查看: 2154|回復: 0
藍牙hc-06控制單片機LED燈程序
ID:115923 發表于 2018-9-3 11:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h> //頭文件調用,寫程序時都要加上
#include <stdlib.h>
#define uint unsigned int //宏定義,為了后面定義變量書寫簡便
code unsigned char  LED[] ={~0x3F,~0x06,~0x5B,~0x4F,~0x66,~0x6D,~0x7D,~0x07,~0x7F,~0x6F,~0x77,~0x7C,~0x39,~0x5E,~0x79,~0x71};
void main (void)
       SCON= 0x50;      // SCON: 模式1, 8-bit UART, 使能接收
       TMOD|= 0x20;
       TH1=0xfd;           //波特率9600 初值
       TL1=0xfd;
       TR1=1;
       EA=1;                 //打開總中斷
       ES=1;                 //打開串口中斷
       while(1)              //主循環不做任何動作
/* 串口中斷程序*/
void UART_SER () interrupt 4
       uchar n;  //定義臨時變量
       if(RI)           //判斷是接收中斷產生
              RI=0;    //標志位清零
              n=SBUF;//讀入緩沖區的值
              switch(n)
                     case'0':P2=~LED[0];break;
                     case'1':P2=~LED[1];break;
                     case'2':P2=~LED[2];break;
                     case'3':P2=~LED[3];break;
                     case'4':P2=~LED[4];break;
                     case'5':P2=~LED[5];break;
                     case'6':P2=~LED[6];break;
                     case'7':P2=~LED[7];break;
                     case'8':P2=~LED[8];break;
                     case'9':P2=~LED[9];break;
                     case'A':P2=~LED[10];break;
                     case'B':P2=~LED[11];break;
                     case'C':P2=~LED[12];break;
                     case'D':P2=~LED[13];break;
                     case'E':P2=~LED[14];break;
                     case'F':P2=~LED[15];break;
                     default: P2=~LED[0];
              TI=1;
              SBUF=n;//把接收到的值再發回
       if(TI)           //如果是發送標志位,清零
       TI=0;
