查看: 4430|回復: 1
Quartus13.0使用教程(共35頁英文版pdf下載)
Quartus® II Introduction for VHDL Users
This tutorial presents an introduction to the Quartus® II software. It gives a general overview of a typical CAD
flow for designing circuits that are implemented by using FPGA devices, and shows how this flow is realized in the
Quartus® II software. The design process is illustrated by giving step-by-step instructions for using the Quartus®
II software to implement a simple circuit in an Altera® FPGA device.
The Quartus® II system includes full support for all of the popular methods of entering a description of the
desired circuit into a CAD system. This tutorial makes use of the VHDL design entry method, in which the
user specifies the desired circuit in the VHDL hardware description language. Another version of this tutorial is
available that uses Verilog hardware description language.
The screen captures in the tutorial were obtained using Quartus® II version 13.0; if other versions of the soft-
ware are used, some of the images may be slightly different.
Contents:
Getting Started
Starting a New Project
Design Entry Using VHDL Code
Compiling the VHDL Code
Using the RTL Viewer
Specifying Timing Constraints
Quartus® II Window
完整的pdf格式文檔51黑下載地址(共35頁):
quartus_ii_13.0_VHDL官方æ.pdf (1.99 MB, 下載次數: 16)
ID:393904 發表于 2018-9-5 10:48 | 只看該作者
謝謝樓主分享!!!!!!!!!!
