查看: 18943|回復(fù): 10
STM32F103使用TIM3定時(shí)器輸出兩路PWM控制直流電機(jī)
ID:375370 發(fā)表于 2018-7-20 09:24 | 顯示全部樓層 |閱讀模式
1、首先打開PWM輸出實(shí)驗(yàn)例程(這里采用正點(diǎn)原子精英版例程),打開led.c,對相關(guān)端口進(jìn)行修改
void LED_Init(void)
GPIO_InitTypeDef  GPIO_InitStructure;
RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_GPIOE, ENABLE);         //使能PB,PE端口時(shí)鐘
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_5|GPIO_Pin_7|GPIO_Pin_9;                                 //設(shè)置IO口,使用        //PB.5,PB.0作為PWM輸出口,
        //PB.2 PB.6,PB.7,PB.9作為電機(jī)輸出信號口
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;                  //推挽輸出
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 //IO口速度為50MHz
GPIO_Init(GPIOB, &GPIO_InitStructure);                                         //根據(jù)設(shè)定參數(shù)初始化GPIOB.5
GPIO_SetBits(GPIOB,GPIO_Pin_0|GPIO_Pin_5);                                                 //PB.5 輸出高
        GPIO_ResetBits(GPIOB,GPIO_Pin_2|GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_9);
// GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5;                             //LED1-->PE.5 端口配置, 推挽輸出
// GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;                  //推挽輸出
//GPIO_Init(GPIOE, &GPIO_InitStructure);                                           //推挽輸出 ,IO口速度為50MHz
//GPIO_SetBits(GPIOE,GPIO_Pin_5);                                                  //PE.5 輸出高
2、在led.h中定義輸出IO口
#ifndef __LED_H
#define __LED_H
#include "sys.h"
#define ENA PBout(5)// PB5
#define IN1 PBout(2)
#define IN2 PBout(6)
#define ENB PBout(0)//PB0
#define IN3 PBout(7)
#define IN4 PBout(9)
#define LED1 PEout(5)// PE5
void LED_Init(void);//初始化
#endif
3、打開timer.c,對pwm初始化函數(shù)進(jìn)行修改
//TIM3 PWM部分初始化
//PWM輸出初始化
//arr:自動(dòng)重裝值
//psc:時(shí)鐘預(yù)分頻數(shù)
void TIM3_PWM_Init(u16 arr,u16 psc)
        TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
        TIM_OCInitTypeDef  TIM_OCInitStructure;
        RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3, ENABLE);        //使能定時(shí)器3時(shí)鐘
         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB  | RCC_APB2Periph_AFIO, ENABLE);  //使能GPIO外設(shè)和AFIO復(fù)用功能模塊時(shí)鐘
        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE); //Timer3部分重映射  TIM3_CH2->PB5
   //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM3 CH2的PWM脈沖波形        GPIOB.5
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5; //TIM_CH2
        GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;  //復(fù)用推挽輸出
        GPIO_Init(GPIOB, &GPIO_InitStructure);//初始化GPIO
//        GPIO_PinRemapConfig(GPIO_PartialRemap_TIM3, ENABLE);
         //設(shè)置該引腳為復(fù)用輸出功能,輸出TIM3 CH3的PWM脈沖波形        GPIOB.0
        GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0; //TIM_CH3
   //初始化TIM3
        TIM_TimeBaseStructure.TIM_Period = arr; //設(shè)置在下一個(gè)更新事件裝入活動(dòng)的自動(dòng)重裝載寄存器周期的值
        TIM_TimeBaseStructure.TIM_Prescaler =psc; //設(shè)置用來作為TIMx時(shí)鐘頻率除數(shù)的預(yù)分頻值
        TIM_TimeBaseStructure.TIM_ClockDivision = 0; //設(shè)置時(shí)鐘分割:TDTS = Tck_tim
        TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;  //TIM向上計(jì)數(shù)模式
        TIM_TimeBaseInit(TIM3, &TIM_TimeBaseStructure); //根據(jù)TIM_TimeBaseInitStruct中指定的參數(shù)初始化TIMx的時(shí)間基數(shù)單位
        //初始化TIM3 Channel2 PWM模式
        TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM2; //選擇定時(shí)器模式:TIM脈沖寬度調(diào)制模式2
         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable; //比較輸出使能
        TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High; //輸出極性:TIM輸出比較極性高
        TIM_OC2Init(TIM3, &TIM_OCInitStructure);  //根據(jù)T指定的參數(shù)初始化外設(shè)TIM3 OC2
        TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);  //使能TIM3在CCR2上的預(yù)裝載寄存器
        TIM_OC3Init(TIM3, &TIM_OCInitStructure);  //根據(jù)T指定的參數(shù)初始化外設(shè)TIM3 OC3
        TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
        TIM_Cmd(TIM3, ENABLE);  //使能TIM3
4、最后在主函數(shù)進(jìn)行操作,將PB.5和PB.0接L298N的ENA和ENB,IN1,IN2接PB.2和PB.6,IN3,IN4接PB.7和PB.9
(我這里是通過按鍵KEY1進(jìn)行加速,KEY_UP進(jìn)行轉(zhuǎn)動(dòng)方向的改變,具體需要什么功能可自行設(shè)置)
int main(void)
         u16 pwmval;
        u8 dir=1;
        u8 key,m1,m2;
        delay_init();                     //延時(shí)函數(shù)初始化
        NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);          //設(shè)置NVIC中斷分組2:2位搶占優(yōu)先級,2位響應(yīng)優(yōu)先級
        uart_init(115200);         //串口初始化為115200
         LED_Init();                             //LED端口初始化
        KEY_Init();
         TIM3_PWM_Init(899,0);         //不分頻。PWM頻率=72000000/900=80Khz
         pwmval = 0;
         m1 = 0;
         m2 = 1;
                key = KEY_Scan(0);
                if(key == KEY1_PRES)
                        pwmval -= 50;
                if(key == WKUP_PRES)
                        pwmval = 350;
                        m1 = ~m1;
                        m2 = ~m2;
                delay_ms(10);
                TIM_SetCompare2(TIM3,pwmval);
                TIM_SetCompare3(TIM3,pwmval);
                IN1 = m1;
                IN2 = m2;
                IN3 = m1;
                IN4 = m2;
全部資料51hei下載地址:
電機(jī)PWM輸出實(shí)驗(yàn).rar (281.36 KB, 下載次數(shù): 413)
ID:105206 發(fā)表于 2019-2-5 15:40 | 顯示全部樓層
看看,學(xué)習(xí)了
ID:413728 發(fā)表于 2019-3-19 10:39 | 顯示全部樓層
謝謝分享
ID:413728 發(fā)表于 2019-3-19 10:40 | 顯示全部樓層
謝謝分享
ID:512279 發(fā)表于 2019-4-14 23:19 | 顯示全部樓層
很想下載來學(xué)習(xí),感謝分享
ID:583577 發(fā)表于 2019-7-13 17:21 | 顯示全部樓層
下載來學(xué)習(xí),感謝分享
ID:160995 發(fā)表于 2019-8-1 22:14 | 顯示全部樓層
看看,學(xué)習(xí)了
ID:258644 發(fā)表于 2019-8-18 14:34 | 顯示全部樓層
學(xué)習(xí)學(xué)習(xí)
ID:663863 發(fā)表于 2019-12-14 19:28 | 顯示全部樓層
那如果我用TB9612的話怎么接線?
ID:146041 發(fā)表于 2020-4-20 13:24 | 顯示全部樓層
學(xué)習(xí)使用下,根據(jù)官方例程修改的
ID:826991 發(fā)表于 2020-11-28 11:28 | 顯示全部樓層
proteus仿真電機(jī)不轉(zhuǎn)
