1、找到安裝Keil路徑;
2、在UV4目錄下的global.prop文件;
3、替換這個(gè)文件就可以了。
2018-7-14 09:36 上傳
- # properties for all file types
- indent.automatic=1
- virtual.space=0
- view.whitespace=0
- view.endofline=0
- code.page=0
- caretline.visible=0
- highlight.matchingbraces=1
- print.syntax.coloring=1
- use.tab.color=1
- create.backup.files=0
- auto.load.ext.modfiles=0
- save.prj.before.dbg=0
- save.files.before.dbg=0
- function.scanner.project=1
- function.scanner.files=1
- function.scanner.modules=1
- # properties for c/cpp files
- syntax.colouring.cpp=1
- use.tab.cpp=0
- tabsize.cpp=2
- line.margin.visible.cpp=1
- fold.cpp=1
- monospaced.font.cpp=1
- # properties for asm files
- syntax.colouring.asm=1
- use.tab.asm=0
- tabsize.asm=4
- line.margin.visible.asm=1
- monospaced.font.asm=1
- # properties for other files
- use.tabs=0
- tabsize=4
- line.margin.visible.txt=0
- monospaced.font.txt=1
- # setting for code completion and syntax check
- cc.autolist=1
- cc.highlightsyntax=1
- cc.showparameters=1
- cc.triggerlist=0
- cc.triggernumchars=3
- cc.enter.as.fillup=0
- # autosave for editor files
- autosave=0
- autosave.interval=5
- # vertical edge at right margin
- edge.mode=0
- edge.column=80
- # Specification for text selection and caret line
- selection.fore=#000000
- selection.back=#FFFFFF
- caret.fore=#D8D8D8
- caret.back=#3E3E3E
- # Color for vertical edge
- edge.colour=#66FAFA
- # C/C++ Editor files
- template.cpp="#define","#define |";"#if","#if |\r\n\r\n#endif";\\
- "#include","#include ";"Header","// Header:\r\n// File Name: |\r\n// Author:\r\n// Date:\r\n";\\
- "continue","continue;";"do","do\r\n{\r\n\t// TODO: enter the block content here\r\n\t\r\n\t|\r\n} while ();\r\n";\\
- "enum","enum |\r\n{\r\n\t\r\n};\r\n";"for","for(|;;)\r\n{\r\n}";\\
- "fpointer_type","typedef int (* |F)();\r\n";"function","void function(|)\r\n{\r\n\r\n}\r\n";\\
- "if","if (|)";"ifelse","if (|)\r\n{\r\n}\r\nelse\r\n{\r\n}";\\
- "struct","struct | \r\n{\r\n\r\n};\r\n";"switch","switch (|)\r\n{\r\n\tcase:\r\n\t\tbreak;\r\n\tcase:\r\n\t\tbreak;\r\n\tdefault:\r\n\t\tbreak;\r\n}";\\
- "void","void | ();\r\n";"while","while (|)\r\n{\r\n}";\\
- font.monospace.cpp=Consolas
- style.cpp.32=font:Consolas,size:12,fore:#CFCFCF,back:#2F2F2F
- style.cpp.4=font:Consolas,size:12,fore:#FF2291,back:#2F2F2F
- style.cpp.10=font:Consolas,size:12,fore:#0098E1,back:#2F2F2F
- style.cpp.1=font:Consolas,size:12,fore:#8080FF,back:#2F2F2F
- style.cpp.2=font:Consolas,size:12,fore:#7F7F7F,back:#2F2F2F
- style.cpp.5=font:Consolas,size:12,fore:#FF00FF,back:#2F2F2F,italics
- style.cpp.6=font:Consolas,size:12,fore:#80FF80,back:#2F2F2F
- style.cpp.11=font:Consolas,size:12,fore:#FFFFFF,back:#2F2F2F
- style.cpp.9=font:Consolas,size:12,fore:#FF8080,back:#2F2F2F
- style.cpp.7=font:Consolas,size:12,fore:#FF0080,back:#2F2F2F
- style.cpp.34=font:Consolas,size:12,fore:#500000,back:#20FFFF
- style.cpp.35=font:Consolas,size:12,fore:#FF0000,back:#FFFFFF
- style.cpp.16=font:Consolas,size:12,fore:#D9006C,back:#FFFFFF
- style.cpp.12=font:Consolas,size:12,fore:#000000,back:#E0C0E0
- # Asm Editor files
- font.monospace.asm=Courier New
- style.asm.32=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
- style.asm.1=font:Courier New,size:10,fore:#808040,back:#2F2F2F
- style.asm.2=font:Courier New,size:10,fore:#D56A00,back:#2F2F2F
- style.asm.3=font:Courier New,size:10,fore:#FF8040,back:#2F2F2F
- style.asm.4=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
- style.asm.5=font:Courier New,size:10,fore:#FFFFFF,back:#2F2F2F
- style.asm.6=font:Courier New,size:10,fore:#FFFF80,back:#2F2F2F
- style.asm.7=font:Courier New,size:10,fore:#FFFF80,back:#2F2F2F
- style.asm.9=font:Courier New,size:10,fore:#80FFFF,back:#2F2F2F
- style.asm.10=font:Courier New,size:10,fore:#80FFFF,back:#2F2F2F
- style.asm.11=font:Courier New,size:10,fore:#007F00,back:#2F2F2F
- style.asm.12=font:Courier New,size:10,fore:#FF80FF,back:#2F2F2F
- style.asm.8=font:Courier New,size:10,fore:#46AA03,back:#2F2F2F
- # Editor Text files
- font.monospace.txt=Courier New
- style.txt.32=font:Verdana,size:10,fore:#FFFFFF,back:#2F2F2F
2018-7-15 00:45 上傳
全部資料51hei下載地址:
keil5 代碼配色.rar
(1.55 KB, 下載次數(shù): 906)
2018-7-14 09:38 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
評(píng)分
查看全部評(píng)分
