查看: 2135|回復: 1
基于stm32正弦波發生器
ID:387450 發表于 2018-8-18 08:21 | 顯示全部樓層 |閱讀模式
#include "led.h"
#include "delay.h"
#include "sys.h"
#include "usart.h"
#include "lcd.h"
#include "adc.h"
#include "key.h"
#include "dac.h"
int main(void)
        u16 adcx;
        float temp;
         u8 t=0;
        u16 dacval=0;
        u8 key;
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設置中斷優先級分組2
        delay_init();                     //延時函數初始化
        uart_init(9600);                 //串口初始化為9600
        LED_Init();                                  //初始化與LED連接的硬件接口
         LCD_Init();                                   //初始化LCD
        KEY_Init();                                //按鍵初始化
         Adc_Init();                                  //ADC初始化
        Dac1_Init();                         //DAC通道1初始化
        POINT_COLOR=RED;//設置字體為紅色
        LCD_ShowString(60,50,200,16,16,"Mini STM32");
        LCD_ShowString(60,70,200,16,16,"DAC TEST");
        LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(60,110,200,16,16,"2014/3/9");
        LCD_ShowString(60,130,200,16,16,"WK_UP:+  KEY0:-");
        //顯示提示信息
        POINT_COLOR=BLUE;//設置字體為藍色
        LCD_ShowString(60,150,200,16,16,"DAC VAL:");
        LCD_ShowString(60,170,200,16,16,"DAC VOL:0.000V");
        LCD_ShowString(60,190,200,16,16,"ADC VOL:0.000V");
        DAC_SetChannel1Data(DAC_Align_12b_R, 0);//????0
                t++;
                key=KEY_Scan(0);
                if(key==WKUP_PRES)
                        if(dacval<4000)dacval+=200;
                        DAC_SetChannel1Data(DAC_Align_12b_R, dacval);//??DAC?
                }else if(key==KEY0_PRES)
                        if(dacval>200)dacval-=200;
                        else dacval=0;
                if(t==10||key==KEY0_PRES||key==WKUP_PRES)         //WKUP/KEY1按下了,或者定時時間到了
                         adcx=DAC_GetDataOutputValue(DAC_Channel_1);//??????DAC??
                        LCD_ShowxNum(124,150,adcx,4,16,0);             //顯示DAC寄存器值
                        temp=(float)adcx*(3.3/4096);                        //得到DAC電壓值
                        adcx=temp;
                         LCD_ShowxNum(124,170,temp,1,16,0);             //顯示電壓值整數部分
                         temp-=adcx;
                        temp*=1000;
                        LCD_ShowxNum(140,170,temp,3,16,0X80);         //顯示電壓值的小數部分
                         adcx=Get_Adc_Average(ADC_Channel_1,10);                //得到ADC轉換值
                        temp=(float)adcx*(3.3/4096);                        //得到ADC電壓值
                        adcx=temp;
                         LCD_ShowxNum(124,190,temp,1,16,0);             //顯示電壓值整數部分
                         temp-=adcx;
                        temp*=1000;
                        LCD_ShowxNum(140,190,temp,3,16,0X80);         //顯示電壓值的小數部分
                        LED0=!LED0;
                        t=0;
                delay_ms(10);
ID:1 發表于 2018-8-18 17:01 | 顯示全部樓層
此貼補全工程包 原理圖后即可獲得100黑幣
