查看: 2912|回復(fù): 0
級聯(lián)74HC165,單片機讀數(shù)據(jù)不正常的問題
ID:368360 發(fā)表于 2018-7-10 08:20 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
unsigned char key_data_hc165[2];
void HC165_Init(unsigned char *str,unsigned char n)
    unsigned char i,j,tmp;
        KEY_STB = 0;      //read all the data to the latch
        _nop_();
        _nop_();
        KEY_STB = 1;
        delay_ms(1);
        KEY_CLK = 0;
        for(j = 0;j < n;j++)
                tmp = 0;
                for(i=0; i<8; i++)
                        tmp<<=1;      //left shift 1 bit
                        tmp|=KEY_DATA1;
                        KEY_CLK=0;                //CLK set zero
                        _nop_();                         //risiing edge
                        _nop_();
                        KEY_CLK=1;               //CLK set one
                        _nop_();
                *str++=tmp;
