LED 點陣電子顯示屏是集微電子技術(shù)、計算機(jī)技術(shù)、信息處理技術(shù)于一體的大型顯示屏系統(tǒng)。它以其色彩鮮艷,動態(tài)范圍廣,亮度高,壽命長,工作穩(wěn)定可靠等優(yōu)點而成為眾多顯示媒體以及戶外作業(yè)顯示的理想選擇。同時也可廣泛應(yīng)用到軍事、車站、賓館、體育、新聞、金融、證券、廣告以及交通運輸?shù)仍S多行業(yè)。本次設(shè)計的點陣顯示屏主要是通過單片機(jī)直接控制行掃描,然后用74LS138來控制列掃描。這個設(shè)計的軟硬件都成功通過了PROTEUS的仿真調(diào)試。 MCS-48成功應(yīng)用的推動下,許多半導(dǎo)體公司和計算機(jī)公司也競相研制和開發(fā)自己的單片機(jī)系列。到目前為止,世界各地廠商也相繼研制出大約50個系列300多個品種的單片機(jī)產(chǎn)品,可以滿足不同領(lǐng)域的需要。代表產(chǎn)品有Intel公司的MCS-51單片機(jī),Motorola公司的MC6081、MC6082系列機(jī),Zilog公司的Z-8系列機(jī),TI公司的TMS7000系列機(jī)等,此外Rockwell、NS、GI和日本的NEC、松下、日立等公司也先生產(chǎn)了自己的單片機(jī)系列。
電路原理圖如下:
2018-8-29 17:51 上傳
單片機(jī)源程序如下:
- #include<reg51.h>
- #include<intrins.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define data1 P0
- #define data2 P2
- sbit s1=P3^6;
- sbit s2=P3^7;
- bit fangxiang;
- uint alt=0,net=0,sl=160;
- bit mode;
- uchar code tab[]={
- // (0) (1) 新(2) 年(3) 快(4) 樂(5) (6) (7)
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",0*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",1*/
- 0x02,0x04,0x22,0x48,0x2A,0x52,0xA6,0x41,0x63,0xFE,0x26,0x40,0x2A,0x50,0x22,0x49,
- 0x00,0x06,0x3F,0xF8,0x22,0x00,0x22,0x00,0x23,0xFF,0x42,0x00,0x02,0x00,0x00,0x00,/*"新",2*/
- 0x00,0x20,0x04,0x20,0x18,0x20,0xE3,0xE0,0x22,0x20,0x22,0x20,0x22,0x20,0x22,0x20,
- 0x3F,0xFF,0x22,0x20,0x22,0x20,0x22,0x20,0x22,0x20,0x20,0x20,0x00,0x20,0x00,0x00,/*"年",3*/
- 0x00,0x80,0x07,0x00,0x00,0x00,0xFF,0xFF,0x08,0x00,0x04,0x81,0x10,0x82,0x10,0x8C,
- 0x10,0xB0,0xFF,0xC0,0x10,0xB0,0x10,0x8C,0x1F,0x82,0x00,0x81,0x00,0x81,0x00,0x00,/*"快",4*/
- 0x00,0x00,0x00,0x04,0x07,0x08,0x39,0x10,0x21,0x60,0x21,0x02,0x21,0x01,0x2F,0xFE,
- 0x41,0x00,0x41,0x00,0xC1,0x40,0x41,0x20,0x01,0x10,0x01,0x0C,0x00,0x00,0x00,0x00,/*"樂",5*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",6*/
- 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",7*/
- void delay(uint z) //延時子函數(shù)
- uchar x;
- for(;z>0;z--)
- for(x=110;x>0;x--);
- void xianshi() //顯示
- uchar aa,i;
- for(i=0;i<16;i++)
- P1=i; //列掃描
- data1=tab[net+aa]; //取出上8行數(shù)據(jù)輸出
- aa++;
- data2=tab[net+aa]; //取出下8行數(shù)據(jù)輸出
- aa++;
- delay(5); //延時
- data1=0; //清屏
- data2=0; //清屏
- P1=0x00; //消除余輝
- if(aa>30) aa=0; //字模地址
- void main() //主函數(shù)
- ET1=1; //使能定時器0
- EA=1; //開啟總中斷
- TR1=1; //開始計數(shù)
- while(1) //無限循環(huán)
- xianshi(); //顯示
- if(s1==0) //檢測按鍵
- delay(30); //延時消抖
- TR1=~TR1; //按下暫停 ,暫按繼續(xù)
- while(!s1)xianshi();
- delay(30);
- if(s2==0) //檢測按鍵
- delay(30); //延時消抖
- fangxiang=~fangxiang; //方向取反
- while(!s2)xianshi();
- delay(30);
- void timer1() interrupt 3
- alt++;
- if(alt==10) //到一定的時間加以實現(xiàn)左移
- alt=0;
- if(fangxiang==0) //如果是正向 正向移動
- net=net+2;
- if(net>sl) //字移動數(shù)量
- net=0;
- else //否則反向移動
- net=net-2;
- if(net<2)
- net=sl; //字移動數(shù)量
點陣程序.rar
(1.13 KB, 下載次數(shù): 77)
2018-8-29 12:57 上傳
直接程序 下載積分: 黑幣 -5
Protel Schematic.pdf
(37.22 KB, 下載次數(shù): 62)
2018-8-29 12:56 上傳
上原理圖 下載積分: 黑幣 -5
