查看: 1660|回復: 1
SHT2X溫濕傳感器測量代碼
ID:384738 發表于 2018-8-9 21:47 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
void Sht_Measure(void)
    u16 temp;
    u8 temp1, temp2;
    u8 rh1, rh2;
    u32 rh = 0;
    s32 rh_lin;
    Sht_Start();
    Sht_Send_Byte(T);
    if(Sht_Read_Ack())       //讀ACK
        printf("ACK error \r\n");
        return;
    Set_Data_In();
    while(SHTDATA)        //延時等待DATA變低
        Led_Run();
    temp1 = Sht_Read_Byte();      //讀高8位數據
    Sht_Send_Ack();        //發送一個ACK
    temp2 = Sht_Read_Byte();
    temp=(temp1<<8)+temp2;    //讀低8位并合成一個16位數據
    Sht_Read_Byte();       //讀CRC
    //printf("%x  %x  %d  \r\n", temp1, temp2, temp);
    temp_true=temp-3963;       //14bit溫度轉換,其結果為實際溫度*100
    Sht_Start();
    Sht_Send_Byte(RH);
        return;
    Set_Data_In();
        Led_Run();
    rh1 = Sht_Read_Byte();      //讀高8位數據
    rh2 = Sht_Read_Byte();
    rh=(rh1<<8)+rh2;    //讀低8位并合成一個16位數據
    rh_lin  = 0.0405*rh  - 400 - 0.0000028*rh*rh;
    rh_true = (temp_true+3963-2500)*(1+0.00008*rh)+rh_lin;
#endif
ID:284488 發表于 2018-8-10 08:56 | 只看該作者
感謝樓主的分享!
