LCD1602
- #include "include.h"
- //LCD1602
- /********IO引腳定義***********************************************************/
- sbit LCD_RS=P1^0;//定義引腳
- sbit LCD_RW=P1^1;
- sbit LCD_E=P1^2;
- /********宏定義***********************************************************/
- #define LCD_Data P0
- #define Busy 0x80 //用于檢測LCD狀態(tài)字中的Busy標識
- /********數(shù)據(jù)定義*************************************************************/
- //unsigned char code uctech[] = {"MCU218"};
- /***********主函數(shù)開始********************************************************/
- void main(void)
- Delay400Ms(); //啟動等待,等LCD講入工作狀態(tài)
- LCDInit(); //初始化
- Delay5Ms(); //延時片刻(可不要)
- DisplayListChar(0, 0, uctech);
- DisplayOneChar(4, 1, 'a');
- ReadDataLCD(); //測試用句無意義
- while(1);
- /***********寫數(shù)據(jù)********************************************************/
- void WriteDataLCD(unsigned char WDLCD)
- ReadStatusLCD(); //檢測忙
- LCD_Data = WDLCD;
- LCD_RS = 1;
- LCD_RW = 0;
- LCD_E = 0; //若晶振速度太高可以在這后加小的延時
- LCD_E = 0; //延時
- LCD_E = 1;
- /***********寫指令********************************************************/
- void WriteCommandLCD(unsigned char WCLCD,BuysC) //BuysC為0時忽略忙檢測
- if (BuysC) ReadStatusLCD(); //根據(jù)需要檢測忙
- LCD_Data = WCLCD;
- LCD_RS = 0;
- LCD_RW = 0;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- /***********讀數(shù)據(jù)********************************************************/
- unsigned char ReadDataLCD(void)
- LCD_RS = 1;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- return(LCD_Data);
- /***********讀狀態(tài)*******************************************************/
- unsigned char ReadStatusLCD(void)
- LCD_Data = 0xFF;
- LCD_RS = 0;
- LCD_RW = 1;
- LCD_E = 0;
- LCD_E = 0;
- LCD_E = 1;
- while (LCD_Data & Busy); //檢測忙信號
- return(LCD_Data);
- /***********初始化********************************************************/
- void LCDInit(void)
- LCD_Data = 0;
- WriteCommandLCD(0x38,0); //三次模式設(shè)置,不檢測忙信號
- Delay5Ms();
- Delay5Ms();
- Delay5Ms();
- WriteCommandLCD(0x38,1); //顯示模式設(shè)置,開始要求每次檢測忙信號
- WriteCommandLCD(0x08,1); //關(guān)閉顯示
- WriteCommandLCD(0x01,1); //顯示清屏
- WriteCommandLCD(0x06,1); //顯示光標移動設(shè)置
- WriteCommandLCD(0x0C,1); //顯示開及光標設(shè)置
- /***********按指定位置顯示一個字符*******************************************/
- void DisplayOneChar(unsigned char X, unsigned char Y, unsigned char DData)
- Y &= 0x1;
- X &= 0xF; //限制X不能大于15,Y不能大于1
- if (Y) X |= 0x40; //當要顯示第二行時地址碼+0x40;
- X |= 0x80; //算出指令碼
- WriteCommandLCD(X, 0); //這里不檢測忙信號,發(fā)送地址碼
- WriteDataLCD(DData);
- /***********按指定位置顯示一串字符*****************************************/
- void DisplayListChar(unsigned char X, unsigned char Y, unsigned char code *DData)
- unsigned char ListLength;
- ListLength = 0;
- Y &= 0x1;
- while (DData[ListLength]>=0x20){ //若到達字串尾則退出
- if (X <= 0xF){ //X坐標應(yīng)小于0xF
- DisplayOneChar(X, Y, DData[ListLength]); //顯示單個字符
- ListLength++;
- X++;
- /***********短延時********************************************************/
- void Delay5Ms(void)
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- /***********長延時********************************************************/
- void Delay400Ms(void)
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //顯示AD轉(zhuǎn)換值
- void display_AD_value(unsigned int result)
- int i=0;
- unsigned int temp=0;
- unsigned char str[3];
- unsigned int j=100;
- unsigned char k=0;
- DisplayOneChar(0, 0, 'U'); //顯示單個字符
- DisplayOneChar(1, 0, '='); //顯示單個字
- DisplayOneChar(6, 0, 'V'); //顯示單個字符
- for(i=0; i<=2; i++)
- temp=result/j;
- result=result-j*temp;
- str[i]=(unsigned char)(temp+0x30);
- j/=10;
- for(k=0,i=0; i<4; k++,i++)
- if(i==0)
- DisplayOneChar(k+2, 0, str[i]); //顯示單個字符
- else if(i==1)
- DisplayOneChar(k+2, 0, '.'); //顯示單個字符
- else
- DisplayOneChar(k+2, 0, str[i-1]); //顯示單個字符
- //顯示電機轉(zhuǎn)動角度
- void display_motor_rotaition(unsigned int result)
- int i=0;
- unsigned char str[4];
- unsigned int j=1000;
- DisplayOneChar(0, 1, 'A'); //顯示單個字符
- DisplayOneChar(1, 1, 'n'); //顯示單個字
- DisplayOneChar(2, 1, 'g'); //顯示單個字符
- DisplayOneChar(3, 1, '='); //顯示單個字符
- DisplayOneChar(9, 1, 'd'); //顯示單個字符
- DisplayOneChar(10, 1, 'u'); //顯示單個字符
- for(i=0; i<=3; i++)
- temp=result/j;
- j/=10;
- for(k=0,i=0; i<5; k++,i++)
- if(i==4)
- DisplayOneChar(k+4, 1, str[i-1]); //顯示單個字符
- else if(i==3)
- DisplayOneChar(k+4, 1, '.'); //顯示單個字符
- else
- DisplayOneChar(k+4, 1, str[i]); //顯示單個字符
LCD1602.rar
(8.88 KB, 下載次數(shù): 13)
2018-8-30 16:21 上傳
下載積分: 黑幣 -5
