查看: 3176|回復: 0
創客集結號:Arduino按鍵實驗
本次實驗要實現按鍵控制LED亮滅效果。按下點亮,再次按下熄滅。
1.原理圖:
2.代碼如下:
int ButtonState;
int ButtonLastState;
int ButtonCounter;
void setup() {
  // put your setup code here, to run once:
  pinMode(13,OUTPUT);
  pinMode(11,INPUT_PULLUP);
  Serial.begin(9600);
void loop() {
  // put your main code here, to run repeatedly:
  ButtonState = digitalRead(11);
  if(ButtonState != ButtonLastState)
    if(ButtonState)
        Serial.println("on");
        ButtonCounter++;
      Serial.println("off");
    delay(100);
  ButtonLastState = ButtonState;
  if(ButtonCounter%2)
    //Serial.println(ButtonCounter);
    digitalWrite(13,1);
    digitalWrite(13,0);
若想學習更多Arduino知識,可以搜查創客集結號
