查看: 2420|回復: 0
HAL庫的lcd顯示
ID:389045 發表于 2018-8-22 21:35 | 顯示全部樓層 |閱讀模式
  1. #include "lcd.h"
  2. //#include "stdlib.h"
  3. #include <stdio.h>
  4. #include "font.h"
  5.
  6. //2.4′ç/2.8′ç/3.5′ç/4.3′ç TFTòo¾§Çy¶ˉ
  7. //Ö§3ÖÇy¶ˉICDíoŰüà¨:ILI9341/ILI9325/RM68042/RM68021/ILI9320/ILI9328/LGDP4531/LGDP4535/
  8. //                  SPFD5408/SSD1289/1505/B505/C505/NT35310/NT35510μè
  9.
  10. //LCDμÄ»-±êÑÕé«oí±3¾°é«
  11. u16 POINT_COLOR=0x0000;        //»-±êÑÕé«
  12. u16 BACK_COLOR=0xFFFF;  //±3¾°é«
  13. //1üàíLCDÖØòa2Îêy
  14. //ĬèÏÎaêúÆá
  15. _lcd_dev lcddev;
  16.
  17. //D′¼Ä′æÆ÷oˉêy
  18. //regval:¼Ä′æÆ÷Öμ
  19. void LCD_WR_REG(u16 regval)
  20. {
  21.         LCD->LCD_REG=regval;//D′èëòaD′μļÄ′æÆ÷DòoÅ
  22. }
  23. //D′LCDêy¾Y
  24. //data:òaD′èëμÄÖμ
  25. void LCD_WR_DATA(u16 data)
  26. {
  27.         LCD->LCD_RAM=data;
  28. }
  29. //¶áLCDêy¾Y
  30. //·μ»ØÖμ:¶áμ½μÄÖμ
  31. u16 LCD_RD_DATA(void)
  32. {
  33.         return LCD->LCD_RAM;
  34. }
  35. //D′¼Ä′æÆ÷
  36. //LCD_Reg:¼Ä′æÆ÷μØÖ·
  37. //LCD_RegValue:òaD′èëμÄêy¾Y
  38. void LCD_WriteReg(u16 LCD_Reg, u16 LCD_RegValue)
  39. {
  40.         LCD->LCD_REG = LCD_Reg;                //D′èëòaD′μļÄ′æÆ÷DòoÅ
  41.         LCD->LCD_RAM = LCD_RegValue;//D′èëêy¾Y
  42. }
  43. //¶á¼Ä′æÆ÷
  44. //LCD_Reg:¼Ä′æÆ÷μØÖ·
  45. //·μ»ØÖμ:¶áμ½μÄêy¾Y
  46. u16 LCD_ReadReg(u16 LCD_Reg)
  47. {
  48.         LCD_WR_REG(LCD_Reg);                //D′èëòa¶áμļÄ′æÆ÷DòoÅ
  49.         HAL_Delay(5);
  50.         return LCD_RD_DATA();                //·μ»Ø¶áμ½μÄÖμ
  51. }
  52. //¿aê¼D′GRAM
  53. void LCD_WriteRAM_Prepare(void)
  54. {
  55.         LCD->LCD_REG=lcddev.wramcmd;
  56. }
  57. //LCDD′GRAM
  58. //RGB_Code:ÑÕé«Öμ
  59. void LCD_WriteRAM(u16 RGB_Code)
  60. {
  61.         LCD->LCD_RAM = RGB_Code;//D′ê®áùλGRAM
  62. }
  63. //′óILI93xx¶á3öμÄêy¾YÎaGBR¸ñê½£¬¶øÎòÃÇD′èëμÄê±oòÎaRGB¸ñ꽡£
  64. //í¨1y¸Ãoˉêy×a»»
  65. //c:GBR¸ñê½μÄÑÕé«Öμ
  66. //·μ»ØÖμ£oRGB¸ñê½μÄÑÕé«Öμ
  67. u16 LCD_BGR2RGB(u16 c)
  68. {
  69.         u16  r,g,b,rgb;
  70.         b=(c>>0)&0x1f;
  71.         g=(c>>5)&0x3f;
  72.         r=(c>>11)&0x1f;
  73.         rgb=(b<<11)+(g<<5)+(r<<0);
  74.         return(rgb);
  75. }
  76. //μ±mdk -O1ê±¼äóÅ»ˉê±DèòaéèÖÃ
  77. //Ñóê±i
  78. void opt_delay(u8 i)
  79. {
  80.         while(i--);
  81. }
  82. //¶á衸öÄ3μãμÄÑÕé«Öμ
  83. //x,y:×ø±ê
  84. //·μ»ØÖμ:′ËμãμÄÑÕé«
  85. u16 LCD_ReadPoint(u16 x,u16 y)
  86. {
  87.         u16 r=0,g=0,b=0;
  88.         if(x>=lcddev.width||y>=lcddev.height)return 0;        //3¬1yáË·¶Î§,Ö±½ó·μ»Ø
  89.         LCD_SetCursor(x,y);
  90.         if(lcddev.id==0X9341||lcddev.id==0X6804||lcddev.id==0X5310)LCD_WR_REG(0X2E);//9341/6804/3510 ·¢Ëí¶áGRAMÖ¸áî
  91.         else if(lcddev.id==0X5510)LCD_WR_REG(0X2E00);        //5510 ·¢Ëí¶áGRAMÖ¸áî
  92.         else LCD_WR_REG(R34);                                                       //ÆäËûIC·¢Ëí¶áGRAMÖ¸áî
  93.         if(lcddev.id==0X9320)opt_delay(2);                                //FOR 9320,Ñóê±2us
  94.         if(LCD->LCD_RAM)r=0;                                                        //dummy Read
  95.         opt_delay(2);
  96.         r=LCD->LCD_RAM;        //êμ¼ê×ø±êÑÕé«
  97.         if(lcddev.id==0X9341||lcddev.id==0X5310||lcddev.id==0X5510)                //9341/NT35310/NT35510òa·Ö2′ζá3ö
  98.         {
  99.                 opt_delay(2);
  100.                 b=LCD->LCD_RAM;
  101.                 g=r&0XFF;                //¶Ôóú9341/5310/5510,μúò»′ζáè¡μÄêÇRGμÄÖμ,RÔúǰ,GÔúoó,¸÷Õ¼8λ
  102.                 g<<=8;
  103.         }else if(lcddev.id==0X6804)r=LCD->LCD_RAM;                //6804μú¶t′ζáè¡μÄ2ÅêÇÕæêμÖμ
  104.         if(lcddev.id==0X9325||lcddev.id==0X4535||lcddev.id==0X4531||lcddev.id==0X8989||lcddev.id==0XB505)return r;        //Õa¼¸ÖÖICÖ±½ó·μ»ØÑÕé«Öμ
  105.         else if(lcddev.id==0X9341||lcddev.id==0X5310||lcddev.id==0X5510)return (((r>>11)<<11)|((g>>10)<<5)|(b>>11));//ILI9341/NT35310/NT35510Dèòa1«ê½×a»»ò»ÏÂ
  106.         else return LCD_BGR2RGB(r);                                                //ÆäËûIC
  107. }
  108. //LCD¿aÆôÏÔê¾
  109. void LCD_DisplayOn(void)
  110. {
  111.         if(lcddev.id==0X9341||lcddev.id==0X6804||lcddev.id==0X5310)LCD_WR_REG(0X29);        //¿aÆôÏÔê¾
  112.         else if(lcddev.id==0X5510)LCD_WR_REG(0X2900);        //¿aÆôÏÔê¾
  113.         else LCD_WriteReg(R7,0x0173);                                          //¿aÆôÏÔê¾
  114. }
  115. //LCD1رÕÏÔê¾
  116. void LCD_DisplayOff(void)
  117. {
  118.         if(lcddev.id==0X9341||lcddev.id==0X6804||lcddev.id==0X5310)LCD_WR_REG(0X28);        //1رÕÏÔê¾
  119.         else if(lcddev.id==0X5510)LCD_WR_REG(0X2800);        //1رÕÏÔê¾
  120.         else LCD_WriteReg(R7,0x0);//1رÕÏÔê¾
  121. }
  122. //éèÖÃ1a±êλÖÃ
  123. //Xpos:oá×ø±ê
  124. //Ypos:×Y×ø±ê
  125. void LCD_SetCursor(u16 Xpos, u16 Ypos)
  126. {
  127.         if(lcddev.id==0X9341||lcddev.id==0X5310)
  128.         {
  129.                 LCD_WR_REG(lcddev.setxcmd);
  130.                 LCD_WR_DATA(Xpos>>8);
  131.                 LCD_WR_DATA(Xpos&0XFF);
  132.                 LCD_WR_REG(lcddev.setycmd);
  133.                 LCD_WR_DATA(Ypos>>8);
  134.                 LCD_WR_DATA(Ypos&0XFF);
  135.         }else if(lcddev.id==0X6804)
  136.         {
  137.                 if(lcddev.dir==1)Xpos=lcddev.width-1-Xpos;//oáÆáê±′|àí
  138.                 LCD_WR_REG(lcddev.setxcmd);
  139.                 LCD_WR_DATA(Xpos>>8);
  140.                 LCD_WR_DATA(Xpos&0XFF);
  141.                 LCD_WR_REG(lcddev.setycmd);
  142.                 LCD_WR_DATA(Ypos>>8);
  143.                 LCD_WR_DATA(Ypos&0XFF);
  144.         }else if(lcddev.id==0X5510)
  145.         {
  146.                 LCD_WR_REG(lcddev.setxcmd);
  147.                 LCD_WR_DATA(Xpos>>8);
  148.                 LCD_WR_REG(lcddev.setxcmd+1);
  149.                 LCD_WR_DATA(Xpos&0XFF);
  150.                 LCD_WR_REG(lcddev.setycmd);
  151.                 LCD_WR_DATA(Ypos>>8);
  152.                 LCD_WR_REG(lcddev.setycmd+1);
  153.                 LCD_WR_DATA(Ypos&0XFF);
  154.         }else
  155.         {
  156.                 if(lcddev.dir==1)Xpos=lcddev.width-1-Xpos;//oáÆáÆäêμ¾íêÇμ÷×ax,y×ø±ê
  157.                 LCD_WriteReg(lcddev.setxcmd, Xpos);
  158.                 LCD_WriteReg(lcddev.setycmd, Ypos);
  159.         }
  160. }
  161. //éèÖÃLCDμÄ×Ô¶ˉé¨Ãè·½Ïò
  162. //×¢òa:ÆäËûoˉêy¿éÄü»áêüμ½′ËoˉêyéèÖÃμÄó°Ïì(óèÆäêÇ9341/6804ÕaὸöÆæYa),
  163. //ËùòÔ,ò»°ãéèÖÃÎaL2R_U2D¼′¿é,èç1ûéèÖÃÎaÆäËûé¨Ãè·½ê½,¿éÄüμ¼ÖÂÏÔê¾2»Õy3£.
  164. //dir:0~7,′ú±í8¸ö·½Ïò(¾ßì嶨òå¼ûlcd.h)
  165. //9320/9325/9328/4531/4535/1505/b505/8989/5408/9341/5310/5510μèICòѾ-êμ¼ê2aêÔ
  166. void LCD_Scan_Dir(u8 dir)
  167. {
  168.         u16 regval=0;
  169.         u16 dirreg=0;
  170.         u16 temp;
  171.         if(lcddev.dir==1&&lcddev.id!=0X6804)//oáÆáê±£¬¶Ô68042»¸Ä±äé¨Ãè·½Ïò£¡
  172.         {
  173.                 switch(dir)//·½Ïò×a»»
  174.                 {
  175.                         case 0:dir=6;break;
  176.                         case 1:dir=7;break;
  177.                         case 2:dir=4;break;
  178.                         case 3:dir=5;break;
  179.                         case 4:dir=1;break;
  180.                         case 5:dir=0;break;
  181.                         case 6:dir=3;break;
  182.                         case 7:dir=2;break;
  183.                 }
  184.         }
  185.         if(lcddev.id==0x9341||lcddev.id==0X6804||lcddev.id==0X5310||lcddev.id==0X5510)//9341/6804/5310/5510,oüìØêa
  186.         {
  187.                 switch(dir)
  188.                 {
  189.                         case L2R_U2D://′ó×óμ½óò,′óéÏμ½ÏÂ
  190.                                 regval|=(0<<7)|(0<<6)|(0<<5);
  191.                                 break;
  192.                         case L2R_D2U://′ó×óμ½óò,′óÏÂμ½éÏ
  193.                                 regval|=(1<<7)|(0<<6)|(0<<5);
  194.                                 break;
  195.                         case R2L_U2D://′óóòμ½×ó,′óéÏμ½ÏÂ
  196.                                 regval|=(0<<7)|(1<<6)|(0<<5);
  197.                                 break;
  198.                         case R2L_D2U://′óóòμ½×ó,′óÏÂμ½éÏ
  199.                                 regval|=(1<<7)|(1<<6)|(0<<5);
  200.                                 break;
  201.                         case U2D_L2R://′óéÏμ½ÏÂ,′ó×óμ½óò
  202.                                 regval|=(0<<7)|(0<<6)|(1<<5);
  203.                                 break;
  204.                         case U2D_R2L://′óéÏμ½ÏÂ,′óóòμ½×ó
  205.                                 regval|=(0<<7)|(1<<6)|(1<<5);
  206.                                 break;
  207.                         case D2U_L2R://′óÏÂμ½éÏ,′ó×óμ½óò
  208.                                 regval|=(1<<7)|(0<<6)|(1<<5);
  209.                                 break;
  210.                         case D2U_R2L://′óÏÂμ½éÏ,′óóòμ½×ó
  211.                                 regval|=(1<<7)|(1<<6)|(1<<5);
  212.                                 break;
  213.                 }
  214.                 if(lcddev.id==0X5510)dirreg=0X3600;
  215.                 else dirreg=0X36;
  216.                 if((lcddev.id!=0X5310)&&(lcddev.id!=0X5510))regval|=0X08;//5310/55102»DèòaBGR
  217.                 if(lcddev.id==0X6804)regval|=0x02;//6804μÄBIT6oí9341μÄ·′áË
  218.                 LCD_WriteReg(dirreg,regval);
  219.                 if((regval&0X20)||lcddev.dir==1)
  220.                 {
  221.                         if(lcddev.width<lcddev.height)//½»»»X,Y
  222.                         {
  223.                                 temp=lcddev.width;
  224.                                 lcddev.width=lcddev.height;
  225.                                 lcddev.height=temp;
  226.                         }
  227.                 }else
  228.                 {
  229.                         if(lcddev.width>lcddev.height)//½»»»X,Y
  230.                         {
  231.                                 temp=lcddev.width;
  232.                                 lcddev.width=lcddev.height;
  233.                                 lcddev.height=temp;
  234.                         }
  235.                 }
  236.                 if(lcddev.id==0X5510)
  237.                 {
  238.                         LCD_WR_REG(lcddev.setxcmd);LCD_WR_DATA(0);
  239.                         LCD_WR_REG(lcddev.setxcmd+1);LCD_WR_DATA(0);
  240.                         LCD_WR_REG(lcddev.setxcmd+2);LCD_WR_DATA((lcddev.width-1)>>8);
  241.                         LCD_WR_REG(lcddev.setxcmd+3);LCD_WR_DATA((lcddev.width-1)&0XFF);
  242.                         LCD_WR_REG(lcddev.setycmd);LCD_WR_DATA(0);
  243.                         LCD_WR_REG(lcddev.setycmd+1);LCD_WR_DATA(0);
  244.                         LCD_WR_REG(lcddev.setycmd+2);LCD_WR_DATA((lcddev.height-1)>>8);
  245.                         LCD_WR_REG(lcddev.setycmd+3);LCD_WR_DATA((lcddev.height-1)&0XFF);
  246.                 }else
  247.                 {
  248.                         LCD_WR_REG(lcddev.setxcmd);
  249.                         LCD_WR_DATA(0);LCD_WR_DATA(0);
  250.                         LCD_WR_DATA((lcddev.width-1)>>8);LCD_WR_DATA((lcddev.width-1)&0XFF);
  251.                         LCD_WR_REG(lcddev.setycmd);
  252.                         LCD_WR_DATA(0);LCD_WR_DATA(0);
  253.                         LCD_WR_DATA((lcddev.height-1)>>8);LCD_WR_DATA((lcddev.height-1)&0XFF);
  254.                 }
  255.           }else
  256.         {
  257.                 switch(dir)
  258.                 {
  259.                         case L2R_U2D://′ó×óμ½óò,′óéÏμ½ÏÂ
  260.                                 regval|=(1<<5)|(1<<4)|(0<<3);
  261.                                 break;
  262.                         case L2R_D2U://′ó×óμ½óò,′óÏÂμ½éÏ
  263.                                 regval|=(0<<5)|(1<<4)|(0<<3);
  264.                                 break;
  265.                         case R2L_U2D://′óóòμ½×ó,′óéÏμ½ÏÂ
  266.                                 regval|=(1<<5)|(0<<4)|(0<<3);
  267.                                 break;
  268.                         case R2L_D2U://′óóòμ½×ó,′óÏÂμ½éÏ
  269.                                 regval|=(0<<5)|(0<<4)|(0<<3);
  270.                                 break;
  271.                         case U2D_L2R://′óéÏμ½ÏÂ,′ó×óμ½óò
  272.                                 regval|=(1<<5)|(1<<4)|(1<<3);
  273.                                 break;
  274.                         case U2D_R2L://′óéÏμ½ÏÂ,′óóòμ½×ó
  275.                                 regval|=(1<<5)|(0<<4)|(1<<3);
  276.                                 break;
  277.                         case D2U_L2R://′óÏÂμ½éÏ,′ó×óμ½óò
  278.                                 regval|=(0<<5)|(1<<4)|(1<<3);
  279.                                 break;
  280.                         case D2U_R2L://′óÏÂμ½éÏ,′óóòμ½×ó
  281.                                 regval|=(0<<5)|(0<<4)|(1<<3);
  282.                                 break;
  283.                 }
  284.                 if(lcddev.id==0x8989)//8989 IC
  285.                 {
  286.                         dirreg=0X11;
  287.                         regval|=0X6040;        //65K
  288.                  }else//ÆäËûÇy¶ˉIC
  289.                 {
  290.                         dirreg=0X03;
  291.                         regval|=1<<12;
  292.                 }
  293.                 LCD_WriteReg(dirreg,regval);
  294.         }
  295. }
  296. //»-μã
  297. //x,y:×ø±ê
  298. //POINT_COLOR:′ËμãμÄÑÕé«
  299. void LCD_DrawPoint(u16 x,u16 y)
  300. {
  301.         LCD_SetCursor(x,y);                //éèÖÃ1a±êλÖÃ
  302.         LCD_WriteRAM_Prepare();        //¿aê¼D′èëGRAM
  303.         LCD->LCD_RAM=POINT_COLOR;
  304. }
  305. //¿ìËù»-μã
  306. //x,y:×ø±ê
  307. //color:ÑÕé«
  308. void LCD_Fast_DrawPoint(u16 x,u16 y,u16 color)
  309. {
  310.         if(lcddev.id==0X9341||lcddev.id==0X5310)
  311.         {
  312.                 LCD_WR_REG(lcddev.setxcmd);
  313.                 LCD_WR_DATA(x>>8);
  314.                 LCD_WR_DATA(x&0XFF);
  315.                 LCD_WR_REG(lcddev.setycmd);
  316.                 LCD_WR_DATA(y>>8);
  317.                 LCD_WR_DATA(y&0XFF);
  318.         }else if(lcddev.id==0X5510)
  319.         {
  320.                 LCD_WR_REG(lcddev.setxcmd);LCD_WR_DATA(x>>8);
  321.                 LCD_WR_REG(lcddev.setxcmd+1);LCD_WR_DATA(x&0XFF);
  322.                 LCD_WR_REG(lcddev.setycmd);LCD_WR_DATA(y>>8);
  323.                 LCD_WR_REG(lcddev.setycmd+1);LCD_WR_DATA(y&0XFF);
  324.         }else if(lcddev.id==0X6804)
  325.         {
  326.                 if(lcddev.dir==1)x=lcddev.width-1-x;//oáÆáê±′|àí
  327.                 LCD_WR_REG(lcddev.setxcmd);
  328.                 LCD_WR_DATA(x>>8);
  329.                 LCD_WR_DATA(x&0XFF);
  330.                 LCD_WR_REG(lcddev.setycmd);
  331.                 LCD_WR_DATA(y>>8);
  332.                 LCD_WR_DATA(y&0XFF);
  333.         }else
  334.         {
  335.                 if(lcddev.dir==1)x=lcddev.width-1-x;//oáÆáÆäêμ¾íêÇμ÷×ax,y×ø±ê
  336.                 LCD_WriteReg(lcddev.setxcmd,x);
  337.                 LCD_WriteReg(lcddev.setycmd,y);
  338.         }
  339.         LCD->LCD_REG=lcddev.wramcmd;
  340.         LCD->LCD_RAM=color;
  341. }
  342. //éèÖÃLCDÏÔê¾·½Ïò
  343. //dir:0,êúÆá£»1,oáÆá
  344. void LCD_Display_Dir(u8 dir)
  345. {
  346.         if(dir==0)                        //êúÆá
  347.         {
  348.                 lcddev.dir=0;        //êúÆá
  349.                 lcddev.width=240;
  350.                 lcddev.height=320;
  351.                 if(lcddev.id==0X9341||lcddev.id==0X6804||lcddev.id==0X5310)
  352.                 {
  353.                         lcddev.wramcmd=0X2C;
  354.                          lcddev.setxcmd=0X2A;
  355.                         lcddev.setycmd=0X2B;
  356.                         if(lcddev.id==0X6804||lcddev.id==0X5310)
  357.                         {
  358.                                 lcddev.width=320;
  359.                                 lcddev.height=480;
  360.                         }
  361.                 }else if(lcddev.id==0X8989)
  362.                 {
  363.                         lcddev.wramcmd=R34;
  364.                          lcddev.setxcmd=0X4E;
  365.                         lcddev.setycmd=0X4F;
  366.                 }else if(lcddev.id==0x5510)
  367.                 {
  368.                         lcddev.wramcmd=0X2C00;
  369.                          lcddev.setxcmd=0X2A00;
  370.                         lcddev.setycmd=0X2B00;
  371.                         lcddev.width=480;
  372.                         lcddev.height=800;
  373.                 }else
  374.                 {
  375.                         lcddev.wramcmd=R34;
  376.                          lcddev.setxcmd=R32;
  377.                         lcddev.setycmd=R33;
  378.                 }
  379.         }else                                 //oáÆá
  380.         {
  381.                 lcddev.dir=1;        //oáÆá
  382.                 lcddev.width=320;
  383.                 lcddev.height=240;
  384.                 if(lcddev.id==0X9341||lcddev.id==0X5310)
  385.                 {
  386.                         lcddev.wramcmd=0X2C;
  387.                          lcddev.setxcmd=0X2A;
  388.                         lcddev.setycmd=0X2B;
  389.                 }else if(lcddev.id==0X6804)
  390.                 {
  391.                         lcddev.wramcmd=0X2C;
  392.                          lcddev.setxcmd=0X2B;
  393.                         lcddev.setycmd=0X2A;
  394.                 }else if(lcddev.id==0X8989)
  395.                 {
  396.                         lcddev.wramcmd=R34;
  397.                          lcddev.setxcmd=0X4F;
  398.                         lcddev.setycmd=0X4E;
  399.                 }else if(lcddev.id==0x5510)
  400.                 {
  401.                         lcddev.wramcmd=0X2C00;
  402.                          lcddev.setxcmd=0X2A00;
  403.                         lcddev.setycmd=0X2B00;
  404.                         lcddev.width=800;
  405.                         lcddev.height=480;
  406.                 }else
  407.                 {
  408.                         lcddev.wramcmd=R34;
  409.                          lcddev.setxcmd=R33;
  410.                         lcddev.setycmd=R32;
  411.                 }
  412.                 if(lcddev.id==0X6804||lcddev.id==0X5310)
  413.                 {
  414.                         lcddev.width=480;
  415.                         lcddev.height=320;
  416.                 }
  417.         }
  418.         LCD_Scan_Dir(DFT_SCAN_DIR);        //ĬèÏé¨Ãè·½Ïò
  419. }
  420. //éèÖÃ′°¿ú,2¢×Ô¶ˉéèÖû-μã×ø±êμ½′°¿ú×óéϽÇ(sx,sy).
  421. //sx,sy:′°¿úÆeê¼×ø±ê(×óéϽÇ)
  422. //width,height:′°¿ú¿í¶èoí¸ß¶è,±ØDë′óóú0!!
  423. //′°ìå′óD¡:width*height.
  424. //68042,oáÆáê±2»Ö§3Ö′°¿úéèÖÃ!!
  425. void LCD_Set_Window(u16 sx,u16 sy,u16 width,u16 height)
  426. {
  427.         u8 hsareg,heareg,vsareg,veareg;
  428.         u16 hsaval,heaval,vsaval,veaval;
  429.         width=sx+width-1;
  430.         height=sy+height-1;
  431.         if(lcddev.id==0X9341||lcddev.id==0X5310||lcddev.id==0X6804)//6804oáÆá2»Ö§3Ö
  432.         {
  433.                 LCD_WR_REG(lcddev.setxcmd);
  434.                 LCD_WR_DATA(sx>>8);
  435.                 LCD_WR_DATA(sx&0XFF);
  436.                 LCD_WR_DATA(width>>8);
  437.                 LCD_WR_DATA(width&0XFF);
  438.                 LCD_WR_REG(lcddev.setycmd);
  439.                 LCD_WR_DATA(sy>>8);
  440.                 LCD_WR_DATA(sy&0XFF);
  441.                 LCD_WR_DATA(height>>8);
  442.                 LCD_WR_DATA(height&0XFF);
  443.         }else if(lcddev.id==0X5510)
  444.         {
  445.                 LCD_WR_REG(lcddev.setxcmd);LCD_WR_DATA(sx>>8);
  446.                 LCD_WR_REG(lcddev.setxcmd+1);LCD_WR_DATA(sx&0XFF);
  447.                 LCD_WR_REG(lcddev.setxcmd+2);LCD_WR_DATA(width>>8);
  448.                 LCD_WR_REG(lcddev.setxcmd+3);LCD_WR_DATA(width&0XFF);
  449.                 LCD_WR_REG(lcddev.setycmd);LCD_WR_DATA(sy>>8);
  450.                 LCD_WR_REG(lcddev.setycmd+1);LCD_WR_DATA(sy&0XFF);
  451.                 LCD_WR_REG(lcddev.setycmd+2);LCD_WR_DATA(height>>8);
  452.                 LCD_WR_REG(lcddev.setycmd+3);LCD_WR_DATA(height&0XFF);
  453.         }else        //ÆäËûÇy¶ˉIC
  454.         {
  455.                 if(lcddev.dir==1)//oáÆá
  456.                 {
  457.                         //′°¿úÖμ
  458.                         hsaval=sy;
  459.                         heaval=height;
  460.                         vsaval=lcddev.width-width-1;
  461.                         veaval=lcddev.width-sx-1;
  462.                 }else
  463.                 {
  464.                         hsaval=sx;
  465.                         heaval=width;
  466.                         vsaval=sy;
  467.                         veaval=height;
  468.                 }
  469.                  if(lcddev.id==0X8989)//8989 IC
  470.                 {
  471.                         hsareg=0X44;heareg=0X44;//ˮƽ·½Ïò′°¿ú¼Ä′æÆ÷ (1289μÄóéò»¸ö¼Ä′æÆ÷¿ØÖÆ)
  472.                         hsaval|=(heaval<<8);        //μÃμ½¼Ä′æÆ÷Öμ.
  473.                         heaval=hsaval;
  474.                         vsareg=0X45;veareg=0X46;//′1Ö±·½Ïò′°¿ú¼Ä′æÆ÷
  475.                 }else  //ÆäËûÇy¶ˉIC
  476.                 {
  477.                         hsareg=0X50;heareg=0X51;//ˮƽ·½Ïò′°¿ú¼Ä′æÆ÷
  478.                         vsareg=0X52;veareg=0X53;//′1Ö±·½Ïò′°¿ú¼Ä′æÆ÷
  479.                 }
  480.                 //éèÖüÄ′æÆ÷Öμ
  481.                 LCD_WriteReg(hsareg,hsaval);
  482.                 LCD_WriteReg(heareg,heaval);
  483.                 LCD_WriteReg(vsareg,vsaval);
  484.                 LCD_WriteReg(veareg,veaval);
  485.                 LCD_SetCursor(sx,sy);        //éèÖÃ1a±êλÖÃ
  486.         }
  487. }
  488. //3õê¼»ˉlcd
  489. //¸Ã3õê¼»ˉoˉêy¿éòÔ3õê¼»ˉ¸÷ÖÖILI93XXòo¾§,μ«êÇÆäËûoˉêyêÇ»ùóúILI9320μÄ!!!
  490. //ÔúÆäËûDíoÅμÄÇy¶ˉD¾Æ¬éÏûóD2aêÔ!
  491. //////////////////////////////////////////////////////////////////////
  492. void LCD_Init(void)
  493. {
  494.
  495.         HAL_Delay(50); // delay 50 ms
  496.         LCD_WriteReg(0x0000,0x0001);
  497.         HAL_Delay(50); // delay 50 ms
  498.           lcddev.id = LCD_ReadReg(0x0000);
  499.           if(lcddev.id<0XFF||lcddev.id==0XFFFF||lcddev.id==0X9300)//¶áμ½ID2»Õyè·,DÂÔölcddev.id==0X9300ÅD¶Ï£¬òòÎa9341ÔúÎ′±»¸′λμÄÇé¿öÏ»ᱻ¶á3é9300
  500.         {
  501.                 //3¢êÔ9341 IDμĶáè¡
  502.                 LCD_WR_REG(0XD3);
  503.                 LCD_RD_DATA();                                 //dummy read
  504.                 LCD_RD_DATA();                       //¶áμ½0X00
  505.           lcddev.id=LCD_RD_DATA();           //¶áè¡93
  506.                 lcddev.id<<=8;
  507.                 lcddev.id|=LCD_RD_DATA();          //¶áè¡41
  508.                 if(lcddev.id!=0X9341)                //·Ç9341,3¢êÔêÇ2»êÇ6804
  509.                 {
  510.                         LCD_WR_REG(0XBF);
  511.                         LCD_RD_DATA();                         //dummy read
  512.                          LCD_RD_DATA();               //¶á»Ø0X01
  513.                          LCD_RD_DATA();                         //¶á»Ø0XD0
  514.                           lcddev.id=LCD_RD_DATA();//Õaàï¶á»Ø0X68
  515.                         lcddev.id<<=8;
  516.                           lcddev.id|=LCD_RD_DATA();//Õaàï¶á»Ø0X04
  517.                         if(lcddev.id!=0X6804)        //ò22»êÇ6804,3¢êÔ¿′¿′êÇ2»êÇNT35310
  518.                         {
  519.                                 LCD_WR_REG(0XD4);
  520.                                 LCD_RD_DATA();                                 //dummy read
  521.                                 LCD_RD_DATA();                           //¶á»Ø0X01
  522.                                 lcddev.id=LCD_RD_DATA();        //¶á»Ø0X53
  523.                                 lcddev.id<<=8;
  524.                                 lcddev.id|=LCD_RD_DATA();        //Õaàï¶á»Ø0X10
  525.                                 if(lcddev.id!=0X5310)                //ò22»êÇNT35310,3¢êÔ¿′¿′êÇ2»êÇNT35510
  526.                                 {
  527.                                         LCD_WR_REG(0XDA00);
  528.                                         LCD_RD_DATA();                   //¶á»Ø0X00
  529.                                         LCD_WR_REG(0XDB00);
  530.                                         lcddev.id=LCD_RD_DATA();//¶á»Ø0X80
  531.                                         lcddev.id<<=8;
  532.                                         LCD_WR_REG(0XDC00);
  533.                                         lcddev.id|=LCD_RD_DATA();//¶á»Ø0X00
  534.                                         if(lcddev.id==0x8000)lcddev.id=0x5510;//NT35510¶á»ØμÄIDêÇ8000H,Îa·½±ãÇø·Ö,ÎòÃÇÇ¿ÖÆéèÖÃÎa5510
  535.                                 }
  536.                         }
  537.                 }
  538.         }
  539.         //printf(" LCD ID:%x\r\n",lcddev.id); //′òó¡LCD ID
  540.         if(lcddev.id==0X9341)        //93413õê¼»ˉ
  541.         {
  542.                 LCD_WR_REG(0xCF);
  543.                 LCD_WR_DATA(0x00);
  544.                 LCD_WR_DATA(0xC1);
  545.                 LCD_WR_DATA(0X30);
  546.                 LCD_WR_REG(0xED);
  547.                 LCD_WR_DATA(0x64);
  548.                 LCD_WR_DATA(0x03);
  549.                 LCD_WR_DATA(0X12);
  550.                 LCD_WR_DATA(0X81);
  551.                 LCD_WR_REG(0xE8);
  552.                 LCD_WR_DATA(0x85);
  553.                 LCD_WR_DATA(0x10);
  554.                 LCD_WR_DATA(0x7A);
  555.                 LCD_WR_REG(0xCB);
  556.                 LCD_WR_DATA(0x39);
  557.                 LCD_WR_DATA(0x2C);
  558.                 LCD_WR_DATA(0x00);
  559.                 LCD_WR_DATA(0x34);
  560.                 LCD_WR_DATA(0x02);
  561.                 LCD_WR_REG(0xF7);
  562.                 LCD_WR_DATA(0x20);
  563.                 LCD_WR_REG(0xEA);
  564.                 LCD_WR_DATA(0x00);
  565.                 LCD_WR_DATA(0x00);
  566.                 LCD_WR_REG(0xC0);    //Power control
  567.                 LCD_WR_DATA(0x1B);   //VRH[5:0]
  568.                 LCD_WR_REG(0xC1);    //Power control
  569.                 LCD_WR_DATA(0x01);   //SAP[2:0];BT[3:0]
  570.                 LCD_WR_REG(0xC5);    //VCM control
  571.                 LCD_WR_DATA(0x30);          //3F
  572.                 LCD_WR_DATA(0x30);          //3C
  573.                 LCD_WR_REG(0xC7);    //VCM control2
  574.                 LCD_WR_DATA(0XB7);
  575.                 LCD_WR_REG(0x36);    // Memory Access Control
  576.                 LCD_WR_DATA(0x48);
  577.                 LCD_WR_REG(0x3A);
  578.                 LCD_WR_DATA(0x55);
  579.                 LCD_WR_REG(0xB1);
  580.                 LCD_WR_DATA(0x00);
  581.                 LCD_WR_DATA(0x1A);
  582.                 LCD_WR_REG(0xB6);    // Display Function Control
  583.                 LCD_WR_DATA(0x0A);
  584.                 LCD_WR_DATA(0xA2);
  585.                 LCD_WR_REG(0xF2);    // 3Gamma Function Disable
  586.                 LCD_WR_DATA(0x00);
  587.                 LCD_WR_REG(0x26);    //Gamma curve selected
  588.                 LCD_WR_DATA(0x01);
  589.                 LCD_WR_REG(0xE0);    //Set Gamma
  590.                 LCD_WR_DATA(0x0F);
  591.                 LCD_WR_DATA(0x2A);
  592.                 LCD_WR_DATA(0x28);
  593.                 LCD_WR_DATA(0x08);
  594.                 LCD_WR_DATA(0x0E);
  595.                 LCD_WR_DATA(0x08);
  596.                 LCD_WR_DATA(0x54);
  597.                 LCD_WR_DATA(0XA9);
  598.                 LCD_WR_DATA(0x43);
  599.                 LCD_WR_DATA(0x0A);
  600.                 LCD_WR_DATA(0x0F);
  601.                 LCD_WR_DATA(0x00);
  602.                 LCD_WR_DATA(0x00);
  603.                 LCD_WR_DATA(0x00);
  604.                 LCD_WR_DATA(0x00);
  605.                 LCD_WR_REG(0XE1);    //Set Gamma
  606.                 LCD_WR_DATA(0x00);
  607.                 LCD_WR_DATA(0x15);
  608.                 LCD_WR_DATA(0x17);
  609.                 LCD_WR_DATA(0x07);
  610.                 LCD_WR_DATA(0x11);
  611.                 LCD_WR_DATA(0x06);
  612.                 LCD_WR_DATA(0x2B);
  613.                 LCD_WR_DATA(0x56);
  614.                 LCD_WR_DATA(0x3C);
  615.                 LCD_WR_DATA(0x05);
  616.                 LCD_WR_DATA(0x10);
  617.                 LCD_WR_DATA(0x0F);
  618.                 LCD_WR_DATA(0x3F);
  619.                 LCD_WR_DATA(0x3F);
  620.                 LCD_WR_DATA(0x0F);
  621.                 LCD_WR_REG(0x2B);
  622.                 LCD_WR_DATA(0x00);
  623.                 LCD_WR_DATA(0x00);
  624.                 LCD_WR_DATA(0x01);
  625.                 LCD_WR_DATA(0x3f);
  626.                 LCD_WR_REG(0x2A);
  627.                 LCD_WR_DATA(0x00);
  628.                 LCD_WR_DATA(0x00);
  629.                 LCD_WR_DATA(0x00);
  630.                 LCD_WR_DATA(0xef);
  631.                 LCD_WR_REG(0x11); //Exit Sleep
  632.                 HAL_Delay(120);
  633.                 LCD_WR_REG(0x29); //display on
  634.         }else if(lcddev.id==0x6804) //68043õê¼»ˉ
  635.         {
  636.                 LCD_WR_REG(0X11);
  637.                 HAL_Delay(20);
  638.                 LCD_WR_REG(0XD0);//VCI1  VCL  VGH  VGL DDVDH VREG1OUT power amplitude setting
  639.                 LCD_WR_DATA(0X07);
  640.                 LCD_WR_DATA(0X42);
  641.                 LCD_WR_DATA(0X1D);
  642.                 LCD_WR_REG(0XD1);//VCOMH VCOM_AC amplitude setting
  643.                 LCD_WR_DATA(0X00);
  644.                 LCD_WR_DATA(0X1a);
  645.                 LCD_WR_DATA(0X09);
  646.                 LCD_WR_REG(0XD2);//Operational Amplifier Circuit Constant Current Adjust , charge pump frequency setting
  647.                 LCD_WR_DATA(0X01);
  648.                 LCD_WR_DATA(0X22);
  649.                 LCD_WR_REG(0XC0);//REV SM GS
  650.                 LCD_WR_DATA(0X10);
  651.                 LCD_WR_DATA(0X3B);
  652.                 LCD_WR_DATA(0X00);
  653.                 LCD_WR_DATA(0X02);
  654.                 LCD_WR_DATA(0X11);
  655.
  656.                 LCD_WR_REG(0XC5);// Frame rate setting = 72HZ  when setting 0x03
  657.                 LCD_WR_DATA(0X03);
  658.
  659.                 LCD_WR_REG(0XC8);//Gamma setting
  660.                 LCD_WR_DATA(0X00);
  661.                 LCD_WR_DATA(0X25);
  662.                 LCD_WR_DATA(0X21);
  663.                 LCD_WR_DATA(0X05);
  664.                 LCD_WR_DATA(0X00);
  665.                 LCD_WR_DATA(0X0a);
  666.                 LCD_WR_DATA(0X65);
  667.                 LCD_WR_DATA(0X25);
  668.                 LCD_WR_DATA(0X77);
  669.                 LCD_WR_DATA(0X50);
  670.                 LCD_WR_DATA(0X0f);
  671.                 LCD_WR_DATA(0X00);
  672.
  673.                    LCD_WR_REG(0XF8);
  674.                 LCD_WR_DATA(0X01);
  675.                 LCD_WR_REG(0XFE);
  676.                 LCD_WR_DATA(0X00);
  677.                 LCD_WR_DATA(0X02);
  678.
  679.                 LCD_WR_REG(0X20);//Exit invert mode
  680.                 LCD_WR_REG(0X36);
  681.                 LCD_WR_DATA(0X08);//Ô-à′êÇa
  682.
  683.                 LCD_WR_REG(0X3A);
  684.                 LCD_WR_DATA(0X55);//16λģ꽠
  685.                 LCD_WR_REG(0X2B);
  686.                 LCD_WR_DATA(0X00);
  687.                 LCD_WR_DATA(0X00);
  688.                 LCD_WR_DATA(0X01);
  689.                 LCD_WR_DATA(0X3F);
  690.
  691.                 LCD_WR_REG(0X2A);
  692.                 LCD_WR_DATA(0X00);
  693.                 LCD_WR_DATA(0X00);
  694.                 LCD_WR_DATA(0X01);
  695.                 LCD_WR_DATA(0XDF);
  696.                 HAL_Delay(120);
  697.                 LCD_WR_REG(0X29);
  698.         }else if(lcddev.id==0x5310)
  699.         {
  700.                 LCD_WR_REG(0xED);
  701.                 LCD_WR_DATA(0x01);
  702.                 LCD_WR_DATA(0xFE);
  703.                 LCD_WR_REG(0xEE);
  704.                 LCD_WR_DATA(0xDE);
  705.                 LCD_WR_DATA(0x21);
  706.                 LCD_WR_REG(0xF1);
  707.                 LCD_WR_DATA(0x01);
  708.                 LCD_WR_REG(0xDF);
  709.                 LCD_WR_DATA(0x10);
  710.                 //VCOMvoltage//
  711.                 LCD_WR_REG(0xC4);
  712.                 LCD_WR_DATA(0x8F);          //5f
  713.                 LCD_WR_REG(0xC6);
  714.                 LCD_WR_DATA(0x00);
  715.                 LCD_WR_DATA(0xE2);
  716.                 LCD_WR_DATA(0xE2);
  717.                 LCD_WR_DATA(0xE2);
  718.                 LCD_WR_REG(0xBF);
  719.                 LCD_WR_DATA(0xAA);
  720.                 LCD_WR_REG(0xB0);
  721.                 LCD_WR_DATA(0x0D);
  722.                 LCD_WR_DATA(0x00);
  723.                 LCD_WR_DATA(0x0D);
  724.                 LCD_WR_DATA(0x00);
  725.                 LCD_WR_DATA(0x11);
  726.                 LCD_WR_DATA(0x00);
  727.                 LCD_WR_DATA(0x19);
  728.                 LCD_WR_DATA(0x00);
  729.                 LCD_WR_DATA(0x21);
  730.                 LCD_WR_DATA(0x00);
  731.                 LCD_WR_DATA(0x2D);
  732.                 LCD_WR_DATA(0x00);
  733.                 LCD_WR_DATA(0x3D);
  734.                 LCD_WR_DATA(0x00);
  735.                 LCD_WR_DATA(0x5D);
  736.                 LCD_WR_DATA(0x00);
  737.                 LCD_WR_DATA(0x5D);
  738.                 LCD_WR_DATA(0x00);
  739.                 LCD_WR_REG(0xB1);
  740.                 LCD_WR_DATA(0x80);
  741.                 LCD_WR_DATA(0x00);
  742.                 LCD_WR_DATA(0x8B);
  743.                 LCD_WR_DATA(0x00);
  744.                 LCD_WR_DATA(0x96);
  745.                 LCD_WR_DATA(0x00);
  746.                 LCD_WR_REG(0xB2);
  747.                 LCD_WR_DATA(0x00);
  748.                 LCD_WR_DATA(0x00);
  749.                 LCD_WR_DATA(0x02);
  750.                 LCD_WR_DATA(0x00);
  751.                 LCD_WR_DATA(0x03);
  752.                 LCD_WR_DATA(0x00);
  753.                 LCD_WR_REG(0xB3);
  754.                 LCD_WR_DATA(0x00);
  755.                 LCD_WR_DATA(0x00);
  756.                 LCD_WR_DATA(0x00);
  757.                 LCD_WR_DATA(0x00);
  758.                 LCD_WR_DATA(0x00);
  759.                 LCD_WR_DATA(0x00);
  760.                 LCD_WR_DATA(0x00);
  761.                 LCD_WR_DATA(0x00);
  762.                 LCD_WR_DATA(0x00);
  763.                 LCD_WR_DATA(0x00);
  764.                 LCD_WR_DATA(0x00);
  765.                 LCD_WR_DATA(0x00);
  766.                 LCD_WR_DATA(0x00);
  767.                 LCD_WR_DATA(0x00);
  768.                 LCD_WR_DATA(0x00);
  769.                 LCD_WR_DATA(0x00);
  770.                 LCD_WR_DATA(0x00);
  771.                 LCD_WR_DATA(0x00);
  772.                 LCD_WR_DATA(0x00);
  773.                 LCD_WR_DATA(0x00);
  774.                 LCD_WR_DATA(0x00);
  775.                 LCD_WR_DATA(0x00);
  776.                 LCD_WR_DATA(0x00);
  777.                 LCD_WR_DATA(0x00);
  778.                 LCD_WR_REG(0xB4);
  779.                 LCD_WR_DATA(0x8B);
  780.                 LCD_WR_DATA(0x00);
  781.                 LCD_WR_DATA(0x96);
  782.                 LCD_WR_DATA(0x00);
  783.                 LCD_WR_DATA(0xA1);
  784.                 LCD_WR_DATA(0x00);
  785.                 LCD_WR_REG(0xB5);
  786.                 LCD_WR_DATA(0x02);
  787.                 LCD_WR_DATA(0x00);
  788.                 LCD_WR_DATA(0x03);
  789.                 LCD_WR_DATA(0x00);
  790.                 LCD_WR_DATA(0x04);
  791.                 LCD_WR_DATA(0x00);
  792.                 LCD_WR_REG(0xB6);
  793.                 LCD_WR_DATA(0x00);
  794.                 LCD_WR_DATA(0x00);
  795.                 LCD_WR_REG(0xB7);
  796.                 LCD_WR_DATA(0x00);
  797.                 LCD_WR_DATA(0x00);
  798.                 LCD_WR_DATA(0x3F);
  799.                 LCD_WR_DATA(0x00);
  800.                 LCD_WR_DATA(0x5E);
  801.                 LCD_WR_DATA(0x00);
  802.                 LCD_WR_DATA(0x64);
  803.                 LCD_WR_DATA(0x00);
  804.                 LCD_WR_DATA(0x8C);
  805.                 LCD_WR_DATA(0x00);
  806.                 LCD_WR_DATA(0xAC);
  807.                 LCD_WR_DATA(0x00);
  808.                 LCD_WR_DATA(0xDC);
  809.                 LCD_WR_DATA(0x00);
  810.                 LCD_WR_DATA(0x70);
  811.                 LCD_WR_DATA(0x00);
  812.                 LCD_WR_DATA(0x90);
  813.                 LCD_WR_DATA(0x00);
  814.                 LCD_WR_DATA(0xEB);
  815.                 LCD_WR_DATA(0x00);
  816.                 LCD_WR_DATA(0xDC);
  817.                 LCD_WR_DATA(0x00);
  818.                 LCD_WR_REG(0xB8);
  819.                 LCD_WR_DATA(0x00);
  820.                 LCD_WR_DATA(0x00);
  821.                 LCD_WR_DATA(0x00);
  822.                 LCD_WR_DATA(0x00);
  823.                 LCD_WR_DATA(0x00);
  824.                 LCD_WR_DATA(0x00);
  825.                 LCD_WR_DATA(0x00);
  826.                 LCD_WR_DATA(0x00);
  827.                 LCD_WR_REG(0xBA);
  828.                 LCD_WR_DATA(0x24);
  829.                 LCD_WR_DATA(0x00);
  830.                 LCD_WR_DATA(0x00);
  831.                 LCD_WR_DATA(0x00);
  832.                 LCD_WR_REG(0xC1);
  833.                 LCD_WR_DATA(0x20);
  834.                 LCD_WR_DATA(0x00);
  835.                 LCD_WR_DATA(0x54);
  836.                 LCD_WR_DATA(0x00);
  837.                 LCD_WR_DATA(0xFF);
  838.                 LCD_WR_DATA(0x00);
  839.                 LCD_WR_REG(0xC2);
  840.                 LCD_WR_DATA(0x0A);
  841.                 LCD_WR_DATA(0x00);
  842.                 LCD_WR_DATA(0x04);
  843.                 LCD_WR_DATA(0x00);
  844.                 LCD_WR_REG(0xC3);
  845.                 LCD_WR_DATA(0x3C);
  846.                 LCD_WR_DATA(0x00);
  847.                 LCD_WR_DATA(0x3A);
  848.                 LCD_WR_DATA(0x00);
  849.                 LCD_WR_DATA(0x39);
  850.                 LCD_WR_DATA(0x00);
  851.                 LCD_WR_DATA(0x37);
  852.                 LCD_WR_DATA(0x00);
  853.                 LCD_WR_DATA(0x3C);
  854.                 LCD_WR_DATA(0x00);
  855.                 LCD_WR_DATA(0x36);
  856.                 LCD_WR_DATA(0x00);
  857.                 LCD_WR_DATA(0x32);
  858.                 LCD_WR_DATA(0x00);
  859.                 LCD_WR_DATA(0x2F);
  860.                 LCD_WR_DATA(0x00);
  861.                 LCD_WR_DATA(0x2C);
  862.                 LCD_WR_DATA(0x00);
  863.                 LCD_WR_DATA(0x29);
  864.                 LCD_WR_DATA(0x00);
  865.                 LCD_WR_DATA(0x26);
  866.                 LCD_WR_DATA(0x00);
  867.                 LCD_WR_DATA(0x24);
  868.                 LCD_WR_DATA(0x00);
  869.                 LCD_WR_DATA(0x24);
  870.                 LCD_WR_DATA(0x00);
  871.                 LCD_WR_DATA(0x23);
  872.                 LCD_WR_DATA(0x00);
  873.                 LCD_WR_DATA(0x3C);
  874.                 LCD_WR_DATA(0x00);
  875.                 LCD_WR_DATA(0x36);
  876.                 LCD_WR_DATA(0x00);
  877.                 LCD_WR_DATA(0x32);
  878.                 LCD_WR_DATA(0x00);
  879.                 LCD_WR_DATA(0x2F);
  880.                 LCD_WR_DATA(0x00);
  881.                 LCD_WR_DATA(0x2C);
  882.                 LCD_WR_DATA(0x00);
  883.                 LCD_WR_DATA(0x29);
  884.                 LCD_WR_DATA(0x00);
  885.                 LCD_WR_DATA(0x26);
  886.                 LCD_WR_DATA(0x00);
  887.                 LCD_WR_DATA(0x24);
  888.                 LCD_WR_DATA(0x00);
  889.                 LCD_WR_DATA(0x24);
  890.                 LCD_WR_DATA(0x00);
  891.                 LCD_WR_DATA(0x23);
  892.                 LCD_WR_DATA(0x00);
  893.                 LCD_WR_REG(0xC4);
  894.                 LCD_WR_DATA(0x62);
  895.                 LCD_WR_DATA(0x00);
  896.                 LCD_WR_DATA(0x05);
  897.                 LCD_WR_DATA(0x00);
  898.                 LCD_WR_DATA(0x84);
  899.                 LCD_WR_DATA(0x00);
  900.                 LCD_WR_DATA(0xF0);
  901.                 LCD_WR_DATA(0x00);
  902.                 LCD_WR_DATA(0x18);
  903.                 LCD_WR_DATA(0x00);
  904.                 LCD_WR_DATA(0xA4);
  905.                 LCD_WR_DATA(0x00);
  906.                 LCD_WR_DATA(0x18);
  907.                 LCD_WR_DATA(0x00);
  908.                 LCD_WR_DATA(0x50);
  909.                 LCD_WR_DATA(0x00);
  910.                 LCD_WR_DATA(0x0C);
  911.                 LCD_WR_DATA(0x00);
  912.                 LCD_WR_DATA(0x17);
  913.                 LCD_WR_DATA(0x00);
  914.                 LCD_WR_DATA(0x95);
  915.                 LCD_WR_DATA(0x00);
  916.                 LCD_WR_DATA(0xF3);
  917.                 LCD_WR_DATA(0x00);
  918.                 LCD_WR_DATA(0xE6);
  919.                 LCD_WR_DATA(0x00);
  920.                 LCD_WR_REG(0xC5);
  921.                 LCD_WR_DATA(0x32);
  922.                 LCD_WR_DATA(0x00);
  923.                 LCD_WR_DATA(0x44);
  924.                 LCD_WR_DATA(0x00);
  925.                 LCD_WR_DATA(0x65);
  926.                 LCD_WR_DATA(0x00);
  927.                 LCD_WR_DATA(0x76);
  928.                 LCD_WR_DATA(0x00);
  929.                 LCD_WR_DATA(0x88);
  930.                 LCD_WR_DATA(0x00);
  931.                 LCD_WR_REG(0xC6);
  932.                 LCD_WR_DATA(0x20);
  933.                 LCD_WR_DATA(0x00);
  934.                 LCD_WR_DATA(0x17);
  935.                 LCD_WR_DATA(0x00);
  936.                 LCD_WR_DATA(0x01);
  937.                 LCD_WR_DATA(0x00);
  938.                 LCD_WR_REG(0xC7);
  939.                 LCD_WR_DATA(0x00);
  940.                 LCD_WR_DATA(0x00);
  941.                 LCD_WR_DATA(0x00);
  942.                 LCD_WR_DATA(0x00);
  943.                 LCD_WR_REG(0xC8);
  944.                 LCD_WR_DATA(0x00);
  945.                 LCD_WR_DATA(0x00);
  946.                 LCD_WR_DATA(0x00);
  947.                 LCD_WR_DATA(0x00);
  948.                 LCD_WR_REG(0xC9);
  949.                 LCD_WR_DATA(0x00);
  950.                 LCD_WR_DATA(0x00);
  951.                 LCD_WR_DATA(0x00);
  952.                 LCD_WR_DATA(0x00);
  953.                 LCD_WR_DATA(0x00);
  954.                 LCD_WR_DATA(0x00);
  955.                 LCD_WR_DATA(0x00);
  956.                 LCD_WR_DATA(0x00);
  957.                 LCD_WR_DATA(0x00);
  958.                 LCD_WR_DATA(0x00);
  959.                 LCD_WR_DATA(0x00);
  960.                 LCD_WR_DATA(0x00);
  961.                 LCD_WR_DATA(0x00);
  962.                 LCD_WR_DATA(0x00);
  963.                 LCD_WR_DATA(0x00);
  964.                 LCD_WR_DATA(0x00);
  965.                 LCD_WR_REG(0xE0);
  966.                 LCD_WR_DATA(0x16);
  967.                 LCD_WR_DATA(0x00);
  968.                 LCD_WR_DATA(0x1C);
  969.                 LCD_WR_DATA(0x00);
  970.                 LCD_WR_DATA(0x21);
  971.                 LCD_WR_DATA(0x00);
  972.                 LCD_WR_DATA(0x36);
  973.                 LCD_WR_DATA(0x00);
  974.                 LCD_WR_DATA(0x46);
  975.                 LCD_WR_DATA(0x00);
  976.                 LCD_WR_DATA(0x52);
  977.                 LCD_WR_DATA(0x00);
  978.                 LCD_WR_DATA(0x64);
  979.                 LCD_WR_DATA(0x00);
  980.                 LCD_WR_DATA(0x7A);
  981.                 LCD_WR_DATA(0x00);
  982.                 LCD_WR_DATA(0x8B);
  983.                 LCD_WR_DATA(0x00);
  984.                 LCD_WR_DATA(0x99);
  985.                 LCD_WR_DATA(0x00);
  986.                 LCD_WR_DATA(0xA8);
  987.                 LCD_WR_DATA(0x00);
  988.                 LCD_WR_DATA(0xB9);
  989.                 LCD_WR_DATA(0x00);
  990.                 LCD_WR_DATA(0xC4);
  991.                 LCD_WR_DATA(0x00);
  992.                 LCD_WR_DATA(0xCA);
  993.                 LCD_WR_DATA(0x00);
  994.                 LCD_WR_DATA(0xD2);
  995.                 LCD_WR_DATA(0x00);
  996.                 LCD_WR_DATA(0xD9);
  997.                 LCD_WR_DATA(0x00);
  998.                 LCD_WR_DATA(0xE0);
  999.                 LCD_WR_DATA(0x00);
  1000.                 LCD_WR_DATA(0xF3);
  1001.                 LCD_WR_DATA(0x00);
  1002.                 LCD_WR_REG(0xE1);
  1003.                 LCD_WR_DATA(0x16);
  1004.                 LCD_WR_DATA(0x00);
  1005.                 LCD_WR_DATA(0x1C);
  1006.                 LCD_WR_DATA(0x00);
  1007.                 LCD_WR_DATA(0x22);
  1008.                 LCD_WR_DATA(0x00);
  1009.                 LCD_WR_DATA(0x36);
  1010.                 LCD_WR_DATA(0x00);
  1011.                 LCD_WR_DATA(0x45);
  1012.                 LCD_WR_DATA(0x00);
  1013.                 LCD_WR_DATA(0x52);
  1014.                 LCD_WR_DATA(0x00);
  1015.                 LCD_WR_DATA(0x64);
  1016.                 LCD_WR_DATA(0x00);
  1017.                 LCD_WR_DATA(0x7A);
  1018.                 LCD_WR_DATA(0x00);
  1019.                 LCD_WR_DATA(0x8B);
  1020.                 LCD_WR_DATA(0x00);
  1021.                 LCD_WR_DATA(0x99);
  1022.                 LCD_WR_DATA(0x00);
  1023.                 LCD_WR_DATA(0xA8);
  1024.                 LCD_WR_DATA(0x00);
  1025.                 LCD_WR_DATA(0xB9);
  1026.                 LCD_WR_DATA(0x00);
  1027.                 LCD_WR_DATA(0xC4);
  1028.                 LCD_WR_DATA(0x00);
  1029.                 LCD_WR_DATA(0xCA);
  1030.                 LCD_WR_DATA(0x00);
  1031.                 LCD_WR_DATA(0xD2);
  1032.                 LCD_WR_DATA(0x00);
  1033.                 LCD_WR_DATA(0xD8);
  1034.                 LCD_WR_DATA(0x00);
  1035.                 LCD_WR_DATA(0xE0);
  1036.                 LCD_WR_DATA(0x00);
  1037.                 LCD_WR_DATA(0xF3);
  1038.                 LCD_WR_DATA(0x00);
  1039.                 LCD_WR_REG(0xE2);
  1040.                 LCD_WR_DATA(0x05);
  1041.                 LCD_WR_DATA(0x00);
  1042.                 LCD_WR_DATA(0x0B);
  1043.                 LCD_WR_DATA(0x00);
  1044.                 LCD_WR_DATA(0x1B);
  1045.                 LCD_WR_DATA(0x00);
  1046.                 LCD_WR_DATA(0x34);
  1047.                 LCD_WR_DATA(0x00);
  1048.                 LCD_WR_DATA(0x44);
  1049.                 LCD_WR_DATA(0x00);
  1050.                 LCD_WR_DATA(0x4F);
  1051.                 LCD_WR_DATA(0x00);
  1052.                 LCD_WR_DATA(0x61);
  1053.                 LCD_WR_DATA(0x00);
  1054.                 LCD_WR_DATA(0x79);
  1055.                 LCD_WR_DATA(0x00);
  1056.                 LCD_WR_DATA(0x88);
  1057.                 LCD_WR_DATA(0x00);
  1058.                 LCD_WR_DATA(0x97);
  1059.                 LCD_WR_DATA(0x00);
  1060.                 LCD_WR_DATA(0xA6);
  1061.                 LCD_WR_DATA(0x00);
  1062.                 LCD_WR_DATA(0xB7);
  1063.                 LCD_WR_DATA(0x00);
  1064.                 LCD_WR_DATA(0xC2);
  1065.                 LCD_WR_DATA(0x00);
  1066.                 LCD_WR_DATA(0xC7);
  1067.                 LCD_WR_DATA(0x00);
  1068.                 LCD_WR_DATA(0xD1);
  1069.                 LCD_WR_DATA(0x00);
  1070.                 LCD_WR_DATA(0xD6);
  1071.                 LCD_WR_DATA(0x00);
  1072.                 LCD_WR_DATA(0xDD);
  1073.                 LCD_WR_DATA(0x00);
  1074.                 LCD_WR_DATA(0xF3);
  1075.                 LCD_WR_DATA(0x00);
  1076.                 LCD_WR_REG(0xE3);
  1077.                 LCD_WR_DATA(0x05);
  1078.                 LCD_WR_DATA(0x00);
  1079.                 LCD_WR_DATA(0xA);
  1080.                 LCD_WR_DATA(0x00);
  1081.                 LCD_WR_DATA(0x1C);
  1082.                 LCD_WR_DATA(0x00);
  1083.                 LCD_WR_DATA(0x33);
  1084.                 LCD_WR_DATA(0x00);
  1085.                 LCD_WR_DATA(0x44);
  1086.                 LCD_WR_DATA(0x00);
  1087.                 LCD_WR_DATA(0x50);
  1088.                 LCD_WR_DATA(0x00);
  1089.                 LCD_WR_DATA(0x62);
  1090.                 LCD_WR_DATA(0x00);
  1091.                 LCD_WR_DATA(0x78);
  1092.                 LCD_WR_DATA(0x00);
  1093.                 LCD_WR_DATA(0x88);
  1094.                 LCD_WR_DATA(0x00);
  1095.                 LCD_WR_DATA(0x97);
  1096.                 LCD_WR_DATA(0x00);
  1097.                 LCD_WR_DATA(0xA6);
  1098.                 LCD_WR_DATA(0x00);
  1099.                 LCD_WR_DATA(0xB7);
  1100.                 LCD_WR_DATA(0x00);
  1101.                 LCD_WR_DATA(0xC2);
  1102.                 LCD_WR_DATA(0x00);
  1103.                 LCD_WR_DATA(0xC7);
  1104.                 LCD_WR_DATA(0x00);
  1105.                 LCD_WR_DATA(0xD1);
  1106.                 LCD_WR_DATA(0x00);
  1107.                 LCD_WR_DATA(0xD5);
  1108.                 LCD_WR_DATA(0x00);
  1109.                 LCD_WR_DATA(0xDD);
  1110.                 LCD_WR_DATA(0x00);
  1111.                 LCD_WR_DATA(0xF3);
  1112.                 LCD_WR_DATA(0x00);
  1113.                 LCD_WR_REG(0xE4);
  1114.                 LCD_WR_DATA(0x01);
  1115.                 LCD_WR_DATA(0x00);
  1116.                 LCD_WR_DATA(0x01);
  1117.                 LCD_WR_DATA(0x00);
  1118.                 LCD_WR_DATA(0x02);
  1119.                 LCD_WR_DATA(0x00);
  1120.                 LCD_WR_DATA(0x2A);
  1121.                 LCD_WR_DATA(0x00);
  1122.                 LCD_WR_DATA(0x3C);
  1123.                 LCD_WR_DATA(0x00);
  1124.                 LCD_WR_DATA(0x4B);
  1125.                 LCD_WR_DATA(0x00);
  1126.                 LCD_WR_DATA(0x5D);
  1127.                 LCD_WR_DATA(0x00);
  1128.                 LCD_WR_DATA(0x74);
  1129.                 LCD_WR_DATA(0x00);
  1130.                 LCD_WR_DATA(0x84);
  1131.                 LCD_WR_DATA(0x00);
  1132.                 LCD_WR_DATA(0x93);
  1133.                 LCD_WR_DATA(0x00);
  1134.                 LCD_WR_DATA(0xA2);
  1135.                 LCD_WR_DATA(0x00);
  1136.                 LCD_WR_DATA(0xB3);
  1137.                 LCD_WR_DATA(0x00);
  1138.                 LCD_WR_DATA(0xBE);
  1139.                 LCD_WR_DATA(0x00);
  1140.                 LCD_WR_DATA(0xC4);
  1141.                 LCD_WR_DATA(0x00);
  1142.                 LCD_WR_DATA(0xCD);
  1143.                 LCD_WR_DATA(0x00);
  1144.                 LCD_WR_DATA(0xD3);
  1145.                 LCD_WR_DATA(0x00);
  1146.                 LCD_WR_DATA(0xDD);
  1147.                 LCD_WR_DATA(0x00);
  1148.                 LCD_WR_DATA(0xF3);
  1149.                 LCD_WR_DATA(0x00);
  1150.                 LCD_WR_REG(0xE5);
  1151.                 LCD_WR_DATA(0x00);
  1152.                 LCD_WR_DATA(0x00);
  1153.                 LCD_WR_DATA(0x00);
  1154.                 LCD_WR_DATA(0x00);
  1155.                 LCD_WR_DATA(0x02);
  1156.                 LCD_WR_DATA(0x00);
  1157.                 LCD_WR_DATA(0x29);
  1158.                 LCD_WR_DATA(0x00);
  1159.                 LCD_WR_DATA(0x3C);
  1160.                 LCD_WR_DATA(0x00);
  1161.                 LCD_WR_DATA(0x4B);
  1162.                 LCD_WR_DATA(0x00);
  1163.                 LCD_WR_DATA(0x5D);
  1164.                 LCD_WR_DATA(0x00);
  1165.                 LCD_WR_DATA(0x74);
  1166.                 LCD_WR_DATA(0x00);
  1167.                 LCD_WR_DATA(0x84);
  1168.                 LCD_WR_DATA(0x00);
  1169.                 LCD_WR_DATA(0x93);
  1170.                 LCD_WR_DATA(0x00);
  1171.                 LCD_WR_DATA(0xA2);
  1172.                 LCD_WR_DATA(0x00);
  1173.                 LCD_WR_DATA(0xB3);
  1174.                 LCD_WR_DATA(0x00);
  1175.                 LCD_WR_DATA(0xBE);
  1176.                 LCD_WR_DATA(0x00);
  1177.                 LCD_WR_DATA(0xC4);
  1178.                 LCD_WR_DATA(0x00);
  1179.                 LCD_WR_DATA(0xCD);
  1180.                 LCD_WR_DATA(0x00);
  1181.                 LCD_WR_DATA(0xD3);
  1182.                 LCD_WR_DATA(0x00);
  1183.                 LCD_WR_DATA(0xDC);
  1184.                 LCD_WR_DATA(0x00);
  1185.                 LCD_WR_DATA(0xF3);
  1186.                 LCD_WR_DATA(0x00);
  1187.                 LCD_WR_REG(0xE6);
  1188.                 LCD_WR_DATA(0x11);
  1189.                 LCD_WR_DATA(0x00);
  1190.                 LCD_WR_DATA(0x34);
  1191.                 LCD_WR_DATA(0x00);
  1192.                 LCD_WR_DATA(0x56);
  1193.                 LCD_WR_DATA(0x00);
  1194.                 LCD_WR_DATA(0x76);
  1195.                 LCD_WR_DATA(0x00);
  1196.                 LCD_WR_DATA(0x77);
  1197.                 LCD_WR_DATA(0x00);
  1198.                 LCD_WR_DATA(0x66);
  1199.                 LCD_WR_DATA(0x00);
  1200.                 LCD_WR_DATA(0x88);
  1201.                 LCD_WR_DATA(0x00);
  1202.                 LCD_WR_DATA(0x99);
  1203.                 LCD_WR_DATA(0x00);
  1204.                 LCD_WR_DATA(0xBB);
  1205.                 LCD_WR_DATA(0x00);
  1206.                 LCD_WR_DATA(0x99);
  1207.                 LCD_WR_DATA(0x00);
  1208.                 LCD_WR_DATA(0x66);
  1209.                 LCD_WR_DATA(0x00);
  1210.                 LCD_WR_DATA(0x55);
  1211.                 LCD_WR_DATA(0x00);
  1212.                 LCD_WR_DATA(0x55);
  1213.                 LCD_WR_DATA(0x00);
  1214.                 LCD_WR_DATA(0x45);
  1215.                 LCD_WR_DATA(0x00);
  1216.                 LCD_WR_DATA(0x43);
  1217.                 LCD_WR_DATA(0x00);
  1218.                 LCD_WR_DATA(0x44);
  1219.                 LCD_WR_DATA(0x00);
  1220.                 LCD_WR_REG(0xE7);
  1221.                 LCD_WR_DATA(0x32);
  1222.                 LCD_WR_DATA(0x00);
  1223.                 LCD_WR_DATA(0x55);
  1224.                 LCD_WR_DATA(0x00);
  1225.                 LCD_WR_DATA(0x76);
  1226.                 LCD_WR_DATA(0x00);
  1227.                 LCD_WR_DATA(0x66);
  1228.                 LCD_WR_DATA(0x00);
  1229.                 LCD_WR_DATA(0x67);
  1230.                 LCD_WR_DATA(0x00);
  1231.                 LCD_WR_DATA(0x67);
  1232.                 LCD_WR_DATA(0x00);
  1233.                 LCD_WR_DATA(0x87);
  1234.                 LCD_WR_DATA(0x00);
  1235.                 LCD_WR_DATA(0x99);
  1236.                 LCD_WR_DATA(0x00);
  1237.                 LCD_WR_DATA(0xBB);
  1238.                 LCD_WR_DATA(0x00);
  1239.                 LCD_WR_DATA(0x99);
  1240.                 LCD_WR_DATA(0x00);
  1241.                 LCD_WR_DATA(0x77);
  1242.                 LCD_WR_DATA(0x00);
  1243.                 LCD_WR_DATA(0x44);
  1244.                 LCD_WR_DATA(0x00);
  1245.                 LCD_WR_DATA(0x56);
  1246.                 LCD_WR_DATA(0x00);
  1247.                 LCD_WR_DATA(0x23);
  1248.                 LCD_WR_DATA(0x00);
  1249.                 LCD_WR_DATA(0x33);
  1250.                 LCD_WR_DATA(0x00);
  1251.                 LCD_WR_DATA(0x45);
  1252.                 LCD_WR_DATA(0x00);
  1253.                 LCD_WR_REG(0xE8);
  1254.                 LCD_WR_DATA(0x00);
  1255.                 LCD_WR_DATA(0x00);
  1256.                 LCD_WR_DATA(0x99);
  1257.                 LCD_WR_DATA(0x00);
  1258.                 LCD_WR_DATA(0x87);
  1259.                 LCD_WR_DATA(0x00);
  1260.                 LCD_WR_DATA(0x88);
  1261.                 LCD_WR_DATA(0x00);
  1262.                 LCD_WR_DATA(0x77);
  1263.                 LCD_WR_DATA(0x00);
  1264.                 LCD_WR_DATA(0x66);
  1265.                 LCD_WR_DATA(0x00);
  1266.                 LCD_WR_DATA(0x88);
  1267.                 LCD_WR_DATA(0x00);
  1268.                 LCD_WR_DATA(0xAA);
  1269.                 LCD_WR_DATA(0x00);
  1270.                 LCD_WR_DATA(0xBB);
  1271.                 LCD_WR_DATA(0x00);
  1272.                 LCD_WR_DATA(0x99);
  1273.                 LCD_WR_DATA(0x00);
  1274.                 LCD_WR_DATA(0x66);
  1275.                 LCD_WR_DATA(0x00);
  1276.                 LCD_WR_DATA(0x55);
  1277.                 LCD_WR_DATA(0x00);
  1278.                 LCD_WR_DATA(0x55);
  1279.                 LCD_WR_DATA(0x00);
  1280.                 LCD_WR_DATA(0x44);
  1281.                 LCD_WR_DATA(0x00);
  1282.                 LCD_WR_DATA(0x44);
  1283.                 LCD_WR_DATA(0x00);
  1284.                 LCD_WR_DATA(0x55);
  1285.                 LCD_WR_DATA(0x00);
  1286.                 LCD_WR_REG(0xE9);
  1287.                 LCD_WR_DATA(0xAA);
  1288.                 LCD_WR_DATA(0x00);
  1289.                 LCD_WR_DATA(0x00);
  1290.                 LCD_WR_DATA(0x00);
  1291.                 LCD_WR_REG(0x00);
  1292.                 LCD_WR_DATA(0xAA);
  1293.                 LCD_WR_REG(0xCF);
  1294.                 LCD_WR_DATA(0x00);
  1295.                 LCD_WR_DATA(0x00);
  1296.                 LCD_WR_DATA(0x00);
  1297.                 LCD_WR_DATA(0x00);
  1298.                 LCD_WR_DATA(0x00);
  1299.                 LCD_WR_DATA(0x00);
  1300.                 LCD_WR_DATA(0x00);
  1301.                 LCD_WR_DATA(0x00);
  1302.                 LCD_WR_DATA(0x00);
  1303.                 LCD_WR_DATA(0x00);
  1304.                 LCD_WR_DATA(0x00);
  1305.                 LCD_WR_DATA(0x00);
  1306.                 LCD_WR_DATA(0x00);
  1307.                 LCD_WR_DATA(0x00);
  1308.                 LCD_WR_DATA(0x00);
  1309.                 LCD_WR_DATA(0x00);
  1310.                 LCD_WR_DATA(0x00);
  1311.                 LCD_WR_REG(0xF0);
  1312.                 LCD_WR_DATA(0x00);
  1313.                 LCD_WR_DATA(0x50);
  1314.                 LCD_WR_DATA(0x00);
  1315.                 LCD_WR_DATA(0x00);
  1316.                 LCD_WR_DATA(0x00);
  1317.                 LCD_WR_REG(0xF3);
  1318.                 LCD_WR_DATA(0x00);
  1319.                 LCD_WR_REG(0xF9);
  1320.                 LCD_WR_DATA(0x06);
  1321.                 LCD_WR_DATA(0x10);
  1322.                 LCD_WR_DATA(0x29);
  1323.                 LCD_WR_DATA(0x00);
  1324.                 LCD_WR_REG(0x3A);
  1325.                 LCD_WR_DATA(0x55);        //66
  1326.                 LCD_WR_REG(0x11);
  1327.                 HAL_Delay(100);
  1328.                 LCD_WR_REG(0x29);
  1329.                 LCD_WR_REG(0x35);
  1330.                 LCD_WR_DATA(0x00);
  1331.                 LCD_WR_REG(0x51);
  1332.                 LCD_WR_DATA(0xFF);
  1333.                 LCD_WR_REG(0x53);
  1334.                 LCD_WR_DATA(0x2C);
  1335.                 LCD_WR_REG(0x55);
  1336.                 LCD_WR_DATA(0x82);
  1337.                 LCD_WR_REG(0x2c);
  1338.         }else if(lcddev.id==0x5510)
  1339.         {
  1340.                 LCD_WriteReg(0xF000,0x55);
  1341.                 LCD_WriteReg(0xF001,0xAA);
  1342.                 LCD_WriteReg(0xF002,0x52);
  1343.                 LCD_WriteReg(0xF003,0x08);
  1344.                 LCD_WriteReg(0xF004,0x01);
  1345.                 //AVDD Set AVDD 5.2V
  1346.                 LCD_WriteReg(0xB000,0x0D);
  1347.                 LCD_WriteReg(0xB001,0x0D);
  1348.                 LCD_WriteReg(0xB002,0x0D);
  1349.                 //AVDD ratio
  1350.                 LCD_WriteReg(0xB600,0x34);
  1351.                 LCD_WriteReg(0xB601,0x34);
  1352.                 LCD_WriteReg(0xB602,0x34);
  1353.                 //AVEE -5.2V
  1354.                 LCD_WriteReg(0xB100,0x0D);
  1355.                 LCD_WriteReg(0xB101,0x0D);
  1356.                 LCD_WriteReg(0xB102,0x0D);
  1357.                 //AVEE ratio
  1358.                 LCD_WriteReg(0xB700,0x34);
  1359.                 LCD_WriteReg(0xB701,0x34);
  1360.                 LCD_WriteReg(0xB702,0x34);
  1361.                 //VCL -2.5V
  1362.                 LCD_WriteReg(0xB200,0x00);
  1363.                 LCD_WriteReg(0xB201,0x00);
  1364.                 LCD_WriteReg(0xB202,0x00);
  1365.                 //VCL ratio
  1366.                 LCD_WriteReg(0xB800,0x24);
  1367.                 LCD_WriteReg(0xB801,0x24);
  1368.                 LCD_WriteReg(0xB802,0x24);
  1369.                 //VGH 15V (Free pump)
  1370.                 LCD_WriteReg(0xBF00,0x01);
  1371.                 LCD_WriteReg(0xB300,0x0F);
  1372.                 LCD_WriteReg(0xB301,0x0F);
  1373.                 LCD_WriteReg(0xB302,0x0F);
  1374.                 //VGH ratio
  1375.                 LCD_WriteReg(0xB900,0x34);
  1376.                 LCD_WriteReg(0xB901,0x34);
  1377.                 LCD_WriteReg(0xB902,0x34);
  1378.                 //VGL_REG -10V
  1379.                 LCD_WriteReg(0xB500,0x08);
  1380.                 LCD_WriteReg(0xB501,0x08);
  1381.                 LCD_WriteReg(0xB502,0x08);
  1382.                 LCD_WriteReg(0xC200,0x03);
  1383.                 //VGLX ratio
  1384.                 LCD_WriteReg(0xBA00,0x24);
  1385.                 LCD_WriteReg(0xBA01,0x24);
  1386.                 LCD_WriteReg(0xBA02,0x24);
  1387.                 //VGMP/VGSP 4.5V/0V
  1388.                 LCD_WriteReg(0xBC00,0x00);
  1389.                 LCD_WriteReg(0xBC01,0x78);
  1390.                 LCD_WriteReg(0xBC02,0x00);
  1391.                 //VGMN/VGSN -4.5V/0V
  1392.                 LCD_WriteReg(0xBD00,0x00);
  1393.                 LCD_WriteReg(0xBD01,0x78);
  1394.                 LCD_WriteReg(0xBD02,0x00);
  1395.                 //VCOM
  1396.                 LCD_WriteReg(0xBE00,0x00);
  1397.                 LCD_WriteReg(0xBE01,0x64);
  1398.                 //Gamma Setting
  1399.                 LCD_WriteReg(0xD100,0x00);
  1400.                 LCD_WriteReg(0xD101,0x33);
  1401.                 LCD_WriteReg(0xD102,0x00);
  1402.                 LCD_WriteReg(0xD103,0x34);
  1403.                 LCD_WriteReg(0xD104,0x00);
  1404.                 LCD_WriteReg(0xD105,0x3A);
  1405.                 LCD_WriteReg(0xD106,0x00);
  1406.                 LCD_WriteReg(0xD107,0x4A);
  1407.                 LCD_WriteReg(0xD108,0x00);
  1408.                 LCD_WriteReg(0xD109,0x5C);
  1409.                 LCD_WriteReg(0xD10A,0x00);
  1410.                 LCD_WriteReg(0xD10B,0x81);
  1411.                 LCD_WriteReg(0xD10C,0x00);
  1412.                 LCD_WriteReg(0xD10D,0xA6);
  1413.                 LCD_WriteReg(0xD10E,0x00);
  1414.                 LCD_WriteReg(0xD10F,0xE5);
  1415.                 LCD_WriteReg(0xD110,0x01);
  1416.                 LCD_WriteReg(0xD111,0x13);
  1417.                 LCD_WriteReg(0xD112,0x01);
  1418.                 LCD_WriteReg(0xD113,0x54);
  1419.                 LCD_WriteReg(0xD114,0x01);
  1420.                 LCD_WriteReg(0xD115,0x82);
  1421.                 LCD_WriteReg(0xD116,0x01);
  1422.                 LCD_WriteReg(0xD117,0xCA);
  1423.                 LCD_WriteReg(0xD118,0x02);
  1424.                 LCD_WriteReg(0xD119,0x00);
  1425.                 LCD_WriteReg(0xD11A,0x02);
  1426.                 LCD_WriteReg(0xD11B,0x01);
  1427.                 LCD_WriteReg(0xD11C,0x02);
  1428.                 LCD_WriteReg(0xD11D,0x34);
  1429.                 LCD_WriteReg(0xD11E,0x02);
  1430.                 LCD_WriteReg(0xD11F,0x67);
  1431.                 LCD_WriteReg(0xD120,0x02);
  1432.                 LCD_WriteReg(0xD121,0x84);
  1433.                 LCD_WriteReg(0xD122,0x02);
  1434.                 LCD_WriteReg(0xD123,0xA4);
  1435.                 LCD_WriteReg(0xD124,0x02);
  1436.                 LCD_WriteReg(0xD125,0xB7);
  1437.                 LCD_WriteReg(0xD126,0x02);
  1438.                 LCD_WriteReg(0xD127,0xCF);
  1439.                 LCD_WriteReg(0xD128,0x02);
  1440.                 LCD_WriteReg(0xD129,0xDE);
  1441.                 LCD_WriteReg(0xD12A,0x02);
  1442.                 LCD_WriteReg(0xD12B,0xF2);
  1443.                 LCD_WriteReg(0xD12C,0x02);
  1444.                 LCD_WriteReg(0xD12D,0xFE);
  1445.                 LCD_WriteReg(0xD12E,0x03);
  1446.                 LCD_WriteReg(0xD12F,0x10);
  1447.                 LCD_WriteReg(0xD130,0x03);
  1448.                 LCD_WriteReg(0xD131,0x33);
  1449.                 LCD_WriteReg(0xD132,0x03);
  1450.                 LCD_WriteReg(0xD133,0x6D);
  1451.                 LCD_WriteReg(0xD200,0x00);
  1452.                 LCD_WriteReg(0xD201,0x33);
  1453.                 LCD_WriteReg(0xD202,0x00);
  1454.                 LCD_WriteReg(0xD203,0x34);
  1455.                 LCD_WriteReg(0xD204,0x00);
  1456.                 LCD_WriteReg(0xD205,0x3A);
  1457.                 LCD_WriteReg(0xD206,0x00);
  1458.                 LCD_WriteReg(0xD207,0x4A);
  1459.                 LCD_WriteReg(0xD208,0x00);
  1460.                 LCD_WriteReg(0xD209,0x5C);
  1461.                 LCD_WriteReg(0xD20A,0x00);
  1462.                 LCD_WriteReg(0xD20B,0x81);
  1463.                 LCD_WriteReg(0xD20C,0x00);
  1464.                 LCD_WriteReg(0xD20D,0xA6);
  1465.                 LCD_WriteReg(0xD20E,0x00);
  1466.                 LCD_WriteReg(0xD20F,0xE5);
  1467.                 LCD_WriteReg(0xD210,0x01);
  1468.                 LCD_WriteReg(0xD211,0x13);
  1469.                 LCD_WriteReg(0xD212,0x01);
  1470.                 LCD_WriteReg(0xD213,0x54);
  1471.                 LCD_WriteReg(0xD214,0x01);
  1472.                 LCD_WriteReg(0xD215,0x82);
  1473.                 LCD_WriteReg(0xD216,0x01);
  1474.                 LCD_WriteReg(0xD217,0xCA);
  1475.                 LCD_WriteReg(0xD218,0x02);
  1476.                 LCD_WriteReg(0xD219,0x00);
  1477.                 LCD_WriteReg(0xD21A,0x02);
  1478.                 LCD_WriteReg(0xD21B,0x01);
  1479.                 LCD_WriteReg(0xD21C,0x02);
  1480.                 LCD_WriteReg(0xD21D,0x34);
  1481.                 LCD_WriteReg(0xD21E,0x02);
  1482.                 LCD_WriteReg(0xD21F,0x67);
  1483.                 LCD_WriteReg(0xD220,0x02);
  1484.                 LCD_WriteReg(0xD221,0x84);
  1485.                 LCD_WriteReg(0xD222,0x02);
  1486.                 LCD_WriteReg(0xD223,0xA4);
  1487.                 LCD_WriteReg(0xD224,0x02);
  1488.                 LCD_WriteReg(0xD225,0xB7);
  1489.                 LCD_WriteReg(0xD226,0x02);
  1490.                 LCD_WriteReg(0xD227,0xCF);
  1491.                 LCD_WriteReg(0xD228,0x02);
  1492.                 LCD_WriteReg(0xD229,0xDE);
  1493.                 LCD_WriteReg(0xD22A,0x02);
  1494.                 LCD_WriteReg(0xD22B,0xF2);
  1495.                 LCD_WriteReg(0xD22C,0x02);
  1496.                 LCD_WriteReg(0xD22D,0xFE);
  1497.                 LCD_WriteReg(0xD22E,0x03);
  1498.                 LCD_WriteReg(0xD22F,0x10);
  1499.                 LCD_WriteReg(0xD230,0x03);
  1500.                 LCD_WriteReg(0xD231,0x33);
  1501.                 LCD_WriteReg(0xD232,0x03);
  1502.                 LCD_WriteReg(0xD233,0x6D);
  1503.                 LCD_WriteReg(0xD300,0x00);
  1504.                 LCD_WriteReg(0xD301,0x33);
  1505.                 LCD_WriteReg(0xD302,0x00);
  1506.                 LCD_WriteReg(0xD303,0x34);
  1507.                 LCD_WriteReg(0xD304,0x00);
  1508.                 LCD_WriteReg(0xD305,0x3A);
  1509.                 LCD_WriteReg(0xD306,0x00);
  1510.                 LCD_WriteReg(0xD307,0x4A);
  1511.                 LCD_WriteReg(0xD308,0x00);
  1512.                 LCD_WriteReg(0xD309,0x5C);
  1513.                 LCD_WriteReg(0xD30A,0x00);
  1514.                 LCD_WriteReg(0xD30B,0x81);
  1515.                 LCD_WriteReg(0xD30C,0x00);
  1516.                 LCD_WriteReg(0xD30D,0xA6);
  1517.                 LCD_WriteReg(0xD30E,0x00);
  1518.                 LCD_WriteReg(0xD30F,0xE5);
  1519.                 LCD_WriteReg(0xD310,0x01);
  1520.                 LCD_WriteReg(0xD311,0x13);
  1521.                 LCD_WriteReg(0xD312,0x01);
  1522.                 LCD_WriteReg(0xD313,0x54);
  1523.                 LCD_WriteReg(0xD314,0x01);
  1524.                 LCD_WriteReg(0xD315,0x82);
  1525.                 LCD_WriteReg(0xD316,0x01);
  1526.                 LCD_WriteReg(0xD317,0xCA);
  1527.                 LCD_WriteReg(0xD318,0x02);
  1528.                 LCD_WriteReg(0xD319,0x00);
  1529.                 LCD_WriteReg(0xD31A,0x02);
  1530.                 LCD_WriteReg(0xD31B,0x01);
  1531.                 LCD_WriteReg(0xD31C,0x02);
  1532.                 LCD_WriteReg(0xD31D,0x34);
  1533.                 LCD_WriteReg(0xD31E,0x02);
  1534.                 LCD_WriteReg(0xD31F,0x67);
  1535.                 LCD_WriteReg(0xD320,0x02);
  1536.                 LCD_WriteReg(0xD321,0x84);
  1537.                 LCD_WriteReg(0xD322,0x02);
  1538.                 LCD_WriteReg(0xD323,0xA4);
  1539.                 LCD_WriteReg(0xD324,0x02);
  1540.                 LCD_WriteReg(0xD325,0xB7);
  1541.                 LCD_WriteReg(0xD326,0x02);
  1542.                 LCD_WriteReg(0xD327,0xCF);
  1543.                 LCD_WriteReg(0xD328,0x02);
  1544.                 LCD_WriteReg(0xD329,0xDE);
  1545.                 LCD_WriteReg(0xD32A,0x02);
  1546.                 LCD_WriteReg(0xD32B,0xF2);
  1547.                 LCD_WriteReg(0xD32C,0x02);
  1548.                 LCD_WriteReg(0xD32D,0xFE);
  1549.                 LCD_WriteReg(0xD32E,0x03);
  1550.                 LCD_WriteReg(0xD32F,0x10);
  1551.                 LCD_WriteReg(0xD330,0x03);
  1552.                 LCD_WriteReg(0xD331,0x33);
  1553.                 LCD_WriteReg(0xD332,0x03);
  1554.                 LCD_WriteReg(0xD333,0x6D);
  1555.                 LCD_WriteReg(0xD400,0x00);
  1556.                 LCD_WriteReg(0xD401,0x33);
  1557.                 LCD_WriteReg(0xD402,0x00);
  1558.                 LCD_WriteReg(0xD403,0x34);
  1559.                 LCD_WriteReg(0xD404,0x00);
  1560.                 LCD_WriteReg(0xD405,0x3A);
  1561.                 LCD_WriteReg(0xD406,0x00);
  1562.                 LCD_WriteReg(0xD407,0x4A);
  1563.                 LCD_WriteReg(0xD408,0x00);
  1564.                 LCD_WriteReg(0xD409,0x5C);
  1565.                 LCD_WriteReg(0xD40A,0x00);
  1566.                 LCD_WriteReg(0xD40B,0x81);
  1567.                 LCD_WriteReg(0xD40C,0x00);
  1568.                 LCD_WriteReg(0xD40D,0xA6);
  1569.                 LCD_WriteReg(0xD40E,0x00);
  1570.                 LCD_WriteReg(0xD40F,0xE5);
  1571.                 LCD_WriteReg(0xD410,0x01);
  1572.                 LCD_WriteReg(0xD411,0x13);
  1573.                 LCD_WriteReg(0xD412,0x01);
  1574.                 LCD_WriteReg(0xD413,0x54);
  1575.                 LCD_WriteReg(0xD414,0x01);
  1576.                 LCD_WriteReg(0xD415,0x82);
  1577.                 LCD_WriteReg(0xD416,0x01);
  1578.                 LCD_WriteReg(0xD417,0xCA);
  1579.                 LCD_WriteReg(0xD418,0x02);
  1580.                 LCD_WriteReg(0xD419,0x00);
  1581.                 LCD_WriteReg(0xD41A,0x02);
  1582.                 LCD_WriteReg(0xD41B,0x01);
  1583.                 LCD_WriteReg(0xD41C,0x02);
  1584.                 LCD_WriteReg(0xD41D,0x34);
  1585.                 LCD_WriteReg(0xD41E,0x02);
  1586.                 LCD_WriteReg(0xD41F,0x67);
  1587.                 LCD_WriteReg(0xD420,0x02);
  1588.                 LCD_WriteReg(0xD421,0x84);
  1589.                 LCD_WriteReg(0xD422,0x02);
  1590.                 LCD_WriteReg(0xD423,0xA4);
  1591.                 LCD_WriteReg(0xD424,0x02);
  1592.                 LCD_WriteReg(0xD425,0xB7);
  1593.                 LCD_WriteReg(0xD426,0x02);
  1594.                 LCD_WriteReg(0xD427,0xCF);
  1595.                 LCD_WriteReg(0xD428,0x02);
  1596.                 LCD_WriteReg(0xD429,0xDE);
  1597.                 LCD_WriteReg(0xD42A,0x02);
  1598.                 LCD_WriteReg(0xD42B,0xF2);
  1599.                 LCD_WriteReg(0xD42C,0x02);
  1600.                 LCD_WriteReg(0xD42D,0xFE);
  1601.                 LCD_WriteReg(0xD42E,0x03);
  1602.                 LCD_WriteReg(0xD42F,0x10);
  1603.                 LCD_WriteReg(0xD430,0x03);
  1604.                 LCD_WriteReg(0xD431,0x33);
  1605.                 LCD_WriteReg(0xD432,0x03);
  1606.                 LCD_WriteReg(0xD433,0x6D);
  1607.                 LCD_WriteReg(0xD500,0x00);
  1608.                 LCD_WriteReg(0xD501,0x33);
  1609.                 LCD_WriteReg(0xD502,0x00);
  1610.                 LCD_WriteReg(0xD503,0x34);
  1611.                 LCD_WriteReg(0xD504,0x00);
  1612.                 LCD_WriteReg(0xD505,0x3A);
  1613.                 LCD_WriteReg(0xD506,0x00);
  1614.                 LCD_WriteReg(0xD507,0x4A);
  1615.                 LCD_WriteReg(0xD508,0x00);
  1616.                 LCD_WriteReg(0xD509,0x5C);
  1617.                 LCD_WriteReg(0xD50A,0x00);
  1618.                 LCD_WriteReg(0xD50B,0x81);
  1619.                 LCD_WriteReg(0xD50C,0x00);
  1620.                 LCD_WriteReg(0xD50D,0xA6);
  1621.                 LCD_WriteReg(0xD50E,0x00);
  1622.                 LCD_WriteReg(0xD50F,0xE5);
  1623.                 LCD_WriteReg(0xD510,0x01);
  1624.                 LCD_WriteReg(0xD511,0x13);
  1625.                 LCD_WriteReg(0xD512,0x01);
  1626.                 LCD_WriteReg(0xD513,0x54);
  1627.                 LCD_WriteReg(0xD514,0x01);
  1628.                 LCD_WriteReg(0xD515,0x82);
  1629.                 LCD_WriteReg(0xD516,0x01);
  1630.                 LCD_WriteReg(0xD517,0xCA);
  1631.                 LCD_WriteReg(0xD518,0x02);
  1632.                 LCD_WriteReg(0xD519,0x00);
  1633.                 LCD_WriteReg(0xD51A,0x02);
  1634.                 LCD_WriteReg(0xD51B,0x01);
  1635.                 LCD_WriteReg(0xD51C,0x02);
  1636.                 LCD_WriteReg(0xD51D,0x34);
  1637.                 LCD_WriteReg(0xD51E,0x02);
  1638.                 LCD_WriteReg(0xD51F,0x67);
  1639.                 LCD_WriteReg(0xD520,0x02);
  1640.                 LCD_WriteReg(0xD521,0x84);
  1641.                 LCD_WriteReg(0xD522,0x02);
  1642.                 LCD_WriteReg(0xD523,0xA4);
  1643.                 LCD_WriteReg(0xD524,0x02);
  1644.                 LCD_WriteReg(0xD525,0xB7);
  1645.                 LCD_WriteReg(0xD526,0x02);
  1646.                 LCD_WriteReg(0xD527,0xCF);
  1647.                 LCD_WriteReg(0xD528,0x02);
  1648.                 LCD_WriteReg(0xD529,0xDE);
  1649.                 LCD_WriteReg(0xD52A,0x02);
  1650.                 LCD_WriteReg(0xD52B,0xF2);
  1651.                 LCD_WriteReg(0xD52C,0x02);
  1652.                 LCD_WriteReg(0xD52D,0xFE);
  1653.                 LCD_WriteReg(0xD52E,0x03);
  1654.                 LCD_WriteReg(0xD52F,0x10);
  1655.                 LCD_WriteReg(0xD530,0x03);
  1656.                 LCD_WriteReg(0xD531,0x33);
  1657.                 LCD_WriteReg(0xD532,0x03);
  1658.                 LCD_WriteReg(0xD533,0x6D);
  1659.                 LCD_WriteReg(0xD600,0x00);
  1660.                 LCD_WriteReg(0xD601,0x33);
  1661.                 LCD_WriteReg(0xD602,0x00);
  1662.                 LCD_WriteReg(0xD603,0x34);
  1663.                 LCD_WriteReg(0xD604,0x00);
  1664.                 LCD_WriteReg(0xD605,0x3A);
  1665.                 LCD_WriteReg(0xD606,0x00);
  1666.                 LCD_WriteReg(0xD607,0x4A);
  1667.                 LCD_WriteReg(0xD608,0x00);
  1668.                 LCD_WriteReg(0xD609,0x5C);
  1669.                 LCD_WriteReg(0xD60A,0x00);
  1670.                 LCD_WriteReg(0xD60B,0x81);
  1671.                 LCD_WriteReg(0xD60C,0x00);
  1672.                 LCD_WriteReg(0xD60D,0xA6);
  1673.                 LCD_WriteReg(0xD60E,0x00);
  1674.                 LCD_WriteReg(0xD60F,0xE5);
  1675.                 LCD_WriteReg(0xD610,0x01);
  1676.                 LCD_WriteReg(0xD611,0x13);
  1677.                 LCD_WriteReg(0xD612,0x01);
  1678.                 LCD_WriteReg(0xD613,0x54);
  1679.                 LCD_WriteReg(0xD614,0x01);
  1680.                 LCD_WriteReg(0xD615,0x82);
  1681.                 LCD_WriteReg(0xD616,0x01);
  1682.                 LCD_WriteReg(0xD617,0xCA);
  1683.                 LCD_WriteReg(0xD618,0x02);
  1684.                 LCD_WriteReg(0xD619,0x00);
  1685.                 LCD_WriteReg(0xD61A,0x02);
  1686.                 LCD_WriteReg(0xD61B,0x01);
  1687.                 LCD_WriteReg(0xD61C,0x02);
  1688.                 LCD_WriteReg(0xD61D,0x34);
  1689.                 LCD_WriteReg(0xD61E,0x02);
  1690.                 LCD_WriteReg(0xD61F,0x67);
  1691.                 LCD_WriteReg(0xD620,0x02);
  1692.                 LCD_WriteReg(0xD621,0x84);
  1693.                 LCD_WriteReg(0xD622,0x02);
  1694.                 LCD_WriteReg(0xD623,0xA4);
  1695.                 LCD_WriteReg(0xD624,0x02);
  1696.                 LCD_WriteReg(0xD625,0xB7);
  1697.                 LCD_WriteReg(0xD626,0x02);
  1698.                 LCD_WriteReg(0xD627,0xCF);
  1699.                 LCD_WriteReg(0xD628,0x02);
  1700.                 LCD_WriteReg(0xD629,0xDE);
  1701.                 LCD_WriteReg(0xD62A,0x02);
  1702.                 LCD_WriteReg(0xD62B,0xF2);
  1703.                 LCD_WriteReg(0xD62C,0x02);
  1704.                 LCD_WriteReg(0xD62D,0xFE);
  1705.                 LCD_WriteReg(0xD62E,0x03);
  1706.                 LCD_WriteReg(0xD62F,0x10);
  1707.                 LCD_WriteReg(0xD630,0x03);
  1708.                 LCD_WriteReg(0xD631,0x33);
  1709.                 LCD_WriteReg(0xD632,0x03);
  1710.                 LCD_WriteReg(0xD633,0x6D);
  1711.                 //LV2 Page 0 enable
  1712.                 LCD_WriteReg(0xF000,0x55);
  1713.                 LCD_WriteReg(0xF001,0xAA);
  1714.                 LCD_WriteReg(0xF002,0x52);
  1715.                 LCD_WriteReg(0xF003,0x08);
  1716.                 LCD_WriteReg(0xF004,0x00);
  1717.                 //Display control
  1718.                 LCD_WriteReg(0xB100, 0xCC);
  1719.                 LCD_WriteReg(0xB101, 0x00);
  1720.                 //Source hold time
  1721.                 LCD_WriteReg(0xB600,0x05);
  1722.                 //Gate EQ control
  1723.                 LCD_WriteReg(0xB700,0x70);
  1724.                 LCD_WriteReg(0xB701,0x70);
  1725.                 //Source EQ control (Mode 2)
  1726.                 LCD_WriteReg(0xB800,0x01);
  1727.                 LCD_WriteReg(0xB801,0x03);
  1728.                 LCD_WriteReg(0xB802,0x03);
  1729.                 LCD_WriteReg(0xB803,0x03);
  1730.                 //Inversion mode (2-dot)
  1731.                 LCD_WriteReg(0xBC00,0x02);
  1732.                 LCD_WriteReg(0xBC01,0x00);
  1733.                 LCD_WriteReg(0xBC02,0x00);
  1734.                 //Timing control 4H w/ 4-delay
  1735.                 LCD_WriteReg(0xC900,0xD0);
  1736.                 LCD_WriteReg(0xC901,0x02);
  1737.                 LCD_WriteReg(0xC902,0x50);
  1738.                 LCD_WriteReg(0xC903,0x50);
  1739.                 LCD_WriteReg(0xC904,0x50);
  1740.                 LCD_WriteReg(0x3500,0x00);
  1741.                 LCD_WriteReg(0x3A00,0x55);  //16-bit/pixel
  1742.                 LCD_WR_REG(0x1100);
  1743.                 HAL_Delay(120);
  1744.                 LCD_WR_REG(0x2900);
  1745.         }else if(lcddev.id==0x9325)//9325
  1746.         {
  1747.                 LCD_WriteReg(0x00E5,0x78F0);
  1748.                 LCD_WriteReg(0x0001,0x0100);
  1749.                 LCD_WriteReg(0x0002,0x0700);
  1750.                 LCD_WriteReg(0x0003,0x1030);
  1751.                 LCD_WriteReg(0x0004,0x0000);
  1752.                 LCD_WriteReg(0x0008,0x0202);
  1753.                 LCD_WriteReg(0x0009,0x0000);
  1754.                 LCD_WriteReg(0x000A,0x0000);
  1755.                 LCD_WriteReg(0x000C,0x0000);
  1756.                 LCD_WriteReg(0x000D,0x0000);
  1757.                 LCD_WriteReg(0x000F,0x0000);
  1758.                 //power on sequence VGHVGL
  1759.                 LCD_WriteReg(0x0010,0x0000);
  1760.                 LCD_WriteReg(0x0011,0x0007);
  1761.                 LCD_WriteReg(0x0012,0x0000);
  1762.                 LCD_WriteReg(0x0013,0x0000);
  1763.                 LCD_WriteReg(0x0007,0x0000);
  1764.                 //vgh
  1765.                 LCD_WriteReg(0x0010,0x1690);
  1766.                 LCD_WriteReg(0x0011,0x0227);
  1767.                 //delayms(100);
  1768.                 //vregiout
  1769.                 LCD_WriteReg(0x0012,0x009D); //0x001b
  1770.                 //delayms(100);
  1771.                 //vom amplitude
  1772.                 LCD_WriteReg(0x0013,0x1900);
  1773.                 //delayms(100);
  1774.                 //vom H
  1775.                 LCD_WriteReg(0x0029,0x0025);
  1776.                 LCD_WriteReg(0x002B,0x000D);
  1777.                 //gamma
  1778.                 LCD_WriteReg(0x0030,0x0007);
  1779.                 LCD_WriteReg(0x0031,0x0303);
  1780.                 LCD_WriteReg(0x0032,0x0003);// 0006
  1781.                 LCD_WriteReg(0x0035,0x0206);
  1782.                 LCD_WriteReg(0x0036,0x0008);
  1783.                 LCD_WriteReg(0x0037,0x0406);
  1784.                 LCD_WriteReg(0x0038,0x0304);//0200
  1785.                 LCD_WriteReg(0x0039,0x0007);
  1786.                 LCD_WriteReg(0x003C,0x0602);// 0504
  1787.                 LCD_WriteReg(0x003D,0x0008);
  1788.                 //ram
  1789.                 LCD_WriteReg(0x0050,0x0000);
  1790.                 LCD_WriteReg(0x0051,0x00EF);
  1791.                 LCD_WriteReg(0x0052,0x0000);
  1792.                 LCD_WriteReg(0x0053,0x013F);
  1793.                 LCD_WriteReg(0x0060,0xA700);
  1794.                 LCD_WriteReg(0x0061,0x0001);
  1795.                 LCD_WriteReg(0x006A,0x0000);
  1796.                 //
  1797.                 LCD_WriteReg(0x0080,0x0000);
  1798.                 LCD_WriteReg(0x0081,0x0000);
  1799.                 LCD_WriteReg(0x0082,0x0000);
  1800.                 LCD_WriteReg(0x0083,0x0000);
  1801.                 LCD_WriteReg(0x0084,0x0000);
  1802.                 LCD_WriteReg(0x0085,0x0000);
  1803.                 //
  1804.                 LCD_WriteReg(0x0090,0x0010);
  1805.                 LCD_WriteReg(0x0092,0x0600);
  1806.
  1807.                 LCD_WriteReg(0x0007,0x0133);
  1808.                 LCD_WriteReg(0x00,0x0022);//
  1809.         }else if(lcddev.id==0x9328)//ILI9328   OK
  1810.         {
  1811.                   LCD_WriteReg(0x00EC,0x108F);// internal timeing
  1812.                 LCD_WriteReg(0x00EF,0x1234);// ADD
  1813.                 //LCD_WriteReg(0x00e7,0x0010);
  1814.         //LCD_WriteReg(0x0000,0x0001);//¿aÆôÄú2¿ê±Öó
  1815.         LCD_WriteReg(0x0001,0x0100);
  1816.         LCD_WriteReg(0x0002,0x0700);//μçÔ′¿aÆô
  1817.                 //LCD_WriteReg(0x0003,(1<<3)|(1<<4) );         //65K  RGB
  1818.                 //DRIVE TABLE(¼Ä′æÆ÷ 03H)
  1819.                 //BIT3=AM BIT4:5=ID0:1
  1820.                 //AM ID0 ID1   FUNCATION
  1821.                 // 0  0   0           R->L D->U
  1822.                 // 1  0   0           D->U        R->L
  1823.                 // 0  1   0           L->R D->U
  1824.                 // 1  1   0    D->U        L->R
  1825.                 // 0  0   1           R->L U->D
  1826.                 // 1  0   1    U->D        R->L
  1827.                 // 0  1   1    L->R U->D Õy3£¾íóÃÕa¸ö.
  1828.                 // 1  1   1           U->D        L->R
  1829.         LCD_WriteReg(0x0003,(1<<12)|(3<<4)|(0<<3) );//65K
  1830.         LCD_WriteReg(0x0004,0x0000);
  1831.         LCD_WriteReg(0x0008,0x0202);
  1832.         LCD_WriteReg(0x0009,0x0000);
  1833.         LCD_WriteReg(0x000a,0x0000);//display setting
  1834.         LCD_WriteReg(0x000c,0x0001);//display setting
  1835.         LCD_WriteReg(0x000d,0x0000);//0f3c
  1836.         LCD_WriteReg(0x000f,0x0000);
  1837.                 //μçÔ′ÅäÖÃ
  1838.         LCD_WriteReg(0x0010,0x0000);
  1839.         LCD_WriteReg(0x0011,0x0007);
  1840.         LCD_WriteReg(0x0012,0x0000);
  1841.         LCD_WriteReg(0x0013,0x0000);
  1842.              LCD_WriteReg(0x0007,0x0001);
  1843.                HAL_Delay(50);
  1844.         LCD_WriteReg(0x0010,0x1490);
  1845.         LCD_WriteReg(0x0011,0x0227);
  1846.         HAL_Delay(50);
  1847.         LCD_WriteReg(0x0012,0x008A);
  1848.         HAL_Delay(50);
  1849.         LCD_WriteReg(0x0013,0x1a00);
  1850.         LCD_WriteReg(0x0029,0x0006);
  1851.         LCD_WriteReg(0x002b,0x000d);
  1852.         HAL_Delay(50);
  1853.         LCD_WriteReg(0x0020,0x0000);
  1854.         LCD_WriteReg(0x0021,0x0000);
  1855.                 HAL_Delay(50);
  1856.                 //ù¤ÂíD£Õy
  1857.         LCD_WriteReg(0x0030,0x0000);
  1858.         LCD_WriteReg(0x0031,0x0604);
  1859.         LCD_WriteReg(0x0032,0x0305);
  1860.         LCD_WriteReg(0x0035,0x0000);
  1861.         LCD_WriteReg(0x0036,0x0C09);
  1862.         LCD_WriteReg(0x0037,0x0204);
  1863.         LCD_WriteReg(0x0038,0x0301);
  1864.         LCD_WriteReg(0x0039,0x0707);
  1865.         LCD_WriteReg(0x003c,0x0000);
  1866.         LCD_WriteReg(0x003d,0x0a0a);
  1867.         HAL_Delay(50);
  1868.         LCD_WriteReg(0x0050,0x0000); //ˮƽGRAMÆeê¼Î»ÖÃ
  1869.         LCD_WriteReg(0x0051,0x00ef); //ˮƽGRAMÖÕÖ1λÖà
  1870.         LCD_WriteReg(0x0052,0x0000); //′1Ö±GRAMÆeê¼Î»Öà
  1871.         LCD_WriteReg(0x0053,0x013f); //′1Ö±GRAMÖÕÖ1λÖà
  1872.          LCD_WriteReg(0x0060,0xa700);
  1873.         LCD_WriteReg(0x0061,0x0001);
  1874.         LCD_WriteReg(0x006a,0x0000);
  1875.         LCD_WriteReg(0x0080,0x0000);
  1876.         LCD_WriteReg(0x0081,0x0000);
  1877.         LCD_WriteReg(0x0082,0x0000);
  1878.         LCD_WriteReg(0x0083,0x0000);
  1879.         LCD_WriteReg(0x0084,0x0000);
  1880.         LCD_WriteReg(0x0085,0x0000);
  1881.
  1882.         LCD_WriteReg(0x0090,0x0010);
  1883.         LCD_WriteReg(0x0092,0x0600);
  1884.         //¿aÆôÏÔê¾éèÖà
  1885.         LCD_WriteReg(0x0007,0x0133);
  1886.         }else if(lcddev.id==0x9320)//2aêÔOK.
  1887.         {
  1888.                 LCD_WriteReg(0x00,0x0000);
  1889.                 LCD_WriteReg(0x01,0x0100);        //Driver Output Contral.
  1890.                 LCD_WriteReg(0x02,0x0700);        //LCD Driver Waveform Contral.
  1891.                 LCD_WriteReg(0x03,0x1030);//Entry Mode Set.
  1892.                 //LCD_WriteReg(0x03,0x1018);        //Entry Mode Set.
  1893.
  1894.                 LCD_WriteReg(0x04,0x0000);        //Scalling Contral.
  1895.                 LCD_WriteReg(0x08,0x0202);        //Display Contral 2.(0x0207)
  1896.                 LCD_WriteReg(0x09,0x0000);        //Display Contral 3.(0x0000)
  1897.                 LCD_WriteReg(0x0a,0x0000);        //Frame Cycle Contal.(0x0000)
  1898.                 LCD_WriteReg(0x0c,(1<<0));        //Extern Display Interface Contral 1.(0x0000)
  1899.                 LCD_WriteReg(0x0d,0x0000);        //Frame Maker Position.
  1900.                 LCD_WriteReg(0x0f,0x0000);        //Extern Display Interface Contral 2.
  1901.                 HAL_Delay(50);
  1902.                 LCD_WriteReg(0x07,0x0101);        //Display Contral.
  1903.                 HAL_Delay(50);
  1904.                 LCD_WriteReg(0x10,(1<<12)|(0<<8)|(1<<7)|(1<<6)|(0<<4));        //Power Control 1.(0x16b0)
  1905.                 LCD_WriteReg(0x11,0x0007);        //Power Control 2.(0x0001)
  1906.                 LCD_WriteReg(0x12,(1<<8)|(1<<4)|(0<<0));                                //Power Control 3.(0x0138)
  1907.                 LCD_WriteReg(0x13,0x0b00);        //Power Control 4.
  1908.                 LCD_WriteReg(0x29,0x0000);        //Power Control 7.
  1909.
  1910.                 LCD_WriteReg(0x2b,(1<<14)|(1<<4));
  1911.                 LCD_WriteReg(0x50,0);        //Set X Star
  1912.                 //ˮƽGRAMÖÕÖ1λÖÃSet X End.
  1913.                 LCD_WriteReg(0x51,239);        //Set Y Star
  1914.                 LCD_WriteReg(0x52,0);        //Set Y End.t.
  1915.                 LCD_WriteReg(0x53,319);        //
  1916.
  1917.                 LCD_WriteReg(0x60,0x2700);        //Driver Output Control.
  1918.                 LCD_WriteReg(0x61,0x0001);        //Driver Output Control.
  1919.                 LCD_WriteReg(0x6a,0x0000);        //Vertical Srcoll Control.
  1920.
  1921.                 LCD_WriteReg(0x80,0x0000);        //Display Position? Partial Display 1.
  1922.                 LCD_WriteReg(0x81,0x0000);        //RAM Address Start? Partial Display 1.
  1923.                 LCD_WriteReg(0x82,0x0000);        //RAM Address End-Partial Display 1.
  1924.                 LCD_WriteReg(0x83,0x0000);        //Displsy Position? Partial Display 2.
  1925.                 LCD_WriteReg(0x84,0x0000);        //RAM Address Start? Partial Display 2.
  1926.                 LCD_WriteReg(0x85,0x0000);        //RAM Address End? Partial Display 2.
  1927.
  1928.                 LCD_WriteReg(0x90,(0<<7)|(16<<0));        //Frame Cycle Contral.(0x0013)
  1929.                 LCD_WriteReg(0x92,0x0000);        //Panel Interface Contral 2.(0x0000)
  1930.                 LCD_WriteReg(0x93,0x0001);        //Panel Interface Contral 3.
  1931.                 LCD_WriteReg(0x95,0x0110);        //Frame Cycle Contral.(0x0110)
  1932.                 LCD_WriteReg(0x97,(0<<8));        //
  1933.                 LCD_WriteReg(0x98,0x0000);        //Frame Cycle Contral.
  1934.                 LCD_WriteReg(0x07,0x0173);        //(0x0173)
  1935.         }else if(lcddev.id==0X9331)//OK |/|/|
  1936.         {
  1937.                 LCD_WriteReg(0x00E7, 0x1014);
  1938.                 LCD_WriteReg(0x0001, 0x0100); // set SS and SM bit
  1939.                 LCD_WriteReg(0x0002, 0x0200); // set 1 line inversion
  1940.         LCD_WriteReg(0x0003,(1<<12)|(3<<4)|(1<<3));//65K
  1941.                 //LCD_WriteReg(0x0003, 0x1030); // set GRAM write direction and BGR=1.
  1942.                 LCD_WriteReg(0x0008, 0x0202); // set the back porch and front porch
  1943.                 LCD_WriteReg(0x0009, 0x0000); // set non-display area refresh cycle ISC[3:0]
  1944.                 LCD_WriteReg(0x000A, 0x0000); // FMARK function
  1945.                 LCD_WriteReg(0x000C, 0x0000); // RGB interface setting
  1946.                 LCD_WriteReg(0x000D, 0x0000); // Frame marker Position
  1947.                 LCD_WriteReg(0x000F, 0x0000); // RGB interface polarity
  1948.                 //*************Power On sequence ****************//
  1949.                 LCD_WriteReg(0x0010, 0x0000); // SAP, BT[3:0], AP, DSTB, SLP, STB
  1950.                 LCD_WriteReg(0x0011, 0x0007); // DC1[2:0], DC0[2:0], VC[2:0]
  1951.                 LCD_WriteReg(0x0012, 0x0000); // VREG1OUT voltage
  1952.                 LCD_WriteReg(0x0013, 0x0000); // VDV[4:0] for VCOM amplitude
  1953.                 HAL_Delay(200); // Dis-charge capacitor power voltage
  1954.                 LCD_WriteReg(0x0010, 0x1690); // SAP, BT[3:0], AP, DSTB, SLP, STB
  1955.                 LCD_WriteReg(0x0011, 0x0227); // DC1[2:0], DC0[2:0], VC[2:0]
  1956.                 HAL_Delay(50); // Delay 50ms
  1957.                 LCD_WriteReg(0x0012, 0x000C); // Internal reference voltage= Vci;
  1958.                 HAL_Delay(50); // Delay 50ms
  1959.                 LCD_WriteReg(0x0013, 0x0800); // Set VDV[4:0] for VCOM amplitude
  1960.                 LCD_WriteReg(0x0029, 0x0011); // Set VCM[5:0] for VCOMH
  1961.                 LCD_WriteReg(0x002B, 0x000B); // Set Frame Rate
  1962.                 HAL_Delay(50); // Delay 50ms
  1963.                 LCD_WriteReg(0x0020, 0x0000); // GRAM horizontal Address
  1964.                 LCD_WriteReg(0x0021, 0x013f); // GRAM Vertical Address
  1965.                 // ----------- Adjust the Gamma Curve ----------//
  1966.                 LCD_WriteReg(0x0030, 0x0000);
  1967.                 LCD_WriteReg(0x0031, 0x0106);
  1968.                 LCD_WriteReg(0x0032, 0x0000);
  1969.                 LCD_WriteReg(0x0035, 0x0204);
  1970.                 LCD_WriteReg(0x0036, 0x160A);
  1971.                 LCD_WriteReg(0x0037, 0x0707);
  1972.                 LCD_WriteReg(0x0038, 0x0106);
  1973.                 LCD_WriteReg(0x0039, 0x0707);
  1974.                 LCD_WriteReg(0x003C, 0x0402);
  1975.                 LCD_WriteReg(0x003D, 0x0C0F);
  1976.                 //------------------ Set GRAM area ---------------//
  1977.                 LCD_WriteReg(0x0050, 0x0000); // Horizontal GRAM Start Address
  1978.                 LCD_WriteReg(0x0051, 0x00EF); // Horizontal GRAM End Address
  1979.                 LCD_WriteReg(0x0052, 0x0000); // Vertical GRAM Start Address
  1980.                 LCD_WriteReg(0x0053, 0x013F); // Vertical GRAM Start Address
  1981.                 LCD_WriteReg(0x0060, 0x2700); // Gate Scan Line
  1982.                 LCD_WriteReg(0x0061, 0x0001); // NDL,VLE, REV
  1983.                 LCD_WriteReg(0x006A, 0x0000); // set scrolling line
  1984.                 //-------------- Partial Display Control ---------//
  1985.                 LCD_WriteReg(0x0080, 0x0000);
  1986.                 LCD_WriteReg(0x0081, 0x0000);
  1987.                 LCD_WriteReg(0x0082, 0x0000);
  1988.                 LCD_WriteReg(0x0083, 0x0000);
  1989.                 LCD_WriteReg(0x0084, 0x0000);
  1990.                 LCD_WriteReg(0x0085, 0x0000);
  1991.                 //-------------- Panel Control -------------------//
  1992.                 LCD_WriteReg(0x0090, 0x0010);
  1993.                 LCD_WriteReg(0x0092, 0x0600);
  1994.                 LCD_WriteReg(0x0007, 0x0133); // 262K color and display ON
  1995.         }else if(lcddev.id==0x5408)
  1996.         {
  1997.                 LCD_WriteReg(0x01,0x0100);
  1998.                 LCD_WriteReg(0x02,0x0700);//LCD Driving Waveform Contral
  1999.                 LCD_WriteReg(0x03,0x1030);//Entry ModeéèÖÃ
  2000.                 //Ö¸Õë′ó×óÖáóò×Ôé϶øÏÂμÄ×Ô¶ˉÔöÄ£ê½
  2001.                 //Normal Mode(Window Mode disable)
  2002.                 //RGB¸ñê½
  2003.                 //16λêy¾Y2′Î′«êäμÄ8×üÏßéèÖÃ
  2004.                 LCD_WriteReg(0x04,0x0000); //Scalling Control register
  2005.                 LCD_WriteReg(0x08,0x0207); //Display Control 2
  2006.                 LCD_WriteReg(0x09,0x0000); //Display Control 3
  2007.                 LCD_WriteReg(0x0A,0x0000); //Frame Cycle Control
  2008.                 LCD_WriteReg(0x0C,0x0000); //External Display Interface Control 1
  2009.                 LCD_WriteReg(0x0D,0x0000); //Frame Maker Position
  2010.                 LCD_WriteReg(0x0F,0x0000); //External Display Interface Control 2
  2011.                 HAL_Delay(20);
  2012.                 //TFT òo¾§2êé«í¼ÏñÏÔê¾·½·¨14
  2013.                 LCD_WriteReg(0x10,0x16B0); //0x14B0 //Power Control 1
  2014.                 LCD_WriteReg(0x11,0x0001); //0x0007 //Power Control 2
  2015.                 LCD_WriteReg(0x17,0x0001); //0x0000 //Power Control 3
  2016.                 LCD_WriteReg(0x12,0x0138); //0x013B //Power Control 4
  2017.                 LCD_WriteReg(0x13,0x0800); //0x0800 //Power Control 5
  2018.                 LCD_WriteReg(0x29,0x0009); //NVM read data 2
  2019.                 LCD_WriteReg(0x2a,0x0009); //NVM read data 3
  2020.                 LCD_WriteReg(0xa4,0x0000);
  2021.                 LCD_WriteReg(0x50,0x0000); //éèÖÃ2ù×÷′°¿úμÄXÖá¿aê¼áD
  2022.                 LCD_WriteReg(0x51,0x00EF); //éèÖÃ2ù×÷′°¿úμÄXÖá½áêøáD
  2023.                 LCD_WriteReg(0x52,0x0000); //éèÖÃ2ù×÷′°¿úμÄYÖá¿aê¼DD
  2024.                 LCD_WriteReg(0x53,0x013F); //éèÖÃ2ù×÷′°¿úμÄYÖá½áêøDD
  2025.                 LCD_WriteReg(0x60,0x2700); //Driver Output Control
  2026.                 //éèÖÃÆáÄ»μÄμãêyòÔ¼°é¨ÃèμÄÆeê¼DD
  2027.                 LCD_WriteReg(0x61,0x0001); //Driver Output Control
  2028.                 LCD_WriteReg(0x6A,0x0000); //Vertical Scroll Control
  2029.                 LCD_WriteReg(0x80,0x0000); //Display Position ¨C Partial Display 1
  2030.                 LCD_WriteReg(0x81,0x0000); //RAM Address Start ¨C Partial Display 1
  2031.                 LCD_WriteReg(0x82,0x0000); //RAM address End - Partial Display 1
  2032.                 LCD_WriteReg(0x83,0x0000); //Display Position ¨C Partial Display 2
  2033.                 LCD_WriteReg(0x84,0x0000); //RAM Address Start ¨C Partial Display 2
  2034.                 LCD_WriteReg(0x85,0x0000); //RAM address End ¨C Partail Display2
  2035.                 LCD_WriteReg(0x90,0x0013); //Frame Cycle Control
  2036.                 LCD_WriteReg(0x92,0x0000);  //Panel Interface Control 2
  2037.                 LCD_WriteReg(0x93,0x0003); //Panel Interface control 3
  2038.                 LCD_WriteReg(0x95,0x0110);  //Frame Cycle Control
  2039.                 LCD_WriteReg(0x07,0x0173);
  2040.                 HAL_Delay(50);
  2041.         }
  2042.         else if(lcddev.id==0x1505)//OK
  2043.         {
  2044.                 // second release on 3/5  ,luminance is acceptable,water wave appear during camera preview
  2045.         LCD_WriteReg(0x0007,0x0000);
  2046.         HAL_Delay(50);
  2047.         LCD_WriteReg(0x0012,0x011C);//0x011A   why need to set several times?
  2048.         LCD_WriteReg(0x00A4,0x0001);//NVM
  2049.         LCD_WriteReg(0x0008,0x000F);
  2050.         LCD_WriteReg(0x000A,0x0008);
  2051.         LCD_WriteReg(0x000D,0x0008);
  2052.                   //ù¤ÂíD£Õy
  2053.         LCD_WriteReg(0x0030,0x0707);
  2054.         LCD_WriteReg(0x0031,0x0007); //0x0707
  2055.         LCD_WriteReg(0x0032,0x0603);
  2056.         LCD_WriteReg(0x0033,0x0700);
  2057.         LCD_WriteReg(0x0034,0x0202);
  2058.         LCD_WriteReg(0x0035,0x0002); //?0x0606
  2059.         LCD_WriteReg(0x0036,0x1F0F);
  2060.         LCD_WriteReg(0x0037,0x0707); //0x0f0f  0x0105
  2061.         LCD_WriteReg(0x0038,0x0000);
  2062.         LCD_WriteReg(0x0039,0x0000);
  2063.         LCD_WriteReg(0x003A,0x0707);
  2064.         LCD_WriteReg(0x003B,0x0000); //0x0303
  2065.         LCD_WriteReg(0x003C,0x0007); //?0x0707
  2066.         LCD_WriteReg(0x003D,0x0000); //0x1313//0x1f08
  2067.         HAL_Delay(50);
  2068.         LCD_WriteReg(0x0007,0x0001);
  2069.         LCD_WriteReg(0x0017,0x0001);//¿aÆôμçÔ′
  2070.         HAL_Delay(50);
  2071.                   //μçÔ′ÅäÖÃ
  2072.         LCD_WriteReg(0x0010,0x17A0);
  2073.         LCD_WriteReg(0x0011,0x0217);//reference voltage VC[2:0]   Vciout = 1.00*Vcivl
  2074.         LCD_WriteReg(0x0012,0x011E);//0x011c  //Vreg1out = Vcilvl*1.80   is it the same as Vgama1out ?
  2075.         LCD_WriteReg(0x0013,0x0F00);//VDV[4:0]-->VCOM Amplitude VcomL = VcomH - Vcom Ampl
  2076.         LCD_WriteReg(0x002A,0x0000);
  2077.         LCD_WriteReg(0x0029,0x000A);//0x0001F  Vcomh = VCM1[4:0]*Vreg1out    gate source voltage??
  2078.         LCD_WriteReg(0x0012,0x013E);// 0x013C  power supply on
  2079.         //Coordinates Control//
  2080.         LCD_WriteReg(0x0050,0x0000);//0x0e00
  2081.         LCD_WriteReg(0x0051,0x00EF);
  2082.         LCD_WriteReg(0x0052,0x0000);
  2083.         LCD_WriteReg(0x0053,0x013F);
  2084.             //Pannel Image Control//
  2085.         LCD_WriteReg(0x0060,0x2700);
  2086.         LCD_WriteReg(0x0061,0x0001);
  2087.         LCD_WriteReg(0x006A,0x0000);
  2088.         LCD_WriteReg(0x0080,0x0000);
  2089.             //Partial Image Control//
  2090.         LCD_WriteReg(0x0081,0x0000);
  2091.         LCD_WriteReg(0x0082,0x0000);
  2092.         LCD_WriteReg(0x0083,0x0000);
  2093.         LCD_WriteReg(0x0084,0x0000);
  2094.         LCD_WriteReg(0x0085,0x0000);
  2095.                   //Panel Interface Control//
  2096.         LCD_WriteReg(0x0090,0x0013);//0x0010 frenqucy
  2097.         LCD_WriteReg(0x0092,0x0300);
  2098.         LCD_WriteReg(0x0093,0x0005);
  2099.         LCD_WriteReg(0x0095,0x0000);
  2100.         LCD_WriteReg(0x0097,0x0000);
  2101.         LCD_WriteReg(0x0098,0x0000);
  2102.
  2103.         LCD_WriteReg(0x0001,0x0100);
  2104.         LCD_WriteReg(0x0002,0x0700);
  2105.         LCD_WriteReg(0x0003,0x1038);//é¨Ãè·½Ïò éÏ->Ï  ×ó->óò
  2106.         LCD_WriteReg(0x0004,0x0000);
  2107.         LCD_WriteReg(0x000C,0x0000);
  2108.         LCD_WriteReg(0x000F,0x0000);
  2109.         LCD_WriteReg(0x0020,0x0000);
  2110.         LCD_WriteReg(0x0021,0x0000);
  2111.         LCD_WriteReg(0x0007,0x0021);
  2112.         HAL_Delay(20);
  2113.         LCD_WriteReg(0x0007,0x0061);
  2114.         HAL_Delay(20);
  2115.         LCD_WriteReg(0x0007,0x0173);
  2116.         HAL_Delay(20);
  2117.         }else if(lcddev.id==0xB505)
  2118.         {
  2119.                 LCD_WriteReg(0x0000,0x0000);
  2120.                 LCD_WriteReg(0x0000,0x0000);
  2121.                 LCD_WriteReg(0x0000,0x0000);
  2122.                 LCD_WriteReg(0x0000,0x0000);
  2123.
  2124.                 LCD_WriteReg(0x00a4,0x0001);
  2125.                 HAL_Delay(20);
  2126.                 LCD_WriteReg(0x0060,0x2700);
  2127.                 LCD_WriteReg(0x0008,0x0202);
  2128.
  2129.                 LCD_WriteReg(0x0030,0x0214);
  2130.                 LCD_WriteReg(0x0031,0x3715);
  2131.                 LCD_WriteReg(0x0032,0x0604);
  2132.                 LCD_WriteReg(0x0033,0x0e16);
  2133.                 LCD_WriteReg(0x0034,0x2211);
  2134.                 LCD_WriteReg(0x0035,0x1500);
  2135.                 LCD_WriteReg(0x0036,0x8507);
  2136.                 LCD_WriteReg(0x0037,0x1407);
  2137.                 LCD_WriteReg(0x0038,0x1403);
  2138.                 LCD_WriteReg(0x0039,0x0020);
  2139.
  2140.                 LCD_WriteReg(0x0090,0x001a);
  2141.                 LCD_WriteReg(0x0010,0x0000);
  2142.                 LCD_WriteReg(0x0011,0x0007);
  2143.                 LCD_WriteReg(0x0012,0x0000);
  2144.                 LCD_WriteReg(0x0013,0x0000);
  2145.                 HAL_Delay(20);
  2146.
  2147.                 LCD_WriteReg(0x0010,0x0730);
  2148.                 LCD_WriteReg(0x0011,0x0137);
  2149.                 HAL_Delay(20);
  2150.
  2151.                 LCD_WriteReg(0x0012,0x01b8);
  2152.                 HAL_Delay(20);
  2153.
  2154.                 LCD_WriteReg(0x0013,0x0f00);
  2155.                 LCD_WriteReg(0x002a,0x0080);
  2156.                 LCD_WriteReg(0x0029,0x0048);
  2157.                 HAL_Delay(20);
  2158.
  2159.                 LCD_WriteReg(0x0001,0x0100);
  2160.                 LCD_WriteReg(0x0002,0x0700);
  2161.         LCD_WriteReg(0x0003,0x1038);//é¨Ãè·½Ïò éÏ->Ï  ×ó->óò
  2162.                 LCD_WriteReg(0x0008,0x0202);
  2163.                 LCD_WriteReg(0x000a,0x0000);
  2164.                 LCD_WriteReg(0x000c,0x0000);
  2165.                 LCD_WriteReg(0x000d,0x0000);
  2166.                 LCD_WriteReg(0x000e,0x0030);
  2167.                 LCD_WriteReg(0x0050,0x0000);
  2168.                 LCD_WriteReg(0x0051,0x00ef);
  2169.                 LCD_WriteReg(0x0052,0x0000);
  2170.                 LCD_WriteReg(0x0053,0x013f);
  2171.                 LCD_WriteReg(0x0060,0x2700);
  2172.                 LCD_WriteReg(0x0061,0x0001);
  2173.                 LCD_WriteReg(0x006a,0x0000);
  2174.                 //LCD_WriteReg(0x0080,0x0000);
  2175.                 //LCD_WriteReg(0x0081,0x0000);
  2176.                 LCD_WriteReg(0x0090,0X0011);
  2177.                 LCD_WriteReg(0x0092,0x0600);
  2178.                 LCD_WriteReg(0x0093,0x0402);
  2179.                 LCD_WriteReg(0x0094,0x0002);
  2180.                 HAL_Delay(20);
  2181.
  2182.                 LCD_WriteReg(0x0007,0x0001);
  2183.                 HAL_Delay(20);
  2184.                 LCD_WriteReg(0x0007,0x0061);
  2185.                 LCD_WriteReg(0x0007,0x0173);
  2186.
  2187.                 LCD_WriteReg(0x0020,0x0000);
  2188.                 LCD_WriteReg(0x0021,0x0000);
  2189.                 LCD_WriteReg(0x00,0x22);
  2190.         }else if(lcddev.id==0xC505)
  2191.         {
  2192.                 LCD_WriteReg(0x0000,0x0000);
  2193.                 LCD_WriteReg(0x0000,0x0000);
  2194.                 HAL_Delay(20);
  2195.                 LCD_WriteReg(0x0000,0x0000);
  2196.                 LCD_WriteReg(0x0000,0x0000);
  2197.                 LCD_WriteReg(0x0000,0x0000);
  2198.                 LCD_WriteReg(0x0000,0x0000);
  2199.                 LCD_WriteReg(0x00a4,0x0001);
  2200.                 HAL_Delay(20);
  2201.                 LCD_WriteReg(0x0060,0x2700);
  2202.                 LCD_WriteReg(0x0008,0x0806);
  2203.
  2204.                 LCD_WriteReg(0x0030,0x0703);//gamma setting
  2205.                 LCD_WriteReg(0x0031,0x0001);
  2206.                 LCD_WriteReg(0x0032,0x0004);
  2207.                 LCD_WriteReg(0x0033,0x0102);
  2208.                 LCD_WriteReg(0x0034,0x0300);
  2209.                 LCD_WriteReg(0x0035,0x0103);
  2210.                 LCD_WriteReg(0x0036,0x001F);
  2211.                 LCD_WriteReg(0x0037,0x0703);
  2212.                 LCD_WriteReg(0x0038,0x0001);
  2213.                 LCD_WriteReg(0x0039,0x0004);
  2214.
  2215.
  2216.
  2217.                 LCD_WriteReg(0x0090, 0x0015);        //80Hz
  2218.                 LCD_WriteReg(0x0010, 0X0410);        //BT,AP
  2219.                 LCD_WriteReg(0x0011,0x0247);        //DC1,DC0,VC
  2220.                 LCD_WriteReg(0x0012, 0x01BC);
  2221.                 LCD_WriteReg(0x0013, 0x0e00);
  2222.                 HAL_Delay(120);
  2223.                 LCD_WriteReg(0x0001, 0x0100);
  2224.                 LCD_WriteReg(0x0002, 0x0200);
  2225.                 LCD_WriteReg(0x0003, 0x1030);
  2226.
  2227.                 LCD_WriteReg(0x000A, 0x0008);
  2228.                 LCD_WriteReg(0x000C, 0x0000);
  2229.
  2230.                 LCD_WriteReg(0x000E, 0x0020);
  2231.                 LCD_WriteReg(0x000F, 0x0000);
  2232.                 LCD_WriteReg(0x0020, 0x0000);        //H Start
  2233.                 LCD_WriteReg(0x0021, 0x0000);        //V Start
  2234.                 LCD_WriteReg(0x002A,0x003D);        //vcom2
  2235.                 HAL_Delay(20);
  2236.                 LCD_WriteReg(0x0029, 0x002d);
  2237.                 LCD_WriteReg(0x0050, 0x0000);
  2238.                 LCD_WriteReg(0x0051, 0xD0EF);
  2239.                 LCD_WriteReg(0x0052, 0x0000);
  2240.                 LCD_WriteReg(0x0053, 0x013F);
  2241.                 LCD_WriteReg(0x0061, 0x0000);
  2242.                 LCD_WriteReg(0x006A, 0x0000);
  2243.                 LCD_WriteReg(0x0092,0x0300);
  2244.                 LCD_WriteReg(0x0093, 0x0005);
  2245.                 LCD_WriteReg(0x0007, 0x0100);
  2246.         }else if(lcddev.id==0x8989)//OK |/|/|
  2247.         {
  2248.                 LCD_WriteReg(0x0000,0x0001);//′ò¿a¾§Õñ
  2249.             LCD_WriteReg(0x0003,0xA8A4);//0xA8A4
  2250.             LCD_WriteReg(0x000C,0x0000);
  2251.             LCD_WriteReg(0x000D,0x080C);
  2252.             LCD_WriteReg(0x000E,0x2B00);
  2253.             LCD_WriteReg(0x001E,0x00B0);
  2254.             LCD_WriteReg(0x0001,0x2B3F);//Çy¶ˉêä3ö¿ØÖÆ320*240  0x6B3F
  2255.             LCD_WriteReg(0x0002,0x0600);
  2256.             LCD_WriteReg(0x0010,0x0000);
  2257.             LCD_WriteReg(0x0011,0x6078); //¶¨òåêy¾Y¸ñê½  16Î»é«                 oáÆá 0x6058
  2258.             LCD_WriteReg(0x0005,0x0000);
  2259.             LCD_WriteReg(0x0006,0x0000);
  2260.             LCD_WriteReg(0x0016,0xEF1C);
  2261.             LCD_WriteReg(0x0017,0x0003);
  2262.             LCD_WriteReg(0x0007,0x0233); //0x0233
  2263.             LCD_WriteReg(0x000B,0x0000);
  2264.             LCD_WriteReg(0x000F,0x0000); //é¨Ãè¿aê¼μØÖ·
  2265.             LCD_WriteReg(0x0041,0x0000);
  2266.             LCD_WriteReg(0x0042,0x0000);
  2267.             LCD_WriteReg(0x0048,0x0000);
  2268.             LCD_WriteReg(0x0049,0x013F);
  2269.             LCD_WriteReg(0x004A,0x0000);
  2270.             LCD_WriteReg(0x004B,0x0000);
  2271.             LCD_WriteReg(0x0044,0xEF00);
  2272.             LCD_WriteReg(0x0045,0x0000);
  2273.             LCD_WriteReg(0x0046,0x013F);
  2274.             LCD_WriteReg(0x0030,0x0707);
  2275.             LCD_WriteReg(0x0031,0x0204);
  2276.             LCD_WriteReg(0x0032,0x0204);
  2277.             LCD_WriteReg(0x0033,0x0502);
  2278.             LCD_WriteReg(0x0034,0x0507);
  2279.             LCD_WriteReg(0x0035,0x0204);
  2280.             LCD_WriteReg(0x0036,0x0204);
  2281.             LCD_WriteReg(0x0037,0x0502);
  2282.             LCD_WriteReg(0x003A,0x0302);
  2283.             LCD_WriteReg(0x003B,0x0302);
  2284.             LCD_WriteReg(0x0023,0x0000);
  2285.             LCD_WriteReg(0x0024,0x0000);
  2286.             LCD_WriteReg(0x0025,0x8000);
  2287.             LCD_WriteReg(0x004f,0);        //DDê×Ö·0
  2288.             LCD_WriteReg(0x004e,0);        //áDê×Ö·0
  2289.         }else if(lcddev.id==0x4531)//OK |/|/|
  2290.         {
  2291.                 LCD_WriteReg(0X00,0X0001);
  2292.                 HAL_Delay(10);
  2293.                 LCD_WriteReg(0X10,0X1628);
  2294.                 LCD_WriteReg(0X12,0X000e);//0x0006
  2295.                 LCD_WriteReg(0X13,0X0A39);
  2296.                 HAL_Delay(10);
  2297.                 LCD_WriteReg(0X11,0X0040);
  2298.                 LCD_WriteReg(0X15,0X0050);
  2299.                 HAL_Delay(10);
  2300.                 LCD_WriteReg(0X12,0X001e);//16
  2301.                 HAL_Delay(10);
  2302.                 LCD_WriteReg(0X10,0X1620);
  2303.                 LCD_WriteReg(0X13,0X2A39);
  2304.                 HAL_Delay(10);
  2305.                 LCD_WriteReg(0X01,0X0100);
  2306.                 LCD_WriteReg(0X02,0X0300);
  2307.                 LCD_WriteReg(0X03,0X1038);//¸Ä±ä·½ÏòμÄ
  2308.                 LCD_WriteReg(0X08,0X0202);
  2309.                 LCD_WriteReg(0X0A,0X0008);
  2310.                 LCD_WriteReg(0X30,0X0000);
  2311.                 LCD_WriteReg(0X31,0X0402);
  2312.                 LCD_WriteReg(0X32,0X0106);
  2313.                 LCD_WriteReg(0X33,0X0503);
  2314.                 LCD_WriteReg(0X34,0X0104);
  2315.                 LCD_WriteReg(0X35,0X0301);
  2316.                 LCD_WriteReg(0X36,0X0707);
  2317.                 LCD_WriteReg(0X37,0X0305);
  2318.                 LCD_WriteReg(0X38,0X0208);
  2319.                 LCD_WriteReg(0X39,0X0F0B);
  2320.                 LCD_WriteReg(0X41,0X0002);
  2321.                 LCD_WriteReg(0X60,0X2700);
  2322.                 LCD_WriteReg(0X61,0X0001);
  2323.                 LCD_WriteReg(0X90,0X0210);
  2324.                 LCD_WriteReg(0X92,0X010A);
  2325.                 LCD_WriteReg(0X93,0X0004);
  2326.                 LCD_WriteReg(0XA0,0X0100);
  2327.                 LCD_WriteReg(0X07,0X0001);
  2328.                 LCD_WriteReg(0X07,0X0021);
  2329.                 LCD_WriteReg(0X07,0X0023);
  2330.                 LCD_WriteReg(0X07,0X0033);
  2331.                 LCD_WriteReg(0X07,0X0133);
  2332.                 LCD_WriteReg(0XA0,0X0000);
  2333.         }else if(lcddev.id==0x4535)
  2334.         {
  2335.                 LCD_WriteReg(0X15,0X0030);
  2336.                 LCD_WriteReg(0X9A,0X0010);
  2337.                 LCD_WriteReg(0X11,0X0020);
  2338.                 LCD_WriteReg(0X10,0X3428);
  2339.                 LCD_WriteReg(0X12,0X0002);//16
  2340.                 LCD_WriteReg(0X13,0X1038);
  2341.                 HAL_Delay(40);
  2342.                 LCD_WriteReg(0X12,0X0012);//16
  2343.                 HAL_Delay(40);
  2344.                   LCD_WriteReg(0X10,0X3420);
  2345.                 LCD_WriteReg(0X13,0X3038);
  2346.                 HAL_Delay(70);
  2347.                 LCD_WriteReg(0X30,0X0000);
  2348.                 LCD_WriteReg(0X31,0X0402);
  2349.                 LCD_WriteReg(0X32,0X0307);
  2350.                 LCD_WriteReg(0X33,0X0304);
  2351.                 LCD_WriteReg(0X34,0X0004);
  2352.                 LCD_WriteReg(0X35,0X0401);
  2353.                 LCD_WriteReg(0X36,0X0707);
  2354.                 LCD_WriteReg(0X37,0X0305);
  2355.                 LCD_WriteReg(0X38,0X0610);
  2356.                 LCD_WriteReg(0X39,0X0610);
  2357.
  2358.                 LCD_WriteReg(0X01,0X0100);
  2359.                 LCD_WriteReg(0X02,0X0300);
  2360.                 LCD_WriteReg(0X03,0X1030);//¸Ä±ä·½ÏòμÄ
  2361.                 LCD_WriteReg(0X08,0X0808);
  2362.                 LCD_WriteReg(0X0A,0X0008);
  2363.                 LCD_WriteReg(0X60,0X2700);
  2364.                 LCD_WriteReg(0X61,0X0001);
  2365.                 LCD_WriteReg(0X90,0X013E);
  2366.                 LCD_WriteReg(0X92,0X0100);
  2367.                 LCD_WriteReg(0X93,0X0100);
  2368.                 LCD_WriteReg(0XA0,0X3000);
  2369.                 LCD_WriteReg(0XA3,0X0010);
  2370.                 LCD_WriteReg(0X07,0X0001);
  2371.                 LCD_WriteReg(0X07,0X0021);
  2372.                 LCD_WriteReg(0X07,0X0023);
  2373.                 LCD_WriteReg(0X07,0X0033);
  2374.                 LCD_WriteReg(0X07,0X0133);
  2375.         }
  2376.         LCD_Display_Dir(0);                         //ĬèÏÎaêúÆá
  2377.         LCD_LED_ON;                                            //μãáá±31a
  2378.         LCD_Clear(WHITE);
  2379. }
  2380. //ÇåÆáoˉêy
  2381. //color:òaÇåÆáμÄìî3äé«
  2382. void LCD_Clear(u16 color)
  2383. {
  2384.         u32 index=0;
  2385.         u32 totalpoint=lcddev.width;
  2386.         totalpoint*=lcddev.height;                         //μÃμ½×üμãêy
  2387.         if((lcddev.id==0X6804)&&(lcddev.dir==1))//6804oáÆáμÄê±oòìØêa′|àí
  2388.         {
  2389.                 lcddev.dir=0;
  2390.                 lcddev.setxcmd=0X2A;
  2391.                 lcddev.setycmd=0X2B;
  2392.                 LCD_SetCursor(0x00,0x0000);                //éèÖÃ1a±êλÖà
  2393.                 lcddev.dir=1;
  2394.                   lcddev.setxcmd=0X2B;
  2395.                 lcddev.setycmd=0X2A;
  2396.         }else LCD_SetCursor(0x00,0x0000);        //éèÖÃ1a±êλÖÃ
  2397.         LCD_WriteRAM_Prepare();                     //¿aê¼D′èëGRAM
  2398.         for(index=0;index<totalpoint;index++)
  2399.         {
  2400.                 LCD->LCD_RAM=color;
  2401.         }
  2402. }
  2403. //ÔúÖ¸¶¨ÇøóòÄúìî3äμ¥¸öÑÕé«
  2404. //(sx,sy),(ex,ey):ìî3侨DζԽÇ×ø±ê,Çøóò′óD¡Îa:(ex-sx+1)*(ey-sy+1)
  2405. //color:òaìî3äμÄÑÕé«
  2406. void LCD_Fill(u16 sx,u16 sy,u16 ex,u16 ey,u16 color)
  2407. {
  2408.         u16 i,j;
  2409.         u16 xlen=0;
  2410.         u16 temp;
  2411.         if((lcddev.id==0X6804)&&(lcddev.dir==1))        //6804oáÆáμÄê±oòìØêa′|àí
  2412.         {
  2413.                 temp=sx;
  2414.                 sx=sy;
  2415.                 sy=lcddev.width-ex-1;
  2416.                 ex=ey;
  2417.                 ey=lcddev.width-temp-1;
  2418.                 lcddev.dir=0;
  2419.                 lcddev.setxcmd=0X2A;
  2420.                 lcddev.setycmd=0X2B;
  2421.                 LCD_Fill(sx,sy,ex,ey,color);
  2422.                 lcddev.dir=1;
  2423.                   lcddev.setxcmd=0X2B;
  2424.                 lcddev.setycmd=0X2A;
  2425.         }else
  2426.         {
  2427.                 xlen=ex-sx+1;
  2428.                 for(i=sy;i<=ey;i++)
  2429.                 {
  2430.                          LCD_SetCursor(sx,i);                                      //éèÖÃ1a±êλÖÃ
  2431.                         LCD_WriteRAM_Prepare();                             //¿aê¼D′èëGRAM
  2432.                         for(j=0;j<xlen;j++)LCD_WR_DATA(color);        //éèÖÃ1a±êλÖà
  2433.                 }
  2434.         }
  2435. }
  2436. //ÔúÖ¸¶¨ÇøóòÄúìî3äÖ¸¶¨ÑÕé«¿é
  2437. //(sx,sy),(ex,ey):ìî3侨DζԽÇ×ø±ê,Çøóò′óD¡Îa:(ex-sx+1)*(ey-sy+1)
  2438. //color:òaìî3äμÄÑÕé«
  2439. void LCD_Color_Fill(u16 sx,u16 sy,u16 ex,u16 ey,u16 *color)
  2440. {
  2441.         u16 height,width;
  2442.         u16 i,j;
  2443.         width=ex-sx+1;                         //μÃμ½ìî3äμÄ¿í¶è
  2444.         height=ey-sy+1;                        //¸ß¶è
  2445.         for(i=0;i<height;i++)
  2446.         {
  2447.                 LCD_SetCursor(sx,sy+i);           //éèÖÃ1a±êλÖÃ
  2448.                 LCD_WriteRAM_Prepare();     //¿aê¼D′èëGRAM
  2449.                 for(j=0;j<width;j++)LCD->LCD_RAM=color[i*height+j];//D′èëêy¾Y
  2450.         }
  2451. }
  2452. //»-Ïß
  2453. //x1,y1:Æeμã×ø±ê
  2454. //x2,y2:ÖÕμã×ø±ê
  2455. void LCD_DrawLine(u16 x1, u16 y1, u16 x2, u16 y2)
  2456. {
  2457.         u16 t;
  2458.         int xerr=0,yerr=0,delta_x,delta_y,distance;
  2459.         int incx,incy,uRow,uCol;
  2460.         delta_x=x2-x1; //¼ÆËã×ø±êÔöá¿
  2461.         delta_y=y2-y1;
  2462.         uRow=x1;
  2463.         uCol=y1;
  2464.         if(delta_x>0)incx=1; //éèÖÃμ¥2½·½Ïò
  2465.         else if(delta_x==0)incx=0;//′1Ö±Ïß
  2466.         else {incx=-1;delta_x=-delta_x;}
  2467.         if(delta_y>0)incy=1;
  2468.         else if(delta_y==0)incy=0;//ˮƽÏß
  2469.         else{incy=-1;delta_y=-delta_y;}
  2470.         if( delta_x>delta_y)distance=delta_x; //ѡ衻ù±¾Ôöá¿×ø±êÖá
  2471.         else distance=delta_y;
  2472.         for(t=0;t<=distance+1;t++ )//»-Ïßêä3ö
  2473.         {
  2474.                 LCD_DrawPoint(uRow,uCol);//»-μã
  2475.                 xerr+=delta_x ;
  2476.                 yerr+=delta_y ;
  2477.                 if(xerr>distance)
  2478.                 {
  2479.                         xerr-=distance;
  2480.                         uRow+=incx;
  2481.                 }
  2482.                 if(yerr>distance)
  2483.                 {
  2484.                         yerr-=distance;
  2485.                         uCol+=incy;
  2486.                 }
  2487.         }
  2488. }
  2489. //»-¾ØDΠ
  2490. //(x1,y1),(x2,y2):¾ØDÎμĶԽÇ×ø±ê
  2491. void LCD_DrawRectangle(u16 x1, u16 y1, u16 x2, u16 y2)
  2492. {
  2493.         LCD_DrawLine(x1,y1,x2,y1);
  2494.         LCD_DrawLine(x1,y1,x1,y2);
  2495.         LCD_DrawLine(x1,y2,x2,y2);
  2496.         LCD_DrawLine(x2,y1,x2,y2);
  2497. }
  2498. //ÔúÖ¸¶¨Î»Öû-ò»¸öÖ¸¶¨′óD¡μÄÔ2
  2499. //(x,y):ÖDDÄμã
  2500. //r    :°ë¾¶
  2501. void Draw_Circle(u16 x0,u16 y0,u8 r)
  2502. {
  2503.         int a,b;
  2504.         int di;
  2505.         a=0;b=r;
  2506.         di=3-(r<<1);             //ÅD¶ÏϸöμãλÖÃμıêÖ¾
  2507.         while(a<=b)
  2508.         {
  2509.                 LCD_DrawPoint(x0+a,y0-b);             //5
  2510.                 LCD_DrawPoint(x0+b,y0-a);             //0
  2511.                 LCD_DrawPoint(x0+b,y0+a);             //4
  2512.                 LCD_DrawPoint(x0+a,y0+b);             //6
  2513.                 LCD_DrawPoint(x0-a,y0+b);             //1
  2514.                 LCD_DrawPoint(x0-b,y0+a);
  2515.                 LCD_DrawPoint(x0-a,y0-b);             //2
  2516.                   LCD_DrawPoint(x0-b,y0-a);             //7
  2517.                 a++;
  2518.                 //ê1óÃBresenhamËã·¨»-Ô2
  2519.                 if(di<0)di +=4*a+6;
  2520.                 else
  2521.                 {
  2522.                         di+=10+4*(a-b);
  2523.                         b--;
  2524.                 }
  2525.         }
  2526. }
  2527. //ÔúÖ¸¶¨Î»ÖÃÏÔê¾ò»¸ö×Ö·û
  2528. //x,y:Æeê¼×ø±ê
  2529. //num:òaÏÔê¾μÄ×Ö·û:" "--->"~"
  2530. //size:×Öìå′óD¡ 12/16
  2531. //mode:μt¼ó·½ê½(1)»1êÇ·Çμt¼ó·½ê½(0)
  2532. void LCD_ShowChar(u16 x,u16 y,u8 num,u8 size,u8 mode)
  2533. {
  2534.     u8 temp,t1,t;
  2535.         u16 y0=y;
  2536.         u16 colortemp=POINT_COLOR;
  2537.         //éèÖÃ′°¿ú
  2538.         num=num-' ';//μÃμ½Æ«òÆoóμÄÖμ
  2539.         if(!mode) //·Çμt¼ó·½ê½
  2540.         {
  2541.             for(t=0;t<size;t++)
  2542.             {
  2543.                         if(size==12)temp=asc2_1206[num][t];  //μ÷óÃ1206×Öìå
  2544.                         else temp=asc2_1608[num][t];                 //μ÷óÃ1608×Öìå
  2545.                 for(t1=0;t1<8;t1++)
  2546.                         {
  2547.                         if(temp&0x80)POINT_COLOR=colortemp;
  2548.                                 else POINT_COLOR=BACK_COLOR;
  2549.                                 LCD_DrawPoint(x,y);
  2550.                                 temp<<=1;
  2551.                                 y++;
  2552.                                 if(x>=lcddev.width){POINT_COLOR=colortemp;return;}//3¬ÇøóòáË
  2553.                                 if((y-y0)==size)
  2554.                                 {
  2555.                                         y=y0;
  2556.                                         x++;
  2557.                                         if(x>=lcddev.width){POINT_COLOR=colortemp;return;}//3¬ÇøóòáË
  2558.                                         break;
  2559.                                 }
  2560.                         }
  2561.             }
  2562.         }else//μt¼ó·½ê½
  2563.         {
  2564.             for(t=0;t<size;t++)
  2565.             {
  2566.                         if(size==12)temp=asc2_1206[num][t];  //μ÷óÃ1206×Öìå
  2567.                         else temp=asc2_1608[num][t];                 //μ÷óÃ1608×Öìå
  2568.                 for(t1=0;t1<8;t1++)
  2569.                         {
  2570.                         if(temp&0x80)LCD_DrawPoint(x,y);
  2571.                                 temp<<=1;
  2572.                                 y++;
  2573.                                 if(x>=lcddev.height){POINT_COLOR=colortemp;return;}//3¬ÇøóòáË
  2574.                                 if((y-y0)==size)
  2575.                                 {
  2576.                                         y=y0;
  2577.                                         x++;
  2578.                                         if(x>=lcddev.width){POINT_COLOR=colortemp;return;}//3¬ÇøóòáË
  2579.                                         break;
  2580.                                 }
  2581.                         }
  2582.             }
  2583.         }
  2584.         POINT_COLOR=colortemp;
  2585. }
  2586. //m^noˉêy
  2587. //·μ»ØÖμ:m^n′η½.
  2588. u32 LCD_Pow(u8 m,u8 n)
  2589. {
  2590.         u32 result=1;
  2591.         while(n--)result*=m;
  2592.         return result;
  2593. }
  2594. //ÏÔê¾êy×Ö,¸ßλÎa0,Ôò2»ÏÔê¾
  2595. //x,y :Æeμã×ø±ê
  2596. //len :êy×ÖμÄλêy
  2597. //size:×Öìå′óD¡
  2598. //color:ÑÕé«
  2599. //num:êyÖμ(0~4294967295);
  2600. void LCD_ShowNum(u16 x,u16 y,u32 num,u8 len,u8 size)
  2601. {
  2602.         u8 t,temp;
  2603.         u8 enshow=0;
  2604.         for(t=0;t<len;t++)
  2605.         {
  2606.                 temp=(num/LCD_Pow(10,len-t-1))%10;
  2607.                 if(enshow==0&&t<(len-1))
  2608.                 {
  2609.                         if(temp==0)
  2610.                         {
  2611.                                 LCD_ShowChar(x+(size/2)*t,y,' ',size,0);
  2612.                                 continue;
  2613.                         }else enshow=1;
  2614.
  2615.                 }
  2616.                  LCD_ShowChar(x+(size/2)*t,y,temp+'0',size,0);
  2617.         }
  2618. }
  2619. //ÏÔê¾êy×Ö,¸ßλÎa0,»1êÇÏÔê¾
  2620. //x,y:Æeμã×ø±ê
  2621. //num:êyÖμ(0~999999999);
  2622. //len:3¤¶è(¼′òaÏÔê¾μÄλêy)
  2623. //size:×Öìå′óD¡
  2624. //mode:
  2625. //[7]:0,2»ìî3ä;1,ìî3ä0.
  2626. //[6:1]:񜠓
  2627. //[0]:0,·Çμt¼óÏÔê¾;1,μt¼óÏÔê¾.
  2628. void LCD_ShowxNum(u16 x,u16 y,u32 num,u8 len,u8 size,u8 mode)
  2629. {
  2630.         u8 t,temp;
  2631.         u8 enshow=0;
  2632.         for(t=0;t<len;t++)
  2633.         {
  2634.                 temp=(num/LCD_Pow(10,len-t-1))%10;
  2635.                 if(enshow==0&&t<(len-1))
  2636.                 {
  2637.                         if(temp==0)
  2638.                         {
  2639.                                 if(mode&0X80)LCD_ShowChar(x+(size/2)*t,y,'0',size,mode&0X01);
  2640.                                 else LCD_ShowChar(x+(size/2)*t,y,' ',size,mode&0X01);
  2641.                                 continue;
  2642.                         }else enshow=1;
  2643.
  2644.                 }
  2645.                  LCD_ShowChar(x+(size/2)*t,y,temp+'0',size,mode&0X01);
  2646.         }
  2647. }
  2648. //ÏÔê¾×Ö·û′®
  2649. //x,y:Æeμã×ø±ê
  2650. //width,height:Çøóò′óD¡
  2651. //size:×Öìå′óD¡
  2652. //*p:×Ö·û′®Æeê¼μØÖ·
  2653. void LCD_ShowString(u16 x,u16 y,u16 width,u16 height,u8 size,u8 *p)
  2654. {
  2655.         u8 x0=x;
  2656.         width+=x;
  2657.         height+=y;
  2658.     while((*p<='~')&&(*p>=' '))//ÅD¶ÏêÇ2»êÇ·Ç·¨×Ö·û!
  2659.     {
  2660.         if(x>=width){x=x0;y+=size;}
  2661.         if(y>=height)break;//íË3ö
  2662.         LCD_ShowChar(x,y,*p,size,0);
  2663.         x+=size/2;
  2664.         p++;
  2665.     }
  2666. }
