查看: 2520|回復(fù): 5
我又來問這段程序是什么意思了
ID:386561 發(fā)表于 2018-8-21 19:13 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
#include <intrins.h>
#include "delay.h"
sbit RS = P2^4;
sbit RW = P2^5;
sbit E  = P2^6;
sbit RES = P2^3;
sbit PSB = P2^1;
sbit PAUSE = P3^0;
#define DataPort P0        //MCU P0<------> LCM
                    檢測忙位
void Check_Busy()
    RS=0;
    RW=1;
    E=1;
    DataPort=0xff;
    while((DataPort&0x80)==0x80);//忙則等待
    E=0;
                   寫命令
void Write_Cmd(unsigned char Cmd)
        Check_Busy();
        RS=0;
        RW=0;
        E=1;
        DataPort=Cmd;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                    寫數(shù)據(jù)
void Write_Data(unsigned char Data)
        Check_Busy();
        RS=1;
        RW=0;
        E=1;
        DataPort=Data;
        DelayUs2x(5);
        E=0;
        DelayUs2x(5);
                   液晶屏初始化
void Init_ST7920()
   DelayMs(40);           //大于40MS的延時程序
   PSB=1;                 //設(shè)置為8BIT并口工作模式
   DelayMs(1);            //延時
   RES=0;                 //復(fù)位
   DelayMs(1);            //延時
   RES=1;                 //復(fù)位置高
   DelayMs(10);
   Write_Cmd(0x30);       //選擇基本指令集
   DelayUs2x(50);         //延時大于100us
   Write_Cmd(0x30);       //選擇8bit數(shù)據(jù)流
   DelayUs2x(20);         //延時大于37us
   Write_Cmd(0x0c);       //開顯示(無游標、不反白)
   Write_Cmd(0x01);       //清除顯示,并且設(shè)定地址指針為00H
   DelayMs(15);           //延時大于10ms
   Write_Cmd(0x06);       //指定在資料的讀取及寫入時,設(shè)定游標的移動方向及指定顯示的移位,光標從右向左加1位移動
                   用戶自定義字符
void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
                   顯示字符串
x:橫坐標值,范圍0~8
y:縱坐標值,范圍1~4
void LCD_PutString(unsigned char x,unsigned char y,unsigned char code *s)
switch(y)
          case 1: Write_Cmd(0x80+x);break;
          case 2: Write_Cmd(0x90+x);break;
          case 3: Write_Cmd(0x88+x);break;
          case 4: Write_Cmd(0x98+x);break;
      default:break;
while(*s>0)
      Write_Data(*s);
      s++;
      DelayUs2x(50);
                      清屏
void ClrScreen()
   Write_Cmd(0x01);
   DelayMs(15);
                 主程序
main()
  unsigned char i;
   CGRAM();     //寫入自定義字符
      Init_ST7920();   //初始化
      LCD_PutString(0,1,"重量:");
          LCD_PutString(0,2,"單價:");
          LCD_PutString(0,3,"總價:");
      LCD_PutString(0,4,"");
          for(i=0;i<30;i++)
          DelayMs(200);
所以void CGRAM()
     int i;
     Write_Cmd(0x30);
     Write_Cmd(0x40);
}   這一串有什么用?對程序的影響是啥?
無效樓層,該帖已經(jīng)被刪除
ID:277550 發(fā)表于 2018-8-21 20:32 | 只看該作者
main()
  unsigned char i;
   CGRAM();     //寫入自定義字符------------------------看這行說明
整個程序,應(yīng)該是模擬穩(wěn)重、計算總價,顯示在LCD屏
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:387076 發(fā)表于 2018-8-21 20:33 | 只看該作者
這個需要查看屏幕的datasheet的,估計是屏幕的相關(guān)指令。
類似1602的write_com(0x38);//設(shè)置16X2顯示,顯示5X7點陣,8位數(shù)據(jù)接口
還有相關(guān)寄存器的設(shè)置 比如光標這樣的
參與人數(shù) 1黑幣 +50 收起 理由
admin + 50 回帖助人的獎勵!
ID:386561 發(fā)表于 2018-8-21 21:56 | 只看該作者
devcang 發(fā)表于 2018-8-21 20:32
main()
  unsigned char i;
我確實想寫這么個程序,但是我是直接改的,所以這一句我不太懂,但是那個寫入自定義我還是不懂,他這是定義了什么?
ID:386561 發(fā)表于 2018-8-21 21:57 | 只看該作者
Hank丶Huang 發(fā)表于 2018-8-21 20:33
類似1602的write_com(0x38);//設(shè)置16X2顯示,顯 ...
偶  謝謝 ,所以這玩意真的是設(shè)置大小的。。。。。。
ID:384109 發(fā)表于 2018-8-21 22:56 | 只看該作者
這個是對帶字庫的12864液晶的設(shè)置參數(shù),帶字庫的12864液晶有多種工作模式,需要選擇,也可以切換
