#include "reg52.h"
sbit RW=P2^1;
sbit RS=P2^0;
sbit E=P2^2;
bit at=0;
uchar code shen[]={"CLOCK!"};
uchar code word[]={0x30,0x31,0x32,0x33,0x34,0x35,0x36,0x37,0x38,0x39,0x3a,0x20};
uchar dispbuf[8],h,m,s,counter;
void delay()
uchar i;
for(i=0;i<255;i++);
/*******寫(xiě)命令**********/
void lcd_wmc(uchar i)
P0=i;
RS=0;
RW=0;
E=0;
delay();
E=1;
/*******寫(xiě)數(shù)據(jù)***********/
void lcd_wmd(uchar i)
P0=i;
RS=1;
RW=0;
E=0;
delay();
E=1;
/*******初始化液晶*******/
void lcd_init()
uchar i;
lcd_wmc(0x01);
lcd_wmc(0x38);
lcd_wmc(0x0c);
lcd_wmc(0x06);
lcd_wmc(0xc9);
for(i=0;i<6;i++)
lcd_wmd(shen[i]);
lcd_wmc(0xc0);
/*******更新緩沖區(qū)子程序*******/
void newbuf()
dispbuf[0]=s%10;
dispbuf[1]=s/10;
dispbuf[3]=m%10;
dispbuf[4]=m/10;
dispbuf[6]=h%10;
dispbuf[7]=h/10;
/*******顯示子程序**********/
void disp(uchar dispadd)
uchar tmp;
lcd_wmc(dispadd);
tmp=dispbuf[7];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[6];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[5];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[4];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[3];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[2];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[1];
tmp=word[tmp];
lcd_wmd(tmp);
tmp=dispbuf[0];
tmp=word[tmp];
lcd_wmd(tmp);
/*********************鍵盤(pán)子程序***********************/
uchar keypro(void)
uchar scanl,scanh;
P1=0x0f;//先將所有行線拉低
if((P1&0x0f)!=0x0f) //如果列線有變化
delay();//延遲一段時(shí)間。
if((P1&0x0f)!=0x0f)//如果此時(shí)此刻列線還有變化,說(shuō)明確實(shí)有按鍵按下
scanl=0xfe;
while((scanl&0x10)!=0)
P1=scanl; //給P1口賦掃描碼,每次只拉低一行
if((P1&0xf0)!=0xf0) //如果判斷為真,則說(shuō)明找到了按鍵按下的行
scanh=(P1&0xf0)|0x0f; //計(jì)算識(shí)別碼
return (~scanh)+(~scanl);
else scanl=(scanl<<1)|0x01; //否則依次將第二,第三,第四行拉低
return 0;//沒(méi)有按鍵 按下 返回0
/********************時(shí)間調(diào)整子程序********************/
void adjustime()
uchar k;
static uchar add;
k=keypro();
switch(k)
case 0x88: if(!at){add=0xc1;EA=0;lcd_wmc(0xc1);lcd_wmc(0x0f);at=1;}
else {lcd_wmc(0xc0);lcd_wmc(0x0c);at=0;EA=1;} break;
case 0x48: if(at)
if(add==0xc1){add=0xc7; lcd_wmc(add);}
else {add=add-3;lcd_wmc(add);}
break;
case 0x28: if(at)
if(add==0xc7) {add=0xc1;lcd_wmc(add);}
else {add=add+3;lcd_wmc(add);}
break;
case 0x18: if(at)
if(add==0xc1) h++;
if(h==24)
h=0;
if(add==0xc4) m++;
if(m==60)
m=0;
if(add==0xc7) s++;
if(s==60)
s=0;
newbuf();
disp(0xc0);
lcd_wmc(add);
break;
default: break;
if(k!=0)
while((P1&0xf0)!=0xf0)
P1=0xf0;
/*********************初始化子程序**********************/
void init()
TMOD=0x01;
TH0=0x4c;
TL0=0x00;
EA=1;
ET0=1;
TR0=1;
counter=0;
h=12;m=0;s=0;
dispbuf[2]=10;
dispbuf[5]=10;
/***************************主程序************************/
void main(void)
init();
lcd_init();
adjustime();
if(!at)
//閃爍
if(counter<10)
dispbuf[2]=10;
dispbuf[5]=10;
dispbuf[2]=11;
dispbuf[5]=11;
//更新顯示緩沖區(qū)及調(diào)用顯示程序
if(counter==0)
newbuf();
disp(0xc0);
else if(counter==10)
disp(0xc0);
/*************************定時(shí)器0的中斷**********************/
void Time0() interrupt 1 using 2 //再次強(qiáng)調(diào)中斷子程序執(zhí)行時(shí)間越短越好
TH0=(65536-46075)/256;
TL0=(65536-46075)%256;
counter++;
if(counter==20)
s++;
counter=0;
if(s==60)
m++;
s=0;
if(m==60)
h++;
m=0;
if(h==24)
h=0;
