查看: 1684|回復: 0
超聲波PIC16F877 + HC-SR04 + LCD03
ID:387542 發表于 2018-8-18 13:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
//     PIC16F877 + HC-SR04 + LCD03 example
//     Written October 2008 , using HITECH PIC16 compiler
//   Note - assumes a 20MHz crystal, which is 5MHz timer clock
//   A 1:4 prescaler is used to give a 1.25MHz timer count (0.8uS per tick)
//     This code is Freeware - Use it for any purpose you like.
#include <pic.h>
#include <stdio.h>
__CONFIG(0x3b32);
#define trig RB0
#define echo RB1
void clrscn(void);       // prototypes
void cursor(char pos);
void print(char *p);
void setup(void);
unsigned int get_srf04(void);
char s[21];          // buffer used to hold text to print
void main(void)
unsigned int range;
setup();          // sets up the PIC16F877 I2C port
clrscn();         // clears the LCD03 disply
cursor(2);         // sets cursor to 1st row of LCD03
sprintf(s,"SRF04 Ranger Test");  // text, printed into our buffer
print(s);         // send it to the LCD03
while(1) {         // loop forever
  range = get_srf04();     // get range from srf04 (round trip flight time in 0.8uS units)
  cursor(24);        // sets cursor to 2nd row of LCD03
  sprintf(s,"Range = %dcm  ", range/72); // convert to cm
  cursor(44);        // sets cursor to 3rd row of LCD03
  sprintf(s,"Range = %dinch  ", range/185); // convert to inches
  TMR1H = 0;        // 52mS delay - this is so that the SRF04 ranging is not too rapid
  TMR1L = 0;        // and the previous pulse has faded away before we start the next one
  T1CON = 0x21;       // 1:4 prescale and running
  TMR1IF = 0;
  while(!TMR1IF);      // wait for delay time
  TMR1ON = 0;        // stop timer
TMR1H = 0xff;      // prepare timer for 10uS pulse
TMR1L = -14;
TMR1IF = 0;
trig = 1;       // start trigger pulse
while(!TMR1IF);     // wait 10uS
trig = 0;       // end trigger pulse
TMR1H = 0;       // prepare timer to measure echo pulse
TMR1L = 0;
T1CON = 0x20;      // 1:4 prescale but not running yet
TMR1IF = 0;
while(!echo && !TMR1IF);  // wait for echo pulse to start (go high)
TMR1ON = 1;       // start timer to measure pulse
while(echo && !TMR1IF);   // wait for echo pulse to stop (go low)
return (TMR1H<<8)+TMR1L;  // TMR1H:TMR1L contains flight time of the pulse in 0.8uS units
void clrscn(void)
SEN = 1;        // send start bit
while(SEN);       // and wait for it to clear
SSPIF = 0;
SSPBUF = 0xc6;      // LCD02 I2C address
while(!SSPIF);      // wait for interrupt
SSPIF = 0;       // then clear it.
SSPBUF = 0;       // address of register to write to
while(!SSPIF);      //
SSPIF = 0;       //
SSPBUF = 12;      // clear screen
while(!SSPIF);      //
SSPIF = 0;       //
SSPBUF = 4;       // cursor off
while(!SSPIF);      //
SSPIF = 0;       //
PEN = 1;        // send stop bit
while(PEN);       //
SSPIF = 0;
while(!SSPIF);      //
SSPIF = 0;       //
SSPBUF = 2;       // set cursor
while(!SSPIF);      //
SSPIF = 0;       //
SSPBUF = pos;      //
while(!SSPIF);      //
SSPIF = 0;       //
while(PEN);       //
void print(char *p)
SSPIF = 0;
while(!SSPIF);    //
SSPIF = 0;     //
while(*p) {
  SSPBUF = *p++;   // write the data
  while(!SSPIF);   //
  SSPIF = 0;    //
while(PEN);     //
void setup(void)
unsigned long x;
TRISB = 0xfe;    // RB0 (trig) is output
PORTB = 0xfe;    // and starts low
TRISC = 0xff;
PORTC = 0xff;
SSPSTAT = 0x80;
SSPCON = 0x38;
SSPCON2 = 0x00;
SSPADD = 50;    // SCL = 91khz with 20Mhz Osc
for(x=0; x<300000L; x++);  // wait for LCD03 to initialise
