查看: 5142|回復: 1
傳感器將數據發給51,在給WiFi模塊發送數據,我用串口助手發現能收到,但WiFi模塊...
ID:335695 發表于 2018-8-4 23:26 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
傳感器將數據發給51單片機,單片機在給WiFi模塊發送數據,我用串口助手發現能收到數據,但WiFi模塊沒反應,WiFi模塊工作方式沒變化。請問是代碼錯誤,還是有別的原因(波特率設置對的,TX,RX連接無誤),希望大家能不能給出一些看法和幫助
#include  <REG51.H>
#include  <math.h>    //Keil library
#include  <stdlib.h>  //Keil library
#include  <stdio.h>   //Keil library
#include  <INTRINS.H> //Keil library
#define   uchar unsigned char
#define   uint unsigned int
#define   DataPort P0    //LCD1602數據端口
sbit          SCL=P1^0;      //IIC時鐘引腳定義
sbit           SDA=P1^1;      //IIC數據引腳定義
sbit      LCM_RS=P2^6;   //LCD1602命令端口
sbit      LCM_RW=P2^5;   //LCD1602命令端口
sbit      LCM_EN=P2^7;   //LCD1602命令端口
#define        BMP085_SlaveAddress   0xee          //定義器件在IIC總線中的從地址
#define OSS 0        // Oversampling Setting (note: code is not set up to use other OSS values)
//發送一字節
void sendByte(uchar b)          //發送一個字節
  SBUF = b;
  while(!TI);
  TI=0;
//發送字符串
void sendString(uchar *s)
  while(*s!='\0') //字符串默認 結尾'\0',以此來判斷字符串的結束
    sendByte(*s);
    s++;
//初始化ESP8266WiFi模塊
void initEsp()
  uint a;
  SCON = 0x50;    //8位數據,可變波特率
  TMOD = 0x20;    //設置定時器1工作方式2
  PCON=0X80;
  TL1 = 0xCC;     //設置定時器初值,波特率為4800
  TH1 = 0xCC;
  ET1 = 0;        //禁止定時器1中斷
  ES=1;                                                //打開接收中斷
  EA = 1;
  TR1 = 1;        //啟動定時器1
  for (a=0; a<50000; a++);      //延時幾秒,讓模塊有時間啟動
  sendString("AT+CWMODE=2\n");  //設置為softAP和station共存模式
    //for (a=0; a<50000; a++);      //延時幾秒,讓模塊有時間啟動
  sendString("AT+RST\n");  //重啟生效
  sendString("AT+CIPMUX=1\n"); //啟動多連接
// for (a=0; a<20000; a++);
  sendString("AT+CIPSERVER=1,333\n");//建立server,端口為333
  //sendString("AT+CIPSTO=50\n");     //服務器超時時間設置
  //RI=0;
  //ES=1;   //初始化完成,串行口中斷打開
void Datatransfer ()         {
  //for (a=0; a<20000; a++);
  sendString("AT+CIPSTART=0,'TCP','192.168.4.2',5000\n");//建立server,端口為333
  sendString("AT+CIPSEND=0,19\n");//確定發送的長度
        //RI=0;
// ES=1;   //初始化完成,串行口中斷打開
typedef unsigned char  BYTE;
typedef unsigned short WORD;
uchar ge,shi,bai,qian,wan,shiwan;           //顯示變量
int  dis_data;                              //變量
short ac1;
short ac2;
short ac3;
unsigned short ac4;
unsigned short ac5;
unsigned short ac6;
short b1;
short b2;
short mb;
short mc;
short md;
void delay(unsigned int k);
void InitLcd();                            //初始化lcd1602
void WriteDataLCM(uchar dataW);
void WriteCommandLCM(uchar CMD,uchar Attribc);
void DisplayOneChar(uchar X,uchar Y,uchar DData);
void conversion(long temp_data);
void  Single_Write(uchar SlaveAddress,uchar REG_Address,uchar REG_data);   //單個寫入數據
uchar Single_Read(uchar REG_Address);                                      //單個讀取內部寄存器數據
void  Multiple_Read(uchar,uchar);                                          //連續的讀取內部寄存器數據
void Delay5us();
void BMP085_Start();
void BMP085_Stop();
void BMP085_SendACK(bit ack);
bit  BMP085_RecvACK();
void BMP085_SendByte(BYTE dat);
BYTE BMP085_RecvByte();
void BMP085_ReadPage();
void BMP085_WritePage();
    shiwan=temp_data/100000+0x30 ;
    temp_data=temp_data%100000;   //取余運算
    wan=temp_data/10000+0x30 ;
    temp_data=temp_data%10000;   //取余運算
        qian=temp_data/1000+0x30 ;
    temp_data=temp_data%1000;    //取余運算
    bai=temp_data/100+0x30   ;
    temp_data=temp_data%100;     //取余運算
    shi=temp_data/10+0x30    ;
    temp_data=temp_data%10;      //取余運算
    ge=temp_data+0x30;
unsigned int i,j;
for(i=0;i<k;i++)
for(j=0;j<121;j++)
void WaitForEnable(void)
DataPort=0xff;
LCM_RS=0;LCM_RW=1;_nop_();
LCM_EN=1;_nop_();_nop_();
while(DataPort&0x80);
LCM_EN=0;
if(Attribc)WaitForEnable();
LCM_RS=0;LCM_RW=0;_nop_();
DataPort=CMD;_nop_();
LCM_EN=1;_nop_();_nop_();LCM_EN=0;
WaitForEnable();
LCM_RS=1;LCM_RW=0;_nop_();
DataPort=dataW;_nop_();
void InitLcd()
WriteCommandLCM(0x38,1);
WriteCommandLCM(0x08,1);
WriteCommandLCM(0x01,1);
WriteCommandLCM(0x06,1);
WriteCommandLCM(0x0c,1);
Y&=1;
X&=15;
if(Y)X|=0x40;
X|=0x80;
WriteCommandLCM(X,0);
WriteDataLCM(DData);
延時5微秒(STC90C52RC@12M)
不同的工作環境,需要調整此函數,注意時鐘過快時需要修改
當改用1T的MCU時,請調整此延時函數
void Delay5us()
    _nop_();_nop_();_nop_();_nop_();
延時5毫秒(STC90C52RC@12M)
不同的工作環境,需要調整此函數
當改用1T的MCU時,請調整此延時函數
起始信號
void BMP085_Start()
    SDA = 1;                    //拉高數據線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 0;                    //產生下降沿
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
停止信號
void BMP085_Stop()
    SDA = 0;                    //拉低數據線
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SDA = 1;                    //產生上升沿
    Delay5us();                 //延時
發送應答信號
入口參數:ack (0:ACK 1:NAK)
    SDA = ack;                  //寫應答信號
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
接收應答信號
    SCL = 1;                    //拉高時鐘線
    Delay5us();                 //延時
    CY = SDA;                   //讀應答信號
    SCL = 0;                    //拉低時鐘線
    Delay5us();                 //延時
    return CY;
向IIC總線發送一個字節數據
    BYTE i;
    for (i=0; i<8; i++)         //8位計數器
        dat <<= 1;              //移出數據的最高位
        SDA = CY;               //送數據口
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    BMP085_RecvACK();
從IIC總線接收一個字節數據
    BYTE i;
    BYTE dat = 0;
    SDA = 1;                    //使能內部上拉,準備讀取數據,
        dat <<= 1;
        SCL = 1;                //拉高時鐘線
        Delay5us();             //延時
        dat |= SDA;             //讀數據
        SCL = 0;                //拉低時鐘線
        Delay5us();             //延時
    return dat;
///單字節寫入BMP085內部數據*******************************
    BMP085_Start();                  //起始信號
    BMP085_SendByte(SlaveAddress);   //發送設備地址+寫信號
    BMP085_SendByte(REG_Address);    //內部寄存器地址
    BMP085_SendByte(REG_data);       //內部寄存器數據
    BMP085_Stop();                   //發送停止信號
//單字節讀取BMP085內部數據********************************
{  uchar REG_data;
    BMP085_SendByte(BMP085_SlaveAddress);           //發送設備地址+寫信號
    BMP085_SendByte(REG_Address);            //發送存儲單元地址
    BMP085_SendByte(BMP085_SlaveAddress+1);         //發送設備地址+讀信號
    REG_data=BMP085_RecvByte();              //讀出寄存器數據
        BMP085_SendACK(1);
        BMP085_Stop();                           //停止信號
    return REG_data;
//讀出BMP085內部數據,連續兩個
short Multiple_read(uchar ST_Address)
        uchar msb, lsb;
        short _data;
    BMP085_SendByte(ST_Address);             //發送存儲單元地址
    msb = BMP085_RecvByte();                 //BUF[0]存儲
    BMP085_SendACK(0);                       //回應ACK
    lsb = BMP085_RecvByte();
        BMP085_SendACK(1);                       //最后一個數據需要回NOACK
    _data = msb << 8;
        _data |= lsb;
        return _data;
long bmp085ReadTemp(void)
    BMP085_SendByte(0xF4);                  // write register address
    BMP085_SendByte(0x2E);               // write register data for temp
        delay(10);        // max time is 4.5ms
        return (long) Multiple_read(0xF6);
long bmp085ReadPressure(void)
        long pressure = 0;
    BMP085_SendByte(0x34);                 // write register data for pressure
        pressure = Multiple_read(0xF6);
        pressure &= 0x0000FFFF;
        return pressure;
//初始化BMP085,根據需要請參考pdf進行修改**************
void Init_BMP085()
        ac1 = Multiple_read(0xAA);
        ac2 = Multiple_read(0xAC);
        ac3 = Multiple_read(0xAE);
        ac4 = Multiple_read(0xB0);
        ac5 = Multiple_read(0xB2);
        ac6 = Multiple_read(0xB4);
        b1 =  Multiple_read(0xB6);
        b2 =  Multiple_read(0xB8);
        mb =  Multiple_read(0xBA);
        mc =  Multiple_read(0xBC);
        md =  Multiple_read(0xBE);
long bmp085Convert()
        long ut;
        long up;
        long x1, x2, b5, b6, x3, b3, p;
        unsigned long b4, b7;
        long  temperature;
        long  pressure;
         uint s;
        ut = bmp085ReadTemp();           // 讀取溫度
        up = bmp085ReadPressure();
         // 讀取壓強
        x1 = ((long)ut - ac6) * ac5 >> 15;
        x2 = ((long)         mc << 11) / (x1 + md);
        b5 = x1 + x2;
         temperature = (b5 + 8) >> 4;
         conversion(temperature);
         DisplayOneChar(4,0,'T');       //溫度顯示
     DisplayOneChar(5,0,':');
     DisplayOneChar(7,0,bai);
     DisplayOneChar(8,0,shi);
     DisplayOneChar(9,0,'.');
         DisplayOneChar(10,0,ge);
         DisplayOneChar(11,0,0XDF);     //溫度單位
         DisplayOneChar(12,0,'C');
        b6 = b5 - 4000;
        x1 = (b2 * (b6 * b6 >> 12)) >> 11;
        x2 = ac2 * b6 >> 11;
        x3 = x1 + x2;
        b3 = (((long)ac1 * 4 + x3) + 2)/4;
        x1 = ac3 * b6 >> 13;
        x2 = (b1 * (b6 * b6 >> 12)) >> 16;
        x3 = ((x1 + x2) + 2) >> 2;
        b4 = (ac4 * (unsigned long) (x3 + 32768)) >> 15;
        b7 = ((unsigned long) up - b3) * (50000 >> OSS);
        if( b7 < 0x80000000)
             p = (b7 * 2) / b4 ;
                    p = (b7 / b4) * 2;
        x1 = (p >> 8) * (p >> 8);
        x1 = (x1 * 3038) >> 16;
        x2 = (-7357 * p) >> 16;
         pressure = p + ((x1 + x2 + 3791) >> 4);
         conversion(pressure);
     DisplayOneChar(4,1,'P');    //顯示壓強
     DisplayOneChar(5,1,':');
         DisplayOneChar(6,1,shiwan);
         DisplayOneChar(7,1,wan);
     DisplayOneChar(8,1,qian);
     DisplayOneChar(9,1,'.');
     DisplayOneChar(10,1,bai);
     DisplayOneChar(11,1,shi);
         DisplayOneChar(12,1,'K');   //氣壓單位
         DisplayOneChar(13,1,'p');
         DisplayOneChar(14,1,'a');
s=(shiwan-0x30)*10000 +(wan-0x30)*1000+(qian-0x30)*100+(bai-0x30)*10+(shi-0x30);
   return s;
//******主程序********
  initEsp();
    delay(50);                           //上電延時
    InitLcd();                     //液晶初始化
    Init_BMP085();                //初始化BMP085
  while(1)                         //循環
   char ss[4];
          uint  zz;
        Datatransfer ();
  zz= bmp085Convert();
         sprintf(ss,"%d",zz);
          sendString(ss) ;
     delay(1000);
ID:382890 發表于 2018-8-8 10:15 | 只看該作者
ESP8266一般默認的波特率是115200,AT指令結尾應該是\r\n
