查看: 2598|回復(fù): 0
STM32F103ZET6 12864 4×4按鍵顯示
STM32F103ZET6 12864 4×4按鍵顯示,可拓展方向?qū)拸V,非常適用于新手練習(xí)于創(chuàng)新!!
單片機(jī)源程序如下:
  1. /**
  2.   ******************************************************************************
  3.   * @file    main.c
  4.   * @author  fire
  5.   * @version V1.0
  6.   * @date    2013-xx-xx
  7.   * @brief   測試按鍵
  8.   */
  9. #include "stm32f10x.h"
  10. #include "bsp_led.h"
  11. #include "lcd12864.h"
  12. #include "bsp_SysTick.h"
  13. #include "key.h"
  14.
  15.
  16. int main(void)
  17. {
  18.         LCD12864_Config();
  19.   LCD12864_init();
  20.   KEY_GPIO_InitStruct();
  21.         while(1)
  22.         {
  23.                 int Key;
  24.                 Key=Read_KeyVal();
  25.                 switch(Key)
  26.                 {
  27.                         case 0:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:0"); break;
  28.                         case 1:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:1"); break;
  29.                         case 2:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:2"); break;
  30.                         case 3:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:3"); break;
  31.                         case 4:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:4"); break;
  32.                         case 5:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:5"); break;
  33.                         case 6:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:6"); break;
  34.                         case 7:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:7"); break;
  35.                         case 8:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:8"); break;
  36.                         case 9:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:9"); break;
  37.                         case 10:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:10"); break;
  38.                         case 11:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:11"); break;
  39.                         case 12:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:12"); break;
  40.                         case 13:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:13"); break;
  41.                         case 14:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:14"); break;
  42.                         case 15:  write_12864com(0x01); SysTick_Delay_Ms(5);display_string(1,1,"電壓:15"); break;
  43.           }
  44.   }
  45. }
  46.         /*********************************************END OF FILE**********************/
源--STM32顯示屏調(diào)試.rar (311.97 KB, 下載次數(shù): 80)
