查看: 2877|回復: 1
51循跡小車程序
ID:378302 發表于 2018-7-24 09:24 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
sbit IN1 = P1^0;
sbit IN2 = P1^1;
sbit ENA = P1^2;//右輪
sbit IN3 = P1^3;
sbit IN4 = P1^4;
sbit ENB = P1^5;//左輪
//循跡模塊
sbit left1  = P0^0;
sbit left2  = P0^1;
sbit right2 = P0^3;
sbit right1 = P0^2;
unsigned char zkb1 = 0;
unsigned char zkb2 = 0;
unsigned char t = 0;
unsigned char flag;
void init()
        EA = 1;
        TMOD |= 0x01;
        TH0 =(65536 - 100) / 256;
        TL0 = (65536 - 100)% 256;
        ET0 = 1;
        TR0 = 1;
        ENA = 1;
        ENB = 1;
void turn_left2()//大左轉
        zkb1 =22;
        zkb2= 13;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void turn_left1() //小左轉
        zkb1 = 20;
        zkb2 = 13;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void turn_left3()//中左轉
        zkb1 = 22;
        zkb2 = 13;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void turn_right1()//小右轉
        zkb1 = 10;
        zkb2 = 22;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void turn_right2() //大右轉
        zkb1 = 13;
        zkb2 = 22;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void turn_right3()//中右轉
        zkb1 = 10;
        zkb2 = 22;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void qianjin()
        zkb1=20;
    zkb2=22;
        IN1 = 0;
        IN2 = 1;
    IN3 = 0;
    IN4 = 1;
void houtui()
    zkb1=20;
    zkb2=22;
        IN1 = 1;
        IN2 = 0;
    IN3 = 1;
    IN4 = 0;
void xunji()
        if((left1 == 0)&&(left2 == 1)&&(right2 == 1)&&(right1 == 0))
                flag = 0;
        if((left1 == 0)&&(left2 ==0)&&(right2 == 1)&&(right1 == 0))
                flag = 1;
        if((left1 == 0)&&(left2 == 1)&&(right2 == 0)&&(right1 == 0))
                flag = 2;
        if((left1 == 1)&&(left2 == 0)&&(right2 == 0)&&(right1 == 0))
                flag = 3;
        if((left1 == 0)&&(left2 == 0)&&(right2 == 0)&&(right1 == 1))
                flag = 4;
    if((left1 == 0)&&(left2 == 0)&&(right2 == 0)&&(right1 == 0))
                flag = 5;
        if((left1 == 1)&&(left2 == 0)&&(right2 == 1)&&(right1 == 0))
                flag = 6;
        if((left1 == 0)&&(left2 == 1)&&(right2 == 0)&&(right1 == 1))
                flag = 7;
        switch(flag)
                case 0:qianjin();break;
                case 1:turn_right1();break;
                case 2:turn_left1();break;
                case 3:turn_left2();break;
                case 4:turn_right2();break;
                case 5:houtui();break;
                case 6:turn_left3();break;
                case 7:turn_right3();break;
                default:qianjin();break;
void timer0() interrupt 1
        TH0 = (65536 - 100) / 256;
        TL0 = (65536 - 100) % 256;
        if(t < zkb1 )
                ENA = 1;
                ENA = 0;
        if(t < zkb2 )
            ENB = 1;
                ENB = 0;
        ++t;
        if(t== 50)
                ENA=~ENA;//沒有加這個導致的判斷程序錯亂
                ENB=~ENB;
                t = 0;
        init();
        //zkb1 = 8;
        //zkb2 = 8;
        qianjin();
                        xunji();
#include <reg52.h>
uchar num1,num2,a,b,c,d;
uchar count1=0;
uchar count2=0;
sbit PWM1=P1^0;
sbit IN1=P1^1;
sbit IN2=P1^2;
sbit PWM2=P1^3;
sbit IN3=P1^4;
sbit IN4=P1^5;
sbit ZW=P0^0;
sbit ZN=P0^1;
sbit YN=P0^2;
sbit YW=P0^3;
void delayms (uint z)
        uchar y,x;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void forward_turn1()
        IN1=0;
        IN2=1;
void reverse_turn1()//左電機反轉 //pwm2
        IN1=1;
        IN2=0;
void forward_turn2()//右電機正轉  //pwm1
        IN3=0;
        IN4=1;
void reverse_turn2()//右電機反轉
        IN3=1;
        IN4=0;
void advance()//前進
   forward_turn1();
        forward_turn2();
void houtui()        //后退
        reverse_turn1();
        reverse_turn2();
void init()//初始化子函數
          TMOD=0x11;
          TH0=(65536-1000)/256;//中斷周期1ms
          TL0=(65536-1000)%256;
          TH1=(65536-1000)/256;//中斷周期1ms
          TL1=(65536-1000)%256;
          EA=1;//開總中斷
          ET0=1;//開定時器0中斷
          ET1=1;//開定時器1中斷
          TR0=1; //啟動定時器0
          TR1=1; //啟動定時器1
void depand()  //紅外對管賦值給pwm
if((ZN==1)&&(YN==1)&&(ZW==0)&&(YW==0))
  a=10;
  b=30;
//pwm1右電機,pwm2左電機
void main ()
            advance();
         init();//初始化子函數
          depand();
          //等待中斷發生
void T0_time()interrupt 1//重裝初值,服務左電機
        num1++;
                if(num1=1)//一個定時器周期到了,即將進入中斷
          count1++;
          num1=0;
          if(count1>a&&count1<=b)//左電機前進pwm
          PWM2=0;
          if(count1<=a)
          PWM2=1;
          if(count1==b)
          count1=0;//等于7的時候清零
void T1_time()interrupt 3//重裝初值,服務右電機
        num2++;
                if(num2=1)//一個定時器周期到了,即將進入中斷
          count2++;
          num2=0;
          if(count2>10||count2<=30)//左電機前進pwm
          PWM1=0;
          if(count2<=10)
          PWM1=1;
          if(count2==30)
          count2=0;//等于7的時候清零
                /*if((ZN==1)&&(YN==1)&&(ZW==0)&&(YW==0))//小車直行
                        advance();
                        delayms(100);
                        PWM1=1,PWM2=1;
                        delayms(40);
                        PWM1=0,PWM2=0;
                if((ZW==0)&&(ZN==0)&&(YN==1)&&(YW==0))//小右轉
                        advance();
                        delayms(110);
                        PWM1=1;
                        delayms(30);
                        PWM1=0;
                        delayms(30);
                        PWM2=1;
                        delayms(110);
                        PWM2=0;
                if((ZW==0)&&(ZN==0)&&(YN==1)&&(YW==1))//中右轉
                        advance();
                        delayms(100);
                        PWM1=1;
                        delayms(40);
                        PWM1=0;
                        delayms(60);
                        PWM2=1;
                        delayms(80);
                        PWM2=0;
                if((ZW==0)&&(ZN==0)&&(YN==0)&&(YW==1))//大右轉
                        advance();
                        delayms(110);
                        PWM1=1;
                        delayms(30);
                        PWM1=0;
                        delayms(50);
                        PWM2=1;
                        delayms(90);
                        PWM2=0;
                if((ZW==0)&&(ZN==1)&&(YN==0)&&(YW==0))//小左轉
                        advance();
                        delayms(30);
                        PWM1=1;
                        delayms(110);
                        PWM1=0;
                        delayms(110);
                        PWM2=1;
                        delayms(30);
                        PWM2=0;
                if((ZW==1)&&(ZN==1)&&(YN==0)&&(YW==0))//中左轉
                        advance();
                        delayms(60);
                        PWM1=1;
                        delayms(80);
                        PWM1=0;
                        delayms(100);
                        PWM2=1;
                        delayms(40);
                        PWM2=0;
                if((ZW==1)&&(ZN==0)&&(YN==0)&&(YW==0))//大左轉
                        advance();
                        delayms(50);
                        PWM1=1;
                        delayms(90);
                        PWM1=0;
                        delayms(110);
                        PWM2=1;
                        delayms(30);
                        PWM2=0;
                if((ZN==1)&&(YN==1)&&(ZW==1)&&(YW==1))//停止
                        IN1=0;
                        IN2=0;
                        IN3=0;
                        IN4=0;
                if((ZW==0)&&(ZN==0)&&(YN==0)&&(YW==0))//小車后退
                        houtui();
                        delayms(100);
                        PWM1=1,PWM2=1;
                        delayms(40);
                        PWM1=0,PWM2=0;
ID:669415 發表于 2019-12-20 20:45 | 顯示全部樓層
這是幾路循跡呀
