查看: 1900|回復: 0
單片機 電子時鐘的設計(我們上課實驗內容)
ID:369797 發(fā)表于 2018-7-11 22:35 | 顯示全部樓層 |閱讀模式
設計51單片機基礎的電子時鐘 用串口通訊
  1. ORG 0000H
  2. LJMP MAIN
  3. ORG 000BH
  4. LJMP TIME
  5. ORG 0023H
  6. LJMP CHUANKOU
  7. ORG 0100H
  8. MAIN:
  9.          MOV TMOD,#21H; //t1 8位重裝載 波特率2400  t2 16位定時器
  10.          MOV SCON,#50H;  //串口8位異步收發(fā) 2smod/32 * t1溢出率
  11.          MOV PCON,#00H   //smod 0
  12.          MOV IP,#10H;    //串口優(yōu)先級高
  13.          MOV TH1,#0F3H;
  14.          MOV TL1,#0F3H;
  15.          MOV TH0,#3CH
  16.          MOV TL0,#0B0H;
  17.          MOV IE,#92H;  //EA 1 ES 1 ET0 1
  18.          MOV R2,#20
  19.          SETB TR1 //??t1
  20.          SETB TR0  //??t0
  21.
  22.          MOV 32H,#10H ;
  23.          MOV 31H,#59H ;
  24.          MOV 30H,#58H ;
  25. ShowTime:
  26.          MOV R0,#30H
  27.          MOV R6,#03H
  28.          MOV R3,#01H
  29.          MOV P1,#00H
  30. LOOP:
  31.         MOV A,R3    //A=01H
  32.         MOV DPTR,#8002H
  33.         MOVX @DPTR,A  //???01
  34.         MOV DPTR,#TAB
  35.         MOV A,@R0  //??30H 31 32H???A
  36.         ANL A,#0FH
  37.         MOVC A,@A+DPTR
  38.         MOV DPTR,#8004H
  39.         MOVX @DPTR,A //????
  40.         MOV  A,R3
  41.         RL A
  42.         MOV R3,A  //R3= 10H
  43.         LCALL DL1MS   //????
  44.
  45.         MOV A,R3
  46.         MOV DPTR,#8002H
  47.         MOVX @DPTR,A  //???10
  48.         MOV DPTR,#TAB
  49.         MOV A,@R0
  50.         SWAP A
  51.         ANL A,#0FH
  52.         MOVC A,@A+DPTR
  53.         MOV DPTR,#8004H
  54.         MOVX @DPTR,A   //????
  55.         MOV  A,R3
  56.         RL A
  57.         MOV R3,A   //r3 =01H
  58.         LCALL DL1MS  //????
  59.         INC R0
  60.         DJNZ R6,LOOP
  61.         SJMP ShowTime
  62. DL1MS:
  63.          MOV R7,#250
  64. DL2:
  65.          NOP
  66.          NOP
  67.          DJNZ R7,DL2
  68.          RET
  69. TAB:
  70.          DB 3FH,06H,5BH,4FH,66H,6DH,7DH,07H,7FH,6FH;
  71. TIME:
  72.          MOV TH0,#3CH
  73.          MOV TL0,0B0H;
  74.          DJNZ R2,FANHUI;  //1s ?
  75.          MOV  R2,#20
  76. SECOND:
  77.          MOV A,30H
  78.          ADD A,#01H
  79.          DA  A;
  80.          MOV 30H,A  //30???1
  81.          CJNE A,#60H,FANHUI  //???60s ????
  82. MINUTE:
  83.          MOV 30H,#00H
  84.          MOV A,31H
  85.          ADD A,#01H
  86.          DA A
  87.          MOV 31H,A  //31???1
  88.          CJNE A,#60H, FANHUI
  89. HOUR:
  90.          MOV 31H,#00H
  91.          MOV A,32H
  92.          ADD A,#01H
  93.          DA A
  94.          MOV 32H,A
  95.          CJNE A,#24H,FANHUI
  96.          MOV 32H,#00H
  97. FANHUI:
  98.          RETI;
  99. CHUANKOU:
  100.          CLR RI
  101.          MOV 32H,SBUF
  102.          JNB RI,$
  103.          CLR RI
  104.          MOV 31H,SBUF
  105.          MOV P1,SBUF
  106.          JNB RI,$
  107.          CLR RI
  108.          MOV 30H,SBUF
  109.          SETB EA
  110.          RETI
  111. END
單片機第七次實驗.rar (117.02 KB, 下載次數: 13)
