/O        bit shanshuo_st;                            //閃爍間隔標(biāo)志bit beep_st;                                     //蜂鳴器間隔標(biāo)志sbit DIAN = P0^5;                        //小數(shù)點(diǎn)uchar x=0;                                      //計(jì)數(shù)器signed char m;                                     //溫度值全局變量uchar n;                                              //溫度值全局變量uchar set_st=0;                             //狀態(tài)標(biāo)志signed char shangxian=38;                  //上限報(bào)警溫度,默認(rèn)值為38signed char xiaxian=5;                   //下限報(bào)警溫度,默認(rèn)值為38//uchar code  LEDData[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};uchar code  LEDData[]={0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0xCF,0xDA,0x9B,0xDC,0x9B,0x8B};//
ID:386381 發(fā)表于 2018-9-5 08:33 來自觸屏版 | 只看該作者
#include <AT89X52.h> #define uint unsigned int#define uchar unsigned char           //宏定義#define SET  P3_1                            //定義調(diào)整鍵#define DEC  P3_2                            //定義減少鍵#define ADD  P3_3                            //定義增加鍵#define BEEP P3_6                            //定義蜂鳴器#define ALAM P1_2                                //定義燈光報(bào)警#define DQ   P3_7                             //定義DS18B20總線I/O        bit shanshuo_st;                            //閃爍間隔標(biāo)志bit beep_st;                                     //蜂鳴器間隔標(biāo)志sbit DIAN = P0^5;                        //小數(shù)點(diǎn)uchar x=0;                                      //計(jì)數(shù)器signed char m;                                     //溫度值全局變量uchar n;                                              //溫度值全局變量uchar set_st=0;                             //狀態(tài)標(biāo)志signed char shangxian=38;                  //上限報(bào)警溫度,默認(rèn)值為38signed char xiaxian=5;                   //下限報(bào)警溫度,默認(rèn)值為38//uchar code  LEDData[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xff};uchar code  LEDData[]={0x5F,0x44,0x9D,0xD5,0xC6,0xD3,0xDB,0x47,0xDF,0xD7,0xCF,0xDA,0x9B,0xDC,0x9B,0x8B};///*****顯示開機(jī)初始化等待畫面*****/void Disp_init(void)    {        P0 = ~0x80;      //顯示----        P2 = 0x7F;        Delay(200);        P2 = 0xDF;        Delay(200);           P2 = 0xF7;        Delay(200);        P2 = 0xFD;        Delay(200);        P2 = 0xFF;         //關(guān)閉顯示}/*****顯示溫度子程序*****/void Disp_Temperature(void)     //顯示溫度{        P0 = ~0x98;      //顯示C        P2 = 0x7F;        Delay(100);        P2=0xff;        P0=~LEDData[n];    //顯示個(gè)位        P2 = 0xDF;        Delay(100);        P2=0xff;        P0 =~LEDData[m%10];    //顯示十位        DIAN = 0;         //顯示小數(shù)點(diǎn)        P2 = 0xF7;        Delay(100);        P2=0xff;        P0 =~LEDData[m/10];    //顯示百位        P2 = 0xFD;        Delay(100);        P2 = 0xff;         //關(guān)閉顯示}/*****顯示報(bào)警溫度子程序*****/void Disp_alarm(uchar baojing){        P0 =~0x98;      //顯示C        P2 = 0x7F;        Delay(100);        P2=0xff;        P0 =~LEDData[baojing%10]; //顯示十位        P2 = 0xDF;        Delay(100);        P2=0xff;        P0 =~LEDData[baojing/10]; //顯示百位        P2 = 0xF7;        Delay(100);        P2=0xff;        if(set_st==1)P0 =~0xCE;        else if(set_st==2)P0 =~0x1A; //上限H、下限L標(biāo)示        P2 = 0xFD;        Delay(100);        P2 = 0xff;         //關(guān)閉顯示
ID:97554 發(fā)表于 2018-9-5 08:50 | 只看該作者
看他中括號(hào)里的數(shù)組,第八個(gè)的十六進(jìn)制是怎么寫的。
ID:97554 發(fā)表于 2018-9-5 08:55 | 只看該作者
這個(gè)不看你線路的解法或者你程序中數(shù)組是沒法給你答案的,不同的接法這個(gè)是不一樣的。
ID:370231 發(fā)表于 2018-9-5 09:14 | 只看該作者
把程序放上來不要圖片,圖片看不清楚
ID:393854 發(fā)表于 2018-9-5 09:31 | 只看該作者
不同的接法這個(gè)是不一樣的
ID:97554 發(fā)表于 2018-9-5 09:43 | 只看該作者
共陽數(shù)碼管,低電平有效,7是0XF8是不帶勾的7啊,帶勾的7是0XD8
ID:97554 發(fā)表于 2018-9-5 09:48 | 只看該作者
這是個(gè)數(shù)組是0-9,最后一個(gè)0XFF是全熄狀態(tài)
0XF8
H    G    F    E     D    C    B    A
1     1    1    1     1    0    0    0
8     4    2    1     8    4    2     1
      F                          8
對(duì)應(yīng)的數(shù)碼管只亮ABC三個(gè)筆畫的嘛
ID:96682 發(fā)表于 2018-9-5 10:09 | 只看該作者
習(xí)慣就好,就像 6 和 9 一樣多一橫少一橫都是還是那個(gè)數(shù)字
ID:393890 發(fā)表于 2018-9-5 10:17 | 只看該作者
不就是字庫定義問題,很簡單,看仔細(xì)就可以找到。
ID:393893 發(fā)表于 2018-9-5 10:24 | 只看該作者
修改一下代碼
ID:384109 發(fā)表于 2018-9-5 10:45 | 只看該作者
把這里的0X47改成0X07就可以了
ID:386381 發(fā)表于 2018-9-5 17:33 來自觸屏版 | 只看該作者
謝謝師傅們的耐心解答謝謝
ID:386381 發(fā)表于 2018-9-5 18:14 來自觸屏版 | 只看該作者
問題已經(jīng)解決了把0x47改成0x45好了,謝謝師傅們
