查看: 3195|回復: 0
STM32F103 PWM DAC 輸出實驗
ID:331360 發表于 2018-7-31 17:59 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
部分STM32F10x板子沒有DAC,使用前請查看芯片手冊
void PWM_DAC_Set(u16 vol)
        float temp=vol;
        temp/=100;
        temp=temp*256/3.3;
        TIM_SetCompare1(TIM1,temp);
int main(void)
        u16 adcx;
        float temp;
        u8 t=0;
        u16 pwmval=0;
        u8 key;
        delay_init();
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
        uart_init(115200);
        KEY_Init();
        LED_Init();
        usmart_dev.init(72);
        LCD_Init();
        Adc_Init();
        TIM1_PWM_Init(255,0);        //TIM1 PWM3õê¼»ˉ, Fpwm=72M/256=281.25Khz.
  TIM_SetCompare1(TIM1,100);
        POINT_COLOR=RED;
        LCD_ShowString(60,50,200,16,16,"WarShip STM32");
        LCD_ShowString(60,70,200,16,16,"PWM DAC TEST");
        LCD_ShowString(60,90,200,16,16,"ATOM@ALIENTEK");
        LCD_ShowString(60,110,200,16,16,"2015/1/15");
        LCD_ShowString(60,130,200,16,16,"WK_UP:+  KEY1:-");
        POINT_COLOR=BLUE;
        LCD_ShowString(60,150,200,16,16,"PWM VAL:");
        LCD_ShowString(60,170,200,16,16,"DAC VOL:0.000V");
        LCD_ShowString(60,190,200,16,16,"ADC VOL:0.000V");
        TIM_SetCompare1(TIM1,pwmval);
                t++;
                key=KEY_Scan(0);
                if(key==WKUP_PRES)
                        if(pwmval<250)pwmval+=10;
                }else if(key==KEY1_PRES)
                        if(pwmval>10)pwmval-=10;
                        else pwmval=0;
                        TIM_SetCompare1(TIM1,pwmval);                                 }
                if(t==10||key==KEY1_PRES||key==WKUP_PRES)                 /
                        adcx=TIM_GetCapture1(TIM1);
                        LCD_ShowxNum(124,150,adcx,4,16,0);
                        temp=(float)adcx*(3.3/256);
                        adcx=temp;
                        LCD_ShowxNum(124,170,temp,1,16,0);
                        temp-=adcx;
                        temp*=1000;
                        LCD_ShowxNum(140,170,temp,3,16,0x80);
                        adcx=Get_Adc_Average(ADC_Channel_1,20);
                        temp=(float)adcx*(3.3/4096);
                        adcx=temp;
                        LCD_ShowxNum(124,190,temp,1,16,0);
                        temp*=1000;
                        LCD_ShowxNum(140,190,temp,3,16,0x80);
                        t=0;
                        LED0=!LED0;
                delay_ms(10);
STM32F103 PWM DAC實驗.zip
402.77 KB, 下載次數: 21, 下載積分: 黑幣 -5
STM31F103 PWM DAC 實驗 庫函數版本
收藏收藏3 分享淘帖 頂 踩
