單片機的密碼鎖設計程序帶紅外遙控功能的
電路原理圖如下:
2018-7-13 21:26 上傳
制作出來的實物圖:
2018-7-13 10:51 上傳
單片機源碼:
- #include <REG52.h>
- #include<intrins.h>
- #define LCM_Data P0
- #define uchar unsigned char
- #define uint unsigned int
- //#define w 6 //定義密碼位數
- //時間計算
- #define Imax 14000 //此處為晶振為11.0592時的取值,
- #define Imin 8000 //如用其它頻率的晶振時,
- #define Inum1 1450 //要改變相應的取值。
- #define Inum2 700
- #define Inum3 3000
- sbit lcd1602_rs=P2^5;
- sbit lcd1602_rw=P2^6;
- sbit lcd1602_en=P2^7;
- sbit Scl=P3^4; //24C02串行時鐘
- sbit Sda=P3^5; //24C02串行數據
- sbit ALAM = P2^1; //報警
- sbit KEY = P3^6; //開鎖
- sbit open_led=P2^2; //開鎖指示燈
- bit operation=0; //操作標志位
- bit pass=0; //密碼正確標志
- bit ReInputEn=0; //重置輸入充許標志
- bit s3_keydown=0; //3秒按鍵標志位
- bit key_disable=0; //鎖定鍵盤標志
- unsigned char countt0,second; //t0中斷計數器,秒計數器
- //解碼變量
- unsigned char Im[4]={0x00,0x00,0x00,0x00};
- //全局變量
- uchar f;
- unsigned char m,Tc;
- unsigned char IrOK;
- //void Delay5Ms(void);
- unsigned char code a[]={0xFE,0xFD,0xFB,0xF7}; //控盤掃描控制表
- unsigned char code start_line[] = {"password: "};
- unsigned char code name[] = {"===Coded Lock==="}; //顯示名稱
- unsigned char code Correct[] = {" correct "}; //輸入正確
- unsigned char code Error[] = {" error "}; //輸入錯誤
- unsigned char code codepass[] = {" pass "};
- unsigned char code LockOpen[] = {" open "}; //OPEN
- unsigned char code SetNew[] = {"SetNewWordEnable"};
- unsigned char code Input[] = {"input: "}; //INPUT
- unsigned char code ResetOK[] = {"ResetPasswordOK "};
- unsigned char code initword[] = {"Init password..."};
- unsigned char code Er_try[] = {"error,try again!"};
- unsigned char code again[] = {"input again "};
- unsigned char InputData[6]; //輸入密碼暫存區
- unsigned char CurrentPassword[6]={1,3,1,4,2,0}; //當前密碼值
- unsigned char TempPassword[6];
- unsigned char N=0; //密碼輸入位數記數
- unsigned char ErrorCont; //錯誤次數計數
- unsigned char CorrectCont; //正確輸入計數
- unsigned char ReInputCont; //重新輸入計數
- unsigned char code initpassword[6]={0,0,0,0,0,0};
- //=====================5ms延時==============================
- void Delay5Ms()
- unsigned int TempCyc = 5552;
- while(TempCyc--);
- //===================400ms延時==============================
- void Delay400Ms()
- unsigned char TempCycA = 5;
- unsigned int TempCycB;
- while(TempCycA--)
- TempCycB=7269;
- while(TempCycB--);
- //================================24C02========================================================
- void mDelay(uint t) //延時
- uchar i;
- while(t--)
- for(i=0;i<125;i++)
- void Nop() //空操作
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- /*起始條件*/
- void Start(void)
- Sda=1;
- Scl=1;
- Nop();
- Sda=0;
- Nop();
- /*停止條件*/
- void Stop(void)
- Sda=0;
- Scl=1;
- Nop();
- Sda=1;
- Nop();
- /*應答位*/
- void Ack(void)
- Sda=0;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*反向應答位*/
- void NoAck(void)
- Sda=1;
- Nop();
- Scl=1;
- Nop();
- Scl=0;
- /*發送數據子程序,Data為要求發送的數據*/
- void Send(uchar Data)
- uchar BitCounter=8;
- uchar temp;
- do
- temp=Data;
- Scl=0;
- Nop();
- if((temp&0x80)==0x80)
- Sda=1;
- else
- Sda=0;
- Scl=1;
- temp=Data<<1;
- Data=temp;
- BitCounter--;
- while(BitCounter);
- Scl=0;
- /*讀一字節的數據,并返回該字節值*/
- uchar Read()
- uchar temp=0;
- uchar temp1=0;
- Sda=1;
- do{
- Scl=0;
- Nop();
- Scl=1;
- Nop();
- if(Sda)
- temp=temp|0x01;
- else
- temp=temp&0xfe;
- if(BitCounter-1)
- temp1=temp<<1;
- temp=temp1;
- BitCounter--;
- return(temp);
- void WrToROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- for(i=0;i<Num;i++)
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Send(*(PData+i));
- Ack();
- Stop();
- mDelay(20);
- void RdFromROM(uchar Data[],uchar Address,uchar Num)
- uchar i;
- uchar *PData;
- PData=Data;
- Start();
- Send(0xa0);
- Ack();
- Send(Address+i);
- Ack();
- Start();
- Send(0xa1);
- Ack();
- *(PData+i)=Read();
- Scl=0;
- NoAck();
- Stop();
- //=======================================LCD1602====================================================
- #define yi 0x80 //LCD第一行的初始位置,因為LCD1602字符地址首位D7恒定為1(100000000=80)
- #define er 0x80+0x40 //LCD第二行初始位置(因為第二行第一個字符位置地址是0x40)
- //----------------延時函數,后面經常調用----------------------
- void delay(uint xms)//延時函數,有參函數
- uint x,y;
- for(x=xms;x>0;x--)
- for(y=110;y>0;y--);
- //--------------------------寫指令---------------------------
- void write_1602com(uchar com)//****液晶寫入指令函數****
- lcd1602_rs=0;//數據/指令選擇置為指令
- lcd1602_rw=0; //讀寫選擇置為寫
- P0=com;//送入數據
- delay(1);
- lcd1602_en=1;//拉高使能端,為制造有效的下降沿做準備
- delay(1);
- lcd1602_en=0;//en由高變低,產生下降沿,液晶執行命令
- //-------------------------寫數據-----------------------------
- void write_1602dat(uchar dat)//***液晶寫入數據函數****
- lcd1602_rs=1;//數據/指令選擇置為數據
- P0=dat;//送入數據
- delay(1);
- lcd1602_en=1; //en置高電平,為制造下降沿做準備
- delay(1);
- lcd1602_en=0; //en由高變低,產生下降沿,液晶執行命令
- //-------------------------初始化-------------------------
- void lcd_init()
- write_1602com(0x01);//清顯示
- write_1602com(0x38);//設置液晶工作模式,意思:16*2行顯示,5*7點陣,8位數據
- write_1602com(0x0c);//開顯示不顯示光標
- write_1602com(0x06);//整屏不移動,光標自動右移
- //==============將按鍵值編碼為數值=========================
- unsigned char coding(unsigned char m1,unsigned char hh)
- unsigned char k;
- if(IrOK==1)
- IrOK=0;
- switch(m1)
- case (0x0c): k=1;break;
- case (0x18): k=2;break;
- case (0x5e): k=3;break;
- // case (0xff): k='A';break; //
- case (0x08): k=4;break;
- case (0x1c): k=5;break;
- case (0x5a): k=6;break;
- // case (0x82): k='B';break; //
- case (0x42): k=7;break;
- case (0x52): k=8;break;
- case (0x4a): k=9;break;
- // case (0x84): k='C';break; //
- case (0x43): k='*';break; //撤銷
- case (0x16): k=0;break;
- case (0x15): k='#';break; //確認鍵
- case (0x0d): k='D';break; //重設密碼
- case (0x45): k='A';break; //
- case (0x47): k='A';break; //
- case (0x44): k='A';break; //
- case (0x40): k='A';break; //
- case (0x07): k='A';break; //
- case (0x09): k='A';break; //
- case (0x19): k='A';break; //
- // default:;
- else
- switch(hh)
- case (0x11): k=1;break;
- case (0x21): k=2;break;
- case (0x41): k=3;break;
- case (0x81): k='A';break;
- case (0x12): k=4;break;
- case (0x22): k=5;break;
- case (0x42): k=6;break;
- case (0x82): k='B';break;
- case (0x14): k=7;break;
- case (0x24): k=8;break;
- case (0x44): k=9;break;
- case (0x84): k='C';break;
- case (0x18): k='*';break;
- case (0x28): k=0;break;
- case (0x48): k='#';break;
- case (0x88): k='D';break;
- // default:;
- return(k);
- //=====================按鍵檢測并返回按鍵值===============================
- unsigned char keynum()
- unsigned char row,col,i;
- P1=0xf0;
- if((P1&0xf0)!=0xf0)
- Delay5Ms();
- Delay5Ms();
- row=P1^0xf0; //確定行線
- i=0;
- P1=a[i]; //精確定位
- while(i<4)
- col=~(P1&0xff); //確定列線
- break; //已定位后提前退出
- else
- i++;
- P1=a[i];
- else
- return 0;
- while((P1&0xf0)!=0xf0);
- return (row|col); //行線與列線組合后返回
- else return 0; //無鍵按下時返回0
- //=======================一聲提示音,表示有效輸入========================
- void OneAlam()
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================二聲提示音,表示操作成功========================
- void TwoAlam()
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //========================三聲提示音,表示錯誤========================
- void ThreeAlam()
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- Delay5Ms();
- ALAM=0;
- Delay5Ms();
- ALAM=1;
- //=====================顯示輸入的N個數字,用H代替以便隱藏============================
- void DisplayOne()
- // DisplayOneChar(9+N,1,'*');
- write_1602com(yi+5+N);
- write_1602dat('*');
- //=======================顯示提示輸入=========================
- void DisplayChar()
- unsigned char i;
- if(pass==1)
- //DisplayListChar(0,1,LockOpen);
- write_1602com(er);
- for(i=0;i<16;i++)
- write_1602dat(LockOpen[i]);
- else
- if(N==0)
- //DisplayListChar(0,1,Error);
- for(i=0;i<16;i++)
- write_1602dat(Error[i]);
- else
- //DisplayListChar(0,1,start_line);
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);
- void DisplayInput()
- unsigned char i;
- if(CorrectCont==1)
- //DisplayListChar(0,0,Input);
- for(i=0;i<16;i++)
- write_1602dat(Input[i]);
- //========================重置密碼==================================================
- void ResetPassword()
- unsigned char i;
- unsigned char j;
- if(pass==0)
- pass=0;
- DisplayChar();
- ThreeAlam();
- else
- if(ReInputEn==1)
- if(N==6)
- ReInputCont++;
- if(ReInputCont==2)
- for(i=0;i<6;)
- if(TempPassword[i]==InputData[i]) //將兩次輸入的新密碼作對比
- i++;
- else
- for(j=0;j<16;j++)
- write_1602dat(Error[j]);
- ThreeAlam(); //錯誤提示
- pass=0;
- ReInputEn=0; //關閉重置功能,
- ReInputCont=0;
- DisplayChar();
- break;
- if(i==6)
- //DisplayListChar(0,1,ResetOK);
- for(j=0;j<16;j++)
- write_1602dat(ResetOK[j]);
- TwoAlam(); //操作成功提示
- WrToROM(TempPassword,0,6); //將新密碼寫入24C02存儲
- ReInputEn=0;
- ReInputCont=0;
- CorrectCont=0;
- else
- OneAlam();
- //DisplayListChar(0, 1, again); //顯示再次輸入一次
- for(j=0;j<16;j++)
- write_1602dat(again[j]);
- for(i=0;i<6;i++)
- TempPassword[i]=InputData[i]; //將第一次輸入的數據暫存起來
- N=0; //輸入數據位數計數器清零
- //=======================輸入密碼錯誤超過三過,報警并鎖死鍵盤======================
- void Alam_KeyUnable()
- P1=0x00;
- ALAM=~ALAM;
- Delay5Ms();
- //=======================取消所有操作============================================
- void Cancel()
- unsigned char i;
- unsigned char j;
- //DisplayListChar(0, 1, start_line);
- for(j=0;j<16;j++)
- write_1602dat(start_line[j]);
- TwoAlam(); //提示音
- for(i=0;i<6;i++)
- InputData[i]=0;
- KEY=1; //關閉鎖
- ALAM=1; //報警關
- operation=0; //操作標志位清零
- pass=0; //密碼正確標志清零
- ReInputEn=0; //重置輸入充許標志清零
- // ErrorCont=0; //密碼錯誤輸入次數清零
- CorrectCont=0; //密碼正確輸入次數清零
- ReInputCont=0; //重置密碼輸入次數清零
- open_led=1;
- s3_keydown=0;
- key_disable=0;
- N=0; //輸入位數計數器清零
- //==========================確認鍵,并通過相應標志位執行相應功能===============================
- void Ensure()
- unsigned char i,j;
- RdFromROM(CurrentPassword,0,6); //從24C02里讀出存儲密碼
- if(N==6)
- if(ReInputEn==0) //重置密碼功能未開啟
- for(i=0;i<6;)
- if(CurrentPassword[i]==InputData[i])
- i++;
- else
- i=7;
- ErrorCont++;
- if(ErrorCont>=3&&KEY==1) //錯誤輸入計數達三次時,報警并鎖定鍵盤
- for(i=0;i<16;i++)
- Alam_KeyUnable();
- TR0=1; //開啟定時
- key_disable=1; //鎖定鍵盤
- pass=0;
- break;
- if(i==6)
- CorrectCont++;
- if(CorrectCont==1) //正確輸入計數,當只有一次正確輸入時,開鎖,
- for(j=0;j<16;j++)
- write_1602dat(LockOpen[j]);
- TwoAlam(); //操作成功提示音
- ErrorCont=0;
- KEY=0; //開鎖
- pass=1; //置正確標志位
- TR0=1; //開啟定時
- open_led=0; //開鎖指示燈亮
- for(j=0;j<6;j++) //將輸入清除
- InputData[i]=0;
- else //當兩次正確輸入時,開啟重置密碼功能
- //DisplayListChar(0,1,SetNew);
- for(j=0;j<16;j++)
- write_1602dat(SetNew[j]);
- ReInputEn=1; //允許重置密碼輸入
- CorrectCont=0; //正確計數器清零
- else //=========================當第一次使用或忘記密碼時可以用131420對其密碼初始化============
- if((InputData[0]==1)&&(InputData[1]==3)&&(InputData[2]==1)&&(InputData[3]==4)&&(InputData[4]==2)&&(InputData[5]==0))
- WrToROM(initpassword,0,6); //強制將初始密碼寫入24C02存儲
- //DisplayListChar(0,1,initword); //顯示初始化密碼
- for(j=0;j<16;j++)
- write_1602dat(initword[j]);
- TwoAlam();
- Delay400Ms();
- TwoAlam();
- N=0;
- else
- for(j=0;j<16;j++)
- ThreeAlam(); //錯誤提示音
- pass=0;
- else //當已經開啟重置密碼功能時,而按下開鎖鍵,
- //DisplayListChar(0,1,Er_try);
- for(j=0;j<16;j++)
- write_1602dat(Er_try[j]);
- ThreeAlam();
- else
- for(j=0;j<16;j++)
- pass=0;
- N=0; //將輸入數據計數器清零,為下一次輸入作準備
- operation=1;
- //==============================主函數===============================
- void main()
- unsigned char KEY,NUM;
- P1=0xFF;
- EA=1;
- TMOD=0x11;
- IT1=1;//下降沿有效
- EX1=1;//外部中斷1開
- TH0=0;//T0賦初值
- TL0=0;
- TR0=0;//t0開始計時
- TL1=0xB0;
- TH1=0x3C;
- ET1=1;
- TR1=0;
- Delay400Ms(); //啟動等待,等LCM講入工作狀態
- lcd_init(); //LCD初始化
- write_1602com(yi);//日歷顯示固定符號從第一行第0個位置之后開始顯示
- for(i=0;i<16;i++)
- write_1602dat(name[i]);//向液晶屏寫日歷顯示的固定符號部分
- write_1602com(er);//時間顯示固定符號寫入位置,從第2個位置后開始顯示
- for(i=0;i<16;i++)
- write_1602dat(start_line[i]);//寫顯示時間固定符號,兩個冒號
- write_1602com(er+9); //設置光標位置
- write_1602com(0x0f); //設置光標為閃爍
- Delay5Ms(); //延時片刻(可不要)
- N=0; //初始化數據輸入位數
- while(1)
- if(key_disable==1)
- Alam_KeyUnable();
- else
- ALAM=1; //關報警
- KEY=keynum();
- if(KEY!=0||IrOK==1)
- second=0;
- else
- NUM=coding(Im[2],KEY);
- switch(NUM)
- case ('A'): ; break;
- case ('B'): ; break;
- case ('C'): ; break;
- case ('D'): ResetPassword(); break; //重新設置密碼
- case ('*'): Cancel(); break; //取消當前輸入
- case ('#'): Ensure(); break; //確認鍵,
- default:
- //DisplayListChar(0,1,Input);
- for(i=0;i<16;i++)
- operation=0;
- if(N<6) //當輸入的密碼少于6位時,接受輸入并保存,大于6位時則無效。
- OneAlam(); //按鍵提示音
- //DisplayOneChar(6+N,1,'*');
- for(j=0;j<=N;j++)
- write_1602com(er+6+j);
- InputData[N]=NUM;
- N++;
- else //輸入數據位數大于6后,忽略輸入
- N=6;
- break;
- //*********************************中斷服務函數**************************************
- void time1_int() interrupt 3
- TL1=0xB0;
- TH1=0x3C;
- countt0++;
- if(countt0==20)
- countt0=0;
- second++;
- if(pass==1)
- if(second==1)
- open_led=1; //關指示燈
- TR1=0; //關定時器
- TL1=0xB0;
- TH1=0x3C;
- second=0;
- else
- if(second==3)
- TR1=0;
- second=0;
- key_disable=0;
- s3_keydown=0;
- TL1=0xB0;
- TH1=0x3C;
- else
- TR1=1;
- //外部中斷解碼程序_外部中斷0
- void intersvr1() interrupt 2 using 1
- TR0=1;
- Tc=TH0*256+TL0;//提取中斷時間間隔時長
- TH0=0;
- TL0=0; //定時中斷重新置零
- if((Tc>Imin)&&(Tc<Imax))
- m=0;
- f=1;
- return;
- } //找到啟始碼
- if(f==1)
- if(Tc>Inum1&&Tc<Inum3)
- Im[m/8]=Im[m/8]>>1|0x80; m++;
- if(Tc>Inum2&&Tc<Inum1)
- Im[m/8]=Im[m/8]>>1; m++; //取碼
- if(m==32)
- m=0;
- f=0;
- if(Im[2]==~Im[3])
- IrOK=1;
- TR0=0;
- else IrOK=0; //取碼完成后判斷讀碼是否正確
- } //準備讀下一碼
