查看: 3780|回復: 0
RF7321引腳圖與電路圖 射頻PA功放pdf資料下載
ID:380856 發表于 2018-7-30 14:38 | 顯示全部樓層 |閱讀模式
上傳一個常用的射頻PA功放資料,給大家參考
The RF7321 is a high-power, high-efficiency linear power amplifier
designed for use as final amplification stage in a 3V, 50 ohm LTE mobile
cellular equipment. This PA is developed for the E-UTRAN\LTE Bands 11
and 21 for which operates in the 1427.9MHz to 1462.9MHz frequency
band. The PA is specifically developed for 5MHz to 20MHz channel band-
widths used for the Band 11 or 21 operation on the LTE network. The
RF7321 has two digital control pins to select one of three power bias
states to optimize performance and current drain at lower power levels.
The part also has an integrated directional coupler which eliminates the
need for an external discrete coupler at the output. The RF7321 is fully
LTE compliant and is assembled in a 10-pin, 3mm x 3mm module.
RF7321引腳圖:
RF7321電路圖:
完整的pdf格式文檔51黑下載地址:
rf7321ds_data_sheet (1).pdf (666.07 KB, 下載次數: 9)
