#include<reg52.h>
#define LCD1602_DB P0 //data bus 數(shù)據(jù)總線
sbit LCD1602_RS = P2^6;
sbit LCD1602_RW = P2^5;
sbit LCD1602_EN = P2^7;
void InitLcd1602();
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str);
unsigned char str[] = "Welcome To You";
InitLcd1602();
LcdShowStr(0,0,str);
while(1);
void Read_Busy() //忙檢測函數(shù),判斷bit7是0,允許執(zhí)行;1禁止
unsigned char sta; //
LCD1602_DB = 0xff;
LCD1602_RS = 0;
LCD1602_RW = 1;
do
LCD1602_EN = 1;
sta = LCD1602_DB;
LCD1602_EN = 0; //使能,用完就拉低,釋放總線
}while(sta & 0x80);
void Lcd1602_Write_Cmd(unsigned char cmd) //寫命令
Read_Busy();
LCD1602_RS = 0;
LCD1602_RW = 0;
LCD1602_DB = cmd;
LCD1602_EN = 1;
LCD1602_EN = 0;
void Lcd1602_Write_Data(unsigned char dat) //寫數(shù)據(jù)
Read_Busy();
LCD1602_RS = 1;
LCD1602_RW = 0;
LCD1602_DB = dat;
LCD1602_EN = 1;
LCD1602_EN = 0;
void LcdSetCursor(unsigned char x,unsigned char y) //坐標(biāo)顯示
unsigned char addr;
if(y == 0)
addr = 0x00 + x;
addr = 0x40 + x;
Lcd1602_Write_Cmd(addr|0x80);
void LcdShowStr(unsigned char x,unsigned char y,unsigned char *str) //顯示字符串
LcdSetCursor(x,y); //當(dāng)前字符的坐標(biāo)
while(*str != '\0')
Lcd1602_Write_Data(*str++);
void InitLcd1602() //1602初始化
Lcd1602_Write_Cmd(0x38); //打開,5*8,8位數(shù)據(jù)
Lcd1602_Write_Cmd(0x0c);
Lcd1602_Write_Cmd(0x06);
Lcd1602_Write_Cmd(0x01); //清屏
