- #include "headfile.h"
- #include "KEA128_uart.h"
- #include "KEA128_qiu.h"
- #include "filter.h"
- #include "All_Init.h"
- #define Speed_set 0
- #define zhong 2250
- struct PID_Typedef //PID結(jié)構(gòu)體
- float P;
- float I;
- float D;
- int Error;
- int PreError;
- int PreDError;//
- int d_error;
- int dd_error;
- int Output;
- int target;
- int measure;
- }PID_Typedef;
- float Kp,Kd,Ks;
- extern uint16 val_get_L;//左側(cè)電感電壓值 PTA8
- extern uint16 val_get_R;//右側(cè)電感電壓值 PTA7
- extern uint16 aveL,aveR;
- extern float val_dev_to_one,val_sum_to_one,aveL_to_one,aveR_to_one;
- //extern uint16 val_get_M;
- extern uint8 time_flag,dir_time;
- extern uint8 read_bianmaqi;
- uint8 * itoa(int32 num);
- uint16 SpeedSumL,SpeedSumR;
- uint16 SpeedL,SpeedR;
- uint16 uart_cnt=0;
- uint16 sum_cnt;
- double Speed_L;
- double Speed_R;
- float ActualErr=0.0;
- float Err_L;
- float Err_N;
- float Error=0.0;
- void speedout();
- //void differential();
- void ReadBianMaQi();
- void Ad_deal();
- void MOTOR_PID(struct PID_Typedef *PID,int target,int measure);
- void PID_init();//pid參數(shù)賦值
- struct PID_Typedef Left;
- struct PID_Typedef Right;
- int main(void)
- get_clk(); //獲取時(shí)鐘頻率 必須執(zhí)行
- ALL_Init();
- PID_init();
- pit_init_ms(pit0,1); //初始化pit0 周期設(shè)置為10ms
- set_irq_priority(PIT_CH0_IRQn,1); //設(shè)置pit0優(yōu)先級(jí)
- enable_irq(PIT_CH0_IRQn); //開啟pit0中斷
- EnableInterrupts;
- for(;;)
- ReadBianMaQi();//讀取脈沖10讀取一次,
- speedout(); //40ms進(jìn)行一次控速
- if(time_flag==50)
- time_flag=0;
- //uart_cnt++;
- //if(uart_cnt>=10)
- //uart_cnt=0;
- if(read_bianmaqi>=10)
- {//10ms讀取一次編碼器
- read_bianmaqi=0;
- adc_get();
- filter1();
- adc_to_one();
- Ad_deal();
- SpeedL = ftm_count_get(ftm1);//讀取脈沖
- ftm_count_clean(ftm1);//清除寄存器
- SpeedR = ftm_count_get(ftm0);//讀取脈沖1
- ftm_count_clean(ftm0);//清楚寄存器
- SpeedSumL +=SpeedL;
- SpeedSumR +=SpeedR;
- SpeedL=0;
- SpeedR=0;
- void speedout()
- if(sum_cnt>=40)
- {//40ms進(jìn)行一次速度控制
- sum_cnt=0;
- Left.measure=SpeedSumL;
- Right.measure=SpeedSumR;
- SpeedSumL =0;
- SpeedSumR =0;
- // Left.target=200;
- // Right.target=200;
- if( ActualErr>0)//在一定的范圍內(nèi)才加差速
- Right.target=Speed_set-ActualErr*Ks;
- Left.target=Speed_set+ActualErr;
- else
- Left.target=Speed_set+ActualErr*Ks;
- Right.target=Speed_set-ActualErr;
- if(Left.target > 700) //限幅防止輸出過大
- Left.target= 700;
- if(Left.target <-700) //限幅防止輸出過大
- Left.target=-700;
- if(Right.target > 700)
- Right.target= 700;
- if(Right.target <-700)
- Right.target=-700;
- // MOTOR_PID(&Left,Left.target,Left.measure);
- // MOTOR_PID(&Right,Right.target,Right.measure);
- Left.Output=Left.target;
- Right.Output=Right.target;
- if(Left.Output>=900)//限上值 但是在這里不管下限 在計(jì)算里面管
- Left.Output = 900;
- else if(Left.Output<=-900)
- Left.Output =-900;
- if(Right.Output>=900)//限上值 但是在這里不管下限 在計(jì)算里面管
- Right.Output = 900;
- else if(Right.Output<=-900)
- Right.Output =-900;
- if(Left.Output>=0)
- Left.Output=(uint16)Left.Output+0;
- ftm_pwm_duty(ftm2,ftm_ch2,0);
- ftm_pwm_duty(ftm2,ftm_ch3,Left.Output);
- else
- Left.Output=(uint16)(-Left.Output)+0;
- ftm_pwm_duty(ftm2,ftm_ch3,0);
- ftm_pwm_duty(ftm2,ftm_ch2,Left.Output);
- if(Right.Output>=0)
- Right.Output=(uint16)Right.Output+0;
- ftm_pwm_duty(ftm2,ftm_ch0,0);
- ftm_pwm_duty(ftm2,ftm_ch1,Right.Output);
- else
- Right.Output=(uint16)(-Right.Output)+0;
- ftm_pwm_duty(ftm2,ftm_ch1,0);
- ftm_pwm_duty(ftm2,ftm_ch0,Right.Output);
- /*ftm_pwm_duty(ftm2,ftm_ch0,Left.Output); //,設(shè)置占空比,,右電機(jī)正轉(zhuǎn),,在系統(tǒng)配置中已經(jīng)將PWMIO口改成C0C1C2C3
- ftm_pwm_duty(ftm2,ftm_ch2,0); //左電機(jī)正轉(zhuǎn)
- ftm_pwm_duty(ftm2,ftm_ch3,Right.Output); */
- uart_cnt++;
- if(uart_cnt>=25)
- {//4*25=1000 1秒輸出一次上位機(jī),方便觀察
- uart_cnt=0;
- uart_putstr(uart2,"L編碼器目標(biāo)");
- uart_putstr(uart2,itoa(Left.target));
- uart_putstr(uart2,"\t");
- uart_putstr(uart2,"R編碼器目標(biāo)");
- uart_putstr(uart2,itoa(Right.target));
- uart_putstr(uart2,"\n");
- uart_putstr(uart2,"L編碼器速度");
- uart_putstr(uart2,itoa(Left.measure));
- uart_putstr(uart2,"R編碼器速度");
- uart_putstr(uart2,itoa(Right.measure));
- uart_putstr(uart2,"左邊感量");
- uart_putstr(uart2,itoa(aveL));
- uart_putstr(uart2,"右邊感量");
- uart_putstr(uart2,itoa(aveR));
- uart_putstr(uart2,"LDuty");
- uart_putstr(uart2,itoa(Left.Output));
- uart_putstr(uart2,"\t\t");
- uart_putstr(uart2,"RDuty");
- uart_putstr(uart2,itoa(Right.Output));
- //整數(shù)轉(zhuǎn)換為字符串(輸入整數(shù),返回字符串地址)
- int32 i=0,isNegative=0;
- static uint8 s[15]; //必須是全局變量或者是靜態(tài)變量
- //如果是負(fù)數(shù),先轉(zhuǎn)為正數(shù)
- if((isNegative=num) < 0) num = -num;
- //從個(gè)位開始變?yōu)樽址,直到最高位,最后?yīng)該反轉(zhuǎn)
- do
- s[i++] = num%10 + '0';
- num /= 10;
- }while(num > 0);
- //如果是負(fù)數(shù),補(bǔ)上負(fù)號(hào)
- if(isNegative < 0) s[i++] = '-';
- //最后加上字符串結(jié)束符
- s[i] = '\0';
- /******翻轉(zhuǎn)字符串******/
- //p指向s的頭部
- uint8 *p = s;
- //q指向s的尾部
- uint8 *q = s;
- while(*q) ++q;
- q--;
- //交換移動(dòng)指針,直到p和q交叉
- uint8 temp;
- while(q > p)
- temp = *p;
- *p++ = *q;
- *q-- = temp;
- return s;
- /*pid 調(diào)電機(jī)*/
- /*****差速函數(shù)******/
- /*void differential()
- int chasu=0;
- errorL=aveL-zhong;
- errorR=aveR-zhong;
- tempL=errorL*100;
- tempL=tempL/zhong;
- tempR=errorR*100;
- tempR=tempR/zhong;
- Right.target=(int)(speed_set-error*speed_set/100);
- Left.target=(int)(speed_set-error*speed_set/100);
- /* if( ActualErr>0)//在一定的范圍內(nèi)才加差速
- Right.target=(int)speed_set+ ActualErr;
- Left.target=(int)speed_set-ActualErr*Ks;
- else
- Right.target=(int)speed_set-ActualErr;
- Left.target=(int)speed_set+ ActualErr*Ks;
- if( Left.target> 700) //限幅防止輸出過大
- Left.target= 700;
- if( Left.target <-700) //限幅防止輸出過大
- Left.target=-700;
- if( Right.target > 700)
- if( Right.target <-700)
- //給各自的target賦值
- /******電機(jī)PID部分程序**********/
- /*增量式 pid ,慢慢調(diào) */
- void MOTOR_PID(struct PID_Typedef *PID,int target,int measure) //target目標(biāo)期望值,measure目標(biāo)測(cè)量值,輸出占空比改變量
- PID->Error=target - measure; //計(jì)算偏差。
- PID->d_error = PID->Error - PID->PreError; //偏差計(jì)算(比例)
- PID->dd_error = PID->d_error - PID-> PreDError; //偏差計(jì)算(微分)
- PID->PreError = PID->Error; //存儲(chǔ)當(dāng)前偏差
- PID->PreDError = PID->d_error;
- if ((PID->Error > -5) && (PID->Error <5)) // 設(shè)置調(diào)節(jié)死區(qū) 編碼器返回的值跟目標(biāo)值在小誤差范圍內(nèi)不調(diào)節(jié) 防止超調(diào)過度起反作用
- ; // 不執(zhí)行PID調(diào)節(jié)
- else
- PID->Output+= ((PID->P* PID->d_error) + (PID->I * PID->Error) + (PID->D * PID->dd_error));
- if(PID->Output>=900)//限上值 但是在這里不管下限 在計(jì)算里面管
- PID->Output = 900;
- else if(PID->Output<=0)
- PID->Output =0;
- void Ad_deal()
- float IncrementErr;
- Error=val_dev_to_one*100/pow(val_sum_to_one,1.5); //水平電感偏差
- if(Error>=100)
- Error=100;
- if(Error<=-100)
- Error=-100;
- // Error=(sqrt(AD3)-sqrt(AD1))/(AD1+AD3)*3800;
- /****************增量式PD****************/
- IncrementErr=Kp*(Error-Err_N)+Kd*(Error-2*Err_N+Err_L); //增量式PD
- ActualErr+=IncrementErr; //
- Err_L=Err_N; //
- Err_N=Error;
- // Lost_Err(); //防丟線程序
- /*****************兩輪差速效果*****************/
- if(Error<=0) //計(jì)算兩輪差速效果
- Error=-Error; //
- Ks=Error/10; //
- if(Ks>1.3) //
- Ks=1.3; //0.78 //增大后內(nèi)輪減速明顯
- void PID_init()
- Left.P = 0.4; //左輪P
- Left.I = 0.28; //左輪I
- Left.D = 0; //
- Right.P = 0.4; //右輪P
- Right.I = 0.28; //右輪I
- Right.D = 0; //右輪D
- /* 電感差速 */
- Error=0.0;
- Err_N=0.0;
- Err_L=0.0;
- Kp=5.0;
- Kd=20.0;
- /*左右輪差速效果*/
- Ks=0.0; //在arithmetic.c中賦值Error/10
復(fù)制代碼 |
