查看: 1282|回復: 0
紅外遙控模塊
ID:382761 發表于 2018-8-6 10:48 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg51.h>
#include "lcd2.h"
#include "delay.h"
sbit IR=P3^2;
unsigned char IR_Code[4];
unsigned char IR_Data[33];
unsigned char IR_Time;
bit IR_RCV_OK;
bit IR_Pro_OK;
unsigned char TempData[16];
unsigned char LCD[16]="0123456789ABCDEF";
void Timer_Init(void)
TMOD=0x02;
TH0=0;
TL0=0;
ET0=1;
TR0=1;
void EX0_Init(void)
IT0=1;
EX0=1;
EA=1;
void Time0_ISR(void) interrupt 1
IR_Time ++;
void EX0_ISR(void)interrupt 0
static bit startflag;
static unsigned char BitCnt;
if(startflag)
  if(IR_Time<60&&IR_Time>40)
   BitCnt=0;
  IR_Data[BitCnt]=IR_Time;
  IR_Time=0;
  BitCnt++;
  if(BitCnt==33)
   IR_RCV_OK=1;
   BitCnt=0;
   startflag=0;
   IR_Time=0;
   startflag=1;
   IR_RCV_OK=0;
void IR_Pro(void)
unsigned char i,j,k;
unsigned char val;
k=1;
for(i=0;i<4;i++)
  for(j=1;j<=8;j++)
   if(IR_Data[k]>7)
    val |=0x80;
   if(j<8)
    val>>=1;
   k++;
  IR_Code=val;
  val=0;
IR_Pro_OK=1;
void button(void)
void IR_Work(void)
switch(IR_Code[2])
  case 0x45:button();break;
  default:break;
void IR_Disp(void)
TempData[0]=LCD[IR_Code[0]/16];
TempData[1]=LCD[IR_Code[0]%16];
TempData[2]='-';
TempData[3]=LCD[IR_Code[1]/16];
TempData[4]=LCD[IR_Code[1]%16];
TempData[5]='-';
TempData[6]=LCD[IR_Code[2]/16];
TempData[7]=LCD[IR_Code[2]%16];
TempData[8]='-';
TempData[9]=LCD[IR_Code[3]/16];
TempData[10]=LCD[IR_Code[3]%16];
LCD_Write_String(2,1,TempData);
Timer_Init();
EX0_Init();
LCD_Init();
LCD_Clear();
  if(IR_RCV_OK)
   IR_RCV_OK=0;
   IR_Pro();
  if(IR_Pro_OK)
   IR_Pro_OK=0;
   IR_Work();
   IR_Disp();
紅外遙控.zip
2.26 KB, 下載次數: 8, 下載積分: 黑幣 -5
