查看: 15466|回復(fù): 21
直流無刷電機(jī)開環(huán)STM32控制-霍爾6步換向
ID:368911 發(fā)表于 2018-7-11 11:08 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
直流無刷電機(jī)開環(huán)控制程序-6步換向法
STM32單片機(jī)源程序如下:
  1. #include "stm32f10x.h"
  2. #include <stdio.h>
  3. unsigned short int  CCR1_Val = 0;
  4. unsigned short int  CCR2_Val = 0;
  5. unsigned short int  CCR3_Val = 0;
  6. volatile unsigned char  HALL_Value = 0;
  7. unsigned char HALL_flag =1;
  8. /*******************************************************************************
  9. * 函數(shù)名稱: Timer1_Init();
  10. * 功能描述: 定時(shí)器1初始化
  11. * 輸入?yún)?shù): void
  12. * 返回參數(shù): 無
  13. ********************************************************************************/
  14. void PWM_GPIO_Init(void)
  15. {
  16.      GPIO_InitTypeDef GPIO_InitStructure;
  17.      //時(shí)鐘配置
  18.            RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA|RCC_APB2Periph_GPIOB,ENABLE); // 使能GPIOA/GPIOB端口
  19.
  20.      GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9|GPIO_Pin_10;    //PWM???PA8,9,10
  21.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                     //??????
  22.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  23.     GPIO_Init(GPIOA,&GPIO_InitStructure);                               //???GPIO
  24.     GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13|GPIO_Pin_14|GPIO_Pin_15;  //PWM???PA7
  25.     GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                     //??????
  26.     GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  27.     GPIO_Init(GPIOB,&GPIO_InitStructure);                               //???GPIO
  28. }
  29. /*******************************************************************************
  30. * 函數(shù)名稱: HALL_GPIO_Init();
  31. * 功能描述: 霍爾端口初始化
  32. * 輸入?yún)?shù): void
  33. * 返回參數(shù): 無
  34. ********************************************************************************/
  35. void HALL_GPIO_Init(void)
  36. {
  37.            GPIO_InitTypeDef GPIO_InitStructure;
  38.      RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB , ENABLE);    // 使能GPIOC端口
  39.            GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;  //PWM???PA7
  40.      GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPD;                     //??????
  41.      GPIO_Init(GPIOB, &GPIO_InitStructure);
  42. }
  43. /*******************************************************************************
  44. * 函數(shù)名稱: Timer1_Init();
  45. * 功能描述: 定時(shí)器1初始化
  46. * 輸入?yún)?shù): void
  47. * 返回參數(shù): 無
  48. ********************************************************************************/
  49. void Timer1_Init(void)
  50. {
  51.
  52.         TIM_TimeBaseInitTypeDef TIM_TimeBaseInitStructure;
  53.               TIM_OCInitTypeDef  TIM_OCInitStructure;
  54.               TIM_BDTRInitTypeDef TIM_BDTRInitStructure;
  55.
  56.               PWM_GPIO_Init(); //端口初始化
  57.               HALL_GPIO_Init();
  58.               RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 , ENABLE);   // 打開定時(shí)器1的時(shí)鐘
  59.
  60.
  61.                // 默認(rèn)20KHZ
  62.               //設(shè)定3對(duì)PWM占空比
  63.               CCR1_Val    = 2799;
  64.         CCR2_Val    = 2799;
  65.         CCR3_Val    = 2799;
  66.
  67.               //設(shè)置定時(shí)器相關(guān)參數(shù)
  68.               TIM_TimeBaseInitStructure.TIM_Prescaler = 0;                    // 72MHZ
  69.               TIM_TimeBaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up; // 向上計(jì)數(shù)模式
  70.               TIM_TimeBaseInitStructure.TIM_Period = 3599;         // 自動(dòng)重裝載計(jì)數(shù)器周期的值
  71.               TIM_TimeBaseInitStructure.TIM_ClockDivision = 0;                // 時(shí)鐘分頻系數(shù)--不分頻
  72.         TIM_TimeBaseInitStructure.TIM_RepetitionCounter = 0;
  73.               TIM_TimeBaseInit(TIM1,&TIM_TimeBaseInitStructure);
  74.
  75.         //PWM模式設(shè)置-CH1
  76.                                 TIM_OCInitStructure.TIM_OCMode      = TIM_OCMode_Timing;          //PWM模式
  77.         TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;  //輸出使能
  78.                                 TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;//互補(bǔ)端使能輸出
  79.                                 TIM_OCInitStructure.TIM_Pulse = CCR1_Val ; //設(shè)置占空比
  80.         TIM_OCInitStructure.TIM_OCPolarity   =  TIM_OCPolarity_High;        //設(shè)置輸出極性
  81.                                 TIM_OCInitStructure.TIM_OCNPolarity  =  TIM_OCNPolarity_High; //設(shè)置輸出端互補(bǔ)極性
  82.                                 TIM_OCInitStructure.TIM_OCIdleState  =  TIM_OCIdleState_Set;  //死區(qū)后輸出狀態(tài)
  83.         TIM_OCInitStructure.TIM_OCNIdleState =  TIM_OCNIdleState_Set; //死區(qū)后互補(bǔ)端輸出狀態(tài)
  84.         TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  85.
  86.         TIM_OCInitStructure.TIM_Pulse = CCR2_Val ;
  87.         TIM_OC2Init(TIM1, &TIM_OCInitStructure);
  88.
  89.         TIM_OCInitStructure.TIM_Pulse = CCR3_Val ;
  90.         TIM_OC3Init(TIM1, &TIM_OCInitStructure);
  91.
  92.
  93.                                 //死區(qū)和剎車功能配置,使用了高級(jí)定時(shí)器
  94.                                 TIM_BDTRInitStructure.TIM_OSSRState = TIM_OSSRState_Enable;//運(yùn)行模式下輸出選擇
  95.         TIM_BDTRInitStructure.TIM_OSSIState = TIM_OSSIState_Enable;//空閑模式下輸出選擇
  96.         TIM_BDTRInitStructure.TIM_LOCKLevel = TIM_LOCKLevel_OFF;   //鎖定設(shè)置
  97.         TIM_BDTRInitStructure.TIM_DeadTime = 0xc8;                 //死區(qū)時(shí)間--2us
  98.         TIM_BDTRInitStructure.TIM_Break = TIM_Break_Disable;        //剎車功能使能
  99.         TIM_BDTRInitStructure.TIM_BreakPolarity = TIM_BreakPolarity_High;//剎車輸入極性
  100.         TIM_BDTRInitStructure.TIM_AutomaticOutput = TIM_AutomaticOutput_Disable;//自動(dòng)輸出使能
  101.         TIM_BDTRConfig(TIM1,&TIM_BDTRInitStructure);
  102.
  103.
  104.                                 TIM_CCPreloadControl(TIM1, ENABLE);     //使能預(yù)裝值
  105.
  106.                                 TIM_ITConfig(TIM1, TIM_IT_COM, ENABLE); //開啟通信事件
  107.               TIM_Cmd(TIM1, ENABLE);
  108.         TIM_CtrlPWMOutputs(TIM1, ENABLE);
  109.
  110. }
  111. /*******************************************************************************
  112. * 函數(shù)名稱: BLDC_Hall_Convet();
  113. * 功能描述: 根據(jù)霍爾狀態(tài)進(jìn)行換向--T1 T3 T5/T4 T6 T2排列
  114. * 輸入?yún)?shù): 無
  115. * 返回參數(shù): 無
  116. ********************************************************************************/
  117. void BLDC_Hall_Convet(void)
  118. {
  119. // char PB0_Value,PB1_Value,PB2_Value;
  120. //    PB0_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_0);
  121. //    PB1_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_1)*2;
  122. //    PB2_Value = GPIO_ReadInputDataBit(GPIOB, GPIO_Pin_2)*4;
  123. //
  124. //   HALL_Value = PB0_Value+PB1_Value+PB2_Value;
  125.   HALL_Value =(unsigned char)((GPIO_ReadInputData(GPIOB) & 0x0007));        //讀轉(zhuǎn)子位置
  126.
  127.   if(HALL_flag ==1) //正轉(zhuǎn)
  128.   {
  129.      switch(HALL_Value)   //根據(jù)轉(zhuǎn)子位置,決定CCER輸出相位和轉(zhuǎn)子字偏移量
  130.     {
  131.             case 0x05: //配置 T3/T4
  132.
  133.             /*  Channel2 configuration */
  134.             TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1);
  135.             TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Enable);
  136.             TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
  137.
  138.             /*  Channel1 configuration */
  139.                                                 TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
  140.                                                 TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
  141.                                                 TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_Active);
  142.
  143.                                                 /*  Channel3 configuration */
  144.                                                 TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Disable);
  145.                                                 TIM_CCxNCmd(TIM1, TIM_Channel_3,TIM_CCxN_Enable);
  146.                                                 TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_InActive);
  147.
  148.                                     TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  149.                              break;
  150.             case 0x04: //T4 T5
  151.                              /*  Channel3 configuration */
  152.                                     TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_OCMode_PWM1);
  153.                                                 TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
  154.                                                 TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
  155.
  156.                                                 /*  Channel1 configuration */
  157.                                                 TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Disable);
  158.                                                 TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
  159.                                                 TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_Active);
  160.                                                 /*  Channel2 configuration */
  161.                                                 TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Disable);
  162.                                                 TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
  163.                                                 TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_InActive);
  164.
  165.                                TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  166.                   break;
  167.       case 0x06: //T5 T6
  168.
  169.                                    /*  Channel3 configuration */
  170.                                         TIM_SelectOCxM(TIM1, TIM_Channel_3, TIM_OCMode_PWM1);
  171.                                         TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Enable);
  172.                                         TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Disable);
  173.                                         /*  Channel2 configuration */
  174.                                         TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Disable);
  175.                                         TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
  176.                                         TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_Active);
  177.
  178.                                         /*  Channel1 configuration */
  179.                                         TIM_CCxCmd(TIM1, TIM_Channel_1,  TIM_CCx_Disable);
  180.                                         TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
  181.                                         TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_InActive);
  182.            TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  183.
  184.                              break;
  185.             case 0x02: //T6 T1
  186.
  187.                                   /*  Channel1 configuration */
  188.                                   TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
  189.                                         TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
  190.                                         TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Disable);
  191.
  192.                                         /*  Channel2 configuration */
  193.                                         TIM_CCxCmd(TIM1, TIM_Channel_2,  TIM_CCx_Disable);
  194.                                         TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Enable);
  195.                                         TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_Active);
  196.
  197.                                         /*  Channel3 configuration */
  198.                                         TIM_CCxCmd(TIM1, TIM_Channel_3,  TIM_CCx_Disable);
  199.                                         TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
  200.                                         TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_InActive);
  201.            TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  202.                 break;
  203.             case 0x03: // T1 T2
  204.
  205.                                    TIM_SelectOCxM(TIM1, TIM_Channel_1, TIM_OCMode_PWM1);
  206.                                          TIM_CCxCmd(TIM1, TIM_Channel_1, TIM_CCx_Enable);
  207.                                          TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
  208.                                          /*  Channel3 configuration */
  209.                                          TIM_CCxCmd(TIM1, TIM_Channel_3,  TIM_CCx_Disable);
  210.                                          TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
  211.                                          TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_Active);
  212.                                          /*  Channel2 configuration */
  213.                                          TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Disable);
  214.                                          TIM_CCxNCmd(TIM1, TIM_Channel_2,TIM_CCxN_Enable);
  215.                                          TIM_ForcedOC2Config(TIM1,TIM_ForcedAction_InActive);
  216.
  217.                               TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  218.
  219.                  break;
  220.             case 0x01: //T2 T3
  221.
  222.                                    /*  Channel2 configuration */
  223.                 TIM_SelectOCxM(TIM1, TIM_Channel_2, TIM_OCMode_PWM1 );
  224.                                         TIM_CCxCmd(TIM1, TIM_Channel_2, TIM_CCx_Enable);
  225.                                         TIM_CCxNCmd(TIM1, TIM_Channel_2, TIM_CCxN_Disable);
  226.
  227.                                         /*  Channel3 configuration */
  228.                                         TIM_CCxCmd(TIM1, TIM_Channel_3, TIM_CCx_Disable);
  229.                                         TIM_CCxNCmd(TIM1, TIM_Channel_3, TIM_CCxN_Enable);
  230.                                         TIM_ForcedOC3Config(TIM1,TIM_ForcedAction_Active);
  231.
  232.                                         /*  Channel1 configuration */
  233.                                         TIM_CCxCmd(TIM1, TIM_Channel_1,  TIM_CCx_Disable);
  234.                                         TIM_CCxNCmd(TIM1, TIM_Channel_1, TIM_CCxN_Enable);
  235.                                         TIM_ForcedOC1Config(TIM1,TIM_ForcedAction_InActive);
  236.
  237.                                   TIM_GenerateEvent(TIM1, TIM_EventSource_COM);
  238.                 break;
  239.             default:break;
  240.
  241.
  242.
  243.     }
  244.   }
  245. }
  246. void Nvic_Init(void)
  247. {
  248.
  249.
  250.
  251.    NVIC_InitTypeDef NVIC_InitStructure;                                                   //中斷結(jié)構(gòu)體定?
  252.          NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);
  253.
  254.
  255.         NVIC_InitStructure.NVIC_IRQChannel = TIM1_TRG_COM_IRQn;
  256.   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;      //搶占優(yōu)先級(jí)0
  257.         NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;             //從優(yōu)先級(jí)0
  258.         NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;                //使能IRQ通道
  259.         NVIC_Init(&NVIC_InitStructure);
  260.
  261.
  262.   // 可以繼續(xù)增加,設(shè)置中斷優(yōu)先級(jí)
  263. }
  264.
  265. void TIM1_TRG_COM_IRQHandler(void)
  266. {
  267.          /* Clear TIM1 COM pending bit */
  268.    TIM_ClearITPendingBit(TIM1, TIM_IT_COM);
  269.          BLDC_Hall_Convet();//換向
  270. }
  271. int main(void)
  272. {
  273.         SystemInit(); //系統(tǒng)時(shí)鐘配置函數(shù),通過不同的時(shí)鐘定義,來選擇不同的主頻
  274.         Nvic_Init();
  275.         Timer1_Init();
  276.         BLDC_Hall_Convet();
  277.
  278.   while(1)
  279.         {
  280.
  281.
  282.
  283.   }
  284.
  285. }
  286.
霍爾六步換向成功.rar (289.9 KB, 下載次數(shù): 250)
收藏收藏7 分享淘帖 頂 踩
ID:375234 發(fā)表于 2018-7-23 22:06 | 只看該作者
積分不足啊,等組了再來
ID:15170 發(fā)表于 2018-10-8 12:25 | 只看該作者
電機(jī)不動(dòng)沒有跑起來。
ID:259898 發(fā)表于 2018-10-13 14:40 | 只看該作者
你好,你用的是無刷電機(jī),怎么驅(qū)動(dòng)的
ID:259898 發(fā)表于 2018-10-13 14:51 | 只看該作者
你好,怎么用單片機(jī)驅(qū)動(dòng)無刷電機(jī)
ID:259898 發(fā)表于 2018-10-13 14:54 | 只看該作者
你好,無刷電機(jī)怎么用單片機(jī)驅(qū)動(dòng),可以告訴我嗎
ID:341045 發(fā)表于 2018-10-25 15:45 | 只看該作者
收藏了,謝謝分享
ID:324611 發(fā)表于 2018-12-13 13:17 | 只看該作者
收藏了,學(xué)些下,謝謝分享。
ID:368004 發(fā)表于 2018-12-13 16:39 | 只看該作者
收藏了
ID:445421 發(fā)表于 2018-12-13 19:57 | 只看該作者
我是初學(xué)者,過來學(xué)習(xí)的
ID:446351 發(fā)表于 2018-12-15 11:44 | 只看該作者
問一下作者,那電機(jī)怎么進(jìn)行調(diào)速呢。
ID:479575 發(fā)表于 2019-2-23 10:22 | 只看該作者
積分夠后,下載學(xué)習(xí)學(xué)習(xí)。謝謝!
ID:247186 發(fā)表于 2019-4-30 17:26 | 只看該作者
謝謝樓主
ID:547944 發(fā)表于 2019-5-26 22:58 | 只看該作者
多謝樓主分享  初學(xué)者謝啦
ID:549113 發(fā)表于 2019-5-28 11:03 | 只看該作者
謝謝樓主
ID:638203 發(fā)表于 2020-2-24 11:18 | 只看該作者
謝謝樓主的分享
ID:704942 發(fā)表于 2020-4-8 14:18 | 只看該作者
謝謝分享!!!!!!
ID:62514 發(fā)表于 2020-4-9 22:06 | 只看該作者
收藏一下,覺得有用,好好學(xué)習(xí)。
ID:252765 發(fā)表于 2020-4-11 11:28 | 只看該作者
謝謝樓主
ID:135281 發(fā)表于 2020-8-5 14:53 | 只看該作者
資料不錯(cuò),可以進(jìn)行基礎(chǔ)參考
ID:785125 發(fā)表于 2020-8-6 15:35 | 只看該作者
用的什么驅(qū)動(dòng)板呢?自己做嗎
ID:274323 發(fā)表于 2020-8-6 17:04 | 只看該作者
好  收藏了
