通過(guò)對(duì)RTC的時(shí)鐘編寫,可實(shí)現(xiàn)按鍵修改和TFT液晶顯示
單片機(jī)源程序如下:
- #include "led.h"
- #include "delay.h"
- #include "sys.h"
- #include "usart.h"
- #include "lcd.h"
- #include "usmart.h"
- #include "rtc.h"
- #include "timer.h"
- #include "key.h"
- #include "24cxx.h"
- #include "myiic.h"
- #include "touch.h"
- _calendar_obj calendar_buf; //存放設(shè)置完成時(shí)的值
- _alarm_obj alarm_buf; //存放設(shè)置完成時(shí)的值
- int main(void)
- u8 t=0;
- u8 t1=0;
- u8 temp=0;
- u8 move=0; //move為移動(dòng)的偏移量
- NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);// 設(shè)置中斷優(yōu)先級(jí)分組2
- delay_init(); //延時(shí)函數(shù)初始化
- uart_init(9600); //串口初始化為9600
- LED_Init(); //初始化與LED連接的硬件接口
- LCD_Init(); //初始化LCD
- KEY_Init();
- TIM2_Init(799,89);
- TIM3_Init(799,89);
- usmart_dev.init(72); //初始化USMART
- tp_dev.init(); //觸摸屏初始
- POINT_COLOR=RED;//設(shè)置字體為紅色
- while(RTC_Init()) //RTC初始化 ,一定要初始化成功
- LCD_ShowString(60,130,200,16,16,"RTC ERROR! ");
- delay_ms(800);
- LCD_ShowString(60,130,200,16,16,"RTC Trying...");
- //顯示時(shí)間
- POINT_COLOR=BLUE;//設(shè)置字體為藍(lán)色
- LCD_ShowString(0,10,200,24,24," Date ");
- LCD_ShowString(0,45,200,24,24," - - ");
- LCD_ShowString(0,80,200,24,24," Week ");
- LCD_ShowString(0,150,200,24,24," Time ");
- LCD_ShowString(0,185,200,24,24," : : ");
- LCD_ShowString(0,220,200,24,24," Alarm time"); //按鍵調(diào)整時(shí)間
- LCD_ShowString(0,255,200,24,24," : : ");
- LCD_ShowString(0,280,200,24,24," : : ");
- while(1)
- t1=move;
- if(TIMChange1&(0x01<<7)) //每5ms讀一次鍵值
- TIMChange1&=(~(0x01<<7));
- tp_dev.scan(0);
- if(tp_dev.sta&TP_PRES_DOWN) //觸摸屏被按下
- delay_ms(100);
- if(tp_dev.x[0]<lcddev.width&&tp_dev.y[0]<lcddev.height)
- if(tp_dev.x[0]>(lcddev.width-230)&&tp_dev.y[0]<290)
- Press_KEY_SUB(move); //數(shù)值減(下鍵)
- if(TIMChange&(0x01<<6)) //每5ms讀一次鍵值
- TIMChange&=(~(0x01<<6));
- temp=KEY_Scan(0); //讀鍵值,按移動(dòng)鍵(右鍵)時(shí)不支持連按
- if(temp==KEY_MOVE)
- if(move==12) move=1; //偏移量循環(huán)
- else move++; //移動(dòng)偏移量加一
- timcnt=0; //移動(dòng)一次就把閃爍計(jì)數(shù)值復(fù)位
- if(move) //處于時(shí)間設(shè)置模式中
- Press_KEY_MOVE(move); //調(diào)用子程序,進(jìn)行閃爍和移動(dòng)處理
- RTC_ITConfig(RTC_IT_SEC, DISABLE); // 關(guān)閉RTC 秒中斷
- if(temp==KEY_ADD)Press_KEY_ADD(move); //按數(shù)值加鍵(上鍵),數(shù)值加一,不支持連按
- //if(temp==KEY_SUB)Press_KEY_SUB(move); //數(shù)值減(下鍵),支持連按
- if(temp==KEY_SURE&&move) //確定鍵(左鍵)
- move=0; //move復(fù)位
- calendar_buf=calendar; //把設(shè)置完的值放入緩沖區(qū)
- alarm_buf=alarm; //把設(shè)置完的值放入緩沖區(qū)
- RTC_ITConfig(RTC_IT_SEC, ENABLE); //使能 RTC 秒中斷
- delay_ms(1); //關(guān)閉秒中斷時(shí),RTC還是在走的,開啟秒中斷后要延時(shí)一段時(shí)間,把舊值覆蓋掉
- calendar=calendar_buf; //用設(shè)置后的值覆蓋舊值
- alarm=alarm_buf; //用設(shè)置后的值覆蓋舊值
- RTC_Set(calendar.year,calendar.month,calendar.date,calendar.hour,calendar.min,calendar.sec);//寫入新值
- Set_Alarm(calendar.year,calendar.month,calendar.date,alarm.hour1,alarm.min1,alarm.sec1,alarm.hour2,alarm.min2,alarm.sec2);//寫入新值
- if((t!=calendar.sec&&move==0)||t1!=move) //秒更新或者按下移位鍵,顯示時(shí)間
- t=calendar.sec;
- POINT_COLOR=BLUE;
- LCD_ShowNum(55,45,calendar.year,4,24);
- LCD_ShowNum(125,45,calendar.month,2,24);
- LCD_ShowNum(180,45,calendar.date,2,24);
- switch(calendar.week)
- case 0:
- LCD_ShowString(60,115,200,24,24,"Sunday ");
- break;
- case 1:
- LCD_ShowString(60,115,200,24,24,"Monday ");
- break;
- case 2:
- LCD_ShowString(60,115,200,24,24,"Tuesday ");
- break;
- case 3:
- LCD_ShowString(60,115,200,24,24,"Wednesday");
- break;
- case 4:
- LCD_ShowString(60,115,200,24,24,"Thursday ");
- break;
- case 5:
- LCD_ShowString(60,115,200,24,24,"Friday ");
- break;
- case 6:
- LCD_ShowString(60,115,200,24,24,"Saturday ");
- break;
- …………限于本文篇幅 余下代碼請(qǐng)從51黑下載附件…………
RTC實(shí)時(shí)實(shí)驗(yàn) - 按鍵+2個(gè)鬧鐘 +觸屏.rar
(480.69 KB, 下載次數(shù): 144)
2018-8-1 23:14 上傳
點(diǎn)擊文件名下載附件
評(píng)分
查看全部評(píng)分
