查看: 2172|回復: 0
GY-30用89c52的1602顯示屏上都顯示0,怎么回事啊
ID:381859 發表于 2018-8-4 10:57 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#include<math.h>
#include<stdio.h>
#include<intrins.h>
sbit lcden=P2^7;
sbit lcdrs=P2^6;
sbit lcdwr=P2^5;
sbit sda=P2^0;
sbit scl=P2^1;
uchar ge,shi,bai,qian,wan;           //????
uchar buffer[8];                                   //???????
int s;                        //??
void chaizi(uint temp)     //????
        wan=temp/10000+0x30 ;
    temp=temp%10000;   //????
        qian=temp/1000+0x30 ;
    temp=temp%1000;    //????
    bai=temp/100+0x30;
    temp=temp%100;     //????
    shi=temp/10+0x30;
    temp=temp%10;      //????
    ge=temp+0x30;
void delay_us()     //??5us
void delay_ms(uint t)     //??t??
  uchar i,j;
  for(i=0;i<t;i++)
  for(j=0;j<121;j++)
/************I2C????************/
void BH1750_start() //????
    sda=1;
        scl=1;
        delay_us();
        sda=0;
        delay_us();
        scl=0;
void BH1750_stop()                 //????
        sda=0;
        scl=1;
        delay_us();
        sda=1;
        delay_us();
void send_respons(bit ack)    //?????
     sda=ack;                     //?????
         scl=1;                                 //?????
         delay_us();
         scl=0;
         delay_us();
bit get_respons() //??????
     scl=1;
         delay_us();
         CY=sda;
         scl=0;
         delay_us();
         return CY;
void send_byte(uchar date)    //?IIC??????????
  uchar i;
  for(i=0;i<8;i++)
           date<<=1;
         sda=CY;           //CY?PWS????
         scl=1;
         delay_us();
         scl=0;
         delay_us();
   get_respons();
uchar get_byte()  //?IIC??????????
  uchar j;
  uchar k=0;
  sda=1;       //??????sda???,????????
  for(j=0;j<8;j++)
     k<<=1;
     scl=1;
         delay_us();
         k|=sda; //k????,?sda??;??sda?0??1;???????????
         scl=0;                   //?????????,scl??
         delay_us();
  return k;
void write_add(uchar date)
         BH1750_start();
         send_byte(0x46);  //ADD??,?????0x46
         send_byte(date);
         BH1750_stop();
void read_BH1750(void)         //????BH1750????
     uchar i;
         BH1750_start();
         send_byte(0x46+1);
         for(i=0;i<3;i++)
             buffer[i]=get_byte();
                 if(i == 3)
                         send_respons(1);
                     send_respons(0);
          BH1750_stop();
            delay_ms(5);
void BH1750_init()
   write_add(0x01);
/************LCD??************/
void wait_enable(void)
   P0=0xff;
   lcdrs=0;
   lcdwr=1;
   delay_us();
   lcden=1;
    delay_us();
   while(P0&0x80);
   lcden=0;
void lcd_command(uchar command,uchar shuxin)//????
   if(shuxin)
     wait_enable();
     lcdrs=0;
         lcdwr=0;
         delay_us();
         P0=command;//????lcd??????P0?
         delay_us();
         lcden=1;
         delay_us();
         lcden=0;
void lcd_writebyte(uchar byte)//????
         wait_enable();
         lcdrs=1;
         lcdwr=0;
         delay_us();
         P0=byte;
         delay_us();
         lcden=1;
     delay_us();
         lcden=0;
/*void lcd_set_xy(uchar x,uchar y)//??????
     uchar address;
     if(y==0)       //?????????
        address=0x80+x;
        address=0xc0+x;
        lcd_command(address);
void lcd_display(uchar x,uchar y,uchar h)     //lcd????
   y&=1;
   x&=15;
   if(y)x|=0x40;
   x|=0x80;
    lcd_command(x,0);
    lcd_writebyte(h);
/*void lcd_clean()      //lcd??
     lcd_command(0x01);
         delay_us();
void lcd1602_init()
         lcd_command(0x38,1);
         lcd_command(0x08,1);
         lcd_command(0x01,1);
         lcd_command(0x06,1);
         lcd_command(0x0c,1);
     float result;
         delay_ms(100);
         BH1750_init();
         lcd1602_init();
         write_add(0x01);
     write_add(0x10);
     delay_ms(180);              //??180ms
    read_BH1750();       //??????,???BUF?
    s=buffer[0];
    s=(s<<8)+buffer[1];//????,?????
    result=(float)s/1.2;
    chaizi(result);         //???????
        lcd_display(0,0,'L');
        lcd_display(1,0,'i');
        lcd_display(2,0,'g');
        lcd_display(3,0,'h');
        lcd_display(4,0,'t');
    lcd_display(5,0,':');
        lcd_display(7,0,wan);
    lcd_display(8,0,qian);
    lcd_display(9,0,bai);
    lcd_display(10,0,shi);
        lcd_display(11,0,ge);
        lcd_display(13,0,'l'); ////?????
        lcd_display(14,0,'x');
    lcd_display(0,1,'s');
    lcd_display(1,1,'u');
        lcd_display(2,1,'n');
        lcd_display(3,1,'>');
        lcd_display(4,1,'2');
        lcd_display(5,1,'0');
        lcd_display(9,1,'m');
        lcd_display(10,1,'o');
        lcd_display(11,1,'o');
        lcd_display(12,1,'n');
    lcd_display(13,1,'<');
        lcd_display(14,1,'2');
        lcd_display(15,1,'0');
