查看: 9059|回復(fù): 16
共陽極數(shù)碼管 段選位與上 0xf7 后小數(shù)點顯示 數(shù)字卻不顯示了 是什么原因
ID:377512 發(fā)表于 2018-7-28 18:10 | 顯示全部樓層 |閱讀模式
  1. #include<reg52.h>
  2. #include<intrins.h>
  4. #define MAIN_Fosc                11059200UL
  5. typedef unsigned int INT16U;
  6. sbit DU = P2^6;
  7. sbit WE = P2^7;
  8. uchar code table[]={
  9. //         0                1           2          3                  4                5
  10.         0xc0,  0xf9,  0xa4,  0xb0,  0x99,  0x92,
  11. //         6                 7                8           9          .                 關(guān)顯示
  12.     0x82,  0xf8,  0x80,  0x90,  0x7f,   0xff
  13. };
  14. uchar code T_COM[] = {
  15. //1      2     3       4     5      6
  16. 0x01,  0x02,  0x04,  0x08,  0x10,  0x20
  17. };
  18. void Delay_Ms(INT16U ms)
  19. {
  20.      INT16U i;
  21.          do{
  22.               i = MAIN_Fosc / 96000;
  23.                   while(--i);   //96T per loop
  24.      }while(--ms);
  25. }
  26. void Display(uchar z)
  27. {
  28. //------------------------------
  29.         DU = 0;
  30.         P0 = table[z];
  31.         DU = 1;
  32.         DU = 0;
  33.         WE = 0;
  34.         P0 = T_COM[0];
  35.         WE = 1;
  36.         WE = 0;
  37.         Delay_Ms(3);
  38. //-------------------------------
  39.         DU = 0;
  40.         P0 = table[z] & 0x7f;
  41.         DU = 1;
  42.         DU = 0;
  43.         WE = 0;
  44.         P0 = T_COM[1];
  45.         WE = 1;
  46.         WE = 0;
  47.         Delay_Ms(3);
  48. //------------------------------
  49.         DU = 0;
  50.         P0 = table[z];
  51.         DU = 1;
  52.         DU = 0;
  53.         WE = 0;
  54.         P0 = T_COM[2];
  55.         WE = 1;
  56.         WE = 0;
  57.         Delay_Ms(3);
  58. //-------------------------------
  59.         DU = 0;
  60.         P0 = table[z] & 0x7f;
  61.         DU = 1;
  62.         DU = 0;
  63.         WE = 0;
  64.         P0 = T_COM[3];
  65.         WE = 1;
  66.         WE = 0;
  67.         Delay_Ms(3);
  68. //------------------------------
  69.         DU = 0;
  70.         P0 = table[z];
  71.         DU = 1;
  72.         DU = 0;
  73.         WE = 0;
  74.         P0 = T_COM[4];
  75.         WE = 1;
  76.         WE = 0;
  77.         Delay_Ms(3);
  78. //-------------------------------
  79.         DU = 0;
  80.         P0 = table[z] & 0x7f;
  81.         DU = 1;
  82.         DU = 0;
  83.         WE = 0;
  84.         P0 = T_COM[5];
  85.         WE = 1;
  86.         WE = 0;
  87.         Delay_Ms(3);
  88. }
  89. void main()
  90. {
  91.   Display(0);
  92. }
想不太明白  DP最高位為0的時候會亮  如果輸出0 十六進(jìn)制是 c0 二進(jìn)制就是 1100 0000 與上 0x7F   0111 1111  變成 0100 0000  沒想到有啥毛病  數(shù)碼一直不顯示
ID:96682 發(fā)表于 2018-7-29 03:13 | 顯示全部樓層
樓主列出的二進(jìn)制也不完全對啊
ID:377512 發(fā)表于 2018-7-29 08:45 來自觸屏版 | 顯示全部樓層
wc86110 發(fā)表于 2018-7-29 03:13
樓主列出的二進(jìn)制也不完全對啊
哪里不對
ID:380415 發(fā)表于 2018-7-29 10:29 | 顯示全部樓層
在實際中要做消影操作
ID:213173 發(fā)表于 2018-7-29 10:37 | 顯示全部樓層
樓主要在顯示程序里每位送段碼前加消隱語句!
        P0 = 0xff;//消隱
        DU = 1;//開段選
        DU = 0;//關(guān)段選
        P0 = table[z];//送段碼
        DU = 1;//開段選
        DU = 0;//關(guān)段選
        WE = 0;//贅句
        P0 = T_COM[0];//送位碼
        WE = 1;//開位選
        WE = 0;//關(guān)位選
        Delay_Ms(3);
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎勵!
ID:375003 發(fā)表于 2018-7-29 10:50 | 顯示全部樓層
問題在這里,因為這個點不是在每個位上,如果要顯示小數(shù)點的時候,先要判斷這個位有沒有小數(shù)點
admin + 20 回帖助人的獎勵!
ID:155507 發(fā)表于 2018-7-29 12:16 | 顯示全部樓層
要數(shù)碼顯示, 你把Delay_Ms(3);  設(shè)置成Delay_Ms(9);
ID:377512 發(fā)表于 2018-7-29 12:42 來自觸屏版 | 顯示全部樓層
guangshi_wq 發(fā)表于 2018-7-29 10:50
共陽極 直接和 0x7f與 最高位為0 數(shù)據(jù)的最高位也為0 這樣就不需要判斷了
ID:377512 發(fā)表于 2018-7-29 13:07 來自觸屏版 | 顯示全部樓層
angmall 發(fā)表于 2018-7-29 12:16
設(shè)置成9之后數(shù)碼管交替顯示 還是不是一起顯示 延時的時間太長了
ID:377512 發(fā)表于 2018-7-29 13:10 來自觸屏版 | 顯示全部樓層
去了小數(shù)點就可以完全顯示
ID:261288 發(fā)表于 2018-7-29 20:40 | 顯示全部樓層
段碼”或“0x7f才能顯示
ID:140489 發(fā)表于 2018-7-30 09:34 | 顯示全部樓層
段碼”或“0x7f才能顯示,才是正解,
ID:377512 發(fā)表于 2018-7-30 10:43 來自觸屏版 | 顯示全部樓層
lids 發(fā)表于 2018-7-30 09:34
段碼”或“0x7f才能顯示,才是正解,
要是或的話 數(shù)據(jù)有一位是0和1或之后是 1 改變了數(shù)據(jù)的值 比如 1010 1010按位或0111 1111 變成 1111 1111 或有一個值為1 則為1
admin + 20 回帖助人的獎勵!
ID:213173 發(fā)表于 2018-7-30 17:53 | 顯示全部樓層
李博文 發(fā)表于 2018-7-30 10:43
要是或的話 數(shù)據(jù)有一位是0和1或之后是 1 改變了數(shù)據(jù)的值 比如 1010 1010按位或0111 1111 變成 1111 1111  ...
樓上好多朋友是瞎猜,此程序的共陽數(shù)碼管加點當(dāng)然是 P0 = table[z] & 0x7f; 。由于段碼與位碼共用P0,不加消隱指令肯定會出問題。樓主認(rèn)為去掉 & 0x7f就顯示正常的說法是不正確的,只是樓主用仿真軟件看不出來,要是實際電路就可以看出問題來了。給你改了一下,你試試。#include<reg52.h>
#include<intrins.h>
sbit DU = P2^6;
sbit WE = P2^7;
//         0                1           2          3                  4                5
//1      2     3       4     5      6
     INT16U i;
         do{
     }while(--ms);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[0];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[1];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[2];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[3];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        P0 = table[z];
        DU = 1;
        DU = 0;
        P0 = T_COM[4];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
        P0 = 0xff;
        DU = 0;
        DU = 1;
        DU = 1;
        DU = 0;
        P0 = T_COM[5];
        WE = 1;
        WE = 0;
        Delay_Ms(3);
                Display(0);
參與人數(shù) 2黑幣 +15 收起 理由
NPC-1024 + 8 回帖助人的獎勵!
李博文 + 7 很給力!
ID:377512 發(fā)表于 2018-7-30 19:46 | 顯示全部樓層
wulin 發(fā)表于 2018-7-30 17:53
樓上好多朋友是瞎猜,此程序的共陽數(shù)碼管加點當(dāng)然是 P0 = table[z] & 0x7f; 。由于段碼與位碼共用P0,不 ...
我用八位共陽極的數(shù)碼管怎么 只顯示小數(shù)點 和后兩位數(shù)
ID:213173 發(fā)表于 2018-7-31 05:35 | 顯示全部樓層
李博文 發(fā)表于 2018-7-30 19:46
ID:377512 發(fā)表于 2018-7-31 11:22 來自觸屏版 | 顯示全部樓層
wulin 發(fā)表于 2018-7-31 05:35
這與使用八數(shù)碼管沒有什么關(guān)系,程序是顯示六位,后兩位閑置而已。
一直沒出來這樣的效果
