只需一步,快速開(kāi)始
查看: 1128|回復(fù): 0
C語(yǔ)言驅(qū)動(dòng)12864液晶
ID:374237 發(fā)表于 2018-7-19 10:54 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
C程序
  1. /*漢字顯示12864無(wú)字庫(kù)*/
  2. #include <AT89X051.H>
  3. #define uint unsigned int //定義一下好看
  4. #define uchar unsigned char//定義一下好看
  5. #define guanxian 0x3e //定義關(guān)顯示為16進(jìn)制的0x3e
  6. #define kaixian 0x3f //定義開(kāi)顯示為16進(jìn)制的0x3f
  7. #define ye 0xb8 //定義頁(yè)為16進(jìn)制的0xb8
  8. #define lie 0x40 //定義列為16進(jìn)制的0x40
  9. #define hang 0xc0 //定義行為16進(jìn)制的0xc0
  10. //cuhar code cheng[]= 定義放到ROM的數(shù)組
  11. uchar code y11[]=
  12. {0x40,0x48,0x48,0x48,0xFF,0x48,0x48,0x00,0xC4,0x44,0x44,0x44,0xFC,0x00,0x00,0x00,
  13. 0x80,0x60,0x1F,0x20,0x7F,0x44,0x44,0x40,0x4F,0x50,0x50,0x50,0x50,0x5C,0x40,0x00};
  14. uchar code y12[]=
  15. {0x04,0x04,0x04,0x04,0x9F,0x44,0x24,0x14,0x24,0x44,0x9F,0x04,0x04,0x04,0x04,0x00,
  16. 0x02,0x02,0x01,0x01,0x7E,0x82,0x82,0x82,0x92,0xA2,0x9E,0x81,0xF1,0x02,0x02,0x00};
  17. uchar code y13[]=
  18. {0x10,0x10,0x12,0xD2,0x52,0x5F,0x52,0xF2,0x52,0x5F,0x52,0xD2,0x12,0x10,0x10,0x00,
  19. 0x00,0x00,0x00,0x9F,0x52,0x32,0x12,0x1F,0x12,0x32,0x52,0x9F,0x00,0x00,0x00,0x00};
  20. uchar code y14[]=
  21. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  22. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  23. uchar code z11[]=
  24. {0x20,0x10,0x2C,0xE7,0x24,0x24,0x00,0xF0,0x10,0x10,0xFF,0x10,0x10,0xF0,0x00,0x00,
  25. 0x01,0x01,0x01,0x7F,0x21,0x11,0x00,0x07,0x02,0x02,0xFF,0x02,0x02,0x07,0x00,0x00};
  26. uchar code z12[]=
  27. {0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,
  28. 0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00};
  29. uchar code z13[]=
  30. {0x00,0x00,0xFE,0x02,0x12,0x22,0xC2,0x02,0xC2,0x32,0x02,0xFE,0x00,0x00,0x00,0x00,
  31. 0x80,0x60,0x1F,0x00,0x20,0x10,0x0C,0x03,0x0C,0x30,0x00,0x0F,0x30,0x40,0xF8,0x00};
  32. uchar code z14[]=
  33. {0x02,0xE2,0x22,0x22,0x22,0x22,0x22,0xFE,0x22,0x22,0x22,0x22,0x22,0xE2,0x02,0x00,
  34. 0x00,0xFF,0x00,0x00,0x09,0x12,0x00,0x7F,0x00,0x09,0x12,0x40,0x80,0x7F,0x00,0x00};
  35. uchar code z31[]=
  36. {0x00,0x00,0xF8,0x08,0x48,0x48,0x48,0xFF,0x4A,0x2A,0x2A,0x0A,0xCA,0x18,0x00,0x00,
  37. 0x80,0x60,0x1F,0x80,0x40,0x20,0x1C,0x04,0x05,0x05,0x7D,0x81,0x81,0xE0,0x00,0x00};
  38. uchar code z32[]=
  39. {0x00,0x3E,0x22,0xE2,0x22,0x3E,0x00,0xFE,0x92,0x92,0x92,0xF2,0x92,0x92,0x9E,0x00,
  40. 0x20,0x3F,0x20,0x1F,0x11,0x91,0x60,0x1F,0x00,0xFC,0x44,0x47,0x44,0x44,0xFC,0x00};
  41. uchar code z33[]=
  42. {0x10,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0xF0,0x10,0x11,0x16,0xD0,0x10,0x10,0x00,
  43. 0x80,0x40,0x20,0x18,0x06,0x41,0x20,0x10,0x3F,0x44,0x42,0x41,0x40,0x40,0x78,0x00};
  44. uchar code z34[]=
  45. {0x20,0x20,0x20,0xFC,0x24,0x26,0xA5,0x2C,0x34,0x24,0x24,0xFC,0x20,0x20,0x20,0x00,
  46. 0x40,0x42,0x7D,0x44,0x44,0x7C,0x44,0x45,0x44,0x7D,0x46,0x45,0x7C,0x40,0x40,0x00};
  47. uchar code y31[]=
  48. {0x80,0x80,0x40,0x20,0x10,0x08,0x24,0xC3,0x04,0x08,0x10,0x20,0x40,0x80,0x80,0x00,
  49. 0x00,0x00,0x00,0x02,0x02,0x02,0x02,0x82,0x42,0x22,0x1A,0x06,0x00,0x00,0x00,0x00};
  50. uchar code y32[]=
  51. {0x00,0xFE,0x22,0x22,0xFE,0x00,0x40,0x3C,0x10,0x10,0xFF,0x10,0x10,0x10,0x00,0x00,
  52. 0x80,0x7F,0x02,0x82,0xFF,0x00,0x40,0x42,0x42,0x42,0x7F,0x42,0x42,0x42,0x40,0x00};
  53. uchar code y33[]=
  54. {0x20,0x20,0x24,0x24,0x24,0x3F,0x24,0x24,0x24,0x3F,0x24,0x24,0x24,0x20,0x20,0x00,
  55. 0x00,0x00,0x00,0xFF,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0xFF,0x00,0x00,0x00,0x00};
  56. uchar code y34[]=
  57. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  58. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  59. uchar code z21[]=
  60. {0x02,0x02,0xE2,0x22,0x22,0x32,0x2A,0x26,0x22,0x22,0x22,0x22,0xE2,0x02,0x02,0x00,
  61. 0x00,0x00,0xFF,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0x42,0xFF,0x00,0x00,0x00};
  62. uchar code z22[]=
  63. {0x04,0x04,0x04,0x04,0x04,0xFC,0x44,0x44,0x44,0x44,0x44,0xC4,0x04,0x04,0x04,0x00,
  64. 0x80,0x40,0x20,0x18,0x06,0x01,0x00,0x00,0x40,0x80,0x40,0x3F,0x00,0x00,0x00,0x00};
  65. uchar code z23[]=
  66. {0x00,0x08,0xC8,0x38,0x8F,0x08,0x28,0x10,0xFC,0x4B,0x48,0xF9,0x4A,0x48,0x08,0x00,
  67. 0x04,0x23,0x70,0x2C,0x23,0x28,0x70,0x00,0xFF,0x22,0x22,0x3F,0x22,0x22,0x20,0x00};
  68. uchar code z24[]=
  69. {0x00,0xFC,0x00,0x00,0xFF,0x00,0x02,0xE2,0x22,0x22,0xFE,0x22,0x22,0xE2,0x02,0x00,
  70. 0x00,0x87,0x40,0x30,0x0F,0x00,0x00,0x1F,0x00,0x00,0xFF,0x08,0x10,0x0F,0x00,0x00};
  71. uchar code y21[]=
  72. {0x40,0x40,0x42,0xCC,0x00,0x08,0x48,0x88,0x08,0x08,0x08,0xFF,0x08,0x08,0x08,0x00,
  73. 0x00,0x40,0x20,0x1F,0x20,0x40,0x40,0x41,0x40,0x48,0x50,0x4F,0x40,0x40,0x40,0x00};
  74. uchar code y22[]=
  75. {0x20,0x20,0x20,0x20,0x20,0x20,0x20,0xFF,0x20,0x20,0x20,0x20,0x20,0x20,0x20,0x00,
  76. 0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00};
  77. uchar code y23[]=
  78. {0x10,0x60,0x02,0x0C,0xC0,0x04,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x00,0x00,
  79. 0x04,0x04,0x7C,0x03,0x20,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x20,0x00};
  80. uchar code y24[]=
  81. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  82. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  83. uchar code z41[]=
  84. {0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x40,0x40,0x00,
  85. 0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00};
  86. uchar code z42[]=
  87. {0x96,0x5A,0x32,0x7E,0x31,0x59,0x95,0x12,0x22,0xFE,0x00,0x12,0x22,0xFE,0x00,0x00,
  88. 0x00,0xFF,0x49,0x7F,0x49,0xFF,0x00,0x44,0x82,0x7F,0x04,0x42,0x81,0x7F,0x00,0x00};
  89. uchar code z43[]=
  90. {0x20,0x20,0x20,0xFF,0x20,0x20,0x80,0xF8,0x80,0x40,0xFF,0x20,0x10,0xF0,0x00,0x00,
  91. 0x10,0x30,0x10,0x0F,0x08,0x08,0x00,0x3F,0x40,0x40,0x5F,0x42,0x44,0x43,0x78,0x00};
  92. uchar code z44[]=
  93. {0x01,0x81,0x5D,0x35,0x15,0x5F,0xF5,0x55,0x55,0x5F,0x55,0x55,0xDD,0x41,0x01,0x00,
  94. 0x11,0x08,0x04,0xFE,0x01,0xA0,0x97,0xBD,0x55,0x55,0x55,0xB5,0x97,0x80,0x80,0x00};
  95. uchar code y41[]=
  96. {0xE0,0x00,0xFF,0x10,0x20,0xFE,0x92,0x92,0xFE,0x00,0xF2,0x82,0xFE,0x82,0x82,0x00,
  97. 0x01,0x00,0xFF,0x00,0x00,0x3F,0x10,0x0A,0x9C,0x60,0x18,0x07,0x3E,0x40,0x70,0x00};
  98. uchar code y42[]=
  99. {0x00,0x02,0xE2,0x22,0x22,0xE2,0x32,0x2E,0xE2,0x22,0x22,0x22,0xE2,0x02,0x00,0x00,
  100. 0x00,0x00,0xFF,0x00,0x00,0x3F,0x00,0x00,0x3F,0x00,0x40,0x80,0x7F,0x00,0x00,0x00};
  101. uchar code y43[]=
  102. {0xE0,0x00,0xFF,0x10,0x20,0xFC,0x44,0x54,0x54,0x55,0xFE,0x54,0x54,0xF4,0x44,0x00,
  103. 0x01,0x00,0xFF,0x40,0x30,0x0F,0x20,0x15,0x49,0x85,0x7F,0x09,0x11,0x29,0x24,0x00};
  104. uchar code y44[]=
  105. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  106. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  107. uchar code z211[]=
  108. {0x10,0x0C,0x04,0xE4,0x24,0x24,0x25,0x26,0x24,0x24,0x24,0xE4,0x04,0x14,0x0C,0x00,
  109. 0x40,0x40,0x40,0x7F,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0x7F,0x40,0x40,0x40,0x00};
  110. uchar code z212[]=
  111. {0x00,0x08,0x30,0x00,0xFF,0x00,0x88,0x84,0x53,0x22,0x12,0xCA,0x06,0x00,0x00,0x00,
  112. 0x04,0x04,0x02,0x01,0xFF,0x00,0x02,0x0A,0x12,0x42,0x82,0x7F,0x02,0x02,0x02,0x00};
  113. uchar code z213[]=
  114. {0x48,0x4A,0xFA,0x0A,0xFE,0x09,0xF9,0x49,0xA8,0x00,0x00,0xF0,0x00,0x00,0xFF,0x00,
  115. 0x22,0x11,0x0B,0x04,0xFF,0x04,0x09,0x12,0x23,0x00,0x00,0x0F,0x40,0x80,0x7F,0x00};
  116. uchar code z214[]=
  117. {0x00,0x00,0xF9,0xA9,0xA9,0xAB,0xAB,0xFD,0xAD,0xAB,0xAB,0xA9,0xF8,0x00,0x00,0x00,
  118. 0x00,0x88,0x8B,0x48,0x28,0x18,0x0E,0x09,0x08,0x48,0x88,0x48,0x3B,0x00,0x00,0x00};
  119. uchar code y211[]=
  120. {0x40,0x40,0x42,0xCC,0x00,0x00,0xFC,0x24,0x24,0x26,0x25,0x24,0x24,0x3C,0x00,0x00,
  121. 0x00,0x40,0x20,0x1F,0x20,0x40,0x5F,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0x5F,0x00};
  122. uchar code y212[]=
  123. {0x10,0x0C,0x44,0x24,0x14,0x04,0xC5,0x06,0x04,0x04,0x14,0x24,0x44,0x14,0x0C,0x00,
  124. 0x00,0x81,0x41,0x21,0x11,0x0D,0x03,0x01,0x41,0x81,0x41,0x3F,0x00,0x00,0x00,0x00};
  125. uchar code y213[]=
  126. {0x10,0x0C,0x24,0x24,0x24,0x24,0x25,0x06,0x04,0x04,0xF4,0x24,0x24,0x14,0x0C,0x00,
  127. 0x00,0x81,0x61,0x1F,0x01,0x7F,0x81,0x80,0xA1,0x95,0x89,0x95,0x83,0xF0,0x00,0x00};
  128. uchar code y214[]=
  129. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  130. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  131. uchar code z221[]=
  132. {0x00,0x02,0x02,0x02,0x02,0x82,0x42,0xF2,0x0E,0x42,0x82,0x02,0x02,0x02,0x00,0x00,
  133. 0x10,0x08,0x04,0x02,0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0x01,0x02,0x0C,0x00,0x00};
  134. uchar code z222[]=
  135. {0x00,0x02,0x02,0xF2,0x12,0x12,0x12,0xF2,0x02,0x02,0x02,0xFE,0x02,0x02,0x02,0x00,
  136. 0x00,0x00,0x00,0x0F,0x04,0x04,0x04,0x0F,0x00,0x40,0x80,0x7F,0x00,0x00,0x00,0x00};
  137. uchar code z223[]=
  138. {0x10,0x60,0x02,0x0C,0xC0,0x10,0x10,0x10,0x10,0xFF,0x10,0x10,0x10,0x10,0x10,0x00,
  139. 0x04,0x04,0x7C,0x03,0x00,0x00,0xFF,0x41,0x41,0x41,0x41,0x41,0xFF,0x00,0x00,0x00};
  140. uchar code z224[]=
  141. {0x00,0x20,0x20,0x10,0x08,0x14,0x67,0x84,0x44,0x24,0x14,0x0C,0x00,0x00,0x00,0x00,
  142. 0x04,0x04,0x04,0x02,0xFE,0x43,0x43,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00};
  143. uchar code y221[]=
  144. {0x40,0x30,0x11,0x96,0x90,0x90,0x91,0x96,0x90,0x90,0x98,0x14,0x13,0x50,0x30,0x00,
  145. 0x04,0x04,0x04,0x04,0x04,0x44,0x84,0x7E,0x06,0x05,0x04,0x04,0x04,0x04,0x04,0x00};
  146. uchar code y222[]=
  147. {0x10,0x4C,0xE5,0x55,0x55,0x55,0xE5,0x5F,0x05,0xD5,0x55,0x55,0x45,0xD4,0x0C,0x00,
  148. 0x40,0x5C,0x55,0x55,0xFF,0x55,0x55,0x5C,0x80,0x7F,0x12,0x52,0x92,0x7F,0x00,0x00};
  149. uchar code y223[]=
  150. {0x00,0x02,0x82,0x82,0x82,0x82,0x82,0xFE,0x82,0x82,0x82,0x82,0x82,0x02,0x00,0x00,
  151. 0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00};
  152. uchar code y224[]=
  153. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  154. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  155. uchar code z231[]=
  156. {0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x40,0x40,0x00,
  157. 0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00};
  158. uchar code z232[]=
  159. {0x44,0x44,0x44,0x44,0x5F,0xC4,0x74,0x44,0x44,0x44,0x5F,0x44,0x44,0x44,0x44,0x00,
  160. 0x10,0x08,0x04,0x02,0xFF,0x42,0x42,0x42,0x42,0x42,0x42,0xFE,0x00,0x00,0x00,0x00};
  161. uchar code z233[]=
  162. {0x04,0x04,0x04,0x84,0xE4,0x3C,0x27,0x24,0x24,0x24,0x24,0xE4,0x04,0x04,0x04,0x00,
  163. 0x04,0x02,0x01,0x00,0xFF,0x09,0x09,0x09,0x09,0x49,0x89,0x7F,0x00,0x00,0x00,0x00};
  164. uchar code z234[]=
  165. {0x00,0xE0,0x00,0xFF,0x10,0x64,0x54,0x54,0x54,0x7F,0x54,0x54,0x54,0x44,0x40,0x00,
  166. 0x01,0x00,0x00,0xFF,0x00,0x00,0xFF,0x15,0x15,0x15,0x55,0x95,0x7F,0x00,0x00,0x00};
  167. uchar code y231[]=
  168. {0x40,0x40,0x42,0x42,0x42,0x42,0x42,0xFE,0x42,0x42,0x42,0x42,0x42,0x40,0x40,0x00,
  169. 0x80,0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x80,0x00};
  170. uchar code y232[]=
  171. {0x08,0x08,0xC8,0x08,0x08,0xF8,0x09,0x0E,0x08,0xF8,0x08,0x48,0x88,0x08,0x08,0x00,
  172. 0x08,0x86,0x41,0x20,0x18,0x07,0x00,0x40,0x80,0x7F,0x00,0x00,0x01,0x0E,0x00,0x00};
  173. uchar code y233[]=
  174. {0x20,0x20,0x24,0x24,0x24,0x24,0xBF,0x64,0x24,0x34,0x28,0x24,0x22,0x20,0x20,0x00,
  175. 0x10,0x08,0x04,0x02,0x3F,0x45,0x44,0x44,0x42,0x42,0x42,0x41,0x78,0x00,0x00,0x00};
  176. uchar code y234[]=
  177. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  178. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  179. uchar code z241[]=
  180. {0x00,0x00,0x00,0x00,0x00,0x00,0xC0,0x3F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  181. 0x80,0x40,0x20,0x10,0x0C,0x03,0x00,0x00,0x00,0x03,0x0C,0x10,0x20,0x40,0x80,0x00};
  182. uchar code z242[]=
  183. {0x00,0xF8,0x01,0x06,0x00,0xF0,0x12,0x12,0x12,0xF2,0x02,0x02,0x02,0xFE,0x00,0x00,
  184. 0x00,0xFF,0x00,0x00,0x00,0x1F,0x11,0x11,0x11,0x1F,0x00,0x40,0x80,0x7F,0x00,0x00};
  185. uchar code z243[]=
  186. {0x00,0x02,0x02,0xC2,0x02,0x02,0x02,0xFE,0x82,0x82,0x82,0x82,0x82,0x02,0x00,0x00,
  187. 0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x40,0x40,0x40,0x00};
  188. uchar code z244[]=
  189. {0x40,0x40,0x42,0xCC,0x00,0x08,0xE9,0xAA,0xB8,0xA8,0xA8,0xAA,0xE9,0x08,0x00,0x00,
  190. 0x00,0x40,0x20,0x1F,0x20,0x40,0x5F,0x4A,0x4A,0x4A,0x4A,0x4A,0x5F,0x40,0x40,0x00};
  191. uchar code y241[]=
  192. {0x00,0x00,0x00,0x7F,0x49,0x49,0x49,0x49,0x49,0x49,0x49,0x7F,0x00,0x00,0x00,0x00,
  193. 0x81,0x41,0x21,0x1D,0x21,0x41,0x81,0xFF,0x89,0x89,0x89,0x89,0x89,0x81,0x81,0x00};
  194. uchar code y242[]=
  195. {0x20,0xC2,0x0C,0x00,0x40,0x20,0xD0,0x48,0x44,0x43,0x44,0xC8,0x10,0x20,0x40,0x00,
  196. 0x04,0x04,0x7E,0x01,0x00,0x00,0x3F,0x40,0x40,0x44,0x48,0x47,0x40,0x70,0x00,0x00};
  197. uchar code y243[]=
  198. {0x00,0x20,0x60,0xA1,0xA9,0x6B,0x0B,0x05,0x25,0x6B,0xA1,0xA0,0x60,0x00,0x00,0x00,
  199. 0x40,0x45,0x25,0x24,0x14,0x0D,0x05,0xFE,0x05,0x0D,0x14,0x24,0x25,0x45,0x40,0x00};
  200. uchar code y244[]=
  201. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  202. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  203. uchar code z311[]=
  204. {0x20,0x30,0xAC,0x63,0x20,0x18,0x00,0x04,0x04,0x04,0xFC,0x04,0x04,0x04,0x00,0x00,
  205. 0x22,0x67,0x22,0x12,0x12,0x12,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x40,0x00};
  206. uchar code z312[]=
  207. {0x08,0x06,0x22,0x22,0xA2,0x62,0x3A,0xA2,0x22,0x22,0x22,0x22,0x22,0x0A,0x06,0x00,
  208. 0x10,0x10,0x12,0x13,0x12,0x12,0x12,0xFF,0x12,0x12,0x12,0x12,0x12,0x10,0x10,0x00};
  209. uchar code z313[]=
  210. {0x00,0x02,0x02,0x02,0x02,0x82,0x42,0xF2,0x0E,0x42,0x82,0x02,0x02,0x02,0x00,0x00,
  211. 0x10,0x08,0x04,0x02,0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0x01,0x02,0x0C,0x00,0x00};
  212. uchar code z314[]=
  213. {0x00,0xE0,0x00,0xFF,0x10,0x20,0x00,0xF8,0x08,0x0C,0x0B,0x08,0x08,0xF8,0x00,0x00,
  214. 0x01,0x00,0x00,0xFF,0x00,0x00,0x00,0xFF,0x41,0x41,0x41,0x41,0x41,0xFF,0x00,0x00};
  215. uchar code y311[]=
  216. {0x40,0x40,0x42,0xCC,0x00,0x20,0x22,0xE2,0x22,0x22,0xE2,0x22,0x22,0x20,0x00,0x00,
  217. 0x00,0x80,0x40,0x3F,0x40,0xA0,0x98,0x87,0x80,0x80,0x9F,0xA0,0xA0,0xBC,0x80,0x00};
  218. uchar code y312[]=
  219. {0x00,0x10,0x88,0xC4,0x33,0x00,0x04,0xC4,0x04,0x04,0xFC,0x04,0x04,0x04,0x04,0x00,
  220. 0x02,0x01,0x00,0xFF,0x00,0x40,0x40,0x7F,0x40,0x40,0x7F,0x41,0x41,0x41,0x40,0x00};
  221. uchar code y313[]=
  222. {0x04,0x24,0xC4,0x04,0xE4,0x5C,0x20,0xF8,0x4F,0x48,0x49,0xFA,0x48,0x48,0x08,0x00,
  223. 0x20,0x10,0x0C,0x03,0x04,0x18,0x00,0xFF,0x22,0x22,0x22,0x3F,0x22,0x22,0x20,0x00};
  224. uchar code y314[]=
  225. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  226. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  227. uchar code z321[]=
  228. {0x04,0x04,0x04,0x04,0x04,0xFC,0x44,0x44,0x44,0x44,0x44,0xC4,0x04,0x04,0x04,0x00,
  229. 0x80,0x40,0x20,0x18,0x06,0x01,0x00,0x00,0x40,0x80,0x40,0x3F,0x00,0x00,0x00,0x00};
  230. uchar code z322[]=
  231. {0x00,0x20,0x20,0x20,0xA0,0x60,0x00,0xFF,0x60,0x80,0x40,0x20,0x18,0x00,0x00,0x00,
  232. 0x20,0x10,0x08,0x06,0x01,0x40,0x80,0x7F,0x00,0x01,0x02,0x04,0x08,0x10,0x10,0x00};
  233. uchar code z323[]=
  234. {0x80,0x80,0x84,0x84,0x84,0x84,0x84,0xFC,0x82,0x82,0x82,0x83,0x82,0x80,0x80,0x00,
  235. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  236. uchar code z324[]=
  237. {0x00,0x00,0xF0,0x00,0x00,0x00,0x00,0xFF,0x00,0x00,0x00,0x00,0xF0,0x00,0x00,0x00,
  238. 0x00,0x00,0x3F,0x20,0x20,0x20,0x20,0x3F,0x20,0x20,0x20,0x20,0x7F,0x00,0x00,0x00};
  239. uchar code y321[]=
  240. {0x00,0x00,0x00,0xFE,0x02,0x02,0x02,0x02,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,0x00,
  241. 0x00,0x80,0x40,0x23,0x19,0x01,0x01,0x01,0x01,0x01,0x09,0x13,0x20,0xC0,0x00,0x00};
  242. uchar code y322[]=
  243. {0x08,0x04,0x23,0x22,0x26,0x2A,0x22,0xFA,0x24,0x23,0x22,0x26,0x2A,0x02,0x02,0x00,
  244. 0x01,0x09,0x09,0x09,0x19,0x69,0x09,0x09,0x49,0x89,0x7D,0x09,0x09,0x09,0x01,0x00};
  245. uchar code y323[]=
  246. {0x00,0xF8,0x01,0x42,0x40,0x42,0x42,0xFA,0x42,0x42,0x42,0x42,0x02,0xFE,0x00,0x00,
  247. 0x00,0xFF,0x00,0x08,0x04,0x02,0x01,0x3F,0x01,0x02,0x04,0x48,0x80,0x7F,0x00,0x00};
  248. uchar code y324[]=
  249. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  250. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  251. uchar code z331[]=
  252. {0x00,0x02,0x42,0x42,0x42,0xC2,0x7E,0x42,0x42,0x42,0x42,0xC2,0x02,0x02,0x00,0x00,
  253. 0x40,0x40,0x40,0x40,0x78,0x47,0x40,0x40,0x40,0x40,0x40,0x7F,0x40,0x40,0x40,0x00};
  254. uchar code z332[]=
  255. {0x00,0xF0,0x00,0xFF,0x00,0xF0,0x40,0x20,0x10,0x0C,0x23,0xCC,0x10,0x20,0x40,0x00,
  256. 0x00,0x1F,0x10,0x0F,0x08,0x1F,0x00,0x01,0x09,0x11,0x21,0xD1,0x0D,0x03,0x00,0x00};
  257. uchar code z333[]=
  258. {0x40,0x40,0x42,0xCC,0x00,0x48,0x2A,0x1A,0x8A,0x7E,0x09,0x19,0x29,0x48,0x00,0x00,
  259. 0x00,0x80,0x40,0x3F,0x41,0xA1,0xA5,0x97,0x95,0x89,0x89,0x95,0x93,0xA1,0x81,0x00};
  260. uchar code z334[]=
  261. {0x40,0x40,0x42,0xCC,0x20,0x98,0xE7,0x84,0x44,0xFC,0x44,0x24,0xE4,0x04,0x00,0x00,
  262. 0x00,0x40,0x20,0x1F,0x20,0x40,0x4F,0x50,0x50,0x57,0x51,0x52,0x51,0x5C,0x40,0x00};
  263. uchar code y331[]=
  264. {0x00,0xFE,0x22,0x22,0xFE,0x28,0xA9,0x6E,0x28,0x3F,0x28,0x6C,0xAB,0x28,0x20,0x00,
  265. 0x80,0x7F,0x02,0x82,0xFF,0x01,0x20,0x2D,0x29,0x29,0x29,0x4F,0x88,0x79,0x01,0x00};
  266. uchar code y332[]=
  267. {0x20,0x30,0xAC,0x63,0x20,0x18,0x00,0xFC,0x04,0x04,0xFC,0x04,0x04,0xFC,0x00,0x00,
  268. 0x22,0x67,0x22,0x12,0x12,0x12,0x00,0xFF,0x41,0x41,0x7F,0x41,0x41,0xFF,0x00,0x00};
  269. uchar code y333[]=
  270. {0x10,0x60,0x02,0x0C,0xC0,0x00,0xFC,0x24,0x25,0x26,0x24,0x24,0xFC,0x00,0x00,0x00,
  271. 0x04,0x04,0x7C,0x03,0x00,0x00,0xFF,0x41,0x21,0x07,0x09,0x11,0x29,0x44,0x40,0x00};
  272. uchar code y334[]=
  273. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  274. 0x00,0x00,0x58,0x38,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  275. uchar code z341[]=
  276. {0x00,0x00,0x00,0xFC,0x04,0x04,0x06,0x05,0x04,0x44,0x84,0x7C,0x00,0x00,0x00,0x00,
  277. 0x00,0x10,0x10,0x13,0x12,0x12,0x12,0x12,0x12,0x12,0x52,0x82,0x42,0x3E,0x00,0x00};
  278. uchar code z342[]=
  279. {0x22,0x9A,0x8A,0x8A,0xAF,0xAA,0xAA,0xAA,0xAA,0xAA,0xAF,0x8A,0x8A,0xAA,0x1A,0x00,
  280. 0x00,0x50,0x52,0x4A,0x2A,0x25,0x53,0x8A,0x7C,0x08,0x14,0x24,0x22,0x40,0x40,0x00};
  281. uchar code z343[]=
  282. {0x04,0xE4,0x5C,0x44,0xC4,0x80,0x64,0x2C,0x34,0xA5,0x26,0x34,0x2C,0xA4,0x60,0x00,
  283. 0x01,0x3F,0x10,0x10,0x3F,0x00,0x82,0x62,0x1E,0x0A,0x4B,0x8A,0x7A,0x02,0x00,0x00};
  284. uchar code z344[]=
  285. {0x84,0xE4,0x5C,0xC4,0x00,0x48,0x92,0x02,0xD7,0x52,0x52,0xFA,0x57,0x52,0xDA,0x00,
  286. 0x00,0x3F,0x10,0x3F,0x00,0x10,0xF9,0x04,0x2F,0x65,0xA5,0x2F,0xA5,0xF5,0x2F,0x00};
  287. uchar code y341[]=
  288. {0x40,0x40,0x48,0x48,0x48,0x48,0x48,0xFF,0x48,0x48,0x48,0x48,0x48,0x40,0x40,0x00,
  289. 0x80,0x40,0x20,0x1E,0x20,0x40,0x40,0x7F,0x44,0x44,0x44,0x44,0x44,0x40,0x40,0x00};
  290. uchar code y342[]=
  291. {0x10,0x60,0x02,0x0C,0xC0,0x00,0xFE,0x22,0x22,0xA2,0x22,0x22,0x22,0x3E,0x00,0x00,
  292. 0x04,0x04,0x7C,0x83,0x40,0x30,0x0F,0x00,0x00,0x3F,0x44,0x44,0x42,0x41,0x70,0x00};
  293. uchar code y343[]=
  294. {0x00,0x10,0x10,0x50,0x90,0x10,0xFF,0x10,0x10,0x10,0xF0,0x00,0x00,0x00,0x00,0x00,
  295. 0x80,0x40,0x20,0x10,0x0C,0x03,0x04,0x18,0x00,0x00,0x3F,0x40,0x40,0x40,0x78,0x00};
  296. uchar code y344[]=
  297. {0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  298. 0x00,0x00,0x18,0x24,0x24,0x18,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00};
  299. /*2051單片機(jī)*/
  300. sbit lcdrst=P3^5; //定義P3^5為lcdrst
  301. sbit lcdcs2=P3^1; //定義P3^1為lcdcs2
  302. sbit lcdcs1=P3^0; //定義P3^0為lcdcs1
  303. sbit lcde=P3^4; //定義P3^4為lcde
  304. sbit lcdrw=P3^3; //定義P3^3為lcdrw
  305. sbit lcdrs=P3^2; //定義P3^2為lcdrs
  306. void delay(uint z) //延時(shí)函數(shù)
  307. {
  308. uint x,y;
  309. for(x=z;x>0;x--)
  310. for(y=124;y>0;y--);
  311. }
  312. void write_com(uchar com)//寫命令子函數(shù)
  313. {
  314. lcdrs=0;
  315. lcdrw=0;
  316. P1=com;
  317. delay(1);
  318. lcde=1;
  319. delay(1);
  320. lcde=0;
  321. }
  322. void write_data(uchar dat) //寫數(shù)據(jù)子函數(shù)
  323. {
  324. lcdrs=1;
  325. lcdrw=0;
  326. P1=dat;
  327. delay(1);
  328. lcde=1;
  329. delay(1);
  330. lcde=0;
  331. }
  332. void initlcd() //初始化12864
  333. {
  334. write_com(guanxian);
  335. write_com(kaixian);
  336. write_com(ye);
  337. write_com(lie);
  338. write_com(hang);
  339. }
  340. void cleanlcd() //清屏
  341. {
  342. uchar i,j;
  343. for(i=0;i<8;i++)
  344. {
  345. write_com(ye+i);
  346. write_com(lie);
  347. for(j=0;j<64;j++)
  348. write_data(0x00);
  349. }
  350. }
  351. void dis(uchar yes,uchar lies,uchar *hz) //定義顯示頁(yè),列,行
  352. {
  353. uchar i,j;
  354. for(i=0;i<2;i++)
  355. {
  356. write_com(ye+yes+i);
  357. write_com(lie+lies);
  358. for(j=0;j<16;j++)
  359. write_data(hz[16*i+j]);
  360. }
  361. }
  362. void displaylcd() //顯示函數(shù)
  363. {
  364. //一頁(yè)
  365. lcdcs1=0;
  366. lcdcs2=1;
  367. dis(0,0,z11);
  368. dis(0,16,z12);
  369. dis(0,32,z13);
  370. dis(0,48,z14);
  371. lcdcs1=1;
  372. lcdcs2=0;
  373. dis(0,0,y11);
  374. dis(0,16,y12);
  375. dis(0,32,y13);
  376. dis(0,48,y14);
  377. lcdcs1=0;
  378. lcdcs2=1;
  379. dis(2,0,z21);
  380. dis(2,16,z22);
  381. dis(2,32,z23);
  382. dis(2,48,z24);
  383. lcdcs1=1;
  384. lcdcs2=0;
  385. dis(2,0,y21);
  386. dis(2,16,y22);
  387. dis(2,32,y23);
  388. dis(2,48,y24);
  389. lcdcs1=0;
  390. lcdcs2=1;
  391. dis(4,0,z31);
  392. dis(4,16,z32);
  393. dis(4,32,z33);
  394. dis(4,48,z34);
  395. lcdcs1=1;
  396. lcdcs2=0;
  397. dis(4,0,y31);
  398. dis(4,16,y32);
  399. dis(4,32,y33);
  400. dis(4,48,y34);
  401. lcdcs1=0;
  402. lcdcs2=1;
  403. dis(6,0,z41);
  404. dis(6,16,z42);
  405. dis(6,32,z43);
  406. dis(6,48,z44);
  407. lcdcs1=1;
  408. lcdcs2=0;
  409. dis(6,0,y41);
  410. dis(6,16,y42);
  411. dis(6,32,y43);
  412. dis(6,48,y44);
  413. delay(2000);
  414. //2頁(yè)
  415. lcdcs1=0;
  416. lcdcs2=1;
  417. dis(0,0,z211);
  418. dis(0,16,z212);
  419. dis(0,32,z213);
  420. dis(0,48,z214);
  421. lcdcs1=1;
  422. lcdcs2=0;
  423. dis(0,0,y211);
  424. dis(0,16,y212);
  425. dis(0,32,y213);
  426. dis(0,48,y214);
  427. lcdcs1=0;
  428. lcdcs2=1;
  429. dis(2,0,z221);
  430. dis(2,16,z222);
  431. dis(2,32,z223);
  432. dis(2,48,z224);
  433. lcdcs1=1;
  434. lcdcs2=0;
  435. dis(2,0,y221);
  436. dis(2,16,y222);
  437. dis(2,32,y223);
  438. dis(2,48,y224);
  439. lcdcs1=0;
  440. lcdcs2=1;
  441. dis(4,0,z231);
  442. dis(4,16,z232);
  443. dis(4,32,z233);
  444. dis(4,48,z234);
  445. lcdcs1=1;
  446. lcdcs2=0;
  447. dis(4,0,y231);
  448. dis(4,16,y232);
  449. dis(4,32,y233);
  450. dis(4,48,y234);
  451. lcdcs1=0;
  452. lcdcs2=1;
  453. dis(6,0,z241);
  454. dis(6,16,z242);
  455. dis(6,32,z243);
  456. dis(6,48,z244);
  457. lcdcs1=1;
  458. lcdcs2=0;
  459. dis(6,0,y241);
  460. dis(6,16,y242);
  461. dis(6,32,y243);
  462. dis(6,48,y244);
  463. //3頁(yè)
  464. lcdcs1=0;
  465. lcdcs2=1;
  466. dis(0,0,z311);
  467. dis(0,16,z312);
  468. dis(0,32,z313);
  469. dis(0,48,z314);
  470. lcdcs1=1;
  471. lcdcs2=0;
  472. dis(0,0,y311);
  473. dis(0,16,y312);
  474. dis(0,32,y313);
  475. dis(0,48,y314);
  476. lcdcs1=0;
  477. lcdcs2=1;
  478. dis(2,0,z321);
  479. dis(2,16,z322);
  480. dis(2,32,z323);
  481. dis(2,48,z324);
  482. lcdcs1=1;
  483. lcdcs2=0;
  484. dis(2,0,y321);
  485. dis(2,16,y322);
  486. dis(2,32,y323);
  487. dis(2,48,y324);
  488. lcdcs1=0;
  489. lcdcs2=1;
  490. dis(4,0,z331);
  491. dis(4,16,z332);
  492. dis(4,32,z333);
  493. dis(4,48,z334);
  494. lcdcs1=1;
  495. lcdcs2=0;
  496. dis(4,0,y331);
  497. dis(4,16,y332);
  498. dis(4,32,y333);
  499. dis(4,48,y334);
  500. lcdcs1=0;
  501. lcdcs2=1;
  502. dis(6,0,z341);
  503. dis(6,16,z342);
  504. dis(6,32,z343);
  505. dis(6,48,z344);
  506. lcdcs1=1;
  507. lcdcs2=0;
  508. dis(6,0,y341);
  509. dis(6,16,y342);
  510. dis(6,32,y343);
  511. dis(6,48,y344);
  512. delay(2000);
  513. }
  514. void main()//主函數(shù)
  515. {
  516. initlcd();
  517. cleanlcd();
  518. displaylcd();
  519. while(1);
  520. }
