查看: 3632|回復: 2
51單片機做的十字路口交通燈控制仿真
ID:372292 發表于 2018-7-16 09:21 | 顯示全部樓層 |閱讀模式
#include<reg51.h>
uchar code table[]={
0x3f,0x06,0x5b,0x4f,
0x66,0x6d,0x7d,0x07,
0x7f,0x6f,0x77,0x7c,
0x39,0x5e,0x79,0x71,
0xc9,0x5FF,0x40     };
void delay(uint x);
void display(uchar,uchar,uchar,uchar);
void scankeys();
void traffic();
uchar num,num1,num2,shi1,ge1,shi2,ge2,
value1,value2,value3,value4,count1,
count2,flag1,flag2;
void mian()
     TMOD=0x01;
     TH0=(65536-45872)/256;
     TL0=(65536-45872)%256;
     EA=1;
     ET0=1;
     TR0=1;
     value1=15;
     value2=5;
     value3=10;
     value4=5;
     num1=value1;
     num2=value2+value1;
    P1=0x41;
    if(num==20)
    num=0;
    num1--;
    num2--;
    traffic();
    shi1=num1/10;
    ge1=num1%10;
    shi2=num2/10;
    ge2=num2%10;
scankeys();
display(shi1,ge1,shi2,ge2);
void traffic()
     if(num1==0)
      count1++;
      if(count1==1)
       P1=0x42;
       num1=value2;
      if(count1==2)
       P1=0x14;
       num1=value3+value4;
       if(count1==3)
       P1=0x41;
       num1=value1;
       count1=0;
if(num==0)
count2++;
if(count2==1)
    P1=0x14;
    num2=value3;
if(count2==2)
    P1=0x24;
    num2=value4;
if(count2==3)
    P1=0x41;
    num2=value1+value2;
    count2=0;
void display(uchar shi1,uchar ge1,uchar shi2,uchar ge2)
     uchar temp;
     temp=P2;
     P2=0xfe;
     P0=table[shi1];
     delay(5);
     P2=0xfd;
     P0=table[ge1];
     delay(5);
     P2=0xfd;
     P0=table[shi2];
     delay(5);
     P2=0xf7;
     P0=table[ge2];
     delay(5);
void delay(uint x)
   uint i,j;
   for(i=x;i>0;i--)
   for(j=110;j>0;j--);
void scankeys()
    uchar temp,key;
    P3=0xfe;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    delay(10);
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    temp=P3;
    switch(temp)
    case 0xee:key=0;break;
    case 0xde:key=1;break;
    case 0xbe:key=2;break;
    case 0x7e:key=3;break;
while(temp!=0xf0)
     temp=P3;
     temp=temp&0xf0;
if(key==0)
    TR0=~TR0;
    flag1=~flag1;
    flag2=~flag2;
if(key==1&&flag1==0)
    TR0=0;
    P1=0x44;
    shi1=ge1=shi2=ge2=16;
if(key==2&&flag2==0)
   TR0=1;
   num=0;
   P1=0x41;
   num1=value1;
   num2=value2+value1;
   shi1=num/10;
   ge1=num1%10;
   shi2=num2/10;
   ge2=num2%10;
if(key==3&&P1==0x44)
   P1=0xff;
   delay(1000);
   P1=~P1;
   shi1=ge1=shi2=ge2=17;
   P1=0x44;
    P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    delay(10);
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    temp=P3;
    switch(temp)
    case 0xe7:key=0;break;
    case 0xd7:key=1;break;
    case 0xb7:key=2;break;
    case 0x77:key=3;break;
while(temp!=0xf0)
     temp=P3;
     temp=temp&0xf0;
if(key==0&&P1==0x44)
    P1=0x41;
    shi1=ge1=shi2=ge2=18;
if(key==1&&P1==0x44)
    P1=0x41;
if(key==2&&P1==0x44)
    P1=0x41;
    P1=0x41;
P3=0xfd;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    delay(10);
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    temp=P3;
    switch(temp)
    case 0xeb:key=0;break;
    case 0xdb:key=1;break;
    case 0xbb:key=2;break;
    case 0x7b:key=3;break;
while(temp!=0xf0)
     temp=P3;
     temp=temp&0xf0;
    num2=value3;
    if(num1!=159)
num2++;
value3=num2;
   shi2=num2/10;
   ge2=num2%10;
   num1=value3+value4;
   shi1=num1/10;
   ge1=num1%10;
{  num2=value4;
    if(num1!=159)
num2++;
value4=num2;
   shi2=num2/10;
   ge2=num2%10;
   num1=value3+value4;
   shi1=num1/10;
   ge1=num1%10;
if(key==2&&P1==0x44&&value3>3)
{  num2=value3;
   num2--;
value3=num2;
   shi2=num2/10;
   ge2=num2%10;
   num2=value3+value4;
   shi1=num1/10;
   ge1=num1%10;
if(key==3&&P1==0x44&&value4>3)
{  num2=value4;
   num2--;
value4=num2;
   shi2=num2/10;
   ge2=num2%10;
   num1=value3+value4;
   shi1=num1/10;
   ge1=num1%10;
P3=0xf7;
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    delay(10);
    temp=P3;
    temp=temp&0xf0;
    if(temp!=0xf0)
    temp=P3;
    switch(temp)
while(temp!=0xf0)
   temp=P3;
   temp=temp&0xf0;
   P1=0x41;
   P1=0x41;
   P1=0x41;
   P1=0x41;
void T0_time() interrupt 1
num++;
ID:527416 發表于 2019-6-14 16:37 | 顯示全部樓層
請問信號燈是什么裝置
ID:194782 發表于 2019-6-17 21:21 | 顯示全部樓層
好東西
