查看: 1483|回復: 0
stm8 串口通信,發(fā)送數(shù)字燈亮,字母燈滅
ID:380906 發(fā)表于 2018-7-30 15:36 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include "stm8s.h"
void UART_Init();
void GPIO_Configuration(void)
  GPIO_DeInit(GPIOB);
  GPIO_Init(GPIOB,
            GPIO_PIN_0,
            GPIO_MODE_OUT_PP_HIGH_FAST);
void UART_Init()
  UART2_DeInit();
  UART2_Init(9600 ,
             UART2_WORDLENGTH_8D,
             UART2_STOPBITS_1 ,
             UART2_PARITY_NO,
             UART2_SYNCMODE_CLOCK_DISABLE,
             UART2_MODE_TXRX_ENABLE);
  UART2_ITConfig(UART2_IT_RXNE,ENABLE);
  UART2_Cmd( ENABLE);
  enableInterrupts();
  UART_Init();
  GPIO_Configuration();
#pragma vector=23
__interrupt void EXIT_UART2_IRQHander(void)
  UART2_ClearITPendingBit(UART2_IT_RXNE);
  if(0x30 <= UART2_ReceiveData8() && UART2_ReceiveData8()<= 0x39)
    GPIO_WriteLow(GPIOB, GPIO_PIN_0);
  if((0x41<=UART2_ReceiveData8()&&UART2_ReceiveData8()<= 0x5A)||(0x61<=UART2_ReceiveData8()&&UART2_ReceiveData8()<= 0x7A))
    GPIO_WriteHigh(GPIOB, GPIO_PIN_0);
