查看: 4764|回復: 0
AD834引腳圖與電路圖及pdf資料手冊下載
ID:174732 發表于 2018-8-19 16:08 | 顯示全部樓層 |閱讀模式
AD834電路原理圖如下:
AD834引腳圖:
AD834管腳功能定義:
The AD834 is a monolithic, laser-trimmed four-quadrant analog
multiplier intended for use in high frequency applications, with
a transconductance bandwidth (RL = 50 Ω) in excess of 500 MHz
from either of the differential voltage inputs. In multiplier
modes, the typical total full-scale error is 0.5%, dependent on
the application mode and the external circuitry. Performance
is relatively insensitive to temperature and supply variations due
to the use of stable biasing based on a band gap reference generator
and other design features.
To preserve the full bandwidth potential of the high speed bipolar
process used to fabricate the AD834, the outputs appear as a
differential pair of currents at open collectors. To provide a
single-ended ground referenced voltage output, some form of
external current-to-voltage conversion is needed. This may take
the form of a wideband transformer, balun, or active circuitry
such as an op amp. In some applications (such as power measure-
ment), the subsequent signal processing may not need to have
high bandwidth
完整的pdf格式文檔51黑下載地址:
AD834A.pdf
53.38 KB, 下載次數: 10, 下載積分: 黑幣 -5
AD834.pdf
344.52 KB, 下載次數: 6, 下載積分: 黑幣 -5
MT-080_cn.pdf
634.35 KB, 下載次數: 6, 下載積分: 黑幣 -5
MT-079_cn.pdf
742.27 KB, 下載次數: 5, 下載積分: 黑幣 -5
AD834B.pdf
55.33 KB, 下載次數: 7, 下載積分: 黑幣 -5
