此處用I2C來讀取。使用HAL庫。
單片機(jī)源程序如下:
- /* Includes ------------------------------------------------------------------*/
- #include "main.h"
- #include "stm32f1xx_hal.h"
- #include "i2c.h"
- #include "usart.h"
- #include "gpio.h"
- #include "mpu9255.h"
- /* USER CODE BEGIN Includes */
- #ifdef __GUNC__
- #define PUTCHAR_PROTOTYPE int __io_putchr(int ch)
- #else
- #define PUTCHAR_PROTOTYPE int fputc(int ch,FILE *f)
- #endif
- PUTCHAR_PROTOTYPE
- HAL_UART_Transmit(&huart1,(uint8_t *)&ch,1,0xFFFF);
- return ch;
- /* USER CODE END Includes */
- /* Private variables ---------------------------------------------------------*/
- /* USER CODE BEGIN PV */
- extern I2C_HandleTypeDef hi2c2;
- extern int16_t g[3],a[3];
- /* USER CODE END PV */
- /* Private function prototypes -----------------------------------------------*/
- void SystemClock_Config(void);
- /* USER CODE BEGIN PFP */
- /* USER CODE END PFP */
- /* USER CODE BEGIN 0 */
- /* USER CODE END 0 */
- * @brief The application entry point.
- * @retval None
- int main(void)
- /* USER CODE BEGIN 1 */
- int16_t Re=3;
- uint8_t Date = 0;
- uint8_t date = 0x75;
- /* USER CODE END 1 */
- /* MCU Configuration----------------------------------------------------------*/
- /* Reset of all peripherals, Initializes the Flash interface and the Systick. */
- HAL_Init();
- /* USER CODE BEGIN Init */
- /* USER CODE END Init */
- /* Configure the system clock */
- SystemClock_Config();
- /* USER CODE BEGIN SysInit */
- /* USER CODE END SysInit */
- /* Initialize all configured peripherals */
- MX_GPIO_Init();
- MX_I2C2_Init();
- MX_USART1_UART_Init();
- /* USER CODE BEGIN 2 */
- HAL_Delay(100);
- MPU_Init();
- //Re=MPU_Read_Byte(0x75);
- /* USER CODE END 2 */
- /* Infinite loop */
- /* USER CODE BEGIN WHILE */
- while (1)
- /* USER CODE END WHILE */
- /* USER CODE BEGIN 3 */
- //Re=MPU_Get_Temperature();
- if(HAL_I2C_Mem_Read(&hi2c2,MPU_9255_AddR,date,1,&Date,1,10) == HAL_OK)
- printf("\r\n MPU9255 Test OK \r\n");
- if(MPU_Get_Gyroscope()==0)
- printf("\r\n 陀螺儀:GX:%8d,GY:%8d,GZ:%8d\r\n",g[0],g[1],g[2]);
- else
- printf("\r\n Gyro Read False\r\n");
- if(MPU_Get_Accelerometer()==0)
- printf("\r\n 加速度:AX:%8d,AY:%8d,AZ:%8d\r\n",a[0],a[1],a[2]);
- else
- printf("\r\n Acceleration Read False\r\n");
- if ((Re=MPU_Get_Temperature())!=0)
- printf("\r\n 溫度:T:%8d\r\n",Re);
- else
- printf("\r\n Temperature Read False\r\n");
- else
- printf("\r\n MPU9255 Test False \r\n");
- printf("\r\n \r\n \r\n \r\n");
- HAL_Delay(500);
- /* USER CODE END 3 */
- * @brief System Clock Configuration
- * @retval None
- RCC_OscInitTypeDef RCC_OscInitStruct;
- RCC_ClkInitTypeDef RCC_ClkInitStruct;
- /**Initializes the CPU, AHB and APB busses clocks
- RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
- RCC_OscInitStruct.HSEState = RCC_HSE_ON;
- RCC_OscInitStruct.HSEPredivValue = RCC_HSE_PREDIV_DIV1;
- RCC_OscInitStruct.HSIState = RCC_HSI_ON;
- RCC_OscInitStruct.PLL.PLLState = RCC_PLL_ON;
- RCC_OscInitStruct.PLL.PLLSource = RCC_PLLSOURCE_HSE;
- RCC_OscInitStruct.PLL.PLLMUL = RCC_PLL_MUL9;
- if (HAL_RCC_OscConfig(&RCC_OscInitStruct) != HAL_OK)
- _Error_Handler(__FILE__, __LINE__);
- RCC_ClkInitStruct.ClockType = RCC_CLOCKTYPE_HCLK|RCC_CLOCKTYPE_SYSCLK
- |RCC_CLOCKTYPE_PCLK1|RCC_CLOCKTYPE_PCLK2;
- RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_PLLCLK;
- RCC_ClkInitStruct.AHBCLKDivider = RCC_SYSCLK_DIV1;
- RCC_ClkInitStruct.APB1CLKDivider = RCC_HCLK_DIV2;
- RCC_ClkInitStruct.APB2CLKDivider = RCC_HCLK_DIV1;
- if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_2) != HAL_OK)
- /**Configure the Systick interrupt time
- HAL_SYSTICK_Config(HAL_RCC_GetHCLKFreq()/1000);
- HAL_SYSTICK_CLKSourceConfig(SYSTICK_CLKSOURCE_HCLK);
- /* SysTick_IRQn interrupt configuration */
- HAL_NVIC_SetPriority(SysTick_IRQn, 0, 0);
- /* USER CODE BEGIN 4 */
- /* USER CODE END 4 */
- * @brief This function is executed in case of error occurrence.
- * @param file: The file name as string.
- * @param line: The line in file as a number.
- * @retval None
- void _Error_Handler(char *file, int line)
- /* USER CODE BEGIN Error_Handler_Debug */
- /* User can add his own implementation to report the HAL error return state */
- while(1)
- /* USER CODE END Error_Handler_Debug */
- #ifdef USE_FULL_ASSERT
- * @brief Reports the name of the source file and the source line number
- * where the assert_param error has occurred.
- * @param file: pointer to the source file name
- * @param line: assert_param error line source number
- * @retval None
- void assert_failed(uint8_t* file, uint32_t line)
- /* USER CODE BEGIN 6 */
- /* User can add his own implementation to report the file name and line number,
- tex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
- /* USER CODE END 6 */
- #endif /* USE_FULL_ASSERT */
- /************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
I2C.rar
(9.14 MB, 下載次數(shù): 56)
2018-8-14 17:55 上傳
點(diǎn)擊文件名下載附件
