查看: 2518|回復: 0
MLX90614引腳圖與數據手冊 rev008 Datasheet下載
2 General Description
The  MLX90614  is  an  Infra  Red  thermometer  for  non
contact  temperature measurements.   Both  the  IR sensitive
thermopile detector chip and  the signal conditioning ASSP
are integrated in the same TO-39 can.
Thanks  to  its  low  noise  amplifier,  17-bit  ADC  and
powerful DSP  unit,  a  high  accuracy  and  resolution  of  the
thermometer is achieved.
The  thermometer comes  factory calibrated with a digital
PWM and SMBus (System Management Bus) output.
As  a  standard,  the  10-bit  PWM  is  configured  to
continuously  transmit  the measured  temperature  in  range
of -20…120˚C, with an output resolution of 0.14˚C.
The factory default POR setting is SMBus.
MLX90614引腳圖:
MLX90614數據手冊:
完整的pdf格式文檔51黑下載地址:
MLX90614.pdf (4.59 MB, 下載次數: 5)
