查看: 1896|回復: 0
使用的是51+1602液晶,就是插上點陣后發(fā)現(xiàn)液晶就顯示不出相應的數(shù)字了,求大佬指點...
ID:345750 發(fā)表于 2018-7-20 08:52 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
        #include <reg52.h>
        typedef unsigned char uchar8;
        typedef unsigned int  uint16;
        uchar8 code TAB1[] = "l do what l do";
        uchar8 code TAB2[] = "1711";
        sbit RS = P3^5;           //數(shù)據(jù)or命令選擇端(H/L)
        sbit RW = P3^4;           //讀/寫選擇端(H/L)
        sbit EN = P3^3;           //使能信號(電平)
        sbit BIT_ = P1^6;
        sbit SEG_ = P1^7;
        void DelayMS(uint16 val)
                uint16 i, j;
                for(i = 0; i < val; i++)
                        for(j = 0; j < 113; j++);
        *函數(shù)名稱:DectectBusyBit()
        *函數(shù)功能:檢測狀態(tài)標志位(忙or閑)
        void DectectBusyBit(void)
                P0 = 0xff;                         //讀取狀態(tài)值時,先賦高電平
                RS = 0;
                RW = 1;
                EN = 1;
                DelayMS(1);
                while(P0 & 0x80);         //若LCD忙,則停止在這里,否則走起
                EN = 0;                            //之后將EN初始化為低電平
         *函數(shù)名稱:WrComLCD()
         *函數(shù)功能:為LCD寫指令
         *入口參數(shù):指令(ComVal)
         void WrComLCD(uchar8 ComVal)
                 DectectBusyBit();
                RS = 0;
                RW = 0;
                EN = 1;
                P0 = ComVal;
                DelayMS(1);
                EN = 0;
         *函數(shù)名稱:WrDatLCD()
         *函數(shù)功能:為LCD寫數(shù)據(jù)
         *入口參數(shù): 數(shù)據(jù)(DatVal)
         void WrDatLCD(uchar8 DatVal)
                 DectectBusyBit();
                RS = 1;
                RW = 0;
                EN = 1;
                P0 = DatVal;
                DelayMS(1);
                EN = 0;
         *函數(shù)名稱:LCD_Init()
         *函數(shù)功能:初始化LCD
         void LCD_Init(void)
                 WrComLCD(0x38);
                DelayMS(1);
                WrComLCD(0x38);
                WrComLCD(0x01);
                WrComLCD(0x06);
                DelayMS(1);
                WrComLCD(0x0c);
         void main(void)
                 uchar8 ucval;
                SEG_ = 1;
                P0 = 0x00;
                SEG_ = 0;
                BIT_ = 1;
                P0 = 0xff;
                BIT_ = 0;
                LCD_Init();
                DelayMS(5);
                WrComLCD(0x80);
                while(TAB1[ucval] != '\0')
                        WrDatLCD(TAB1[ucval]);
                        ucval++;
                ucval = 0;
                WrComLCD(0xc0);
                while(TAB2[ucval] != '\0')
                        WrDatLCD(TAB2[ucval]);
                        ucval++;
                while(1);
