查看: 13237|回復(fù): 10
51單片機控制LCD12864顯示漢字
ID:368523 發(fā)表于 2018-7-11 21:42 | 只看該作者 |只看大圖 回帖獎勵 |倒序瀏覽 |閱讀模式
程序:
#include <reg52.h>
#define DATA_PORT P0
sbit LCD12864_EN   = P1^2;
sbit LCD12864_RSET = P1^3;
sbit LCD12864_RS   = P1^0;
sbit LCD12864_RW   = P1^1;
sbit LCD12864_PSB  = P1^6;
void delay(unsigned int xms)  //延時//
        unsigned char i,j;
        for(j = 0; j < xms; j++)
                for(i = 0;i < 110;i++);
bit LcdBusyCheck(){
          bit result;
          LCD12864_RS = 0;
          LCD12864_RW = 1;
          LCD12864_EN = 1;
          result = (bit)(DATA_PORT&0x80);
          LCD12864_EN = 0;
          return result;
void WriteCmdToLCD(unsigned char cmd)
                //        while(LcdBusyCheck());
        delay(10);
          LCD12864_RS = 0;
          LCD12864_RW = 0;
          LCD12864_EN = 1;
          DATA_PORT = cmd;
          delay(5);
        LCD12864_EN = 0;
        delay(5);
        LCD12864_EN = 1;
void WriteDatToLcd(unsigned char dat)
                //while(LcdBusyCheck());
                delay(10);
                LCD12864_RS = 1;
          LCD12864_RW = 0;
          LCD12864_EN = 1;
          DATA_PORT = dat;
          delay(5);
        LCD12864_EN = 0;
        delay(5);
        LCD12864_EN = 1;
void WriteStrToLcd(unsigned char *str)
        while(*str != '\0')
                WriteDatToLcd(*str++);
                delay(5);
void LcdPos(unsigned char x,unsigned char y)
        unsigned char pos;
        if(x == 1)
                x = 0x80;
        }else if(x == 2)
                x = 0x90;
        }else if(x == 3)
                x = 0x88;
        }else if(x == 4)
                x = 0x98;
        pos = x + y - 1;
        WriteCmdToLCD(pos);
void LcdInit()
        LCD12864_PSB = 1;
         LCD12864_RSET = 0;
         delay(10);
        LCD12864_RSET = 1;
        WriteCmdToLCD(0x30);
        delay(5);
        delay(5);
        WriteCmdToLCD(0x18);
        delay(5);
        WriteCmdToLCD(0x10);
        delay(5);
        WriteCmdToLCD(0x01);
        delay(5);
        WriteCmdToLCD(0x06);
        delay(5);
         WriteCmdToLCD(0x0c);
        delay(5);
int main()
                P0 = 0xff;
                P1 = 0xff;
           LcdInit();
                     LcdPos(1,1);
                         WriteStrToLcd("  榆林學(xué)院  ");
                        delay(5);
                LcdPos(2,1);
                         WriteStrToLcd("能源工程學(xué)院");
                        delay(5);
                LcdPos(3,1);
                         WriteStrToLcd("51控制LCD12864");
                        delay(5);
                LcdPos(4,1);
                         WriteStrToLcd("加油吧朋友們。。");
                        delay(500);
51單片機控制LCD12864.zip
14.36 KB, 下載次數(shù): 278, 下載積分: 黑幣 -5
參與人數(shù) 2黑幣 +55 收起 理由
YYQ@DIY + 5 贊一個!
收藏收藏10 分享淘帖 頂3 踩
ID:378263 發(fā)表于 2018-11-29 10:13 | 只看該作者
PSB 是什么角 我這有cs1
ID:521143 發(fā)表于 2019-4-28 22:15 | 只看該作者
覺得對于初學(xué)者來說,這個真的跟有用,多多研究
ID:521143 發(fā)表于 2019-4-28 22:16 | 只看該作者
對于剛剛學(xué)習的我,感覺真的很需要,很實用
ID:649152 發(fā)表于 2019-11-26 09:00 來自觸屏版 | 只看該作者
謝謝分享
ID:649789 發(fā)表于 2019-11-26 11:46 | 只看該作者
謝謝分享,那如果我想讓他滾動起來要怎么改
ID:225536 發(fā)表于 2019-11-26 15:40 | 只看該作者
這尼瑪能點起來 我和你姓
ID:595359 發(fā)表于 2020-5-20 14:46 來自觸屏版 | 只看該作者
psb是什么角
ID:778067 發(fā)表于 2020-7-1 08:03 | 只看該作者
不錯,值得下載
ID:72649 發(fā)表于 2023-11-26 13:23 | 只看該作者
帶字庫嗎?
ID:1053359 發(fā)表于 2023-11-27 10:40 | 只看該作者
pkfpzf 發(fā)表于 2019-11-26 15:40
這尼瑪能點起來 我和你姓
