查看: 3444|回復: 2
ST7565 LCD12864顯示圖片
ID:368523 發表于 2018-7-13 15:42 | 顯示全部樓層 |閱讀模式
  1. #include<reg51.h>
  2. #include"st7565.h"
  3. //---存一個圖片--//
  4. unsigned char code pic[]={
  5. /*--  寬度x高度=128x64  --*/
  6. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,
  7. 0x57,0x53,0x57,0x07,0xFF,0x0F,0xE3,0x0F,0xEF,0xFF,0xEF,0xEF,0xEF,0x03,0xEF,0xEF,
  8. 0xEF,0x0F,0xE3,0x0F,0xEF,0xFF,0x77,0x77,0x17,0x57,0x57,0x53,0x57,0x57,0x17,0x77,
  9. 0x77,0xFF,0xFB,0x8B,0xAB,0x83,0xAB,0x83,0xAB,0x8B,0xFF,0x37,0xDB,0xFF,0xFF,0xFF,
  10. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x07,
  11. 0x57,0x53,0x57,0x07,0xFF,0x0F,0xE3,0x0F,0xEF,0xFF,0xEF,0xEF,0xEF,0x03,0xEF,0xEF,
  12. 0xEF,0x0F,0xE3,0x0F,0xEF,0xFF,0x77,0x77,0x17,0x57,0x57,0x53,0x57,0x57,0x17,0x77,
  13. 0x77,0xFF,0xFB,0x8B,0xAB,0x83,0xAB,0x83,0xAB,0x8B,0xFF,0x37,0xDB,0xFF,0xFF,0xFF,
  14. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xF5,
  15. 0xFB,0xF4,0xEF,0xE0,0xFF,0xF4,0xFB,0xF4,0xEF,0xFF,0xE0,0xEE,0xEE,0xEE,0xEE,0xE0,
  16. 0xFF,0xF4,0xFB,0xF5,0xEC,0xFF,0xE2,0xEF,0xEF,0xE1,0xFD,0xFD,0xFD,0xF9,0xF7,0xEF,
  17. 0xEE,0xFF,0xEB,0xF2,0xFA,0xE2,0xEA,0xFA,0xF2,0xEB,0xFF,0xE0,0xFD,0xFF,0xFF,0xFF,
  18. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xEE,0xF5,
  19. 0xFB,0xF4,0xEF,0xE0,0xFF,0xF4,0xFB,0xF4,0xEF,0xFF,0xE0,0xEE,0xEE,0xEE,0xEE,0xE0,
  20. 0xFF,0xF4,0xFB,0xF5,0xEC,0xFF,0xE2,0xEF,0xEF,0xE1,0xFD,0xFD,0xFD,0xF9,0xF7,0xEF,
  21. 0xEE,0xFF,0xEB,0xF2,0xFA,0xE2,0xEA,0xFA,0xF2,0xEB,0xFF,0xE0,0xFD,0xFF,0xFF,0xFF,
  22. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  23. 0xFF,0xFF,0xFF,0xFF,0xE3,0x81,0x81,0xE3,0xFF,0xFF,0xDF,0xDD,0xD5,0x4D,0x9D,0x00,
  24. 0x9D,0x4D,0xD5,0xDD,0xDF,0xFF,0xFB,0xFB,0x00,0xFB,0xFB,0x9B,0xEB,0xFB,0x0F,0xE9,
  25. 0xEE,0xFF,0xEF,0xEE,0x2A,0xAA,0xAA,0xA8,0xA2,0x0A,0xAA,0x6E,0xEF,0xFF,0xFF,0xFF,
  26. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  27. 0xFF,0xFF,0xFF,0xFF,0xE3,0x81,0x81,0xE3,0xFF,0xFF,0xDF,0xDD,0xD5,0x4D,0x9D,0x00,
  28. 0x9D,0x4D,0xD5,0xDD,0xDF,0xFF,0xFB,0xFB,0x00,0xFB,0xFB,0x9B,0xEB,0xFB,0x0F,0xE9,
  29. 0xEE,0xFF,0xEF,0xEE,0x2A,0xAA,0xAA,0xA8,0xA2,0x0A,0xAA,0x6E,0xEF,0xFF,0xFF,0xFF,
  30. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  31. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFE,0xFF,0x7F,0x78,
  32. 0x7F,0x7F,0xFE,0x7D,0x7D,0xBF,0xBB,0xBB,0xBA,0xBA,0x3A,0xBB,0xBB,0xBD,0xBE,0x7D,
  33. 0x7B,0xBF,0xBF,0xBF,0x78,0xFA,0xFA,0xFA,0xFA,0xF8,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,
  34. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  35. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFC,0xFF,0xFF,0xFF,0xFD,0xFD,0xFE,0xFF,0x7F,0x78,
  36. 0x7F,0x7F,0xFE,0x7D,0x7D,0xBF,0xBB,0xBB,0xBA,0xBA,0x3A,0xBB,0xBB,0xBD,0xBE,0x7D,
  37. 0x7B,0xBF,0xBF,0xBF,0x78,0xFA,0xFA,0xFA,0xFA,0xF8,0xFF,0xFF,0xFE,0xFF,0xFF,0xFF,
  38. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  39. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x87,0xF8,0xFF,0xFF,
  40. 0xFF,0x7F,0x7E,0xBD,0xCF,0x73,0xBF,0xDB,0xDD,0xBD,0x7B,0xFE,0x7F,0xBB,0xDD,0xDD,
  41. 0xBB,0x7F,0xE7,0x9F,0x5F,0xBE,0x7D,0x73,0xEF,0x9F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
  42. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  43. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0x7F,0x87,0xF8,0xFF,0xFF,
  44. 0xFF,0x7F,0x7E,0xBD,0xCF,0x73,0xBF,0xDB,0xDD,0xBD,0x7B,0xFE,0x7F,0xBB,0xDD,0xDD,
  45. 0xBB,0x7F,0xE7,0x9F,0x5F,0xBE,0x7D,0x73,0xEF,0x9F,0x7F,0xFF,0xFF,0xFF,0xFF,0xFF,
  46. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  47. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFD,0x0D,0xF2,0xFC,
  48. 0xFE,0xFF,0xFF,0xEF,0x1F,0x3E,0xDC,0xE8,0xEB,0xED,0xDE,0xD7,0xD6,0xD4,0x68,0x6B,
  49. 0xED,0xF6,0xF7,0xEF,0x1F,0xFE,0xFD,0xF3,0x0E,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
  50. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  51. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFC,0xFD,0x0D,0xF2,0xFC,
  52. 0xFE,0xFF,0xFF,0xEF,0x1F,0x3E,0xDC,0xE8,0xEB,0xED,0xDE,0xD7,0xD6,0xD4,0x68,0x6B,
  53. 0xED,0xF6,0xF7,0xEF,0x1F,0xFE,0xFD,0xF3,0x0E,0xFE,0xFE,0xFF,0xFF,0xFF,0xFF,0xFF,
  54. 0xFF,0xFF,0xFF,0xFF,0xC3,0x81,0x3C,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,
  55. 0xBD,0x00,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,0xBD,0xC3,0xFF,0xFC,0x73,
  56. 0x37,0x2F,0xAF,0xDE,0xDF,0xBF,0xAC,0x9B,0xB7,0xB7,0x6C,0x6C,0x6F,0x6F,0xB6,0xB6,
  57. 0xDB,0xCB,0xD5,0xAA,0x2F,0x37,0x7B,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  58. 0xFF,0xFF,0xFF,0xFF,0xC3,0x81,0x3C,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,
  59. 0xBD,0x00,0x7E,0xFE,0xFE,0xFD,0xF9,0xFD,0xFE,0xFA,0x66,0xBD,0xC3,0xFF,0xFC,0x73,
  60. 0x37,0x2F,0xAF,0xDE,0xDF,0xBF,0xAC,0x9B,0xB7,0xB7,0x6C,0x6C,0x6F,0x6F,0xB6,0xB6,
  61. 0xDB,0xCB,0xD5,0xAA,0x2F,0x37,0x7B,0xFC,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,
  62. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,
  63. 0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,0xDF,0xDF,0xC1,0xC8,0xDC,
  64. 0xFF,0xF8,0xF7,0xEF,0xDF,0xF8,0xF2,0xF2,0xF8,0xFC,0xFE,0xFC,0xFC,0xFE,0xFC,0xF8,
  65. 0xF2,0xD2,0xE8,0xF7,0xF8,0xFF,0xDC,0xC8,0xC1,0xC3,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
  66. 0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,
  67. 0xFF,0xFF,0xFE,0xFC,0xF9,0xF3,0xF7,0xFB,0xFD,0xFE,0xFF,0xDF,0xDF,0xC1,0xC8,0xDC,
  68. 0xFF,0xF8,0xF7,0xEF,0xDF,0xF8,0xF2,0xF2,0xF8,0xFC,0xFE,0xFC,0xFC,0xFE,0xFC,0xF8,
  69. 0xF2,0xD2,0xE8,0xF7,0xF8,0xFF,0xDC,0xC8,0xC1,0xC3,0xC7,0xFF,0xFF,0xFF,0xFF,0xFF,
  70. };
  71. /*******************************************************************************
  72. * 函 數 名         : main
  73. * 函數功能                   : 主函數
  74. * 輸    入         : 無
  75. * 輸    出         : 無
  76. *******************************************************************************/
  77. void main(void)
  78. {
  79.         uchar i , j;
  80.         uint n;
  81.         Lcd12864_Init();        //初始化
  82.         Lcd12864_ClearScreen();        //清屏
  83.         for (i=0;i<8;i++)
  84.         {
  85.             //--設置初始顯示開始位置--//
  86.                 LcdSt7565_WriteCmd(0x40);
  87.                 //--設置Y坐標--//
  88.                 LcdSt7565_WriteCmd(0xB0+i);
  89.
  90.                 //--設置X坐標--//
  91.                 LcdSt7565_WriteCmd(0x10);
  92.                 LcdSt7565_WriteCmd(0x04);
  93.                 for(j=0; j<128; j++)
  94.                 {
  95.                         LcdSt7565_WriteData(~pic[n]);
  96.                         n=n+1;
  97.                 }
  98.         }
  99.         while (1)
  100.         {
  101.         }
  102. }
顯示圖片.rar
2.02 MB, 下載次數: 55, 下載積分: 黑幣 -5
ID:733461 發表于 2020-4-29 15:29 | 顯示全部樓層
問下樓主,圖片數據怎么做出來的,謝謝
ID:231831 發表于 2020-4-30 15:03 | 顯示全部樓層
我要二維碼的,我要二維碼的!!!
